How to build a Heat Bed on the cheap
Check out how others are building and modding their own heated beds
kilroyo
Post by kilroyo »
This is a work in progress , but we start out we an electric charcoal starter. I happened to pick mine up at a menards for $8.00 .
[img]http://xa.yimg.com/kq/groups/80652411/s ... t_bed1.jpg[/img]
Next we take handle apart and remove the heating element
[img]http://xa.yimg.com/kq/groups/80652411/s ... t_bed2.jpg[/img]
I would of swore I took a picture of it all out handle, but I was unable to fine it.
Next take a little bit of patience, but you have to rebend the heating element, I just used a vise and took my time, bending alittle here and there. Dont go to fast or you could snap the tubing. But shape it to the dimensions of your bed.
[img]http://xa.yimg.com/kq/groups/80652411/s ... t_bed3.jpg[/img]
**more to come**
TKL
Re: How to build a Heat Bed on the cheap
Post by TKL »
I am a bit concerned about bending the heat element. You will break the ceramic isolation inside and risk getting high voltage on the metal pipe.
kilroyo
Post by kilroyo »
Its actually a soft silicon inside. Already tried with some power to it and still works pretty good. Gets hot quick. Now working on wrapping the heating element with aluminum wire
Return to “Heated Bed How-To's”
