Found a little time while making parts on the mill to tear down and label wires.
Additionally, someone else has done something similar:
https://passion-impression3d.jimdo.com/
Since I already have a smoothieboard that I tried in a delta(and I hated it!), I'm installing it for now to see if it does better in a cartesian printer(major corner rounding issues in the delta IIRC, I'm sure I posted about it on this forum).
Here is the original control board, it has DRV8825 drivers on it 16x micro stepping
I took lots of pictures so I cold figure out the wiring, it's pretty straight forward - from the link above he measured the motor currents, he also figured out the thermistor calibration but I'll have to dig for it since he didn't post it directly
Under the main board I found this quite interesting, they use an OLIMEX to run the front panel and the USB connections go through it, both in back, and up front.
I plan to power it up outside the printer and see if it's worth messing with for other applications, I don't have any interest in using it for this printer.
Cheapie 24v power supply, S-400-24 meanwell knockoff.
Rough layout
Where I left it for the evening
Z axis is a nema 23 motor so I'll power that with a TB6600 drive. I'm hoping I can add it to the smoothie using some spare pins so I can run both extruders.
X,Y,Extruders are 1.68A
Z stepper is 2.8A
Found a copy of the firmware
https://github.com/chili-epfl/creatr-hs ... guration.h
