z axis homeing
Northspire
- Prints-a-lot
z axis homeing
When I run the g code m119 it reports the x,y,and z probe as not stopped but the z axis reports max stop even if the endstop switch is unplugged. Any Ideas? Also the zstop led is not lighting up like the y and xstop led.
Rostock V2 Meanwell SP 750-24 Power Supply,710n Nano W/l Router,E3D Chimera Hot-End,713 Maker Effector and Hot-End Mount,Duet 0.8.5,Bondtech QR Extruder,PanelDue W/ 7 Inch T/S,Mini IR Height Sensor,24V Heated Bed With SSR,46 Quart Dry Box.
Re: z axis homeing
If you are using NC microswitches or other endstop switches that produce an active high output, then it's normal for them to read stopped when they are disconnected. All other common firmwares work this way too.
If the Z endstop led is not lit when your NC microswitch is not triggered, then you have a wiring fault.
Northspire
- Prints-a-lot
Re: z axis homeing
Sorry for the late reply it was a wiring issue Thanks dc42
