Mount for the Velleman MK138 boards
Chris Muncy
Post by Chris Muncy »
This is a derivative of a derivative on thingiverse. You will need OpenSCAD installed if you want to change any of the dimensions.
Essentially this mount has 4 mounting holes and a slot to slide in the circuit board. All aspects of the design are configurable, I even build one for the EasyDriver.
http://www.thingiverse.com/thing:10115
I've attached my OPENSCAD file modified for the Velleman board and the exported stl file to print.
velleman mount.JPG (17.07 KiB) Viewed 4427 times
Velleman temp controller.stl
(62.99 KiB) Downloaded 378 times
Velleman temp controller.scad
(4.58 KiB) Downloaded 381 times
Chris Muncy
H-1 #5
Leeway
Re: Mount for the Velleman MK138 boards
Post by Leeway »
Prints pretty good. I didn't have Slic3r set well enough to fill in the walls, but it will still function fine. No need for brute strength in this part.
Thanks for the file.
Printed on a Prusa, BTW.
Lee
