Error when uploading repetier max
3d hi maui
Post by 3d hi maui »
This is a newby question. When uploading repetier max i get an error code from extruder.cpp ,const uint8 osAnalogInputChannels[] PROGMEM = ANALOG_INPUT_CHANNELS;
'TEMP_BED_PIN' was not declared in this scope
I have no idea what to do ? Thanks in advance for any and all help !
Re: Error when uploading repetier max
It's a compilation error, where did you get Repetier from? the version provided by SeeMeCNC should just work.
3d hi maui
@Polygonhell,
Thanks for your response, I downloaded repetier max from Seemecnc site about two months ago.
Should I re-download and try again ?
Aloha,
Jay Dub
Probably not a bad idea, you should also make sure you use whatever version of the arduino IDE SeeMeCNCis currently recommending.
3d hi maui
I re-downloaded repetier max and uploaded it to my ramps, and it uploaded correctly.
When i go to make changes in Config.H for my specific machine a "Kossel" I'm getting the same error code on line 221 of Extruder .cpp ....
.const uint8 osAnalogInputChannels[] PROGMEM = ANALOG_INPUT_CHANNELS;
Any ideas?
Thanks
Jay Dub
foshon
Post by foshon »
If your using SMCNC's RepMax do not change anything out of the box, just upload it.
Purple = sarcasm
3d hi maui
foshon wrote:If your using SMCNC's RepMax do not change anything out of the box, just upload it.
I'm setting up the repetier max to be used with a Kossel printer, how can i use without making any changes ?
Then whatever changes you are making are invalid, what are you changing?
3d hi maui
Just the typical adjustments, motherboard type etc.
Something you are doing is stopping it compiling.
You need to change one thing at a time until it stops working, once you've identified that, helping will be a lot easier.
foshon
Post by foshon »
A Kossel is in the same category as any other delta, that portion should be set.
/* Define the type of axis movements needed for your printer. The typical case
is a full cartesian system where x, y and z moves are handled by seperate motors.
0 = full cartesian system, xyz have seperate motors.
1 = z axis + xy H-gantry (x_motor = x+y, y_motor = x-y)
2 = z axis + xy H-gantry (x_motor = x+y, y_motor = y-x)
3 = Delta printers (Rostock, Kossel, RostockMax, Cerberus, etc)
Cases 1 and 2 cover all needed xy H gantry systems. If you get results mirrored etc. you can swap motor connections for x and y. If a motor turns in
the wrong direction change INVERT_X_DIR or INVERT_Y_DIR.
#define DRIVE_SYSTEM 3  //Delta Rostock MAX
Purple = sarcasm
3d hi maui
Hello,
I am still getting the same error code but only when i change the mother board from " 301 Rambo board" to "33 ramps 1.4 ".
All other changes have been successful and have compiled correctly, Why will it not compile correctly when i choose the Ramps 1.4 ?
Thanks for your patients and time, it is much appreciated !
3d hi maui wrote: All other changes have been successful and have compiled correctly, Why will it not compile correctly when i choose the Ramps 1.4 ?
There are a number of settings for digipots values etc that might not work on a RAMPS 1.4, there might also be an issue with the pins the LCD is set up to use.
Around the line that gives the error is there a #if statement I so what does it say.
3d hi maui
Yes, here it is.
#if ANALOG_INPUTS>0
Actually I just looked at the original error, you need to define TEMP_BED_PIN in configuration.h.
It's probably set to something that isn't defined in pins.h for the RAMPS board.
