Whats up everyone?
Juise (just pronounced juice) here from Milwaukee. I decided to jump in head first, I've been eyeing 3D printers for some time now and decided to go with the SeeMeCNC Rostock Max. Along with the kit, I picked up the double extruder, 2 .35 heads, boro plate, the Trick Laser carbon arms with ball socket set, and the trick laser tri-force top. My ultimate goal is to be able to make custom toys, such as action figures and the like. After seeing the Barry Bot on youtube I hope with the proper amount of time/work/learning/practice I'll be able to reliable print at 50 micron.
What are the must read threads here related to assembly of the kit, and dual extruder setup?
Jumping in head first from Milwaukee, WI
Re: Jumping in head first from Milwaukee, WI
Gene's rev 2 manual will get you assembled and running, check for its link in the official docs section.
For dual extrusion, it's been done, but I'm not sure how much documentation there is (check the v2 manual, I haven't looked for this specifically). The Rambo board has all of the proper outputs, the base can mount two spool holders, and the hot-end carrier can hold multiple ends with some modification.
Welcome to the forum!
