Hey guys, anybody who has the CF Arms from Trick Laser can upgrade them to be even better.
http://www.tricklaser.com/Zero-Lash-Straps-RM-ZLASH.htm
Make them ZERO LASH just like the magnetic ball joints!
													ZERO LASH Straps for Trick laser CF arms
- bvandiepenbos
					Last edited by bvandiepenbos on Thu May 23, 2013 11:11 am, edited 1 time in total.
- foshon
Re: ZERO LASH Starps for Trick laser CF arms
Is the price for 1 or a kit?
							Purple = sarcasm
- bvandiepenbos
Price is for set of (6) strapsfoshon wrote:Is the price for 1 or a kit?
Re: ZERO LASH Straps for Trick laser CF arms
Can I just do the same thing with some thick rubber bands?
- foshon
626Pilot wrote:Can I just do the same thing with some thick rubber bands?
I weighed that option as well, for me the 5 dollars more than covered the pain in the arse of taking my arms off again.
Purple = sarcasm
Or someone can experiment with zip ties. Make it the thunderdome of fasteners.
zip ties wont work,  it needs to be elastic/stretchable to maintain tension on the rod joints at all ranges of travel.
they have good solution, although i think it should've been included with the kit.
How bout using a zip tie as a link to tie the ends of a regular rubber band together.
Wrap the band around the arms, zip tie the ends
- bvandiepenbos
cambo3d wrote:zip ties wont work, it needs to be elastic/stretchable to maintain tension on the rod joints at all ranges of travel.
Hey Cambo, as of last monday we are including them standard with the arm kits. And they are available for previous owners to upgrade their arms for a minimal cost on our website. ( only $5.00 with free shipping)
Yes, you can use rubber bands. It needs to be elastic.
We use a soft stretchy latex rubber tubing and a laser cut connecting barb.
