New version: 2.1.2
Talk about Cura software here (http://wiki.ultimaker.com/Cura)
Nylocke
New version: 2.1.2
Post by Nylocke »
This new version looks really nice, and it has a TON of settings. I just downloaded it tonight but I will be trying it out pretty soon here with 2-3 printers. With Jonathan from KISS going AWOL again, Cura seems like the next best thing to me, and this new release has a lot of potential. Over 200 configureable settings and several really cool experimental features make this quite exciting. I'll spend a good while working with it to see what all it can do. If Michael or someone else has any advice on what to try to print while dialing in settings it would be appreciated.
Nylocke
Re: New version: 2.1.2
Post by Nylocke »
Its still essentially a beta release. The pathing looks nice and most features work, but the support for multi extrusion isnt yet implemented (looking on forums and github its in the works) and there is no support for custom printer sizes (only pre defined printers, like the ultimaker lines and a few random ones) or delta printers as of now. I found a forum post explaining why, no one at ultimaker has one (deltas were implememted by an outsider for earlier versions), so they cant test, but one of the leads is willing to work with delta owners to develop support.
Theres some real cool features, like experimental conical supports, advanced features for multi extrusion (2.1 beta had more features available in a .json config file), some different experimemtal features that convert a model to a mesh (as in it prints a mesh) and something else that roughs up the surface. Theres also speed dependent temperature support (not sure how to use it yet), independent retract prime speed (like KISS), coasting (like what 626Pilot made in PHP for KISS), more customizeable speed controls (top layers, solid layers, infill layers, inner and outer perimiters, different parts of support, etc), independent perimeter and infill layer thicknesses, and some other cool features. Also several infill types (including concentric and triangular) that dont do the annoying alternating layer thing that old cura did (where one layer does the 0 degree lines and the next one does the 90 degree ones and so sometimes the lines break and curl up and the nozzle knocks into it).
greyghost
Post by greyghost »
I have been playing around with the latest release of Cura and I agree there are a lot of great settings to play with and a lot of potential. I am fairly new to 3d printing but have a programming background so I wasn't afraid to take a stab at the json files and configuration to make the Max v2 work with cura since it seems support for delta printers was removed in the last few updates. I actually got it so I could add a custom printer profle, and slice and start a print, but that is where I ran into some issues. I'm working on a mac so I'm not sure the path for windows but if you want to add your Rostock to Cura follow these steps:
  • Open Finder and navigate to applications
    Right click on the Cura app and select "Show Package Contents"
    Navigate to Contents->Resources->cura->resources->machines (this is where the json files for each printer are stored)
    Add the RostockMaxV2.json (attached) file to the machines folder.
    Navigate to the meshes folder. (should be just below machines)
    Add the rostockmaxv2.stl to this folder. (this loads the printer image into the cura preview, well part of it. I put just enough so you could get a good perspective.)
    Now open up cura and add a new printer. You should see the option to add your Rostock now.
The json file has a disallowed areas setting which is how you make the print bed circular. Where I am stuck is on the machine start and machine end gcode settings. I basically used the gcode from matter slice, but what happens is when I tell cura to print it sets the heatbed but doesn't heat the hotend. I have to manually do that, and every time I go to print my print head heads all the way over to the end of the plate between y and z towers and just sits there and extrudes. If someone out there with more knowledge can help with the start, end, pause, resume codes, and the overide settings I think we can get a good working solution for people that want to use Cura and their Rostock.
RostockMaxV2 copy.json.txt
(6.38 KiB) Downloaded 894 times
rostockmaxv2.stl
(6.88 MiB) Downloaded 789 times
Nylocke
Post by Nylocke »
I'm also on OS X so I'll try messing around with it. I'm pretty sure I know whats wrong and I can check it out soon.
edit: which version are you using? I have 2.1.2 and I put the .json file in the correct spot (new location is Content/Resources/cura/resources/...) and I edited it so the center is 0,0 (main mistake in your config that was causing the printer to move off to the corner), but the printer won't show up in Cura when I go to add a new printer.
greyghost
Post by greyghost »
Nylocke wrote:I'm also on OS X so I'll try messing around with it. I'm pretty sure I know whats wrong and I can check it out soon.
I'm running 2.1.1, and you are right I forgot to add the extra resources folder in the path. I just updated to 2.1.2 and if you use the json file and stl I provided you should still be able to add the printer. Where and how do you set the center to 0,0?
I've found that the printer not showing is usually due to an error in the json structure. Also make sure you remove the .txt extension. I only added it so I could upload the file. For example the machine_start_gcode and end_gcode have to all be on one line. If you multiline it the printer won't show up. You can use jsonlint to check that. I use sublime text 3 so to make changes what I typically do is multiselct all the \n on the machine_start_gcode settings and put them all on their own line. Then I reselected and fn delete which puts everything back on one line.
I also have found that getting cura to recognize the printer has been kind of a challenge. I usually have to turn on the printer, plugin usb, insert sd card in printer, remove sd card then the print to usb will show up. Also I find the print window very lacking. I'm guessing this is due to lack of support. It basically shows the element and bed temps and that's it. I'd love to have more info and the gcode is suppose to generate it but I'm not sure why it isn't showing up.
Resources:
https://ultimaker.com/en/resources/2051 ... e-settings - goes over the parts of the json file to edit and what each does
https://gist.github.com/onitake/78a3529 ... ab5dede1db - calculates the area to exclude so you have a nice circular bed
http://jsonlint.com/ - checks your json structure for errors
http://quillford.github.io/CuraProfileMaker/ - makes a printer profile for you. Haven't tried it yet but it looks like it would work.
lordbinky
Post by lordbinky »
Nice to see people giving this a go. I started to do the same and the settings working but called it quits when it came to the exclusion areas being hard coded and not wanting to leave watching the print area to my future self (thank you past self). I'll see if I can find where I got the center 0,0 from if Nylock doesn't respond first.
Nylocke
Post by Nylocke »
I got it working, can't test right now though. Should work, you can check out what I changed.
RostockMaxV2.json.zip
(2.44 KiB) Downloaded 1021 times
greyghost
Post by greyghost »
Nylocke wrote:I got it working, can't test right now though. Should work, you can check out what I changed.
Thanks for the code. I tried it and it still heads over to between the y z towers. I've attached the gcode since it should give better insight as to what is going on. I'm still new to the gcode so I'm not totally sure all that is happeing up until line 47 or so.
A couple other things I noticed. The code waits for the bed to heat before heating the hot end. This is different from matter control as it heats them together. Not sure if other slicers are that way or if it just the gcode. For some reason once I hit my target temps the targets got set back to 0 so the print doesn't start. I had to manually set the print temps and then the printer started to print. It homes the towers, goes down center above the bed and then heads over between y and z towers. The x tower arm goes all the way to the down and if I don't shut it off it keeps trying to go lower. I pulled line 47 of the gcode and plugged it into matter control which reproduced the same result. I'll test some more tonight but if anyone can give some more insight it would be great to get it working.
R2_TrentWords cura.gcode
(555.31 KiB) Downloaded 1066 times
Nylocke
Post by Nylocke »
Comparing your Gcode to mine, mine moves based around the center of the delta printer (center is X=0, Y=0, instead of being half of the max values of each axes like on a cartesian printer), while yours is moving way off in the upper right corner
Mine:
G1 F900.000 X0.214 Y0.188 E0.01554
G1 X0.001 Y0.084 E0.02819
G1 X-0.487 Y0.294 E0.05655
G1 X-0.487 Y16.490 E0.92114
G1 X-0.527 Y17.279 E0.96331
G1 X-0.646 Y18.059 E1.00543
G1 X-0.844 Y18.824 E1.04761
G1 X-1.118 Y19.564 E1.08974
G1 X-1.466 Y20.273 E1.13190
G1 X-1.884 Y20.944 E1.17410
G1 X-2.367 Y21.568 E1.21622
G1 X-2.910 Y22.141 E1.25836
G1 X-3.509 Y22.656 E1.30053
G1 X-4.157 Y23.107 E1.34268
G1 X-4.848 Y23.491 E1.38488
G1 X-5.573 Y23.803 E1.42701
G1 X-6.326 Y24.040 E1.46915
Yours:
G1 X127.667 Y125.632 E0.10906
G1 X128.204 Y125.311 E0.14245
G1 X128.614 Y125.100 E0.16707
G1 X129.193 Y124.847 E0.20080
G1 X129.798 Y124.669 E0.23446
G1 X130.677 Y124.470 E0.28257
G1 X131.432 Y124.359 E0.32331
G1 X132.604 Y124.277 E0.38603
G1 X133.011 Y124.265 E0.40776
G1 X134.054 Y124.277 E0.46345
G1 X134.488 Y124.301 E0.48665
G1 X135.672 Y124.418 E0.55016
G1 X136.589 Y124.597 E0.60004
G1 X137.069 Y124.738 E0.62674
G1 X137.663 Y124.954 E0.66048
G1 X138.225 Y125.243 E0.69422
G1 X138.746 Y125.601 E0.72797
G1 X139.373 Y126.187 E0.77378
G1 X139.584 Y126.421 E0.79060
G1 X139.977 Y126.916 E0.82434
The problems with resetting the temps comes from you taking the gcode from matterslice, Some of the format doesn't match the Cura format (the whole {IFEXT0}M109 S{TEMP1} or whatever bit) so Cura doesn't replace these with values, and the firmware interprets these at M109 S0, etc etc etc, which just sets the extruder/bed to 0C. Cura by default inserts this code:
M190 S80.000000
M104 S250.000000
M109 S250.000000
in before all the start Gcode in the json file. Its a peculiar order though, it should be
M104 S250 (Set hotend temp to 250, no wait to heat up)
M190 S80 (Set bed temp to 80, wait to heat up (as in it pauses all gcode until it gets to the set point))
M109 S250 (Sets the hotend to 250 and waits (Same as M190 except for the hotend))
so something might still be up in Cura. I'll check it out.
Also heres my new json file:
(2.27 KiB) Downloaded 948 times
bvandiepenbos
Post by bvandiepenbos »
I have not tested this, but could a workaround be putting a G92 offset in your start code?
G92 X-140 Y-140
Then just use the Cartesian gcode generated by cura.
at least until zero center configuration is figured out.
greyghost
Post by greyghost »
You are right. I pulled the gcode of the test cube from mattercontrol using the cura slicer and Cura. The x y coordinates are definitely off. Thanks for the clarification on the hot end settings. I'll try your json when I get home today. Could there be something in my EEPROM or Repitier code I need to change? I have no problems printing with Matter Control and I've used all three slicers there.
Gcode from Cura
;FLAVOR:RepRap
;TIME:983
M190 S60.000000
M104 S210.000000
M109 S210.000000
;Sliced at: {day} {date} {time}
Basic settings: Layer height: 0.1 Walls: 0.8 Fill: 20.0
Print time: {print_time}
Filament used: {filament_amount}m {filament_weight}g
Filament cost: {filament_cost}
G28 ; Home extruder
M107 ; Turn off fan
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
{IF_EXT0}M104 S{TEMP0} ; EXTRUDER TEMP
{IF_BED}M190 S{BED} ; BED TEMP
{IF_EXT0}M109 S{TEMP0} ; EXTRUDER TEMP
G28 ; HOME
M117 HEATING ELEMENTS
; BEGINNING OF HEAD MOVEMENT WARNING TONES
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M117 KEEP HANDS AWAY
G4 S3
; END OF HEAD WARNING TONES
;Put printing message on LCD screen
M117 Rostock Printing...
;Generated with Cura_SteamEngine 2.1.2
;LAYER_COUNT:98
;LAYER:0
M107
G1 F6600.000000 E-6.50000
G1 Z20.300
G0 F7200.000 X126.373 Y126.559 Z0.600
;TYPE:SKIRT
G1 Z0.300
G1 F6600.000 E0.04158
G1 F900.00000 X126.836 Y126.129 E0.07531
G1 X127.350 Y125.760 E0.10908
G1 X127.906 Y125.460 E0.14281
G1 X128.495 Y125.232 E0.17652
G1 X129.109 Y125.080 E0.21029
G1 X130.000 Y125.000 E0.25805
G1 X150.000 Y125.000 E1.32570
G1 X150.631 Y125.040 E1.35945
G1 X151.252 Y125.159 E1.39320
G1 X151.852 Y125.356 E1.42691
G1 X152.424 Y125.627 E1.46070
G1 X152.956 Y125.967 E1.49441
G1 X153.441 Y126.373 E1.52817
G1 X153.871 Y126.836 E1.56190
G1 X154.240 Y127.350 E1.59568
G1 X154.540 Y127.906 E1.62941
G1 X154.768 Y128.495 E1.66312
G1 X154.920 Y129.109 E1.69689
G1 X155.000 Y130.000 E1.74464
G1 X155.000 Y150.000 E2.81229
G1 X154.960 Y150.631 E2.84604
G1 X154.841 Y151.252 E2.87980
G1 X154.644 Y151.852 E2.91351
G1 X154.373 Y152.424 E2.94730
G1 X154.033 Y152.956 E2.98100
G1 X153.627 Y153.441 E3.01477
G1 X153.164 Y153.871 E3.04850
G1 X152.650 Y154.240 E3.08228
G1 X152.094 Y154.540 E3.11600
G1 X151.505 Y154.768 E3.14972
G1 X150.891 Y154.920 E3.18348
G1 X150.000 Y155.000 E3.23124
G1 X130.000 Y155.000 E4.29889
G1 X129.369 Y154.960 E4.33264
G1 X128.748 Y154.841 E4.36639
G1 X128.148 Y154.644 E4.40011
G1 X127.576 Y154.373 E4.43389
G1 X127.044 Y154.033 E4.46760
G1 X126.559 Y153.627 E4.50136
G1 X126.129 Y153.164 E4.53509
G1 X125.760 Y152.650 E4.56887
G1 X125.460 Y152.094 E4.60260
G1 X125.232 Y151.505 E4.63631
G1 X125.080 Y150.891 E4.67008
G1 X125.000 Y150.000 E4.71783
G1 X125.000 Y130.000 E5.78548
G1 X125.040 Y129.369 E5.81924
G1 X125.159 Y128.748 E5.85299
G1 X125.356 Y128.148 E5.88670
G1 X125.627 Y127.576 E5.92049
G1 X125.967 Y127.044 E5.95419
G1 X126.373 Y126.559 E5.98796
G0 F7200.00000 X126.767 Y126.728
G1 F900.000 X127.225 Y126.331 E6.02032
G1 X127.732 Y125.998 E6.05270
G1 X128.278 Y125.734 E6.08507
G1 X128.854 Y125.545 E6.11743
G1 X129.450 Y125.433 E6.14981
G1 X130.000 Y125.400 E6.17922
G1 X150.000 Y125.400 E7.24687
G1 X150.605 Y125.440 E7.27924
G1 X151.199 Y125.559 E7.31157
G1 X151.773 Y125.755 E7.34395
G1 X152.316 Y126.026 E7.37635
G1 X152.819 Y126.365 E7.40873
G1 X153.272 Y126.767 E7.44106
G1 X153.669 Y127.225 E7.47342
G1 X154.002 Y127.732 E7.50580
G1 X154.266 Y128.278 E7.53817
G1 X154.455 Y128.854 E7.57053
G1 X154.567 Y129.450 E7.60291
G1 X154.600 Y130.000 E7.63232
G1 X154.600 Y150.000 E8.69997
G1 X154.560 Y150.605 E8.73234
G1 X154.441 Y151.199 E8.76468
G1 X154.245 Y151.773 E8.79706
G1 X153.974 Y152.316 E8.82945
G1 X153.635 Y152.819 E8.86183
G1 X153.233 Y153.272 E8.89416
G1 X152.775 Y153.669 E8.92652
G1 X152.268 Y154.002 E8.95890
G1 X151.722 Y154.266 E8.99127
G1 X151.146 Y154.455 E9.02364
G1 X150.550 Y154.567 E9.05601
G1 X150.000 Y154.600 E9.08542
G1 X130.000 Y154.600 E10.15307
G1 X129.395 Y154.560 E10.18544
G1 X128.801 Y154.441 E10.21778
G1 X128.227 Y154.245 E10.25016
G1 X127.684 Y153.974 E10.28255
G1 X127.181 Y153.635 E10.31493
G1 X126.728 Y153.233 E10.34727
G1 X126.331 Y152.775 E10.37962
G1 X125.998 Y152.268 E10.41200
G1 X125.734 Y151.722 E10.44438
G1 X125.545 Y151.146 E10.47674
G1 X125.433 Y150.550 E10.50911
G1 X125.400 Y150.000 E10.53852
G1 X125.400 Y130.000 E11.60617
G1 X125.440 Y129.395 E11.63854
G1 X125.559 Y128.801 E11.67088
G1 X125.755 Y128.227 E11.70326
G1 X126.026 Y127.684 E11.73566
G1 X126.365 Y127.181 E11.76804
G1 X126.767 Y126.728 E11.80037
G0 F7200.00000 X127.160 Y126.906
G1 F900.000 X127.613 Y126.544 E11.83132
G1 X128.111 Y126.249 E11.86222
G1 X128.645 Y126.024 E11.89315
G1 X129.205 Y125.876 E11.92408
G1 X130.000 Y125.800 E11.96671
G1 X150.000 Y125.800 E13.03436
G1 X150.578 Y125.840 E13.06529
G1 X151.145 Y125.959 E13.09621
G1 X151.690 Y126.155 E13.12713
G1 X152.203 Y126.424 E13.15805
G1 X152.674 Y126.761 E13.18897
G1 X153.094 Y127.160 E13.21990
G1 X153.456 Y127.613 E13.25085
G1 X153.751 Y128.111 E13.28175
G1 X153.976 Y128.645 E13.31268
G1 X154.124 Y129.205 E13.34360
G1 X154.200 Y130.000 E13.38624
G1 X154.200 Y150.000 E14.45389
G1 X154.160 Y150.578 E14.48481
G1 X154.041 Y151.145 E14.51574
G1 X153.845 Y151.690 E14.54666
G1 X153.576 Y152.203 E14.57758
G1 X153.239 Y152.674 E14.60850
G1 X152.840 Y153.094 E14.63942
G1 X152.387 Y153.456 E14.67038
G1 X151.889 Y153.751 E14.70128
G1 X151.355 Y153.976 E14.73221
G1 X150.795 Y154.124 E14.76313
G1 X150.000 Y154.200 E14.80576
G1 X130.000 Y154.200 E15.87341
G1 X129.422 Y154.160 E15.90434
G1 X128.855 Y154.041 E15.93527
G1 X128.310 Y153.845 E15.96619
G1 X127.797 Y153.576 E15.99711
G1 X127.326 Y153.239 E16.02803
G1 X126.906 Y152.840 E16.05895
G1 X126.544 Y152.387 E16.08991
G1 X126.249 Y151.889 E16.12080
G1 X126.024 Y151.355 E16.15174
G1 X125.876 Y150.795 E16.18266
G1 X125.800 Y150.000 E16.22529
G1 X125.800 Y130.000 E17.29294
G1 X125.840 Y129.422 E17.32387
G1 X125.959 Y128.855 E17.35480
G1 X126.155 Y128.310 E17.38572
G1 X126.424 Y127.797 E17.41664
G1 X126.761 Y127.326 E17.44755
G1 X127.160 Y126.906 E17.47848
G0 F7200.00000 X130.600 Y130.600
;TYPE:WALL-INNER
G1 F900.000 X149.400 Y130.600 E18.48207
G1 X149.400 Y149.400 E19.48566
G1 X130.600 Y149.400 E20.48925
G1 X130.600 Y130.600 E21.49284
G0 F7200.00000 X130.200 Y130.200
;TYPE:WALL-OUTER
G1 F900.000 X149.800 Y130.200 E22.53914
G1 X149.800 Y149.800 E23.58544
G1 X130.200 Y149.800 E24.63174
G1 X130.200 Y130.200 E25.67803
G0 F7200.00000 X130.759 Y130.759
;TYPE:SKIN
G1 F900.000 X149.239 Y149.239 E27.07317
G0 X149.309 Y149.309
G0 F7200.000 X149.239 Y148.674
G1 F900.000 X131.325 Y130.759 E28.42561
G0 X131.255 Y130.689
G0 F7200.000 X131.890 Y130.759
G1 F900.000 X149.239 Y148.108 E29.73536
G0 X149.309 Y148.178
G0 F7200.000 X149.239 Y147.542
G1 F900.000 X132.456 Y130.759 E31.00238
G0 X132.386 Y130.689
G0 F7200.000 X133.022 Y130.759
G1 F900.000 X149.239 Y146.977 E32.22671
G0 X149.309 Y147.047
G0 F7200.000 X149.239 Y146.411
G1 F900.000 X133.588 Y130.759 E33.40831
G0 X133.518 Y130.689
G0 F7200.000 X134.153 Y130.759
G1 F900.000 X149.239 Y145.845 E34.54721
G0 X149.309 Y145.915
G0 F7200.000 X149.239 Y145.280
G1 F900.000 X134.719 Y130.759 E35.64343
G0 X134.649 Y130.689
G0 F7200.000 X135.285 Y130.759
G1 F900.000 X149.239 Y144.714 E36.69691
G0 X149.309 Y144.784
G0 F7200.000 X149.239 Y144.148
G1 F900.000 X135.850 Y130.759 E37.70771
G0 X135.780 Y130.689
G0 F7200.000 X136.416 Y130.759
G1 F900.000 X149.239 Y143.582 E38.67577
G0 X149.309 Y143.652
G0 F7200.000 X149.239 Y143.017
G1 F900.000 X136.982 Y130.759 E39.60114
G0 X136.912 Y130.689
G0 F7200.000 X137.547 Y130.759
G1 F900.000 X149.239 Y142.451 E40.48382
G0 X149.309 Y142.521
G0 F7200.000 X149.239 Y141.885
G1 F900.000 X138.113 Y130.759 E41.32377
G0 X138.043 Y130.689
G0 F7200.000 X138.679 Y130.759
G1 F900.000 X149.239 Y141.320 E42.12103
G0 X149.309 Y141.390
G0 F7200.000 X149.239 Y140.754
G1 F900.000 X139.244 Y130.759 E42.87559
G0 X139.174 Y130.689
G0 F7200.000 X139.810 Y130.759
G1 F900.000 X149.239 Y140.188 E43.58743
G0 X149.309 Y140.258
G0 F7200.000 X149.239 Y139.623
G1 F900.000 X140.376 Y130.759 E44.25657
G0 X140.306 Y130.689
G0 F7200.000 X140.941 Y130.759
G1 F900.000 X149.239 Y139.057 E44.88302
G0 X149.309 Y139.127
G0 F7200.000 X149.239 Y138.491
G1 F900.000 X141.507 Y130.759 E45.46674
G0 X141.437 Y130.689
G0 F7200.000 X142.073 Y130.759
G1 F900.000 X149.239 Y137.926 E46.00777
G0 X149.309 Y137.996
G0 F7200.000 X149.239 Y137.360
G1 F900.000 X142.638 Y130.759 E46.50611
G0 X142.568 Y130.689
G0 F7200.000 X143.204 Y130.759
G1 F900.000 X149.239 Y136.794 E46.96172
G0 X149.309 Y136.864
G0 F7200.000 X149.239 Y136.229
G1 F900.000 X143.770 Y130.759 E47.37464
G0 X143.700 Y130.689
G0 F7200.000 X144.336 Y130.759
G1 F900.000 X149.239 Y135.663 E47.74482
G0 X149.309 Y135.733
G0 F7200.000 X149.239 Y135.097
G1 F900.000 X144.901 Y130.759 E48.07232
G0 X144.831 Y130.689
G0 F7200.000 X145.467 Y130.759
G1 F900.000 X149.239 Y134.532 E48.35712
G0 X149.309 Y134.602
G0 F7200.000 X149.239 Y133.966
G1 F900.000 X146.033 Y130.759 E48.59919
G0 X145.963 Y130.689
G0 F7200.000 X146.598 Y130.759
G1 F900.000 X149.239 Y133.400 E48.79857
G0 X149.309 Y133.470
G0 F7200.000 X149.239 Y132.834
G1 F900.000 X147.164 Y130.759 E48.95522
G0 X147.094 Y130.689
G0 F7200.000 X147.730 Y130.759
G1 F900.000 X149.239 Y132.269 E49.06918
G0 X149.309 Y132.339
G0 F7200.000 X149.239 Y131.703
G1 F900.000 X148.295 Y130.759 E49.14045
G0 X148.225 Y130.689
G0 F7200.000 X148.861 Y130.759
G1 F900.000 X149.239 Y131.137 E49.16898
G0 F7200.00000 X148.673 Y149.239
G1 F900.000 X130.759 Y131.325 E50.52139
G0 X130.689 Y131.255
G0 F7200.000 X130.759 Y131.890
G1 F900.000 X148.107 Y149.239 E51.83110
G0 X148.177 Y149.309
G0 F7200.000 X147.542 Y149.239
G1 F900.000 X130.759 Y132.456 E53.09812
G0 X130.689 Y132.386
G0 F7200.000 X130.759 Y133.022
G1 F900.000 X146.976 Y149.239 E54.32241
G0 X147.046 Y149.309
G0 F7200.000 X146.410 Y149.239
G1 F900.000 X130.759 Y133.588 E55.50397
G0 X130.689 Y133.518
G0 F7200.000 X130.759 Y134.153
G1 F900.000 X145.845 Y149.239 E56.64288
G0 X145.915 Y149.309
G0 F7200.000 X145.279 Y149.239
G1 F900.000 X130.759 Y134.719 E57.73906
G0 X130.689 Y134.649
G0 F7200.000 X130.759 Y135.285
G1 F900.000 X144.713 Y149.239 E58.79250
G0 X144.783 Y149.309
G0 F7200.000 X144.147 Y149.239
G1 F900.000 X130.759 Y135.850 E59.80326
G0 X130.689 Y135.780
G0 F7200.000 X130.759 Y136.416
G1 F900.000 X143.582 Y149.239 E60.77132
G0 X143.652 Y149.309
G0 F7200.000 X143.016 Y149.239
G1 F900.000 X130.759 Y136.982 E61.69666
G0 X130.689 Y136.912
G0 F7200.000 X130.759 Y137.547
G1 F900.000 X142.450 Y149.239 E62.57930
G0 X142.520 Y149.309
G0 F7200.000 X141.885 Y149.239
G1 F900.000 X130.759 Y138.113 E63.41925
G0 X130.689 Y138.043
G0 F7200.000 X130.759 Y138.679
G1 F900.000 X141.319 Y149.239 E64.21647
G0 X141.389 Y149.309
G0 F7200.000 X140.753 Y149.239
G1 F900.000 X130.759 Y139.244 E64.97099
G0 X130.689 Y139.174
G0 F7200.000 X130.759 Y139.810
G1 F900.000 X140.188 Y149.239 E65.68283
G0 X140.258 Y149.309
G0 F7200.000 X139.622 Y149.239
G1 F900.000 X130.759 Y140.376 E66.35193
G0 X130.689 Y140.306
G0 F7200.000 X130.759 Y140.941
G1 F900.000 X139.056 Y149.239 E66.97835
G0 X139.126 Y149.309
G0 F7200.000 X138.491 Y149.239
G1 F900.000 X130.759 Y141.507 E67.56207
G0 X130.689 Y141.437
G0 F7200.000 X130.759 Y142.073
G1 F900.000 X137.925 Y149.239 E68.10306
G0 X137.995 Y149.309
G0 F7200.000 X137.359 Y149.239
G1 F900.000 X130.759 Y142.638 E68.60136
G0 X130.689 Y142.568
G0 F7200.000 X130.759 Y143.204
G1 F900.000 X136.794 Y149.239 E69.05697
G0 X136.864 Y149.309
G0 F7200.000 X136.228 Y149.239
G1 F900.000 X130.759 Y143.770 E69.46985
G0 X130.689 Y143.700
G0 F7200.000 X130.759 Y144.336
G1 F900.000 X135.662 Y149.239 E69.84000
G0 X135.732 Y149.309
G0 F7200.000 X135.096 Y149.239
G1 F900.000 X130.759 Y144.901 E70.16745
G0 X130.689 Y144.831
G0 F7200.000 X130.759 Y145.467
G1 F900.000 X134.531 Y149.239 E70.45222
G0 X134.601 Y149.309
G0 F7200.000 X133.965 Y149.239
G1 F900.000 X130.759 Y146.033 E70.69425
G0 X130.689 Y145.963
G0 F7200.000 X130.759 Y146.598
G1 F900.000 X133.399 Y149.239 E70.89359
G0 X133.469 Y149.309
G0 F7200.000 X132.834 Y149.239
G1 F900.000 X130.759 Y147.164 E71.05025
G0 X130.689 Y147.094
G0 F7200.000 X130.759 Y147.730
G1 F900.000 X132.268 Y149.239 E71.16417
G0 X132.338 Y149.309
G0 F7200.000 X131.702 Y149.239
G1 F900.000 X130.759 Y148.295 E71.23540
G0 X130.689 Y148.225
G0 F7200.000 X130.759 Y148.861
G1 F900.000 X131.137 Y149.239 E71.26393
G0 F7200.00000 X131.137 Y149.000
;LAYER:1
G0 X130.600 Y149.400 Z0.400
;TYPE:WALL-INNER
G1 F2250.000 X130.600 Y130.600 E71.59846
G1 X149.400 Y130.600 E71.93299
G1 X149.400 Y149.400 E72.26752
G1 X130.600 Y149.400 E72.60205
G0 F7200.00000 X130.200 Y149.800
;TYPE:WALL-OUTER
G1 F1350.000 X130.200 Y130.200 E72.95082
G1 X149.800 Y130.200 E73.29959
G1 X149.800 Y149.800 E73.64835
G1 X130.200 Y149.800 E73.99712
G0 F7200.00000 X130.774 Y149.239
;TYPE:SKIN
G1 F1350.000 X149.239 Y130.775 E74.46177
G0 X149.309 Y130.705
G0 F7200.000 X148.688 Y130.759
G1 F1350.000 X130.759 Y148.688 E74.91295
G0 X130.689 Y148.758
G0 F7200.000 X130.759 Y148.123
G1 F1350.000 X148.123 Y130.759 E75.34991
G0 X148.193 Y130.689
G0 F7200.000 X147.557 Y130.759
G1 F1350.000 X130.759 Y147.557 E75.77263
G0 X130.689 Y147.627
G0 F7200.000 X130.759 Y146.991
G1 F1350.000 X146.991 Y130.759 E76.18110
G0 X147.061 Y130.689
G0 F7200.000 X146.426 Y130.759
G1 F1350.000 X130.759 Y146.426 E76.57536
G0 X130.689 Y146.496
G0 F7200.000 X130.759 Y145.860
G1 F1350.000 X145.860 Y130.759 E76.95537
G0 X145.930 Y130.689
G0 F7200.000 X145.294 Y130.759
G1 F1350.000 X130.759 Y145.294 E77.32114
G0 X130.689 Y145.364
G0 F7200.000 X130.759 Y144.729
G1 F1350.000 X144.729 Y130.759 E77.67269
G0 X144.799 Y130.689
G0 F7200.000 X144.163 Y130.759
G1 F1350.000 X130.759 Y144.163 E78.01000
G0 X130.689 Y144.233
G0 F7200.000 X130.759 Y143.597
G1 F1350.000 X143.597 Y130.759 E78.33307
G0 X143.667 Y130.689
G0 F7200.000 X143.032 Y130.759
G1 F1350.000 X130.759 Y143.032 E78.64192
G0 X130.689 Y143.102
G0 F7200.000 X130.759 Y142.466
G1 F1350.000 X142.466 Y130.759 E78.93652
G0 X142.536 Y130.689
G0 F7200.000 X141.900 Y130.759
G1 F1350.000 X130.759 Y141.900 E79.21688
G0 X130.689 Y141.970
G0 F7200.000 X130.759 Y141.335
G1 F1350.000 X141.335 Y130.759 E79.48302
G0 X141.405 Y130.689
G0 F7200.000 X140.769 Y130.759
G1 F1350.000 X130.759 Y140.769 E79.73492
G0 X130.689 Y140.839
G0 F7200.000 X130.759 Y140.203
G1 F1350.000 X140.203 Y130.759 E79.97258
G0 X140.273 Y130.689
G0 F7200.000 X139.638 Y130.759
G1 F1350.000 X130.759 Y139.638 E80.19602
G0 X130.689 Y139.708
G0 F7200.000 X130.759 Y139.072
G1 F1350.000 X139.072 Y130.759 E80.40521
G0 X139.142 Y130.689
G0 F7200.000 X138.506 Y130.759
G1 F1350.000 X130.759 Y138.506 E80.60016
G0 X130.689 Y138.576
G0 F7200.000 X130.759 Y137.940
G1 F1350.000 X137.940 Y130.759 E80.78087
G0 X138.010 Y130.689
G0 F7200.000 X137.375 Y130.759
G1 F1350.000 X130.759 Y137.375 E80.94736
G0 X130.689 Y137.445
G0 F7200.000 X130.759 Y136.809
G1 F1350.000 X136.809 Y130.759 E81.09961
G0 X136.879 Y130.689
G0 F7200.000 X136.243 Y130.759
G1 F1350.000 X130.759 Y136.243 E81.23761
G0 X130.689 Y136.313
G0 F7200.000 X130.759 Y135.678
G1 F1350.000 X135.678 Y130.759 E81.36140
G0 X135.748 Y130.689
G0 F7200.000 X135.112 Y130.759
G1 F1350.000 X130.759 Y135.112 E81.47094
G0 X130.689 Y135.182
G0 F7200.000 X130.759 Y134.546
G1 F1350.000 X134.546 Y130.759 E81.56624
G0 X134.616 Y130.689
G0 F7200.000 X133.981 Y130.759
G1 F1350.000 X130.759 Y133.981 E81.64732
G0 X130.689 Y134.051
G0 F7200.000 X130.759 Y133.415
G1 F1350.000 X133.415 Y130.759 E81.71415
G0 X133.485 Y130.689
G0 F7200.000 X132.849 Y130.759
G1 F1350.000 X130.759 Y132.849 E81.76675
G0 X130.689 Y132.919
G0 F7200.000 X130.759 Y132.284
G1 F1350.000 X132.284 Y130.759 E81.80513
G0 X132.354 Y130.689
G0 F7200.000 X131.718 Y130.759
G1 F1350.000 X130.759 Y131.718 E81.82926
G0 X130.689 Y131.788
G0 F7200.000 X130.759 Y131.152
G1 F1350.000 X131.152 Y130.759 E81.83915
G0 F7200.00000 X149.239 Y131.340
G1 F1350.000 X131.340 Y149.239 E82.28957
G0 X131.270 Y149.309
G0 F7200.000 X131.905 Y149.239
G1 F1350.000 X149.239 Y131.906 E82.72577
G0 X149.309 Y131.836
G0 F7200.000 X149.239 Y132.472
G1 F1350.000 X132.471 Y149.239 E83.14772
G0 X132.401 Y149.309
G0 F7200.000 X133.037 Y149.239
G1 F1350.000 X149.239 Y133.037 E83.55544
G0 X149.309 Y132.967
G0 F7200.000 X149.239 Y133.603
G1 F1350.000 X133.602 Y149.239 E83.94892
G0 X133.532 Y149.309
G0 F7200.000 X134.168 Y149.239
G1 F1350.000 X149.239 Y134.169 E84.32817
G0 X149.309 Y134.099
G0 F7200.000 X149.239 Y134.734
G1 F1350.000 X134.734 Y149.239 E84.69318
G0 X134.664 Y149.309
G0 F7200.000 X135.299 Y149.239
G1 F1350.000 X149.239 Y135.300 E85.04397
G0 X149.309 Y135.230
G0 F7200.000 X149.239 Y135.866
G1 F1350.000 X135.865 Y149.239 E85.38051
G0 X135.795 Y149.309
G0 F7200.000 X136.431 Y149.239
G1 F1350.000 X149.239 Y136.432 E85.70281
G0 X149.309 Y136.362
G0 F7200.000 X149.239 Y136.997
G1 F1350.000 X136.996 Y149.239 E86.01089
G0 X136.926 Y149.309
G0 F7200.000 X137.562 Y149.239
G1 F1350.000 X149.239 Y137.563 E86.30472
G0 X149.309 Y137.493
G0 F7200.000 X149.239 Y138.129
G1 F1350.000 X138.128 Y149.239 E86.58432
G0 X138.058 Y149.309
G0 F7200.000 X138.694 Y149.239
G1 F1350.000 X149.239 Y138.694 E86.84968
G0 X149.309 Y138.624
G0 F7200.000 X149.239 Y139.260
G1 F1350.000 X139.259 Y149.239 E87.10081
G0 X139.189 Y149.309
G0 F7200.000 X139.825 Y149.239
G1 F1350.000 X149.239 Y139.826 E87.33770
G0 X149.309 Y139.756
G0 F7200.000 X149.239 Y140.391
G1 F1350.000 X140.391 Y149.239 E87.56036
G0 X140.321 Y149.309
G0 F7200.000 X140.956 Y149.239
G1 F1350.000 X149.239 Y140.957 E87.76878
G0 X149.309 Y140.887
G0 F7200.000 X149.239 Y141.523
G1 F1350.000 X141.522 Y149.239 E87.96297
G0 X141.452 Y149.309
G0 F7200.000 X142.088 Y149.239
G1 F1350.000 X149.239 Y142.088 E88.14292
G0 X149.309 Y142.018
G0 F7200.000 X149.239 Y142.654
G1 F1350.000 X142.653 Y149.239 E88.30864
G0 X142.583 Y149.309
G0 F7200.000 X143.219 Y149.239
G1 F1350.000 X149.239 Y143.220 E88.46012
G0 X149.309 Y143.150
G0 F7200.000 X149.239 Y143.785
G1 F1350.000 X143.785 Y149.239 E88.59737
G0 X143.715 Y149.309
G0 F7200.000 X144.350 Y149.239
G1 F1350.000 X149.239 Y144.351 E88.72039
G0 X149.309 Y144.281
G0 F7200.000 X149.239 Y144.917
G1 F1350.000 X144.916 Y149.239 E88.82916
G0 X144.846 Y149.309
G0 F7200.000 X145.482 Y149.239
G1 F1350.000 X149.239 Y145.482 E88.92371
G0 X149.309 Y145.412
G0 F7200.000 X149.239 Y146.048
G1 F1350.000 X146.047 Y149.239 E89.00402
G0 X145.977 Y149.309
G0 F7200.000 X146.613 Y149.239
G1 F1350.000 X149.239 Y146.614 E89.07009
G0 X149.309 Y146.544
G0 F7200.000 X149.239 Y147.180
G1 F1350.000 X147.179 Y149.239 E89.12192
G0 X147.109 Y149.309
G0 F7200.000 X147.745 Y149.239
G1 F1350.000 X149.239 Y147.745 E89.15951
G0 X149.309 Y147.675
G0 F7200.000 X149.239 Y148.311
G1 F1350.000 X148.310 Y149.239 E89.18288
G0 X148.240 Y149.309
G0 F7200.000 X148.876 Y149.239
G1 F1350.000 X149.239 Y148.877 E89.19200
G0 F7200.00000 X149.000 Y148.877
;LAYER:2
G0 X149.400 Y149.400 Z0.500
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E89.52653
G1 X130.600 Y130.600 E89.86106
G1 X149.400 Y130.600 E90.19559
G1 X149.400 Y149.400 E90.53012
G0 F7200.00000 X149.800 Y149.800
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E90.87889
G1 X130.200 Y130.200 E91.22765
G1 X149.800 Y130.200 E91.57642
G1 X149.800 Y149.800 E91.92519
G0 F7200.00000 X149.239 Y149.239
;TYPE:SKIN
G1 F1800.000 X130.759 Y130.759 E92.39023
G0 X130.689 Y130.689
G0 F7200.000 X131.325 Y130.759
G1 F1800.000 X149.239 Y148.674 E92.84105
G0 X149.309 Y148.744
G0 F7200.000 X149.239 Y148.108
G1 F1800.000 X131.890 Y130.759 E93.27763
G0 X131.820 Y130.689
G0 F7200.000 X132.456 Y130.759
G1 F1800.000 X149.239 Y147.542 E93.69997
G0 X149.309 Y147.612
G0 F7200.000 X149.239 Y146.977
G1 F1800.000 X133.022 Y130.759 E94.10808
G0 X132.952 Y130.689
G0 F7200.000 X133.588 Y130.759
G1 F1800.000 X149.239 Y146.411 E94.50194
G0 X149.309 Y146.481
G0 F7200.000 X149.239 Y145.845
G1 F1800.000 X134.153 Y130.759 E94.88158
G0 X134.083 Y130.689
G0 F7200.000 X134.719 Y130.759
G1 F1800.000 X149.239 Y145.280 E95.24699
G0 X149.309 Y145.350
G0 F7200.000 X149.239 Y144.714
G1 F1800.000 X135.285 Y130.759 E95.59815
G0 X135.215 Y130.689
G0 F7200.000 X135.850 Y130.759
G1 F1800.000 X149.239 Y144.148 E95.93508
G0 X149.309 Y144.218
G0 F7200.000 X149.239 Y143.582
G1 F1800.000 X136.416 Y130.759 E96.25777
G0 X136.346 Y130.689
G0 F7200.000 X136.982 Y130.759
G1 F1800.000 X149.239 Y143.017 E96.56622
G0 X149.309 Y143.087
G0 F7200.000 X149.239 Y142.451
G1 F1800.000 X137.547 Y130.759 E96.86045
G0 X137.477 Y130.689
G0 F7200.000 X138.113 Y130.759
G1 F1800.000 X149.239 Y141.885 E97.14043
G0 X149.309 Y141.955
G0 F7200.000 X149.239 Y141.320
G1 F1800.000 X138.679 Y130.759 E97.40618
G0 X138.609 Y130.689
G0 F7200.000 X139.244 Y130.759
G1 F1800.000 X149.239 Y140.754 E97.65771
G0 X149.309 Y140.824
G0 F7200.000 X149.239 Y140.188
G1 F1800.000 X139.810 Y130.759 E97.89498
G0 X139.740 Y130.689
G0 F7200.000 X140.376 Y130.759
G1 F1800.000 X149.239 Y139.623 E98.11803
G0 X149.309 Y139.693
G0 F7200.000 X149.239 Y139.057
G1 F1800.000 X140.941 Y130.759 E98.32685
G0 X140.871 Y130.689
G0 F7200.000 X141.507 Y130.759
G1 F1800.000 X149.239 Y138.491 E98.52142
G0 X149.309 Y138.561
G0 F7200.000 X149.239 Y137.926
G1 F1800.000 X142.073 Y130.759 E98.70177
G0 X142.003 Y130.689
G0 F7200.000 X142.638 Y130.759
G1 F1800.000 X149.239 Y137.360 E98.86788
G0 X149.309 Y137.430
G0 F7200.000 X149.239 Y136.794
G1 F1800.000 X143.204 Y130.759 E99.01975
G0 X143.134 Y130.689
G0 F7200.000 X143.770 Y130.759
G1 F1800.000 X149.239 Y136.229 E99.15739
G0 X149.309 Y136.299
G0 F7200.000 X149.239 Y135.663
G1 F1800.000 X144.336 Y130.759 E99.28078
G0 X144.266 Y130.689
G0 F7200.000 X144.901 Y130.759
G1 F1800.000 X149.239 Y135.097 E99.38995
G0 X149.309 Y135.167
G0 F7200.000 X149.239 Y134.532
G1 F1800.000 X145.467 Y130.759 E99.48488
G0 X145.397 Y130.689
G0 F7200.000 X146.033 Y130.759
G1 F1800.000 X149.239 Y133.966 E99.56557
G0 X149.309 Y134.036
G0 F7200.000 X149.239 Y133.400
G1 F1800.000 X146.598 Y130.759 E99.63203
G0 X146.528 Y130.689
G0 F7200.000 X147.164 Y130.759
G1 F1800.000 X149.239 Y132.834 E99.68425
G0 X149.309 Y132.904
G0 F7200.000 X149.239 Y132.269
G1 F1800.000 X147.730 Y130.759 E99.72224
G0 X147.660 Y130.689
G0 F7200.000 X148.295 Y130.759
G1 F1800.000 X149.239 Y131.703 E99.74599
G0 X149.309 Y131.773
G0 F7200.000 X149.239 Y131.137
G1 F1800.000 X148.861 Y130.759 E99.75550
G0 F7200.00000 X130.759 Y131.325
G1 F1800.000 X148.673 Y149.239 E100.20630
G0 X148.743 Y149.309
G0 F7200.000 X148.107 Y149.239
G1 F1800.000 X130.759 Y131.890 E100.64288
G0 X130.689 Y131.820
G0 F7200.000 X130.759 Y132.456
G1 F1800.000 X147.542 Y149.239 E101.06522
G0 X147.612 Y149.309
G0 F7200.000 X146.976 Y149.239
G1 F1800.000 X130.759 Y133.022 E101.47331
G0 X130.689 Y132.952
G0 F7200.000 X130.759 Y133.588
G1 F1800.000 X146.410 Y149.239 E101.86717
G0 X146.480 Y149.309
G0 F7200.000 X145.845 Y149.239
G1 F1800.000 X130.759 Y134.153 E102.24680
G0 X130.689 Y134.083
G0 F7200.000 X130.759 Y134.719
G1 F1800.000 X145.279 Y149.239 E102.61219
G0 X145.349 Y149.309
G0 F7200.000 X144.713 Y149.239
G1 F1800.000 X130.759 Y135.285 E102.96334
G0 X130.689 Y135.215
G0 F7200.000 X130.759 Y135.850
G1 F1800.000 X144.147 Y149.239 E103.30026
G0 X144.217 Y149.309
G0 F7200.000 X143.582 Y149.239
G1 F1800.000 X130.759 Y136.416 E103.62295
G0 X130.689 Y136.346
G0 F7200.000 X130.759 Y136.982
G1 F1800.000 X143.016 Y149.239 E103.93139
G0 X143.086 Y149.309
G0 F7200.000 X142.450 Y149.239
G1 F1800.000 X130.759 Y137.547 E104.22561
G0 X130.689 Y137.477
G0 F7200.000 X130.759 Y138.113
G1 F1800.000 X141.885 Y149.239 E104.50559
G0 X141.955 Y149.309
G0 F7200.000 X141.319 Y149.239
G1 F1800.000 X130.759 Y138.679 E104.77133
G0 X130.689 Y138.609
G0 F7200.000 X130.759 Y139.244
G1 F1800.000 X140.753 Y149.239 E105.02284
G0 X140.823 Y149.309
G0 F7200.000 X140.188 Y149.239
G1 F1800.000 X130.759 Y139.810 E105.26012
G0 X130.689 Y139.740
G0 F7200.000 X130.759 Y140.376
G1 F1800.000 X139.622 Y149.239 E105.48315
G0 X139.692 Y149.309
G0 F7200.000 X139.056 Y149.239
G1 F1800.000 X130.759 Y140.941 E105.69196
G0 X130.689 Y140.871
G0 F7200.000 X130.759 Y141.507
G1 F1800.000 X138.491 Y149.239 E105.88653
G0 X138.561 Y149.309
G0 F7200.000 X137.925 Y149.239
G1 F1800.000 X130.759 Y142.073 E106.06686
G0 X130.689 Y142.003
G0 F7200.000 X130.759 Y142.638
G1 F1800.000 X137.359 Y149.239 E106.23296
G0 X137.429 Y149.309
G0 F7200.000 X136.794 Y149.239
G1 F1800.000 X130.759 Y143.204 E106.38483
G0 X130.689 Y143.134
G0 F7200.000 X130.759 Y143.770
G1 F1800.000 X136.228 Y149.239 E106.52246
G0 X136.298 Y149.309
G0 F7200.000 X135.662 Y149.239
G1 F1800.000 X130.759 Y144.336 E106.64584
G0 X130.689 Y144.266
G0 F7200.000 X130.759 Y144.901
G1 F1800.000 X135.096 Y149.239 E106.75499
G0 X135.166 Y149.309
G0 F7200.000 X134.531 Y149.239
G1 F1800.000 X130.759 Y145.467 E106.84991
G0 X130.689 Y145.397
G0 F7200.000 X130.759 Y146.033
G1 F1800.000 X133.965 Y149.239 E106.93059
G0 X134.035 Y149.309
G0 F7200.000 X133.399 Y149.239
G1 F1800.000 X130.759 Y146.598 E106.99704
G0 X130.689 Y146.528
G0 F7200.000 X130.759 Y147.164
G1 F1800.000 X132.834 Y149.239 E107.04926
G0 X132.904 Y149.309
G0 F7200.000 X132.268 Y149.239
G1 F1800.000 X130.759 Y147.730 E107.08723
G0 X130.689 Y147.660
G0 F7200.000 X130.759 Y148.295
G1 F1800.000 X131.702 Y149.239 E107.11097
G0 X131.772 Y149.309
G0 F7200.000 X131.137 Y149.239
G1 F1800.000 X130.759 Y148.861 E107.12049
G0 F7200.00000 X131.000 Y148.861
;LAYER:3
G0 X130.759 Y147.730 Z0.600
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E107.15846
G0 F7200.000 X133.602 Y149.239
G1 F3600.000 X149.239 Y133.603 E107.55195
G0 X149.309 Y133.533
G1 F3600.000 X147.730 Y130.759 E107.58993
G1 F3600.000 X130.759 Y146.426 E107.98419
G1 F3600.000 X137.925 Y149.239 E108.16452
G0 F7200.000 X139.259 Y149.239
G1 F3600.000 X149.239 Y139.260 E108.41565
G0 X149.309 Y139.190
G1 F3600.000 X142.073 Y130.759 E108.59600
G1 F3600.000 X130.759 Y140.769 E108.84790
G1 F3600.000 X143.582 Y149.239 E109.17058
G0 F7200.000 X144.916 Y149.239
G1 F3600.000 X149.239 Y144.917 E109.27936
G0 X149.309 Y144.847
G1 F3600.000 X136.416 Y130.759 E109.60205
G1 F3600.000 X130.759 Y135.112 E109.71159
G0 F7200.000 X130.759 Y130.759
G1 F3600.000 X149.239 Y149.239 E110.17663
G0 F7200.000 X149.400 Y149.400
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E110.51116
G1 X130.600 Y130.600 E110.84569
G1 X149.400 Y130.600 E111.18022
G1 X149.400 Y149.400 E111.51475
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E111.86352
G1 X130.200 Y130.200 E112.21229
G1 X149.800 Y130.200 E112.56105
G1 X149.800 Y149.800 E112.90982
G0 F7200.00000 X149.000 Y149.118
;LAYER:4
G0 X149.239 Y149.239 Z0.700
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E113.37486
G0 F7200.000 X130.759 Y135.112
G1 F3600.000 X135.112 Y130.759 E113.48440
G0 X135.182 Y130.689
G1 F3600.000 X149.239 Y143.582 E113.80709
G1 F3600.000 X144.916 Y149.239 E113.91587
G1 F3600.000 X130.759 Y136.416 E114.23855
G0 F7200.000 X130.759 Y140.769
G1 F3600.000 X140.769 Y130.759 E114.49045
G0 X140.839 Y130.689
G1 F3600.000 X149.239 Y137.926 E114.67080
G1 F3600.000 X139.259 Y149.239 E114.92193
G1 F3600.000 X130.759 Y142.073 E115.10226
G0 F7200.000 X130.759 Y146.426
G1 F3600.000 X146.426 Y130.759 E115.49652
G0 X146.496 Y130.689
G1 F3600.000 X149.239 Y132.269 E115.53450
G1 F3600.000 X133.602 Y149.239 E115.92799
G1 F3600.000 X130.759 Y147.730 E115.96596
G0 F7200.000 X130.600 Y149.400
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E116.30050
G1 X149.400 Y130.600 E116.63503
G1 X149.400 Y149.400 E116.96956
G1 X130.600 Y149.400 E117.30409
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E117.65285
G1 X149.800 Y130.200 E118.00162
G1 X149.800 Y149.800 E118.35038
G1 X130.200 Y149.800 E118.69915
G0 F7200.00000 X130.882 Y149.000
;LAYER:5
G0 X130.759 Y147.730 Z0.800
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E118.73712
G1 F3600.000 X149.239 Y133.603 E119.13061
G1 F3600.000 X147.730 Y130.759 E119.16860
G1 F3600.000 X130.759 Y146.426 E119.56285
G1 F3600.000 X137.925 Y149.239 E119.74319
G1 F3600.000 X149.239 Y139.260 E119.99432
G1 F3600.000 X142.073 Y130.759 E120.17466
G1 F3600.000 X130.759 Y140.769 E120.42656
G1 F3600.000 X143.582 Y149.239 E120.74925
G1 F3600.000 X149.239 Y144.917 E120.85802
G1 F3600.000 X136.416 Y130.759 E121.18071
G1 F3600.000 X130.759 Y135.112 E121.29025
G1 F3600.000 X149.239 Y149.239 E121.75530
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E122.08983
G1 X130.600 Y130.600 E122.42436
G1 X149.400 Y130.600 E122.75889
G1 X149.400 Y149.400 E123.09342
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E123.44218
G1 X130.200 Y130.200 E123.79095
G1 X149.800 Y130.200 E124.13972
G1 X149.800 Y149.800 E124.48848
;LAYER:6
G0 X149.239 Y149.239 Z0.900
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E124.95353
G1 F3600.000 X135.112 Y130.759 E125.06307
G1 F3600.000 X149.239 Y143.582 E125.38576
G1 F3600.000 X144.916 Y149.239 E125.49453
G1 F3600.000 X130.759 Y136.416 E125.81722
G1 F3600.000 X140.769 Y130.759 E126.06912
G1 F3600.000 X149.239 Y137.926 E126.24946
G1 F3600.000 X139.259 Y149.239 E126.50059
G1 F3600.000 X130.759 Y142.073 E126.68092
G1 F3600.000 X146.426 Y130.759 E127.07518
G1 F3600.000 X149.239 Y132.269 E127.11317
G1 F3600.000 X133.602 Y149.239 E127.50665
G1 F3600.000 X130.759 Y147.730 E127.54463
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E127.87916
G1 X149.400 Y130.600 E128.21369
G1 X149.400 Y149.400 E128.54822
G1 X130.600 Y149.400 E128.88275
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E129.23152
G1 X149.800 Y130.200 E129.58028
G1 X149.800 Y149.800 E129.92905
G1 X130.200 Y149.800 E130.27781
;LAYER:7
G0 X130.759 Y147.730 Z1.000
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E130.31579
G1 F3600.000 X149.239 Y133.603 E130.70928
G1 F3600.000 X147.730 Y130.759 E130.74726
G1 F3600.000 X130.759 Y146.426 E131.14152
G1 F3600.000 X137.925 Y149.239 E131.32185
G1 F3600.000 X149.239 Y139.260 E131.57298
G1 F3600.000 X142.073 Y130.759 E131.75332
G1 F3600.000 X130.759 Y140.769 E132.00522
G1 F3600.000 X143.582 Y149.239 E132.32791
G1 F3600.000 X149.239 Y144.917 E132.43669
G1 F3600.000 X136.416 Y130.759 E132.75937
G1 F3600.000 X130.759 Y135.112 E132.86892
G1 F3600.000 X149.239 Y149.239 E133.33396
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E133.66849
G1 X130.600 Y130.600 E134.00302
G1 X149.400 Y130.600 E134.33755
G1 X149.400 Y149.400 E134.67208
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E135.02085
G1 X130.200 Y130.200 E135.36961
G1 X149.800 Y130.200 E135.71838
G1 X149.800 Y149.800 E136.06714
;LAYER:8
G0 X149.239 Y149.239 Z1.100
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E136.53219
G1 F3600.000 X135.112 Y130.759 E136.64173
G1 F3600.000 X149.239 Y143.582 E136.96442
G1 F3600.000 X144.916 Y149.239 E137.07319
G1 F3600.000 X130.759 Y136.416 E137.39588
G1 F3600.000 X140.769 Y130.759 E137.64778
G1 F3600.000 X149.239 Y137.926 E137.82812
G1 F3600.000 X139.259 Y149.239 E138.07926
G1 F3600.000 X130.759 Y142.073 E138.25959
G1 F3600.000 X146.426 Y130.759 E138.65384
G1 F3600.000 X149.239 Y132.269 E138.69183
G1 F3600.000 X133.602 Y149.239 E139.08532
G1 F3600.000 X130.759 Y147.730 E139.12329
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E139.45782
G1 X149.400 Y130.600 E139.79235
G1 X149.400 Y149.400 E140.12688
G1 X130.600 Y149.400 E140.46141
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E140.81018
G1 X149.800 Y130.200 E141.15894
G1 X149.800 Y149.800 E141.50771
G1 X130.200 Y149.800 E141.85648
;LAYER:9
G0 X130.759 Y147.730 Z1.200
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E141.89445
G1 F3600.000 X149.239 Y133.603 E142.28794
G1 F3600.000 X147.730 Y130.759 E142.32592
G1 F3600.000 X130.759 Y146.426 E142.72018
G1 F3600.000 X137.925 Y149.239 E142.90051
G1 F3600.000 X149.239 Y139.260 E143.15164
G1 F3600.000 X142.073 Y130.759 E143.33199
G1 F3600.000 X130.759 Y140.769 E143.58389
G1 F3600.000 X143.582 Y149.239 E143.90657
G1 F3600.000 X149.239 Y144.917 E144.01535
G1 F3600.000 X136.416 Y130.759 E144.33804
G1 F3600.000 X130.759 Y135.112 E144.44758
G1 F3600.000 X149.239 Y149.239 E144.91262
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E145.24715
G1 X130.600 Y130.600 E145.58168
G1 X149.400 Y130.600 E145.91621
G1 X149.400 Y149.400 E146.25074
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E146.59951
G1 X130.200 Y130.200 E146.94828
G1 X149.800 Y130.200 E147.29704
G1 X149.800 Y149.800 E147.64581
;LAYER:10
G0 X149.239 Y149.239 Z1.300
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E148.11085
G1 F3600.000 X135.112 Y130.759 E148.22040
G1 F3600.000 X149.239 Y143.582 E148.54308
G1 F3600.000 X144.916 Y149.239 E148.65186
G1 F3600.000 X130.759 Y136.416 E148.97455
G1 F3600.000 X140.769 Y130.759 E149.22644
G1 F3600.000 X149.239 Y137.926 E149.40679
G1 F3600.000 X139.259 Y149.239 E149.65792
G1 F3600.000 X130.759 Y142.073 E149.83825
G1 F3600.000 X146.426 Y130.759 E150.23251
G1 F3600.000 X149.239 Y132.269 E150.27049
G1 F3600.000 X133.602 Y149.239 E150.66398
G1 F3600.000 X130.759 Y147.730 E150.70195
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E151.03649
G1 X149.400 Y130.600 E151.37102
G1 X149.400 Y149.400 E151.70555
G1 X130.600 Y149.400 E152.04008
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E152.38884
G1 X149.800 Y130.200 E152.73761
G1 X149.800 Y149.800 E153.08637
G1 X130.200 Y149.800 E153.43514
;LAYER:11
G0 X130.759 Y147.730 Z1.400
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E153.47311
G1 F3600.000 X149.239 Y133.603 E153.86660
G1 F3600.000 X147.730 Y130.759 E153.90459
G1 F3600.000 X130.759 Y146.426 E154.29884
G1 F3600.000 X137.925 Y149.239 E154.47918
G1 F3600.000 X149.239 Y139.260 E154.73031
G1 F3600.000 X142.073 Y130.759 E154.91065
G1 F3600.000 X130.759 Y140.769 E155.16255
G1 F3600.000 X143.582 Y149.239 E155.48524
G1 F3600.000 X149.239 Y144.917 E155.59401
G1 F3600.000 X136.416 Y130.759 E155.91670
G1 F3600.000 X130.759 Y135.112 E156.02624
G1 F3600.000 X149.239 Y149.239 E156.49129
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E156.82582
G1 X130.600 Y130.600 E157.16035
G1 X149.400 Y130.600 E157.49488
G1 X149.400 Y149.400 E157.82941
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E158.17817
G1 X130.200 Y130.200 E158.52694
G1 X149.800 Y130.200 E158.87571
G1 X149.800 Y149.800 E159.22447
;LAYER:12
G0 X149.239 Y149.239 Z1.500
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E159.68952
G1 F3600.000 X135.112 Y130.759 E159.79906
G1 F3600.000 X149.239 Y143.582 E160.12175
G1 F3600.000 X144.916 Y149.239 E160.23052
G1 F3600.000 X130.759 Y136.416 E160.55321
G1 F3600.000 X140.769 Y130.759 E160.80511
G1 F3600.000 X149.239 Y137.926 E160.98545
G1 F3600.000 X139.259 Y149.239 E161.23658
G1 F3600.000 X130.759 Y142.073 E161.41691
G1 F3600.000 X146.426 Y130.759 E161.81117
G1 F3600.000 X149.239 Y132.269 E161.84916
G1 F3600.000 X133.602 Y149.239 E162.24264
G1 F3600.000 X130.759 Y147.730 E162.28062
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E162.61515
G1 X149.400 Y130.600 E162.94968
G1 X149.400 Y149.400 E163.28421
G1 X130.600 Y149.400 E163.61874
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E163.96751
G1 X149.800 Y130.200 E164.31627
G1 X149.800 Y149.800 E164.66504
G1 X130.200 Y149.800 E165.01380
;LAYER:13
G0 X130.759 Y147.730 Z1.600
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E165.05178
G1 F3600.000 X149.239 Y133.603 E165.44527
G1 F3600.000 X147.730 Y130.759 E165.48325
G1 F3600.000 X130.759 Y146.426 E165.87751
G1 F3600.000 X137.925 Y149.239 E166.05784
G1 F3600.000 X149.239 Y139.260 E166.30897
G1 F3600.000 X142.073 Y130.759 E166.48931
G1 F3600.000 X130.759 Y140.769 E166.74121
G1 F3600.000 X143.582 Y149.239 E167.06390
G1 F3600.000 X149.239 Y144.917 E167.17268
G1 F3600.000 X136.416 Y130.759 E167.49536
G1 F3600.000 X130.759 Y135.112 E167.60491
G1 F3600.000 X149.239 Y149.239 E168.06995
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E168.40448
G1 X130.600 Y130.600 E168.73901
G1 X149.400 Y130.600 E169.07354
G1 X149.400 Y149.400 E169.40807
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E169.75684
G1 X130.200 Y130.200 E170.10560
G1 X149.800 Y130.200 E170.45437
G1 X149.800 Y149.800 E170.80313
;LAYER:14
G0 X149.239 Y149.239 Z1.700
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E171.26818
G1 F3600.000 X135.112 Y130.759 E171.37772
G1 F3600.000 X149.239 Y143.582 E171.70041
G1 F3600.000 X144.916 Y149.239 E171.80918
G1 F3600.000 X130.759 Y136.416 E172.13187
G1 F3600.000 X140.769 Y130.759 E172.38377
G1 F3600.000 X149.239 Y137.926 E172.56411
G1 F3600.000 X139.259 Y149.239 E172.81525
G1 F3600.000 X130.759 Y142.073 E172.99558
G1 F3600.000 X146.426 Y130.759 E173.38983
G1 F3600.000 X149.239 Y132.269 E173.42782
G1 F3600.000 X133.602 Y149.239 E173.82131
G1 F3600.000 X130.759 Y147.730 E173.85928
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E174.19381
G1 X149.400 Y130.600 E174.52834
G1 X149.400 Y149.400 E174.86287
G1 X130.600 Y149.400 E175.19740
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E175.54617
G1 X149.800 Y130.200 E175.89493
G1 X149.800 Y149.800 E176.24370
G1 X130.200 Y149.800 E176.59247
;LAYER:15
G0 X130.759 Y147.730 Z1.800
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E176.63044
G1 F3600.000 X149.239 Y133.603 E177.02393
G1 F3600.000 X147.730 Y130.759 E177.06192
G1 F3600.000 X130.759 Y146.426 E177.45617
G1 F3600.000 X137.925 Y149.239 E177.63650
G1 F3600.000 X149.239 Y139.260 E177.88763
G1 F3600.000 X142.073 Y130.759 E178.06798
G1 F3600.000 X130.759 Y140.769 E178.31988
G1 F3600.000 X143.582 Y149.239 E178.64256
G1 F3600.000 X149.239 Y144.917 E178.75134
G1 F3600.000 X136.416 Y130.759 E179.07403
G1 F3600.000 X130.759 Y135.112 E179.18357
G1 F3600.000 X149.239 Y149.239 E179.64861
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E179.98314
G1 X130.600 Y130.600 E180.31767
G1 X149.400 Y130.600 E180.65220
G1 X149.400 Y149.400 E180.98674
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E181.33550
G1 X130.200 Y130.200 E181.68427
G1 X149.800 Y130.200 E182.03303
G1 X149.800 Y149.800 E182.38180
;LAYER:16
G0 X149.239 Y149.239 Z1.900
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E182.84684
G1 F3600.000 X135.112 Y130.759 E182.95639
G1 F3600.000 X149.239 Y143.582 E183.27907
G1 F3600.000 X144.916 Y149.239 E183.38785
G1 F3600.000 X130.759 Y136.416 E183.71054
G1 F3600.000 X140.769 Y130.759 E183.96243
G1 F3600.000 X149.239 Y137.926 E184.14278
G1 F3600.000 X139.259 Y149.239 E184.39391
G1 F3600.000 X130.759 Y142.073 E184.57424
G1 F3600.000 X146.426 Y130.759 E184.96850
G1 F3600.000 X149.239 Y132.269 E185.00648
G1 F3600.000 X133.602 Y149.239 E185.39997
G1 F3600.000 X130.759 Y147.730 E185.43795
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E185.77248
G1 X149.400 Y130.600 E186.10701
G1 X149.400 Y149.400 E186.44154
G1 X130.600 Y149.400 E186.77607
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E187.12483
G1 X149.800 Y130.200 E187.47360
G1 X149.800 Y149.800 E187.82236
G1 X130.200 Y149.800 E188.17113
;LAYER:17
G0 X130.759 Y147.730 Z2.000
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E188.20910
G1 F3600.000 X149.239 Y133.603 E188.60259
G1 F3600.000 X147.730 Y130.759 E188.64058
G1 F3600.000 X130.759 Y146.426 E189.03483
G1 F3600.000 X137.925 Y149.239 E189.21517
G1 F3600.000 X149.239 Y139.260 E189.46630
G1 F3600.000 X142.073 Y130.759 E189.64664
G1 F3600.000 X130.759 Y140.769 E189.89854
G1 F3600.000 X143.582 Y149.239 E190.22123
G1 F3600.000 X149.239 Y144.917 E190.33000
G1 F3600.000 X136.416 Y130.759 E190.65269
G1 F3600.000 X130.759 Y135.112 E190.76223
G1 F3600.000 X149.239 Y149.239 E191.22728
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E191.56181
G1 X130.600 Y130.600 E191.89634
G1 X149.400 Y130.600 E192.23087
G1 X149.400 Y149.400 E192.56540
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E192.91416
G1 X130.200 Y130.200 E193.26293
G1 X149.800 Y130.200 E193.61170
G1 X149.800 Y149.800 E193.96046
;LAYER:18
G0 X149.239 Y149.239 Z2.100
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E194.42551
G1 F3600.000 X135.112 Y130.759 E194.53505
G1 F3600.000 X149.239 Y143.582 E194.85774
G1 F3600.000 X144.916 Y149.239 E194.96651
G1 F3600.000 X130.759 Y136.416 E195.28920
G1 F3600.000 X140.769 Y130.759 E195.54110
G1 F3600.000 X149.239 Y137.926 E195.72144
G1 F3600.000 X139.259 Y149.239 E195.97257
G1 F3600.000 X130.759 Y142.073 E196.15290
G1 F3600.000 X146.426 Y130.759 E196.54716
G1 F3600.000 X149.239 Y132.269 E196.58515
G1 F3600.000 X133.602 Y149.239 E196.97863
G1 F3600.000 X130.759 Y147.730 E197.01661
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E197.35114
G1 X149.400 Y130.600 E197.68567
G1 X149.400 Y149.400 E198.02020
G1 X130.600 Y149.400 E198.35473
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E198.70350
G1 X149.800 Y130.200 E199.05226
G1 X149.800 Y149.800 E199.40103
G1 X130.200 Y149.800 E199.74979
;LAYER:19
G0 X130.759 Y147.730 Z2.200
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E199.78777
G1 F3600.000 X149.239 Y133.603 E200.18126
G1 F3600.000 X147.730 Y130.759 E200.21924
G1 F3600.000 X130.759 Y146.426 E200.61350
G1 F3600.000 X137.925 Y149.239 E200.79383
G1 F3600.000 X149.239 Y139.260 E201.04496
G1 F3600.000 X142.073 Y130.759 E201.22530
G1 F3600.000 X130.759 Y140.769 E201.47720
G1 F3600.000 X143.582 Y149.239 E201.79989
G1 F3600.000 X149.239 Y144.917 E201.90867
G1 F3600.000 X136.416 Y130.759 E202.23135
G1 F3600.000 X130.759 Y135.112 E202.34090
G1 F3600.000 X149.239 Y149.239 E202.80594
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E203.14047
G1 X130.600 Y130.600 E203.47500
G1 X149.400 Y130.600 E203.80953
G1 X149.400 Y149.400 E204.14406
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E204.49283
G1 X130.200 Y130.200 E204.84159
G1 X149.800 Y130.200 E205.19036
G1 X149.800 Y149.800 E205.53912
;LAYER:20
G0 X149.239 Y149.239 Z2.300
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E206.00417
G1 F3600.000 X135.112 Y130.759 E206.11371
G1 F3600.000 X149.239 Y143.582 E206.43640
G1 F3600.000 X144.916 Y149.239 E206.54517
G1 F3600.000 X130.759 Y136.416 E206.86786
G1 F3600.000 X140.769 Y130.759 E207.11976
G1 F3600.000 X149.239 Y137.926 E207.30010
G1 F3600.000 X139.259 Y149.239 E207.55124
G1 F3600.000 X130.759 Y142.073 E207.73157
G1 F3600.000 X146.426 Y130.759 E208.12582
G1 F3600.000 X149.239 Y132.269 E208.16381
G1 F3600.000 X133.602 Y149.239 E208.55730
G1 F3600.000 X130.759 Y147.730 E208.59527
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E208.92980
G1 X149.400 Y130.600 E209.26433
G1 X149.400 Y149.400 E209.59886
G1 X130.600 Y149.400 E209.93339
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E210.28216
G1 X149.800 Y130.200 E210.63093
G1 X149.800 Y149.800 E210.97969
G1 X130.200 Y149.800 E211.32846
;LAYER:21
G0 X130.759 Y147.730 Z2.400
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E211.36643
G1 F3600.000 X149.239 Y133.603 E211.75992
G1 F3600.000 X147.730 Y130.759 E211.79791
G1 F3600.000 X130.759 Y146.426 E212.19216
G1 F3600.000 X137.925 Y149.239 E212.37249
G1 F3600.000 X149.239 Y139.260 E212.62362
G1 F3600.000 X142.073 Y130.759 E212.80397
G1 F3600.000 X130.759 Y140.769 E213.05587
G1 F3600.000 X143.582 Y149.239 E213.37855
G1 F3600.000 X149.239 Y144.917 E213.48733
G1 F3600.000 X136.416 Y130.759 E213.81002
G1 F3600.000 X130.759 Y135.112 E213.91956
G1 F3600.000 X149.239 Y149.239 E214.38460
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E214.71913
G1 X130.600 Y130.600 E215.05366
G1 X149.400 Y130.600 E215.38819
G1 X149.400 Y149.400 E215.72273
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E216.07149
G1 X130.200 Y130.200 E216.42026
G1 X149.800 Y130.200 E216.76902
G1 X149.800 Y149.800 E217.11779
;LAYER:22
G0 X149.239 Y149.239 Z2.500
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E217.58283
G1 F3600.000 X135.112 Y130.759 E217.69238
G1 F3600.000 X149.239 Y143.582 E218.01506
G1 F3600.000 X144.916 Y149.239 E218.12384
G1 F3600.000 X130.759 Y136.416 E218.44653
G1 F3600.000 X140.769 Y130.759 E218.69842
G1 F3600.000 X149.239 Y137.926 E218.87877
G1 F3600.000 X139.259 Y149.239 E219.12990
G1 F3600.000 X130.759 Y142.073 E219.31023
G1 F3600.000 X146.426 Y130.759 E219.70449
G1 F3600.000 X149.239 Y132.269 E219.74247
G1 F3600.000 X133.602 Y149.239 E220.13596
G1 F3600.000 X130.759 Y147.730 E220.17394
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E220.50847
G1 X149.400 Y130.600 E220.84300
G1 X149.400 Y149.400 E221.17753
G1 X130.600 Y149.400 E221.51206
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E221.86082
G1 X149.800 Y130.200 E222.20959
G1 X149.800 Y149.800 E222.55835
G1 X130.200 Y149.800 E222.90712
;LAYER:23
G0 X130.759 Y147.730 Z2.600
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E222.94509
G1 F3600.000 X149.239 Y133.603 E223.33858
G1 F3600.000 X147.730 Y130.759 E223.37657
G1 F3600.000 X130.759 Y146.426 E223.77082
G1 F3600.000 X137.925 Y149.239 E223.95116
G1 F3600.000 X149.239 Y139.260 E224.20229
G1 F3600.000 X142.073 Y130.759 E224.38263
G1 F3600.000 X130.759 Y140.769 E224.63453
G1 F3600.000 X143.582 Y149.239 E224.95722
G1 F3600.000 X149.239 Y144.917 E225.06599
G1 F3600.000 X136.416 Y130.759 E225.38868
G1 F3600.000 X130.759 Y135.112 E225.49822
G1 F3600.000 X149.239 Y149.239 E225.96327
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E226.29780
G1 X130.600 Y130.600 E226.63233
G1 X149.400 Y130.600 E226.96686
G1 X149.400 Y149.400 E227.30139
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E227.65015
G1 X130.200 Y130.200 E227.99892
G1 X149.800 Y130.200 E228.34769
G1 X149.800 Y149.800 E228.69645
;LAYER:24
G0 X149.239 Y149.239 Z2.700
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E229.16150
G1 F3600.000 X135.112 Y130.759 E229.27104
G1 F3600.000 X149.239 Y143.582 E229.59373
G1 F3600.000 X144.916 Y149.239 E229.70250
G1 F3600.000 X130.759 Y136.416 E230.02519
G1 F3600.000 X140.769 Y130.759 E230.27709
G1 F3600.000 X149.239 Y137.926 E230.45743
G1 F3600.000 X139.259 Y149.239 E230.70856
G1 F3600.000 X130.759 Y142.073 E230.88889
G1 F3600.000 X146.426 Y130.759 E231.28315
G1 F3600.000 X149.239 Y132.269 E231.32114
G1 F3600.000 X133.602 Y149.239 E231.71462
G1 F3600.000 X130.759 Y147.730 E231.75260
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E232.08713
G1 X149.400 Y130.600 E232.42166
G1 X149.400 Y149.400 E232.75619
G1 X130.600 Y149.400 E233.09072
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E233.43949
G1 X149.800 Y130.200 E233.78825
G1 X149.800 Y149.800 E234.13702
G1 X130.200 Y149.800 E234.48578
;LAYER:25
G0 X130.759 Y147.730 Z2.800
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E234.52376
G1 F3600.000 X149.239 Y133.603 E234.91725
G1 F3600.000 X147.730 Y130.759 E234.95523
G1 F3600.000 X130.759 Y146.426 E235.34949
G1 F3600.000 X137.925 Y149.239 E235.52982
G1 F3600.000 X149.239 Y139.260 E235.78095
G1 F3600.000 X142.073 Y130.759 E235.96129
G1 F3600.000 X130.759 Y140.769 E236.21319
G1 F3600.000 X143.582 Y149.239 E236.53588
G1 F3600.000 X149.239 Y144.917 E236.64466
G1 F3600.000 X136.416 Y130.759 E236.96734
G1 F3600.000 X130.759 Y135.112 E237.07689
G1 F3600.000 X149.239 Y149.239 E237.54193
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E237.87646
G1 X130.600 Y130.600 E238.21099
G1 X149.400 Y130.600 E238.54552
G1 X149.400 Y149.400 E238.88005
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E239.22882
G1 X130.200 Y130.200 E239.57758
G1 X149.800 Y130.200 E239.92635
G1 X149.800 Y149.800 E240.27512
;LAYER:26
G0 X149.239 Y149.239 Z2.900
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E240.74016
G1 F3600.000 X135.112 Y130.759 E240.84970
G1 F3600.000 X149.239 Y143.582 E241.17239
G1 F3600.000 X144.916 Y149.239 E241.28116
G1 F3600.000 X130.759 Y136.416 E241.60385
G1 F3600.000 X140.769 Y130.759 E241.85575
G1 F3600.000 X149.239 Y137.926 E242.03609
G1 F3600.000 X139.259 Y149.239 E242.28723
G1 F3600.000 X130.759 Y142.073 E242.46756
G1 F3600.000 X146.426 Y130.759 E242.86181
G1 F3600.000 X149.239 Y132.269 E242.89980
G1 F3600.000 X133.602 Y149.239 E243.29329
G1 F3600.000 X130.759 Y147.730 E243.33126
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E243.66579
G1 X149.400 Y130.600 E244.00032
G1 X149.400 Y149.400 E244.33485
G1 X130.600 Y149.400 E244.66938
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E245.01815
G1 X149.800 Y130.200 E245.36692
G1 X149.800 Y149.800 E245.71568
G1 X130.200 Y149.800 E246.06445
;LAYER:27
G0 X130.759 Y147.730 Z3.000
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E246.10242
G1 F3600.000 X149.239 Y133.603 E246.49591
G1 F3600.000 X147.730 Y130.759 E246.53390
G1 F3600.000 X130.759 Y146.426 E246.92815
G1 F3600.000 X137.925 Y149.239 E247.10848
G1 F3600.000 X149.239 Y139.260 E247.35961
G1 F3600.000 X142.073 Y130.759 E247.53996
G1 F3600.000 X130.759 Y140.769 E247.79186
G1 F3600.000 X143.582 Y149.239 E248.11454
G1 F3600.000 X149.239 Y144.917 E248.22332
G1 F3600.000 X136.416 Y130.759 E248.54601
G1 F3600.000 X130.759 Y135.112 E248.65555
G1 F3600.000 X149.239 Y149.239 E249.12059
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E249.45512
G1 X130.600 Y130.600 E249.78965
G1 X149.400 Y130.600 E250.12418
G1 X149.400 Y149.400 E250.45872
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E250.80748
G1 X130.200 Y130.200 E251.15625
G1 X149.800 Y130.200 E251.50501
G1 X149.800 Y149.800 E251.85378
;LAYER:28
G0 X149.239 Y149.239 Z3.100
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E252.31882
G1 F3600.000 X135.112 Y130.759 E252.42837
G1 F3600.000 X149.239 Y143.582 E252.75105
G1 F3600.000 X144.916 Y149.239 E252.85983
G1 F3600.000 X130.759 Y136.416 E253.18252
G1 F3600.000 X140.769 Y130.759 E253.43441
G1 F3600.000 X149.239 Y137.926 E253.61476
G1 F3600.000 X139.259 Y149.239 E253.86589
G1 F3600.000 X130.759 Y142.073 E254.04622
G1 F3600.000 X146.426 Y130.759 E254.44048
G1 F3600.000 X149.239 Y132.269 E254.47846
G1 F3600.000 X133.602 Y149.239 E254.87195
G1 F3600.000 X130.759 Y147.730 E254.90993
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E255.24446
G1 X149.400 Y130.600 E255.57899
G1 X149.400 Y149.400 E255.91352
G1 X130.600 Y149.400 E256.24805
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E256.59681
G1 X149.800 Y130.200 E256.94558
G1 X149.800 Y149.800 E257.29434
G1 X130.200 Y149.800 E257.64311
;LAYER:29
G0 X130.759 Y147.730 Z3.200
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E257.68108
G1 F3600.000 X149.239 Y133.603 E258.07457
G1 F3600.000 X147.730 Y130.759 E258.11256
G1 F3600.000 X130.759 Y146.426 E258.50682
G1 F3600.000 X137.925 Y149.239 E258.68715
G1 F3600.000 X149.239 Y139.260 E258.93828
G1 F3600.000 X142.073 Y130.759 E259.11862
G1 F3600.000 X130.759 Y140.769 E259.37052
G1 F3600.000 X143.582 Y149.239 E259.69321
G1 F3600.000 X149.239 Y144.917 E259.80198
G1 F3600.000 X136.416 Y130.759 E260.12467
G1 F3600.000 X130.759 Y135.112 E260.23421
G1 F3600.000 X149.239 Y149.239 E260.69926
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E261.03379
G1 X130.600 Y130.600 E261.36832
G1 X149.400 Y130.600 E261.70285
G1 X149.400 Y149.400 E262.03738
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E262.38614
G1 X130.200 Y130.200 E262.73491
G1 X149.800 Y130.200 E263.08368
G1 X149.800 Y149.800 E263.43244
;LAYER:30
G0 X149.239 Y149.239 Z3.300
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E263.89749
G1 F3600.000 X135.112 Y130.759 E264.00703
G1 F3600.000 X149.239 Y143.582 E264.32972
G1 F3600.000 X144.916 Y149.239 E264.43849
G1 F3600.000 X130.759 Y136.416 E264.76118
G1 F3600.000 X140.769 Y130.759 E265.01308
G1 F3600.000 X149.239 Y137.926 E265.19342
G1 F3600.000 X139.259 Y149.239 E265.44455
G1 F3600.000 X130.759 Y142.073 E265.62488
G1 F3600.000 X146.426 Y130.759 E266.01914
G1 F3600.000 X149.239 Y132.269 E266.05713
G1 F3600.000 X133.602 Y149.239 E266.45062
G1 F3600.000 X130.759 Y147.730 E266.48859
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E266.82312
G1 X149.400 Y130.600 E267.15765
G1 X149.400 Y149.400 E267.49218
G1 X130.600 Y149.400 E267.82671
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E268.17548
G1 X149.800 Y130.200 E268.52424
G1 X149.800 Y149.800 E268.87301
G1 X130.200 Y149.800 E269.22177
;LAYER:31
G0 X130.759 Y147.730 Z3.400
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E269.25975
G1 F3600.000 X149.239 Y133.603 E269.65324
G1 F3600.000 X147.730 Y130.759 E269.69122
G1 F3600.000 X130.759 Y146.426 E270.08548
G1 F3600.000 X137.925 Y149.239 E270.26581
G1 F3600.000 X149.239 Y139.260 E270.51694
G1 F3600.000 X142.073 Y130.759 E270.69728
G1 F3600.000 X130.759 Y140.769 E270.94918
G1 F3600.000 X143.582 Y149.239 E271.27187
G1 F3600.000 X149.239 Y144.917 E271.38065
G1 F3600.000 X136.416 Y130.759 E271.70333
G1 F3600.000 X130.759 Y135.112 E271.81288
G1 F3600.000 X149.239 Y149.239 E272.27792
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E272.61245
G1 X130.600 Y130.600 E272.94698
G1 X149.400 Y130.600 E273.28151
G1 X149.400 Y149.400 E273.61604
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E273.96481
G1 X130.200 Y130.200 E274.31357
G1 X149.800 Y130.200 E274.66234
G1 X149.800 Y149.800 E275.01111
;LAYER:32
G0 X149.239 Y149.239 Z3.500
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E275.47615
G1 F3600.000 X135.112 Y130.759 E275.58569
G1 F3600.000 X149.239 Y143.582 E275.90838
G1 F3600.000 X144.916 Y149.239 E276.01715
G1 F3600.000 X130.759 Y136.416 E276.33984
G1 F3600.000 X140.769 Y130.759 E276.59174
G1 F3600.000 X149.239 Y137.926 E276.77208
G1 F3600.000 X139.259 Y149.239 E277.02322
G1 F3600.000 X130.759 Y142.073 E277.20355
G1 F3600.000 X146.426 Y130.759 E277.59780
G1 F3600.000 X149.239 Y132.269 E277.63579
G1 F3600.000 X133.602 Y149.239 E278.02928
G1 F3600.000 X130.759 Y147.730 E278.06725
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E278.40178
G1 X149.400 Y130.600 E278.73631
G1 X149.400 Y149.400 E279.07084
G1 X130.600 Y149.400 E279.40537
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E279.75414
G1 X149.800 Y130.200 E280.10291
G1 X149.800 Y149.800 E280.45167
G1 X130.200 Y149.800 E280.80044
;LAYER:33
G0 X130.759 Y147.730 Z3.600
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E280.83841
G1 F3600.000 X149.239 Y133.603 E281.23190
G1 F3600.000 X147.730 Y130.759 E281.26989
G1 F3600.000 X130.759 Y146.426 E281.66414
G1 F3600.000 X137.925 Y149.239 E281.84447
G1 F3600.000 X149.239 Y139.260 E282.09560
G1 F3600.000 X142.073 Y130.759 E282.27595
G1 F3600.000 X130.759 Y140.769 E282.52785
G1 F3600.000 X143.582 Y149.239 E282.85053
G1 F3600.000 X149.239 Y144.917 E282.95931
G1 F3600.000 X136.416 Y130.759 E283.28200
G1 F3600.000 X130.759 Y135.112 E283.39154
G1 F3600.000 X149.239 Y149.239 E283.85658
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E284.19111
G1 X130.600 Y130.600 E284.52564
G1 X149.400 Y130.600 E284.86018
G1 X149.400 Y149.400 E285.19471
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E285.54347
G1 X130.200 Y130.200 E285.89224
G1 X149.800 Y130.200 E286.24100
G1 X149.800 Y149.800 E286.58977
;LAYER:34
G0 X149.239 Y149.239 Z3.700
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E287.05481
G1 F3600.000 X135.112 Y130.759 E287.16436
G1 F3600.000 X149.239 Y143.582 E287.48704
G1 F3600.000 X144.916 Y149.239 E287.59582
G1 F3600.000 X130.759 Y136.416 E287.91851
G1 F3600.000 X140.769 Y130.759 E288.17040
G1 F3600.000 X149.239 Y137.926 E288.35075
G1 F3600.000 X139.259 Y149.239 E288.60188
G1 F3600.000 X130.759 Y142.073 E288.78221
G1 F3600.000 X146.426 Y130.759 E289.17647
G1 F3600.000 X149.239 Y132.269 E289.21445
G1 F3600.000 X133.602 Y149.239 E289.60794
G1 F3600.000 X130.759 Y147.730 E289.64592
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E289.98045
G1 X149.400 Y130.600 E290.31498
G1 X149.400 Y149.400 E290.64951
G1 X130.600 Y149.400 E290.98404
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E291.33280
G1 X149.800 Y130.200 E291.68157
G1 X149.800 Y149.800 E292.03033
G1 X130.200 Y149.800 E292.37910
;LAYER:35
G0 X130.759 Y147.730 Z3.800
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E292.41707
G1 F3600.000 X149.239 Y133.603 E292.81056
G1 F3600.000 X147.730 Y130.759 E292.84855
G1 F3600.000 X130.759 Y146.426 E293.24281
G1 F3600.000 X137.925 Y149.239 E293.42314
G1 F3600.000 X149.239 Y139.260 E293.67427
G1 F3600.000 X142.073 Y130.759 E293.85461
G1 F3600.000 X130.759 Y140.769 E294.10651
G1 F3600.000 X143.582 Y149.239 E294.42920
G1 F3600.000 X149.239 Y144.917 E294.53797
G1 F3600.000 X136.416 Y130.759 E294.86066
G1 F3600.000 X130.759 Y135.112 E294.97020
G1 F3600.000 X149.239 Y149.239 E295.43525
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E295.76978
G1 X130.600 Y130.600 E296.10431
G1 X149.400 Y130.600 E296.43884
G1 X149.400 Y149.400 E296.77337
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E297.12213
G1 X130.200 Y130.200 E297.47090
G1 X149.800 Y130.200 E297.81967
G1 X149.800 Y149.800 E298.16843
;LAYER:36
G0 X149.239 Y149.239 Z3.900
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E298.63348
G1 F3600.000 X135.112 Y130.759 E298.74302
G1 F3600.000 X149.239 Y143.582 E299.06571
G1 F3600.000 X144.916 Y149.239 E299.17448
G1 F3600.000 X130.759 Y136.416 E299.49717
G1 F3600.000 X140.769 Y130.759 E299.74907
G1 F3600.000 X149.239 Y137.926 E299.92941
G1 F3600.000 X139.259 Y149.239 E300.18054
G1 F3600.000 X130.759 Y142.073 E300.36087
G1 F3600.000 X146.426 Y130.759 E300.75513
G1 F3600.000 X149.239 Y132.269 E300.79312
G1 F3600.000 X133.602 Y149.239 E301.18661
G1 F3600.000 X130.759 Y147.730 E301.22458
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E301.55911
G1 X149.400 Y130.600 E301.89364
G1 X149.400 Y149.400 E302.22817
G1 X130.600 Y149.400 E302.56270
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E302.91147
G1 X149.800 Y130.200 E303.26023
G1 X149.800 Y149.800 E303.60900
G1 X130.200 Y149.800 E303.95776
;LAYER:37
G0 X130.759 Y147.730 Z4.000
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E303.99574
G1 F3600.000 X149.239 Y133.603 E304.38923
G1 F3600.000 X147.730 Y130.759 E304.42721
G1 F3600.000 X130.759 Y146.426 E304.82147
G1 F3600.000 X137.925 Y149.239 E305.00180
G1 F3600.000 X149.239 Y139.260 E305.25293
G1 F3600.000 X142.073 Y130.759 E305.43327
G1 F3600.000 X130.759 Y140.769 E305.68517
G1 F3600.000 X143.582 Y149.239 E306.00786
G1 F3600.000 X149.239 Y144.917 E306.11664
G1 F3600.000 X136.416 Y130.759 E306.43932
G1 F3600.000 X130.759 Y135.112 E306.54887
G1 F3600.000 X149.239 Y149.239 E307.01391
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E307.34844
G1 X130.600 Y130.600 E307.68297
G1 X149.400 Y130.600 E308.01750
G1 X149.400 Y149.400 E308.35203
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E308.70080
G1 X130.200 Y130.200 E309.04956
G1 X149.800 Y130.200 E309.39833
G1 X149.800 Y149.800 E309.74710
;LAYER:38
G0 X149.239 Y149.239 Z4.100
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E310.21214
G1 F3600.000 X135.112 Y130.759 E310.32168
G1 F3600.000 X149.239 Y143.582 E310.64437
G1 F3600.000 X144.916 Y149.239 E310.75314
G1 F3600.000 X130.759 Y136.416 E311.07583
G1 F3600.000 X140.769 Y130.759 E311.32773
G1 F3600.000 X149.239 Y137.926 E311.50807
G1 F3600.000 X139.259 Y149.239 E311.75921
G1 F3600.000 X130.759 Y142.073 E311.93954
G1 F3600.000 X146.426 Y130.759 E312.33379
G1 F3600.000 X149.239 Y132.269 E312.37178
G1 F3600.000 X133.602 Y149.239 E312.76527
G1 F3600.000 X130.759 Y147.730 E312.80324
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E313.13777
G1 X149.400 Y130.600 E313.47230
G1 X149.400 Y149.400 E313.80683
G1 X130.600 Y149.400 E314.14136
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E314.49013
G1 X149.800 Y130.200 E314.83890
G1 X149.800 Y149.800 E315.18766
G1 X130.200 Y149.800 E315.53643
;LAYER:39
G0 X130.759 Y147.730 Z4.200
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E315.57440
G1 F3600.000 X149.239 Y133.603 E315.96789
G1 F3600.000 X147.730 Y130.759 E316.00588
G1 F3600.000 X130.759 Y146.426 E316.40013
G1 F3600.000 X137.925 Y149.239 E316.58046
G1 F3600.000 X149.239 Y139.260 E316.83159
G1 F3600.000 X142.073 Y130.759 E317.01194
G1 F3600.000 X130.759 Y140.769 E317.26384
G1 F3600.000 X143.582 Y149.239 E317.58652
G1 F3600.000 X149.239 Y144.917 E317.69530
G1 F3600.000 X136.416 Y130.759 E318.01799
G1 F3600.000 X130.759 Y135.112 E318.12753
G1 F3600.000 X149.239 Y149.239 E318.59257
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E318.92710
G1 X130.600 Y130.600 E319.26163
G1 X149.400 Y130.600 E319.59617
G1 X149.400 Y149.400 E319.93070
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E320.27946
G1 X130.200 Y130.200 E320.62823
G1 X149.800 Y130.200 E320.97699
G1 X149.800 Y149.800 E321.32576
;LAYER:40
G0 X149.239 Y149.239 Z4.300
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E321.79080
G1 F3600.000 X135.112 Y130.759 E321.90035
G1 F3600.000 X149.239 Y143.582 E322.22303
G1 F3600.000 X144.916 Y149.239 E322.33181
G1 F3600.000 X130.759 Y136.416 E322.65450
G1 F3600.000 X140.769 Y130.759 E322.90640
G1 F3600.000 X149.239 Y137.926 E323.08674
G1 F3600.000 X139.259 Y149.239 E323.33787
G1 F3600.000 X130.759 Y142.073 E323.51820
G1 F3600.000 X146.426 Y130.759 E323.91246
G1 F3600.000 X149.239 Y132.269 E323.95044
G1 F3600.000 X133.602 Y149.239 E324.34393
G1 F3600.000 X130.759 Y147.730 E324.38191
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E324.71644
G1 X149.400 Y130.600 E325.05097
G1 X149.400 Y149.400 E325.38550
G1 X130.600 Y149.400 E325.72003
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E326.06879
G1 X149.800 Y130.200 E326.41756
G1 X149.800 Y149.800 E326.76632
G1 X130.200 Y149.800 E327.11509
;LAYER:41
G0 X130.759 Y147.730 Z4.400
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E327.15306
G1 F3600.000 X149.239 Y133.603 E327.54655
G1 F3600.000 X147.730 Y130.759 E327.58454
G1 F3600.000 X130.759 Y146.426 E327.97880
G1 F3600.000 X137.925 Y149.239 E328.15913
G1 F3600.000 X149.239 Y139.260 E328.41026
G1 F3600.000 X142.073 Y130.759 E328.59060
G1 F3600.000 X130.759 Y140.769 E328.84250
G1 F3600.000 X143.582 Y149.239 E329.16519
G1 F3600.000 X149.239 Y144.917 E329.27396
G1 F3600.000 X136.416 Y130.759 E329.59665
G1 F3600.000 X130.759 Y135.112 E329.70619
G1 F3600.000 X149.239 Y149.239 E330.17124
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E330.50577
G1 X130.600 Y130.600 E330.84030
G1 X149.400 Y130.600 E331.17483
G1 X149.400 Y149.400 E331.50936
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E331.85812
G1 X130.200 Y130.200 E332.20689
G1 X149.800 Y130.200 E332.55566
G1 X149.800 Y149.800 E332.90442
;LAYER:42
G0 X149.239 Y149.239 Z4.500
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E333.36947
G1 F3600.000 X135.112 Y130.759 E333.47901
G1 F3600.000 X149.239 Y143.582 E333.80170
G1 F3600.000 X144.916 Y149.239 E333.91047
G1 F3600.000 X130.759 Y136.416 E334.23316
G1 F3600.000 X140.769 Y130.759 E334.48506
G1 F3600.000 X149.239 Y137.926 E334.66540
G1 F3600.000 X139.259 Y149.239 E334.91653
G1 F3600.000 X130.759 Y142.073 E335.09686
G1 F3600.000 X146.426 Y130.759 E335.49112
G1 F3600.000 X149.239 Y132.269 E335.52911
G1 F3600.000 X133.602 Y149.239 E335.92260
G1 F3600.000 X130.759 Y147.730 E335.96057
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E336.29510
G1 X149.400 Y130.600 E336.62963
G1 X149.400 Y149.400 E336.96416
G1 X130.600 Y149.400 E337.29869
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E337.64746
G1 X149.800 Y130.200 E337.99622
G1 X149.800 Y149.800 E338.34499
G1 X130.200 Y149.800 E338.69375
;LAYER:43
G0 X130.759 Y147.730 Z4.600
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E338.73173
G1 F3600.000 X149.239 Y133.603 E339.12522
G1 F3600.000 X147.730 Y130.759 E339.16320
G1 F3600.000 X130.759 Y146.426 E339.55746
G1 F3600.000 X137.925 Y149.239 E339.73779
G1 F3600.000 X149.239 Y139.260 E339.98892
G1 F3600.000 X142.073 Y130.759 E340.16926
G1 F3600.000 X130.759 Y140.769 E340.42116
G1 F3600.000 X143.582 Y149.239 E340.74385
G1 F3600.000 X149.239 Y144.917 E340.85263
G1 F3600.000 X136.416 Y130.759 E341.17531
G1 F3600.000 X130.759 Y135.112 E341.28486
G1 F3600.000 X149.239 Y149.239 E341.74990
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E342.08443
G1 X130.600 Y130.600 E342.41896
G1 X149.400 Y130.600 E342.75349
G1 X149.400 Y149.400 E343.08802
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E343.43679
G1 X130.200 Y130.200 E343.78555
G1 X149.800 Y130.200 E344.13432
G1 X149.800 Y149.800 E344.48309
;LAYER:44
G0 X149.239 Y149.239 Z4.700
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E344.94813
G1 F3600.000 X135.112 Y130.759 E345.05767
G1 F3600.000 X149.239 Y143.582 E345.38036
G1 F3600.000 X144.916 Y149.239 E345.48913
G1 F3600.000 X130.759 Y136.416 E345.81182
G1 F3600.000 X140.769 Y130.759 E346.06372
G1 F3600.000 X149.239 Y137.926 E346.24407
G1 F3600.000 X139.259 Y149.239 E346.49520
G1 F3600.000 X130.759 Y142.073 E346.67553
G1 F3600.000 X146.426 Y130.759 E347.06978
G1 F3600.000 X149.239 Y132.269 E347.10777
G1 F3600.000 X133.602 Y149.239 E347.50126
G1 F3600.000 X130.759 Y147.730 E347.53923
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E347.87376
G1 X149.400 Y130.600 E348.20829
G1 X149.400 Y149.400 E348.54282
G1 X130.600 Y149.400 E348.87735
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E349.22612
G1 X149.800 Y130.200 E349.57489
G1 X149.800 Y149.800 E349.92365
G1 X130.200 Y149.800 E350.27242
;LAYER:45
G0 X130.759 Y147.730 Z4.800
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E350.31039
G1 F3600.000 X149.239 Y133.603 E350.70388
G1 F3600.000 X147.730 Y130.759 E350.74187
G1 F3600.000 X130.759 Y146.426 E351.13612
G1 F3600.000 X137.925 Y149.239 E351.31645
G1 F3600.000 X149.239 Y139.260 E351.56758
G1 F3600.000 X142.073 Y130.759 E351.74793
G1 F3600.000 X130.759 Y140.769 E351.99983
G1 F3600.000 X143.582 Y149.239 E352.32251
G1 F3600.000 X149.239 Y144.917 E352.43129
G1 F3600.000 X136.416 Y130.759 E352.75398
G1 F3600.000 X130.759 Y135.112 E352.86352
G1 F3600.000 X149.239 Y149.239 E353.32856
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E353.66309
G1 X130.600 Y130.600 E353.99762
G1 X149.400 Y130.600 E354.33216
G1 X149.400 Y149.400 E354.66669
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E355.01545
G1 X130.200 Y130.200 E355.36422
G1 X149.800 Y130.200 E355.71298
G1 X149.800 Y149.800 E356.06175
;LAYER:46
G0 X149.239 Y149.239 Z4.900
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E356.52679
G1 F3600.000 X135.112 Y130.759 E356.63634
G1 F3600.000 X149.239 Y143.582 E356.95902
G1 F3600.000 X144.916 Y149.239 E357.06780
G1 F3600.000 X130.759 Y136.416 E357.39049
G1 F3600.000 X140.769 Y130.759 E357.64239
G1 F3600.000 X149.239 Y137.926 E357.82273
G1 F3600.000 X139.259 Y149.239 E358.07386
G1 F3600.000 X130.759 Y142.073 E358.25419
G1 F3600.000 X146.426 Y130.759 E358.64845
G1 F3600.000 X149.239 Y132.269 E358.68643
G1 F3600.000 X133.602 Y149.239 E359.07992
G1 F3600.000 X130.759 Y147.730 E359.11790
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E359.45243
G1 X149.400 Y130.600 E359.78696
G1 X149.400 Y149.400 E360.12149
G1 X130.600 Y149.400 E360.45602
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E360.80478
G1 X149.800 Y130.200 E361.15355
G1 X149.800 Y149.800 E361.50231
G1 X130.200 Y149.800 E361.85108
;LAYER:47
G0 X130.759 Y147.730 Z5.000
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E361.88905
G1 F3600.000 X149.239 Y133.603 E362.28254
G1 F3600.000 X147.730 Y130.759 E362.32053
G1 F3600.000 X130.759 Y146.426 E362.71479
G1 F3600.000 X137.925 Y149.239 E362.89512
G1 F3600.000 X149.239 Y139.260 E363.14625
G1 F3600.000 X142.073 Y130.759 E363.32659
G1 F3600.000 X130.759 Y140.769 E363.57849
G1 F3600.000 X143.582 Y149.239 E363.90118
G1 F3600.000 X149.239 Y144.917 E364.00995
G1 F3600.000 X136.416 Y130.759 E364.33264
G1 F3600.000 X130.759 Y135.112 E364.44218
G1 F3600.000 X149.239 Y149.239 E364.90723
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E365.24176
G1 X130.600 Y130.600 E365.57629
G1 X149.400 Y130.600 E365.91082
G1 X149.400 Y149.400 E366.24535
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E366.59411
G1 X130.200 Y130.200 E366.94288
G1 X149.800 Y130.200 E367.29165
G1 X149.800 Y149.800 E367.64041
;LAYER:48
G0 X149.239 Y149.239 Z5.100
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E368.10546
G1 F3600.000 X135.112 Y130.759 E368.21500
G1 F3600.000 X149.239 Y143.582 E368.53769
G1 F3600.000 X144.916 Y149.239 E368.64646
G1 F3600.000 X130.759 Y136.416 E368.96915
G1 F3600.000 X140.769 Y130.759 E369.22105
G1 F3600.000 X149.239 Y137.926 E369.40139
G1 F3600.000 X139.259 Y149.239 E369.65252
G1 F3600.000 X130.759 Y142.073 E369.83285
G1 F3600.000 X146.426 Y130.759 E370.22711
G1 F3600.000 X149.239 Y132.269 E370.26510
G1 F3600.000 X133.602 Y149.239 E370.65859
G1 F3600.000 X130.759 Y147.730 E370.69656
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E371.03109
G1 X149.400 Y130.600 E371.36562
G1 X149.400 Y149.400 E371.70015
G1 X130.600 Y149.400 E372.03468
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E372.38345
G1 X149.800 Y130.200 E372.73221
G1 X149.800 Y149.800 E373.08098
G1 X130.200 Y149.800 E373.42974
;LAYER:49
G0 X130.759 Y147.730 Z5.200
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E373.46772
G1 F3600.000 X149.239 Y133.603 E373.86121
G1 F3600.000 X147.730 Y130.759 E373.89919
G1 F3600.000 X130.759 Y146.426 E374.29345
G1 F3600.000 X137.925 Y149.239 E374.47378
G1 F3600.000 X149.239 Y139.260 E374.72491
G1 F3600.000 X142.073 Y130.759 E374.90525
G1 F3600.000 X130.759 Y140.769 E375.15715
G1 F3600.000 X143.582 Y149.239 E375.47984
G1 F3600.000 X149.239 Y144.917 E375.58862
G1 F3600.000 X136.416 Y130.759 E375.91130
G1 F3600.000 X130.759 Y135.112 E376.02085
G1 F3600.000 X149.239 Y149.239 E376.48589
G0 X149.309 Y149.309
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E376.82042
G1 X130.600 Y130.600 E377.15495
G1 X149.400 Y130.600 E377.48948
G1 X149.400 Y149.400 E377.82401
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E378.17278
G1 X130.200 Y130.200 E378.52154
G1 X149.800 Y130.200 E378.87031
G1 X149.800 Y149.800 E379.21908
;LAYER:50
G0 X149.239 Y149.239 Z5.300
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E379.68412
G1 F3600.000 X135.112 Y130.759 E379.79366
G0 F7200.000 X136.416 Y130.759
G1 F3600.000 X149.239 Y143.582 E380.11635
G0 X149.309 Y143.652
G1 F3600.000 X144.916 Y149.239 E380.22512
G1 F3600.000 X130.759 Y136.416 E380.54781
G1 F3600.000 X140.769 Y130.759 E380.79971
G0 F7200.000 X142.073 Y130.759
G1 F3600.000 X149.239 Y137.926 E380.98006
G0 X149.309 Y137.996
G1 F3600.000 X139.259 Y149.239 E381.23119
G1 F3600.000 X130.759 Y142.073 E381.41152
G1 F3600.000 X146.426 Y130.759 E381.80577
G1 F3600.000 X149.239 Y132.269 E381.84376
G1 F3600.000 X133.602 Y149.239 E382.23725
G1 F3600.000 X130.759 Y147.730 E382.27522
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E382.60975
G1 X149.400 Y130.600 E382.94428
G1 X149.400 Y149.400 E383.27881
G1 X130.600 Y149.400 E383.61334
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E383.96211
G1 X149.800 Y130.200 E384.31088
G1 X149.800 Y149.800 E384.65964
G1 X130.200 Y149.800 E385.00841
;LAYER:51
G0 X130.759 Y147.730 Z5.400
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E385.04638
G1 F3600.000 X149.239 Y133.603 E385.43987
G1 F3600.000 X147.730 Y130.759 E385.47786
G1 F3600.000 X130.759 Y146.426 E385.87211
G1 F3600.000 X137.925 Y149.239 E386.05244
G1 F3600.000 X149.239 Y139.260 E386.30357
G1 F3600.000 X142.073 Y130.759 E386.48392
G1 F3600.000 X130.759 Y140.769 E386.73582
G1 F3600.000 X143.582 Y149.239 E387.05850
G1 F3600.000 X149.239 Y144.917 E387.16728
G1 F3600.000 X136.416 Y130.759 E387.48997
G1 F3600.000 X130.759 Y135.112 E387.59951
G1 F3600.000 X149.239 Y149.239 E388.06455
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E388.39908
G1 X130.600 Y130.600 E388.73362
G1 X149.400 Y130.600 E389.06815
G1 X149.400 Y149.400 E389.40268
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E389.75144
G1 X130.200 Y130.200 E390.10021
G1 X149.800 Y130.200 E390.44897
G1 X149.800 Y149.800 E390.79774
;LAYER:52
G0 X149.239 Y149.239 Z5.500
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E391.26278
G1 F3600.000 X135.112 Y130.759 E391.37233
G1 F3600.000 X149.239 Y143.582 E391.69501
G1 F3600.000 X144.916 Y149.239 E391.80379
G1 F3600.000 X130.759 Y136.416 E392.12648
G1 F3600.000 X140.769 Y130.759 E392.37838
G1 F3600.000 X149.239 Y137.926 E392.55872
G1 F3600.000 X139.259 Y149.239 E392.80985
G1 F3600.000 X130.759 Y142.073 E392.99018
G1 F3600.000 X146.426 Y130.759 E393.38444
G0 F7200.000 X147.730 Y130.759
G1 F3600.000 X149.239 Y132.269 E393.42242
G0 X149.309 Y132.339
G1 F3600.000 X133.602 Y149.239 E393.81591
G1 F3600.000 X130.759 Y147.730 E393.85389
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E394.18842
G1 X149.400 Y130.600 E394.52295
G1 X149.400 Y149.400 E394.85748
G1 X130.600 Y149.400 E395.19201
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E395.54077
G1 X149.800 Y130.200 E395.88954
G1 X149.800 Y149.800 E396.23830
G1 X130.200 Y149.800 E396.58707
;LAYER:53
G0 X130.759 Y147.730 Z5.600
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E396.62504
G1 F3600.000 X149.239 Y133.603 E397.01853
G1 F3600.000 X147.730 Y130.759 E397.05652
G1 F3600.000 X130.759 Y146.426 E397.45078
G0 F7200.000 X130.759 Y142.073
G1 F3600.000 X137.925 Y149.239 E397.63111
G0 X137.995 Y149.309
G1 F3600.000 X149.239 Y139.260 E397.88224
G1 F3600.000 X142.073 Y130.759 E398.06258
G1 F3600.000 X130.759 Y140.769 E398.31448
G0 F7200.000 X130.759 Y136.416
G1 F3600.000 X143.582 Y149.239 E398.63717
G0 X143.652 Y149.309
G1 F3600.000 X149.239 Y144.917 E398.74594
G1 F3600.000 X136.416 Y130.759 E399.06863
G1 F3600.000 X130.759 Y135.112 E399.17817
G1 F3600.000 X149.239 Y149.239 E399.64322
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E399.97775
G1 X130.600 Y130.600 E400.31228
G1 X149.400 Y130.600 E400.64681
G1 X149.400 Y149.400 E400.98134
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E401.33011
G1 X130.200 Y130.200 E401.67887
G1 X149.800 Y130.200 E402.02764
G1 X149.800 Y149.800 E402.37640
;LAYER:54
G0 X149.239 Y149.239 Z5.700
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E402.84145
G1 F3600.000 X135.112 Y130.759 E402.95099
G1 F3600.000 X149.239 Y143.582 E403.27368
G1 F3600.000 X144.916 Y149.239 E403.38245
G1 F3600.000 X130.759 Y136.416 E403.70514
G1 F3600.000 X140.769 Y130.759 E403.95704
G1 F3600.000 X149.239 Y137.926 E404.13738
G1 F3600.000 X139.259 Y149.239 E404.38851
G1 F3600.000 X130.759 Y142.073 E404.56884
G1 F3600.000 X146.426 Y130.759 E404.96310
G1 F3600.000 X149.239 Y132.269 E405.00109
G1 F3600.000 X133.602 Y149.239 E405.39458
G1 F3600.000 X130.759 Y147.730 E405.43255
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E405.76708
G1 X149.400 Y130.600 E406.10161
G1 X149.400 Y149.400 E406.43614
G1 X130.600 Y149.400 E406.77067
G0 F7200.00000 X130.200 Y149.800
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E407.11944
G1 X149.800 Y130.200 E407.46820
G1 X149.800 Y149.800 E407.81697
G1 X130.200 Y149.800 E408.16573
;LAYER:55
G0 X130.759 Y147.730 Z5.800
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E408.20371
G0 X132.338 Y149.309
G1 F3600.000 X149.239 Y133.603 E408.59720
G1 F3600.000 X147.730 Y130.759 E408.63518
G0 F7200.000 X146.426 Y130.759
G1 F3600.000 X130.759 Y146.426 E409.02944
G0 X130.689 Y146.496
G1 F3600.000 X137.925 Y149.239 E409.20977
G1 F3600.000 X149.239 Y139.260 E409.46090
G1 F3600.000 X142.073 Y130.759 E409.64124
G1 F3600.000 X130.759 Y140.769 E409.89314
G1 F3600.000 X143.582 Y149.239 E410.21583
G1 F3600.000 X149.239 Y144.917 E410.32461
G1 F3600.000 X136.416 Y130.759 E410.64729
G1 F3600.000 X130.759 Y135.112 E410.75684
G1 F3600.000 X149.239 Y149.239 E411.22188
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E411.55641
G1 X130.600 Y130.600 E411.89094
G1 X149.400 Y130.600 E412.22547
G1 X149.400 Y149.400 E412.56000
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E412.90877
G1 X130.200 Y130.200 E413.25753
G1 X149.800 Y130.200 E413.60630
G1 X149.800 Y149.800 E413.95507
;LAYER:56
G0 X149.239 Y149.239 Z5.900
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E414.42011
G1 F3600.000 X135.112 Y130.759 E414.52965
G1 F3600.000 X149.239 Y143.582 E414.85234
G1 F3600.000 X144.916 Y149.239 E414.96112
G1 F3600.000 X130.759 Y136.416 E415.28380
G1 F3600.000 X140.769 Y130.759 E415.53570
G1 F3600.000 X149.239 Y137.926 E415.71605
G1 F3600.000 X139.259 Y149.239 E415.96718
G1 F3600.000 X130.759 Y142.073 E416.14751
G1 F3600.000 X146.426 Y130.759 E416.54176
G1 F3600.000 X149.239 Y132.269 E416.57975
G1 F3600.000 X133.602 Y149.239 E416.97324
G1 F3600.000 X130.759 Y147.730 E417.01121
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E417.34574
G1 X149.400 Y130.600 E417.68027
G1 X149.400 Y149.400 E418.01480
G1 X130.600 Y149.400 E418.34933
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E418.69810
G1 X149.800 Y130.200 E419.04687
G1 X149.800 Y149.800 E419.39563
G1 X130.200 Y149.800 E419.74440
;LAYER:57
G0 X130.759 Y147.730 Z6.000
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E419.78237
G1 F3600.000 X149.239 Y133.603 E420.17586
G1 F3600.000 X147.730 Y130.759 E420.21385
G1 F3600.000 X130.759 Y146.426 E420.60810
G1 F3600.000 X137.925 Y149.239 E420.78843
G1 F3600.000 X149.239 Y139.260 E421.03956
G1 F3600.000 X142.073 Y130.759 E421.21991
G0 F7200.000 X140.769 Y130.759
G1 F3600.000 X130.759 Y140.769 E421.47181
G0 X130.689 Y140.839
G1 F3600.000 X143.582 Y149.239 E421.79449
G1 F3600.000 X149.239 Y144.917 E421.90327
G1 F3600.000 X136.416 Y130.759 E422.22596
G0 F7200.000 X135.112 Y130.759
G1 F3600.000 X130.759 Y135.112 E422.33550
G0 X130.689 Y135.182
G1 F3600.000 X149.239 Y149.239 E422.80054
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E423.13507
G1 X130.600 Y130.600 E423.46961
G1 X149.400 Y130.600 E423.80414
G1 X149.400 Y149.400 E424.13867
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E424.48743
G1 X130.200 Y130.200 E424.83620
G1 X149.800 Y130.200 E425.18496
G1 X149.800 Y149.800 E425.53373
;LAYER:58
G0 X149.239 Y149.239 Z6.100
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E425.99877
G1 F3600.000 X135.112 Y130.759 E426.10832
G1 F3600.000 X149.239 Y143.582 E426.43100
G1 F3600.000 X144.916 Y149.239 E426.53978
G1 F3600.000 X130.759 Y136.416 E426.86247
G1 F3600.000 X140.769 Y130.759 E427.11437
G1 F3600.000 X149.239 Y137.926 E427.29471
G1 F3600.000 X139.259 Y149.239 E427.54584
G1 F3600.000 X130.759 Y142.073 E427.72617
G1 F3600.000 X146.426 Y130.759 E428.12043
G1 F3600.000 X149.239 Y132.269 E428.15841
G0 F7200.000 X149.239 Y133.603
G1 F3600.000 X133.602 Y149.239 E428.55190
G0 X133.532 Y149.309
G1 F3600.000 X130.759 Y147.730 E428.58988
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E428.92441
G1 X149.400 Y130.600 E429.25894
G1 X149.400 Y149.400 E429.59347
G1 X130.600 Y149.400 E429.92800
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E430.27676
G1 X149.800 Y130.200 E430.62553
G1 X149.800 Y149.800 E430.97430
G1 X130.200 Y149.800 E431.32306
;LAYER:59
G0 X130.759 Y147.730 Z6.200
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E431.36103
G1 F3600.000 X149.239 Y133.603 E431.75452
G1 F3600.000 X147.730 Y130.759 E431.79251
G1 F3600.000 X130.759 Y146.426 E432.18677
G1 F3600.000 X137.925 Y149.239 E432.36710
G1 F3600.000 X149.239 Y139.260 E432.61823
G1 F3600.000 X142.073 Y130.759 E432.79857
G1 F3600.000 X130.759 Y140.769 E433.05047
G1 F3600.000 X143.582 Y149.239 E433.37316
G1 F3600.000 X149.239 Y144.917 E433.48193
G1 F3600.000 X136.416 Y130.759 E433.80462
G1 F3600.000 X130.759 Y135.112 E433.91416
G1 F3600.000 X149.239 Y149.239 E434.37921
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E434.71374
G1 X130.600 Y130.600 E435.04827
G1 X149.400 Y130.600 E435.38280
G1 X149.400 Y149.400 E435.71733
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E436.06610
G1 X130.200 Y130.200 E436.41486
G1 X149.800 Y130.200 E436.76363
G1 X149.800 Y149.800 E437.11239
;LAYER:60
G0 X149.239 Y149.239 Z6.300
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E437.57744
G1 F3600.000 X135.112 Y130.759 E437.68698
G1 F3600.000 X149.239 Y143.582 E438.00967
G1 F3600.000 X144.916 Y149.239 E438.11844
G1 F3600.000 X130.759 Y136.416 E438.44113
G1 F3600.000 X140.769 Y130.759 E438.69303
G1 F3600.000 X149.239 Y137.926 E438.87337
G0 F7200.000 X149.239 Y139.260
G1 F3600.000 X139.259 Y149.239 E439.12450
G0 X139.189 Y149.309
G1 F3600.000 X130.759 Y142.073 E439.30483
G1 F3600.000 X146.426 Y130.759 E439.69909
G1 F3600.000 X149.239 Y132.269 E439.73708
G1 F3600.000 X133.602 Y149.239 E440.13057
G1 F3600.000 X130.759 Y147.730 E440.16854
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E440.50307
G1 X149.400 Y130.600 E440.83760
G1 X149.400 Y149.400 E441.17213
G1 X130.600 Y149.400 E441.50666
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E441.85543
G1 X149.800 Y130.200 E442.20419
G1 X149.800 Y149.800 E442.55296
G1 X130.200 Y149.800 E442.90172
;LAYER:61
G0 X130.759 Y147.730 Z6.400
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E442.93970
G1 F3600.000 X149.239 Y133.603 E443.33319
G1 F3600.000 X147.730 Y130.759 E443.37117
G1 F3600.000 X130.759 Y146.426 E443.76543
G1 F3600.000 X137.925 Y149.239 E443.94576
G1 F3600.000 X149.239 Y139.260 E444.19689
G1 F3600.000 X142.073 Y130.759 E444.37723
G1 F3600.000 X130.759 Y140.769 E444.62913
G1 F3600.000 X143.582 Y149.239 E444.95182
G1 F3600.000 X149.239 Y144.917 E445.06060
G1 F3600.000 X136.416 Y130.759 E445.38328
G1 F3600.000 X130.759 Y135.112 E445.49283
G1 F3600.000 X149.239 Y149.239 E445.95787
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E446.29240
G1 X130.600 Y130.600 E446.62693
G1 X149.400 Y130.600 E446.96146
G1 X149.400 Y149.400 E447.29599
G0 F7200.00000 X149.800 Y149.800
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E447.64476
G1 X130.200 Y130.200 E447.99352
G1 X149.800 Y130.200 E448.34229
G1 X149.800 Y149.800 E448.69106
;LAYER:62
G0 X149.239 Y149.239 Z6.500
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E449.15610
G0 X130.689 Y130.689
G1 F3600.000 X135.112 Y130.759 E449.26564
G1 F3600.000 X149.239 Y143.582 E449.58833
G0 F7200.000 X149.239 Y144.917
G1 F3600.000 X144.916 Y149.239 E449.69711
G0 X144.846 Y149.309
G1 F3600.000 X130.759 Y136.416 E450.01979
G1 F3600.000 X140.769 Y130.759 E450.27169
G1 F3600.000 X149.239 Y137.926 E450.45204
G1 F3600.000 X139.259 Y149.239 E450.70317
G1 F3600.000 X130.759 Y142.073 E450.88350
G1 F3600.000 X146.426 Y130.759 E451.27775
G1 F3600.000 X149.239 Y132.269 E451.31574
G1 F3600.000 X133.602 Y149.239 E451.70923
G1 F3600.000 X130.759 Y147.730 E451.74720
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E452.08173
G1 X149.400 Y130.600 E452.41626
G1 X149.400 Y149.400 E452.75079
G1 X130.600 Y149.400 E453.08532
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E453.43409
G1 X149.800 Y130.200 E453.78286
G1 X149.800 Y149.800 E454.13162
G1 X130.200 Y149.800 E454.48039
;LAYER:63
G0 X130.759 Y147.730 Z6.600
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E454.51836
G1 F3600.000 X149.239 Y133.603 E454.91185
G1 F3600.000 X147.730 Y130.759 E454.94984
G1 F3600.000 X130.759 Y146.426 E455.34409
G1 F3600.000 X137.925 Y149.239 E455.52442
G1 F3600.000 X149.239 Y139.260 E455.77555
G1 F3600.000 X142.073 Y130.759 E455.95590
G1 F3600.000 X130.759 Y140.769 E456.20780
G1 F3600.000 X143.582 Y149.239 E456.53049
G1 F3600.000 X149.239 Y144.917 E456.63926
G0 F7200.000 X149.239 Y143.582
G1 F3600.000 X136.416 Y130.759 E456.96195
G0 X136.346 Y130.689
G1 F3600.000 X130.759 Y135.112 E457.07149
G1 F3600.000 X149.239 Y149.239 E457.53653
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E457.87106
G1 X130.600 Y130.600 E458.20560
G1 X149.400 Y130.600 E458.54013
G1 X149.400 Y149.400 E458.87466
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E459.22342
G1 X130.200 Y130.200 E459.57219
G1 X149.800 Y130.200 E459.92095
G1 X149.800 Y149.800 E460.26972
;LAYER:64
G0 X149.239 Y149.239 Z6.700
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E460.73476
G1 F3600.000 X135.112 Y130.759 E460.84431
G1 F3600.000 X149.239 Y143.582 E461.16699
G1 F3600.000 X144.916 Y149.239 E461.27577
G1 F3600.000 X130.759 Y136.416 E461.59846
G1 F3600.000 X140.769 Y130.759 E461.85036
G1 F3600.000 X149.239 Y137.926 E462.03070
G1 F3600.000 X139.259 Y149.239 E462.28183
G1 F3600.000 X130.759 Y142.073 E462.46216
G1 F3600.000 X146.426 Y130.759 E462.85642
G1 F3600.000 X149.239 Y132.269 E462.89440
G1 F3600.000 X133.602 Y149.239 E463.28789
G1 F3600.000 X130.759 Y147.730 E463.32587
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E463.66040
G1 X149.400 Y130.600 E463.99493
G1 X149.400 Y149.400 E464.32946
G1 X130.600 Y149.400 E464.66399
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E465.01275
G1 X149.800 Y130.200 E465.36152
G1 X149.800 Y149.800 E465.71029
G1 X130.200 Y149.800 E466.05905
;LAYER:65
G0 X130.759 Y147.730 Z6.800
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E466.09702
G1 F3600.000 X149.239 Y133.603 E466.49051
G0 F7200.000 X149.239 Y132.269
G1 F3600.000 X147.730 Y130.759 E466.52850
G0 X147.660 Y130.689
G1 F3600.000 X130.759 Y146.426 E466.92276
G1 F3600.000 X137.925 Y149.239 E467.10309
G1 F3600.000 X149.239 Y139.260 E467.35422
G0 F7200.000 X149.239 Y137.926
G1 F3600.000 X142.073 Y130.759 E467.53456
G0 X142.003 Y130.689
G1 F3600.000 X130.759 Y140.769 E467.78646
G1 F3600.000 X143.582 Y149.239 E468.10915
G1 F3600.000 X149.239 Y144.917 E468.21792
G1 F3600.000 X136.416 Y130.759 E468.54061
G1 F3600.000 X130.759 Y135.112 E468.65015
G1 F3600.000 X149.239 Y149.239 E469.11520
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E469.44973
G1 X130.600 Y130.600 E469.78426
G1 X149.400 Y130.600 E470.11879
G1 X149.400 Y149.400 E470.45332
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E470.80209
G1 X130.200 Y130.200 E471.15085
G1 X149.800 Y130.200 E471.49962
G1 X149.800 Y149.800 E471.84838
;LAYER:66
G0 X149.239 Y149.239 Z6.900
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E472.31343
G1 F3600.000 X135.112 Y130.759 E472.42297
G1 F3600.000 X149.239 Y143.582 E472.74566
G1 F3600.000 X144.916 Y149.239 E472.85443
G0 F7200.000 X143.582 Y149.239
G1 F3600.000 X130.759 Y136.416 E473.17712
G0 X130.689 Y136.346
G1 F3600.000 X140.769 Y130.759 E473.42902
G1 F3600.000 X149.239 Y137.926 E473.60936
G1 F3600.000 X139.259 Y149.239 E473.86049
G0 F7200.000 X137.925 Y149.239
G1 F3600.000 X130.759 Y142.073 E474.04082
G0 X130.689 Y142.003
G1 F3600.000 X146.426 Y130.759 E474.43508
G1 F3600.000 X149.239 Y132.269 E474.47307
G1 F3600.000 X133.602 Y149.239 E474.86656
G1 F3600.000 X130.759 Y147.730 E474.90453
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E475.23906
G1 X149.400 Y130.600 E475.57359
G1 X149.400 Y149.400 E475.90812
G1 X130.600 Y149.400 E476.24265
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E476.59142
G1 X149.800 Y130.200 E476.94018
G1 X149.800 Y149.800 E477.28895
G1 X130.200 Y149.800 E477.63771
;LAYER:67
G0 X130.759 Y147.730 Z7.000
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E477.67569
G1 F3600.000 X149.239 Y133.603 E478.06918
G1 F3600.000 X147.730 Y130.759 E478.10716
G1 F3600.000 X130.759 Y146.426 E478.50142
G1 F3600.000 X137.925 Y149.239 E478.68175
G1 F3600.000 X149.239 Y139.260 E478.93288
G1 F3600.000 X142.073 Y130.759 E479.11322
G1 F3600.000 X130.759 Y140.769 E479.36512
G1 F3600.000 X143.582 Y149.239 E479.68781
G1 F3600.000 X149.239 Y144.917 E479.79659
G1 F3600.000 X136.416 Y130.759 E480.11927
G1 F3600.000 X130.759 Y135.112 E480.22882
G1 F3600.000 X149.239 Y149.239 E480.69386
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E481.02839
G1 X130.600 Y130.600 E481.36292
G1 X149.400 Y130.600 E481.69745
G1 X149.400 Y149.400 E482.03198
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E482.38075
G1 X130.200 Y130.200 E482.72951
G1 X149.800 Y130.200 E483.07828
G1 X149.800 Y149.800 E483.42705
;LAYER:68
G0 X149.239 Y149.239 Z7.100
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E483.89209
G1 F3600.000 X135.112 Y130.759 E484.00163
G1 F3600.000 X149.239 Y143.582 E484.32432
G1 F3600.000 X144.916 Y149.239 E484.43310
G1 F3600.000 X130.759 Y136.416 E484.75578
G1 F3600.000 X140.769 Y130.759 E485.00768
G1 F3600.000 X149.239 Y137.926 E485.18803
G1 F3600.000 X139.259 Y149.239 E485.43916
G1 F3600.000 X130.759 Y142.073 E485.61949
G1 F3600.000 X146.426 Y130.759 E486.01374
G1 F3600.000 X149.239 Y132.269 E486.05173
G1 F3600.000 X133.602 Y149.239 E486.44522
G0 F7200.000 X132.268 Y149.239
G1 F3600.000 X130.759 Y147.730 E486.48319
G0 X130.689 Y147.660
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E486.81772
G1 X149.400 Y130.600 E487.15225
G1 X149.400 Y149.400 E487.48678
G1 X130.600 Y149.400 E487.82131
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E488.17008
G1 X149.800 Y130.200 E488.51885
G1 X149.800 Y149.800 E488.86761
G1 X130.200 Y149.800 E489.21638
;LAYER:69
G0 X130.759 Y147.730 Z7.200
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E489.25435
G0 F7200.000 X133.602 Y149.239
G1 F3600.000 X149.239 Y133.603 E489.64784
G0 X149.309 Y133.533
G1 F3600.000 X147.730 Y130.759 E489.68583
G1 F3600.000 X130.759 Y146.426 E490.08008
G1 F3600.000 X137.925 Y149.239 E490.26041
G0 F7200.000 X139.259 Y149.239
G1 F3600.000 X149.239 Y139.260 E490.51154
G0 X149.309 Y139.190
G1 F3600.000 X142.073 Y130.759 E490.69189
G1 F3600.000 X130.759 Y140.769 E490.94379
G1 F3600.000 X143.582 Y149.239 E491.26648
G0 F7200.000 X144.916 Y149.239
G1 F3600.000 X149.239 Y144.917 E491.37525
G0 X149.309 Y144.847
G1 F3600.000 X136.416 Y130.759 E491.69794
G1 F3600.000 X130.759 Y135.112 E491.80748
G0 F7200.000 X130.759 Y130.759
G1 F3600.000 X149.239 Y149.239 E492.27252
G0 F7200.000 X149.400 Y149.400
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E492.60705
G1 X130.600 Y130.600 E492.94159
G1 X149.400 Y130.600 E493.27612
G1 X149.400 Y149.400 E493.61065
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E493.95941
G1 X130.200 Y130.200 E494.30818
G1 X149.800 Y130.200 E494.65694
G1 X149.800 Y149.800 E495.00571
G0 F7200.00000 X149.000 Y149.118
;LAYER:70
G0 X149.239 Y149.239 Z7.300
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E495.47075
G0 F7200.000 X130.759 Y135.112
G1 F3600.000 X135.112 Y130.759 E495.58030
G0 X135.182 Y130.689
G1 F3600.000 X149.239 Y143.582 E495.90298
G1 F3600.000 X144.916 Y149.239 E496.01176
G1 F3600.000 X130.759 Y136.416 E496.33445
G0 F7200.000 X130.759 Y140.769
G1 F3600.000 X140.769 Y130.759 E496.58635
G0 X140.839 Y130.689
G1 F3600.000 X149.239 Y137.926 E496.76669
G1 F3600.000 X139.259 Y149.239 E497.01782
G1 F3600.000 X130.759 Y142.073 E497.19815
G0 F7200.000 X130.759 Y146.426
G1 F3600.000 X146.426 Y130.759 E497.59241
G0 X146.496 Y130.689
G1 F3600.000 X149.239 Y132.269 E497.63039
G1 F3600.000 X133.602 Y149.239 E498.02388
G1 F3600.000 X130.759 Y147.730 E498.06186
G0 F7200.000 X130.600 Y149.400
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E498.39639
G1 X149.400 Y130.600 E498.73092
G1 X149.400 Y149.400 E499.06545
G1 X130.600 Y149.400 E499.39998
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E499.74874
G1 X149.800 Y130.200 E500.09751
G1 X149.800 Y149.800 E500.44628
G1 X130.200 Y149.800 E500.79504
G0 F7200.00000 X130.882 Y149.000
;LAYER:71
G0 X130.759 Y147.730 Z7.400
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E500.83301
G1 F3600.000 X149.239 Y133.603 E501.22650
G1 F3600.000 X147.730 Y130.759 E501.26449
G1 F3600.000 X130.759 Y146.426 E501.65875
G1 F3600.000 X137.925 Y149.239 E501.83908
G1 F3600.000 X149.239 Y139.260 E502.09021
G1 F3600.000 X142.073 Y130.759 E502.27055
G1 F3600.000 X130.759 Y140.769 E502.52245
G1 F3600.000 X143.582 Y149.239 E502.84514
G1 F3600.000 X149.239 Y144.917 E502.95391
G1 F3600.000 X136.416 Y130.759 E503.27660
G1 F3600.000 X130.759 Y135.112 E503.38614
G1 F3600.000 X149.239 Y149.239 E503.85119
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E504.18572
G1 X130.600 Y130.600 E504.52025
G1 X149.400 Y130.600 E504.85478
G1 X149.400 Y149.400 E505.18931
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E505.53808
G1 X130.200 Y130.200 E505.88684
G1 X149.800 Y130.200 E506.23561
G1 X149.800 Y149.800 E506.58437
;LAYER:72
G0 X149.239 Y149.239 Z7.500
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E507.04942
G1 F3600.000 X135.112 Y130.759 E507.15896
G1 F3600.000 X149.239 Y143.582 E507.48165
G1 F3600.000 X144.916 Y149.239 E507.59042
G1 F3600.000 X130.759 Y136.416 E507.91311
G1 F3600.000 X140.769 Y130.759 E508.16501
G1 F3600.000 X149.239 Y137.926 E508.34535
G1 F3600.000 X139.259 Y149.239 E508.59648
G1 F3600.000 X130.759 Y142.073 E508.77681
G1 F3600.000 X146.426 Y130.759 E509.17107
G1 F3600.000 X149.239 Y132.269 E509.20906
G1 F3600.000 X133.602 Y149.239 E509.60255
G1 F3600.000 X130.759 Y147.730 E509.64052
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E509.97505
G1 X149.400 Y130.600 E510.30958
G1 X149.400 Y149.400 E510.64411
G1 X130.600 Y149.400 E510.97864
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E511.32741
G1 X149.800 Y130.200 E511.67617
G1 X149.800 Y149.800 E512.02494
G1 X130.200 Y149.800 E512.37370
;LAYER:73
G0 X130.759 Y147.730 Z7.600
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E512.41168
G1 F3600.000 X149.239 Y133.603 E512.80517
G1 F3600.000 X147.730 Y130.759 E512.84315
G1 F3600.000 X130.759 Y146.426 E513.23741
G1 F3600.000 X137.925 Y149.239 E513.41774
G1 F3600.000 X149.239 Y139.260 E513.66887
G1 F3600.000 X142.073 Y130.759 E513.84921
G1 F3600.000 X130.759 Y140.769 E514.10111
G1 F3600.000 X143.582 Y149.239 E514.42380
G1 F3600.000 X149.239 Y144.917 E514.53258
G1 F3600.000 X136.416 Y130.759 E514.85526
G1 F3600.000 X130.759 Y135.112 E514.96481
G1 F3600.000 X149.239 Y149.239 E515.42985
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E515.76438
G1 X130.600 Y130.600 E516.09891
G1 X149.400 Y130.600 E516.43344
G1 X149.400 Y149.400 E516.76797
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E517.11674
G1 X130.200 Y130.200 E517.46550
G1 X149.800 Y130.200 E517.81427
G1 X149.800 Y149.800 E518.16304
;LAYER:74
G0 X149.239 Y149.239 Z7.700
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E518.62808
G1 F3600.000 X135.112 Y130.759 E518.73762
G1 F3600.000 X149.239 Y143.582 E519.06031
G1 F3600.000 X144.916 Y149.239 E519.16909
G1 F3600.000 X130.759 Y136.416 E519.49177
G1 F3600.000 X140.769 Y130.759 E519.74367
G1 F3600.000 X149.239 Y137.926 E519.92402
G1 F3600.000 X139.259 Y149.239 E520.17515
G1 F3600.000 X130.759 Y142.073 E520.35548
G1 F3600.000 X146.426 Y130.759 E520.74973
G1 F3600.000 X149.239 Y132.269 E520.78772
G1 F3600.000 X133.602 Y149.239 E521.18121
G1 F3600.000 X130.759 Y147.730 E521.21918
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E521.55371
G1 X149.400 Y130.600 E521.88824
G1 X149.400 Y149.400 E522.22277
G1 X130.600 Y149.400 E522.55730
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E522.90607
G1 X149.800 Y130.200 E523.25484
G1 X149.800 Y149.800 E523.60360
G1 X130.200 Y149.800 E523.95237
;LAYER:75
G0 X130.759 Y147.730 Z7.800
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E523.99034
G1 F3600.000 X149.239 Y133.603 E524.38383
G1 F3600.000 X147.730 Y130.759 E524.42182
G1 F3600.000 X130.759 Y146.426 E524.81607
G1 F3600.000 X137.925 Y149.239 E524.99640
G1 F3600.000 X149.239 Y139.260 E525.24754
G1 F3600.000 X142.073 Y130.759 E525.42788
G1 F3600.000 X130.759 Y140.769 E525.67978
G1 F3600.000 X143.582 Y149.239 E526.00247
G1 F3600.000 X149.239 Y144.917 E526.11124
G1 F3600.000 X136.416 Y130.759 E526.43393
G1 F3600.000 X130.759 Y135.112 E526.54347
G1 F3600.000 X149.239 Y149.239 E527.00851
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E527.34305
G1 X130.600 Y130.600 E527.67758
G1 X149.400 Y130.600 E528.01211
G1 X149.400 Y149.400 E528.34664
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E528.69540
G1 X130.200 Y130.200 E529.04417
G1 X149.800 Y130.200 E529.39293
G1 X149.800 Y149.800 E529.74170
;LAYER:76
G0 X149.239 Y149.239 Z7.900
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E530.20674
G1 F3600.000 X135.112 Y130.759 E530.31629
G1 F3600.000 X149.239 Y143.582 E530.63897
G1 F3600.000 X144.916 Y149.239 E530.74775
G1 F3600.000 X130.759 Y136.416 E531.07044
G1 F3600.000 X140.769 Y130.759 E531.32234
G1 F3600.000 X149.239 Y137.926 E531.50268
G1 F3600.000 X139.259 Y149.239 E531.75381
G1 F3600.000 X130.759 Y142.073 E531.93414
G1 F3600.000 X146.426 Y130.759 E532.32840
G1 F3600.000 X149.239 Y132.269 E532.36638
G1 F3600.000 X133.602 Y149.239 E532.75987
G1 F3600.000 X130.759 Y147.730 E532.79785
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E533.13238
G1 X149.400 Y130.600 E533.46691
G1 X149.400 Y149.400 E533.80144
G1 X130.600 Y149.400 E534.13597
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E534.48473
G1 X149.800 Y130.200 E534.83350
G1 X149.800 Y149.800 E535.18227
G1 X130.200 Y149.800 E535.53103
;LAYER:77
G0 X130.759 Y147.730 Z8.000
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E535.56900
G1 F3600.000 X149.239 Y133.603 E535.96249
G1 F3600.000 X147.730 Y130.759 E536.00048
G1 F3600.000 X130.759 Y146.426 E536.39474
G1 F3600.000 X137.925 Y149.239 E536.57507
G1 F3600.000 X149.239 Y139.260 E536.82620
G1 F3600.000 X142.073 Y130.759 E537.00654
G1 F3600.000 X130.759 Y140.769 E537.25844
G1 F3600.000 X143.582 Y149.239 E537.58113
G1 F3600.000 X149.239 Y144.917 E537.68990
G1 F3600.000 X136.416 Y130.759 E538.01259
G1 F3600.000 X130.759 Y135.112 E538.12213
G1 F3600.000 X149.239 Y149.239 E538.58718
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E538.92171
G1 X130.600 Y130.600 E539.25624
G1 X149.400 Y130.600 E539.59077
G1 X149.400 Y149.400 E539.92530
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E540.27407
G1 X130.200 Y130.200 E540.62283
G1 X149.800 Y130.200 E540.97160
G1 X149.800 Y149.800 E541.32036
;LAYER:78
G0 X149.239 Y149.239 Z8.100
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E541.78541
G1 F3600.000 X135.112 Y130.759 E541.89495
G1 F3600.000 X149.239 Y143.582 E542.21764
G1 F3600.000 X144.916 Y149.239 E542.32641
G1 F3600.000 X130.759 Y136.416 E542.64910
G1 F3600.000 X140.769 Y130.759 E542.90100
G1 F3600.000 X149.239 Y137.926 E543.08134
G1 F3600.000 X139.259 Y149.239 E543.33247
G1 F3600.000 X130.759 Y142.073 E543.51280
G1 F3600.000 X146.426 Y130.759 E543.90706
G1 F3600.000 X149.239 Y132.269 E543.94505
G1 F3600.000 X133.602 Y149.239 E544.33854
G1 F3600.000 X130.759 Y147.730 E544.37651
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E544.71104
G1 X149.400 Y130.600 E545.04557
G1 X149.400 Y149.400 E545.38010
G1 X130.600 Y149.400 E545.71463
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E546.06340
G1 X149.800 Y130.200 E546.41216
G1 X149.800 Y149.800 E546.76093
G1 X130.200 Y149.800 E547.10969
;LAYER:79
G0 X130.759 Y147.730 Z8.200
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E547.14767
G1 F3600.000 X149.239 Y133.603 E547.54116
G1 F3600.000 X147.730 Y130.759 E547.57914
G1 F3600.000 X130.759 Y146.426 E547.97340
G1 F3600.000 X137.925 Y149.239 E548.15373
G1 F3600.000 X149.239 Y139.260 E548.40486
G1 F3600.000 X142.073 Y130.759 E548.58521
G1 F3600.000 X130.759 Y140.769 E548.83710
G1 F3600.000 X143.582 Y149.239 E549.15979
G1 F3600.000 X149.239 Y144.917 E549.26857
G1 F3600.000 X136.416 Y130.759 E549.59125
G1 F3600.000 X130.759 Y135.112 E549.70080
G1 F3600.000 X149.239 Y149.239 E550.16584
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E550.50037
G1 X130.600 Y130.600 E550.83490
G1 X149.400 Y130.600 E551.16943
G1 X149.400 Y149.400 E551.50396
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E551.85273
G1 X130.200 Y130.200 E552.20149
G1 X149.800 Y130.200 E552.55026
G1 X149.800 Y149.800 E552.89903
;LAYER:80
G0 X149.239 Y149.239 Z8.300
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E553.36407
G1 F3600.000 X135.112 Y130.759 E553.47361
G1 F3600.000 X149.239 Y143.582 E553.79630
G1 F3600.000 X144.916 Y149.239 E553.90508
G1 F3600.000 X130.759 Y136.416 E554.22776
G1 F3600.000 X140.769 Y130.759 E554.47966
G1 F3600.000 X149.239 Y137.926 E554.66001
G1 F3600.000 X139.259 Y149.239 E554.91114
G1 F3600.000 X130.759 Y142.073 E555.09147
G1 F3600.000 X146.426 Y130.759 E555.48572
G1 F3600.000 X149.239 Y132.269 E555.52371
G1 F3600.000 X133.602 Y149.239 E555.91720
G1 F3600.000 X130.759 Y147.730 E555.95517
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E556.28970
G1 X149.400 Y130.600 E556.62423
G1 X149.400 Y149.400 E556.95876
G1 X130.600 Y149.400 E557.29329
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E557.64206
G1 X149.800 Y130.200 E557.99083
G1 X149.800 Y149.800 E558.33959
G1 X130.200 Y149.800 E558.68836
;LAYER:81
G0 X130.759 Y147.730 Z8.400
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E558.72633
G1 F3600.000 X149.239 Y133.603 E559.11982
G1 F3600.000 X147.730 Y130.759 E559.15781
G1 F3600.000 X130.759 Y146.426 E559.55206
G1 F3600.000 X137.925 Y149.239 E559.73239
G1 F3600.000 X149.239 Y139.260 E559.98353
G1 F3600.000 X142.073 Y130.759 E560.16387
G1 F3600.000 X130.759 Y140.769 E560.41577
G1 F3600.000 X143.582 Y149.239 E560.73846
G1 F3600.000 X149.239 Y144.917 E560.84723
G1 F3600.000 X136.416 Y130.759 E561.16992
G1 F3600.000 X130.759 Y135.112 E561.27946
G1 F3600.000 X149.239 Y149.239 E561.74450
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E562.07904
G1 X130.600 Y130.600 E562.41357
G1 X149.400 Y130.600 E562.74810
G1 X149.400 Y149.400 E563.08263
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E563.43139
G1 X130.200 Y130.200 E563.78016
G1 X149.800 Y130.200 E564.12892
G1 X149.800 Y149.800 E564.47769
;LAYER:82
G0 X149.239 Y149.239 Z8.500
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E564.94273
G1 F3600.000 X135.112 Y130.759 E565.05228
G1 F3600.000 X149.239 Y143.582 E565.37496
G1 F3600.000 X144.916 Y149.239 E565.48374
G1 F3600.000 X130.759 Y136.416 E565.80643
G1 F3600.000 X140.769 Y130.759 E566.05833
G1 F3600.000 X149.239 Y137.926 E566.23867
G1 F3600.000 X139.259 Y149.239 E566.48980
G1 F3600.000 X130.759 Y142.073 E566.67013
G1 F3600.000 X146.426 Y130.759 E567.06439
G1 F3600.000 X149.239 Y132.269 E567.10237
G1 F3600.000 X133.602 Y149.239 E567.49586
G1 F3600.000 X130.759 Y147.730 E567.53384
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E567.86837
G1 X149.400 Y130.600 E568.20290
G1 X149.400 Y149.400 E568.53743
G1 X130.600 Y149.400 E568.87196
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E569.22072
G1 X149.800 Y130.200 E569.56949
G1 X149.800 Y149.800 E569.91826
G1 X130.200 Y149.800 E570.26702
;LAYER:83
G0 X130.759 Y147.730 Z8.600
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E570.30499
G1 F3600.000 X149.239 Y133.603 E570.69848
G1 F3600.000 X147.730 Y130.759 E570.73647
G1 F3600.000 X130.759 Y146.426 E571.13073
G1 F3600.000 X137.925 Y149.239 E571.31106
G1 F3600.000 X149.239 Y139.260 E571.56219
G1 F3600.000 X142.073 Y130.759 E571.74253
G1 F3600.000 X130.759 Y140.769 E571.99443
G1 F3600.000 X143.582 Y149.239 E572.31712
G1 F3600.000 X149.239 Y144.917 E572.42589
G1 F3600.000 X136.416 Y130.759 E572.74858
G1 F3600.000 X130.759 Y135.112 E572.85812
G1 F3600.000 X149.239 Y149.239 E573.32317
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E573.65770
G1 X130.600 Y130.600 E573.99223
G1 X149.400 Y130.600 E574.32676
G1 X149.400 Y149.400 E574.66129
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E575.01006
G1 X130.200 Y130.200 E575.35882
G1 X149.800 Y130.200 E575.70759
G1 X149.800 Y149.800 E576.05635
;LAYER:84
G0 X149.239 Y149.239 Z8.700
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E576.52140
G1 F3600.000 X135.112 Y130.759 E576.63094
G1 F3600.000 X149.239 Y143.582 E576.95363
G1 F3600.000 X144.916 Y149.239 E577.06240
G1 F3600.000 X130.759 Y136.416 E577.38509
G1 F3600.000 X140.769 Y130.759 E577.63699
G1 F3600.000 X149.239 Y137.926 E577.81733
G1 F3600.000 X139.259 Y149.239 E578.06846
G1 F3600.000 X130.759 Y142.073 E578.24879
G1 F3600.000 X146.426 Y130.759 E578.64305
G1 F3600.000 X149.239 Y132.269 E578.68104
G1 F3600.000 X133.602 Y149.239 E579.07453
G1 F3600.000 X130.759 Y147.730 E579.11250
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E579.44703
G1 X149.400 Y130.600 E579.78156
G1 X149.400 Y149.400 E580.11609
G1 X130.600 Y149.400 E580.45062
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E580.79939
G1 X149.800 Y130.200 E581.14815
G1 X149.800 Y149.800 E581.49692
G1 X130.200 Y149.800 E581.84568
;LAYER:85
G0 X130.759 Y147.730 Z8.800
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E581.88366
G1 F3600.000 X149.239 Y133.603 E582.27715
G1 F3600.000 X147.730 Y130.759 E582.31513
G1 F3600.000 X130.759 Y146.426 E582.70939
G1 F3600.000 X137.925 Y149.239 E582.88972
G1 F3600.000 X149.239 Y139.260 E583.14085
G1 F3600.000 X142.073 Y130.759 E583.32120
G1 F3600.000 X130.759 Y140.769 E583.57309
G1 F3600.000 X143.582 Y149.239 E583.89578
G1 F3600.000 X149.239 Y144.917 E584.00456
G1 F3600.000 X136.416 Y130.759 E584.32724
G1 F3600.000 X130.759 Y135.112 E584.43679
G1 F3600.000 X149.239 Y149.239 E584.90183
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E585.23636
G1 X130.600 Y130.600 E585.57089
G1 X149.400 Y130.600 E585.90542
G1 X149.400 Y149.400 E586.23995
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E586.58872
G1 X130.200 Y130.200 E586.93748
G1 X149.800 Y130.200 E587.28625
G1 X149.800 Y149.800 E587.63502
;LAYER:86
G0 X149.239 Y149.239 Z8.900
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E588.10006
G1 F3600.000 X135.112 Y130.759 E588.20960
G1 F3600.000 X149.239 Y143.582 E588.53229
G1 F3600.000 X144.916 Y149.239 E588.64107
G1 F3600.000 X130.759 Y136.416 E588.96375
G1 F3600.000 X140.769 Y130.759 E589.21565
G1 F3600.000 X149.239 Y137.926 E589.39600
G1 F3600.000 X139.259 Y149.239 E589.64713
G1 F3600.000 X130.759 Y142.073 E589.82746
G1 F3600.000 X146.426 Y130.759 E590.22171
G1 F3600.000 X149.239 Y132.269 E590.25970
G1 F3600.000 X133.602 Y149.239 E590.65319
G1 F3600.000 X130.759 Y147.730 E590.69116
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E591.02569
G1 X149.400 Y130.600 E591.36022
G1 X149.400 Y149.400 E591.69475
G1 X130.600 Y149.400 E592.02928
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E592.37805
G1 X149.800 Y130.200 E592.72682
G1 X149.800 Y149.800 E593.07558
G1 X130.200 Y149.800 E593.42435
;LAYER:87
G0 X130.759 Y147.730 Z9.000
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E593.46232
G1 F3600.000 X149.239 Y133.603 E593.85581
G1 F3600.000 X147.730 Y130.759 E593.89380
G1 F3600.000 X130.759 Y146.426 E594.28805
G1 F3600.000 X137.925 Y149.239 E594.46838
G1 F3600.000 X149.239 Y139.260 E594.71952
G1 F3600.000 X142.073 Y130.759 E594.89986
G1 F3600.000 X130.759 Y140.769 E595.15176
G1 F3600.000 X143.582 Y149.239 E595.47445
G1 F3600.000 X149.239 Y144.917 E595.58322
G1 F3600.000 X136.416 Y130.759 E595.90591
G1 F3600.000 X130.759 Y135.112 E596.01545
G1 F3600.000 X149.239 Y149.239 E596.48049
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E596.81503
G1 X130.600 Y130.600 E597.14956
G1 X149.400 Y130.600 E597.48409
G1 X149.400 Y149.400 E597.81862
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E598.16738
G1 X130.200 Y130.200 E598.51615
G1 X149.800 Y130.200 E598.86491
G1 X149.800 Y149.800 E599.21368
;LAYER:88
G0 X149.239 Y149.239 Z9.100
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E599.67872
G1 F3600.000 X135.112 Y130.759 E599.78827
G1 F3600.000 X149.239 Y143.582 E600.11095
G1 F3600.000 X144.916 Y149.239 E600.21973
G1 F3600.000 X130.759 Y136.416 E600.54242
G1 F3600.000 X140.769 Y130.759 E600.79432
G1 F3600.000 X149.239 Y137.926 E600.97466
G1 F3600.000 X139.259 Y149.239 E601.22579
G1 F3600.000 X130.759 Y142.073 E601.40612
G1 F3600.000 X146.426 Y130.759 E601.80038
G1 F3600.000 X149.239 Y132.269 E601.83836
G1 F3600.000 X133.602 Y149.239 E602.23185
G1 F3600.000 X130.759 Y147.730 E602.26983
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E602.60436
G1 X149.400 Y130.600 E602.93889
G1 X149.400 Y149.400 E603.27342
G1 X130.600 Y149.400 E603.60795
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E603.95671
G1 X149.800 Y130.200 E604.30548
G1 X149.800 Y149.800 E604.65425
G1 X130.200 Y149.800 E605.00301
;LAYER:89
G0 X130.759 Y147.730 Z9.200
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E605.04099
G1 F3600.000 X149.239 Y133.603 E605.43447
G1 F3600.000 X147.730 Y130.759 E605.47246
G1 F3600.000 X130.759 Y146.426 E605.86672
G1 F3600.000 X137.925 Y149.239 E606.04705
G1 F3600.000 X149.239 Y139.260 E606.29818
G1 F3600.000 X142.073 Y130.759 E606.47852
G1 F3600.000 X130.759 Y140.769 E606.73042
G1 F3600.000 X143.582 Y149.239 E607.05311
G1 F3600.000 X149.239 Y144.917 E607.16188
G1 F3600.000 X136.416 Y130.759 E607.48457
G1 F3600.000 X130.759 Y135.112 E607.59411
G1 F3600.000 X149.239 Y149.239 E608.05916
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E608.39369
G1 X130.600 Y130.600 E608.72822
G1 X149.400 Y130.600 E609.06275
G1 X149.400 Y149.400 E609.39728
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E609.74605
G1 X130.200 Y130.200 E610.09481
G1 X149.800 Y130.200 E610.44358
G1 X149.800 Y149.800 E610.79234
;LAYER:90
G0 X149.239 Y149.239 Z9.300
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E611.25739
G1 F3600.000 X135.112 Y130.759 E611.36693
G1 F3600.000 X149.239 Y143.582 E611.68962
G1 F3600.000 X144.916 Y149.239 E611.79839
G1 F3600.000 X130.759 Y136.416 E612.12108
G1 F3600.000 X140.769 Y130.759 E612.37298
G1 F3600.000 X149.239 Y137.926 E612.55332
G1 F3600.000 X139.259 Y149.239 E612.80445
G1 F3600.000 X130.759 Y142.073 E612.98479
G1 F3600.000 X146.426 Y130.759 E613.37904
G1 F3600.000 X149.239 Y132.269 E613.41703
G1 F3600.000 X133.602 Y149.239 E613.81052
G1 F3600.000 X130.759 Y147.730 E613.84849
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E614.18302
G1 X149.400 Y130.600 E614.51755
G1 X149.400 Y149.400 E614.85208
G1 X130.600 Y149.400 E615.18661
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E615.53538
G1 X149.800 Y130.200 E615.88414
G1 X149.800 Y149.800 E616.23291
G1 X130.200 Y149.800 E616.58167
;LAYER:91
G0 X130.759 Y147.730 Z9.400
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E616.61965
G1 F3600.000 X149.239 Y133.603 E617.01314
G1 F3600.000 X147.730 Y130.759 E617.05112
G1 F3600.000 X130.759 Y146.426 E617.44538
G1 F3600.000 X137.925 Y149.239 E617.62571
G1 F3600.000 X149.239 Y139.260 E617.87684
G1 F3600.000 X142.073 Y130.759 E618.05719
G1 F3600.000 X130.759 Y140.769 E618.30908
G1 F3600.000 X143.582 Y149.239 E618.63177
G1 F3600.000 X149.239 Y144.917 E618.74055
G1 F3600.000 X136.416 Y130.759 E619.06323
G1 F3600.000 X130.759 Y135.112 E619.17278
G1 F3600.000 X149.239 Y149.239 E619.63782
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E619.97235
G1 X130.600 Y130.600 E620.30688
G1 X149.400 Y130.600 E620.64141
G1 X149.400 Y149.400 E620.97594
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E621.32471
G1 X130.200 Y130.200 E621.67347
G1 X149.800 Y130.200 E622.02224
G1 X149.800 Y149.800 E622.37101
;LAYER:92
G0 X149.239 Y149.239 Z9.500
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E622.83605
G1 F3600.000 X135.112 Y130.759 E622.94559
G1 F3600.000 X149.239 Y143.582 E623.26828
G1 F3600.000 X144.916 Y149.239 E623.37706
G1 F3600.000 X130.759 Y136.416 E623.69974
G1 F3600.000 X140.769 Y130.759 E623.95164
G1 F3600.000 X149.239 Y137.926 E624.13199
G1 F3600.000 X139.259 Y149.239 E624.38312
G1 F3600.000 X130.759 Y142.073 E624.56345
G1 F3600.000 X146.426 Y130.759 E624.95770
G1 F3600.000 X149.239 Y132.269 E624.99569
G1 F3600.000 X133.602 Y149.239 E625.38918
G1 F3600.000 X130.759 Y147.730 E625.42715
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E625.76168
G1 X149.400 Y130.600 E626.09621
G1 X149.400 Y149.400 E626.43074
G1 X130.600 Y149.400 E626.76528
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E627.11404
G1 X149.800 Y130.200 E627.46281
G1 X149.800 Y149.800 E627.81157
G1 X130.200 Y149.800 E628.16034
;LAYER:93
G0 X130.759 Y147.730 Z9.600
;TYPE:FILL
G1 F3600.000 X132.268 Y149.239 E628.19831
G1 F3600.000 X149.239 Y133.603 E628.59180
G1 F3600.000 X147.730 Y130.759 E628.62979
G1 F3600.000 X130.759 Y146.426 E629.02404
G1 F3600.000 X137.925 Y149.239 E629.20437
G1 F3600.000 X149.239 Y139.260 E629.45551
G1 F3600.000 X142.073 Y130.759 E629.63585
G1 F3600.000 X130.759 Y140.769 E629.88775
G1 F3600.000 X143.582 Y149.239 E630.21044
G1 F3600.000 X149.239 Y144.917 E630.31921
G1 F3600.000 X136.416 Y130.759 E630.64190
G1 F3600.000 X130.759 Y135.112 E630.75144
G1 F3600.000 X149.239 Y149.239 E631.21649
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E631.55102
G1 X130.600 Y130.600 E631.88555
G1 X149.400 Y130.600 E632.22008
G1 X149.400 Y149.400 E632.55461
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E632.90337
G1 X130.200 Y130.200 E633.25214
G1 X149.800 Y130.200 E633.60090
G1 X149.800 Y149.800 E633.94967
;LAYER:94
G0 X149.239 Y149.239 Z9.700
;TYPE:FILL
G1 F3600.000 X130.759 Y130.759 E634.41471
G1 F3600.000 X135.112 Y130.759 E634.52426
G1 F3600.000 X149.239 Y143.582 E634.84694
G1 F3600.000 X144.916 Y149.239 E634.95572
G1 F3600.000 X130.759 Y136.416 E635.27841
G1 F3600.000 X140.769 Y130.759 E635.53031
G1 F3600.000 X149.239 Y137.926 E635.71065
G1 F3600.000 X139.259 Y149.239 E635.96178
G1 F3600.000 X130.759 Y142.073 E636.14211
G1 F3600.000 X146.426 Y130.759 E636.53637
G1 F3600.000 X149.239 Y132.269 E636.57435
G1 F3600.000 X133.602 Y149.239 E636.96784
G1 F3600.000 X130.759 Y147.730 E637.00582
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E637.34035
G1 X149.400 Y130.600 E637.67488
G1 X149.400 Y149.400 E638.00941
G1 X130.600 Y149.400 E638.34394
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E638.69270
G1 X149.800 Y130.200 E639.04147
G1 X149.800 Y149.800 E639.39024
G1 X130.200 Y149.800 E639.73900
;LAYER:95
G0 X130.600 Y149.400 Z9.800
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E640.07353
G1 X149.400 Y130.600 E640.40806
G1 X149.400 Y149.400 E640.74259
G1 X130.600 Y149.400 E641.07712
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E641.42589
G1 X149.800 Y130.200 E641.77465
G1 X149.800 Y149.800 E642.12342
G1 X130.200 Y149.800 E642.47219
G0 F7200.00000 X130.774 Y149.239
;TYPE:SKIN
G1 F1800.000 X149.239 Y130.775 E642.93684
G0 X149.309 Y130.705
G0 F7200.000 X148.688 Y130.759
G1 F1800.000 X130.759 Y148.688 E643.38802
G0 X130.689 Y148.758
G0 F7200.000 X130.759 Y148.123
G1 F1800.000 X148.123 Y130.759 E643.82498
G0 X148.193 Y130.689
G0 F7200.000 X147.557 Y130.759
G1 F1800.000 X130.759 Y147.557 E644.24770
G0 X130.689 Y147.627
G0 F7200.000 X130.759 Y146.991
G1 F1800.000 X146.991 Y130.759 E644.65617
G0 X147.061 Y130.689
G1 F1800.000 X130.759 Y146.426 E645.05043
G0 F7200.000 X130.759 Y145.860
G1 F1800.000 X145.860 Y130.759 E645.43044
G0 X145.930 Y130.689
G0 F7200.000 X145.294 Y130.759
G1 F1800.000 X130.759 Y145.294 E645.79621
G0 X130.689 Y145.364
G0 F7200.000 X130.759 Y144.729
G1 F1800.000 X144.729 Y130.759 E646.14776
G0 X144.799 Y130.689
G0 F7200.000 X144.163 Y130.759
G1 F1800.000 X130.759 Y144.163 E646.48507
G0 X130.689 Y144.233
G0 F7200.000 X130.759 Y143.597
G1 F1800.000 X143.597 Y130.759 E646.80814
G0 X143.667 Y130.689
G0 F7200.000 X143.032 Y130.759
G1 F1800.000 X130.759 Y143.032 E647.11698
G0 X130.689 Y143.102
G0 F7200.000 X130.759 Y142.466
G1 F1800.000 X142.466 Y130.759 E647.41159
G0 X142.536 Y130.689
G0 F7200.000 X141.900 Y130.759
G1 F1800.000 X130.759 Y141.900 E647.69195
G0 X130.689 Y141.970
G0 F7200.000 X130.759 Y141.335
G1 F1800.000 X141.335 Y130.759 E647.95809
G0 X141.405 Y130.689
G1 F1800.000 X130.759 Y140.769 E648.20999
G0 F7200.000 X130.759 Y140.203
G1 F1800.000 X140.203 Y130.759 E648.44765
G0 X140.273 Y130.689
G0 F7200.000 X139.638 Y130.759
G1 F1800.000 X130.759 Y139.638 E648.67108
G0 X130.689 Y139.708
G0 F7200.000 X130.759 Y139.072
G1 F1800.000 X139.072 Y130.759 E648.88028
G0 X139.142 Y130.689
G0 F7200.000 X138.506 Y130.759
G1 F1800.000 X130.759 Y138.506 E649.07523
G0 X130.689 Y138.576
G0 F7200.000 X130.759 Y137.940
G1 F1800.000 X137.940 Y130.759 E649.25594
G0 X138.010 Y130.689
G0 F7200.000 X137.375 Y130.759
G1 F1800.000 X130.759 Y137.375 E649.42243
G0 X130.689 Y137.445
G0 F7200.000 X130.759 Y136.809
G1 F1800.000 X136.809 Y130.759 E649.57468
G0 X136.879 Y130.689
G0 F7200.000 X136.243 Y130.759
G1 F1800.000 X130.759 Y136.243 E649.71268
G0 X130.689 Y136.313
G0 F7200.000 X130.759 Y135.678
G1 F1800.000 X135.678 Y130.759 E649.83646
G0 X135.748 Y130.689
G1 F1800.000 X130.759 Y135.112 E649.94601
G0 F7200.000 X130.759 Y134.546
G1 F1800.000 X134.546 Y130.759 E650.04131
G0 X134.616 Y130.689
G0 F7200.000 X133.981 Y130.759
G1 F1800.000 X130.759 Y133.981 E650.12239
G0 X130.689 Y134.051
G0 F7200.000 X130.759 Y133.415
G1 F1800.000 X133.415 Y130.759 E650.18922
G0 X133.485 Y130.689
G0 F7200.000 X132.849 Y130.759
G1 F1800.000 X130.759 Y132.849 E650.24182
G0 X130.689 Y132.919
G0 F7200.000 X130.759 Y132.284
G1 F1800.000 X132.284 Y130.759 E650.28019
G0 X132.354 Y130.689
G0 F7200.000 X131.718 Y130.759
G1 F1800.000 X130.759 Y131.718 E650.30433
G0 X130.689 Y131.788
G0 F7200.000 X130.759 Y131.152
G1 F1800.000 X131.152 Y130.759 E650.31422
G0 F7200.00000 X149.239 Y131.340
G1 F1800.000 X131.340 Y149.239 E650.76464
G0 X131.270 Y149.309
G0 F7200.000 X131.905 Y149.239
G1 F1800.000 X149.239 Y131.906 E651.20084
G0 X149.309 Y131.836
G0 F7200.000 X149.239 Y132.472
G1 F1800.000 X132.471 Y149.239 E651.62279
G0 X132.401 Y149.309
G0 F7200.000 X133.037 Y149.239
G1 F1800.000 X149.239 Y133.037 E652.03050
G0 X149.309 Y132.967
G1 F1800.000 X133.602 Y149.239 E652.42399
G0 F7200.000 X134.168 Y149.239
G1 F1800.000 X149.239 Y134.169 E652.80324
G0 X149.309 Y134.099
G0 F7200.000 X149.239 Y134.734
G1 F1800.000 X134.734 Y149.239 E653.16825
G0 X134.664 Y149.309
G0 F7200.000 X135.299 Y149.239
G1 F1800.000 X149.239 Y135.300 E653.51904
G0 X149.309 Y135.230
G0 F7200.000 X149.239 Y135.866
G1 F1800.000 X135.865 Y149.239 E653.85558
G0 X135.795 Y149.309
G0 F7200.000 X136.431 Y149.239
G1 F1800.000 X149.239 Y136.432 E654.17788
G0 X149.309 Y136.362
G0 F7200.000 X149.239 Y136.997
G1 F1800.000 X136.996 Y149.239 E654.48596
G0 X136.926 Y149.309
G0 F7200.000 X137.562 Y149.239
G1 F1800.000 X149.239 Y137.563 E654.77979
G0 X149.309 Y137.493
G0 F7200.000 X149.239 Y138.129
G1 F1800.000 X138.128 Y149.239 E655.05939
G0 X138.058 Y149.309
G0 F7200.000 X138.694 Y149.239
G1 F1800.000 X149.239 Y138.694 E655.32475
G0 X149.309 Y138.624
G1 F1800.000 X139.259 Y149.239 E655.57588
G0 F7200.000 X139.825 Y149.239
G1 F1800.000 X149.239 Y139.826 E655.81277
G0 X149.309 Y139.756
G0 F7200.000 X149.239 Y140.391
G1 F1800.000 X140.391 Y149.239 E656.03543
G0 X140.321 Y149.309
G0 F7200.000 X140.956 Y149.239
G1 F1800.000 X149.239 Y140.957 E656.24385
G0 X149.309 Y140.887
G0 F7200.000 X149.239 Y141.523
G1 F1800.000 X141.522 Y149.239 E656.43804
G0 X141.452 Y149.309
G0 F7200.000 X142.088 Y149.239
G1 F1800.000 X149.239 Y142.088 E656.61799
G0 X149.309 Y142.018
G0 F7200.000 X149.239 Y142.654
G1 F1800.000 X142.653 Y149.239 E656.78371
G0 X142.583 Y149.309
G0 F7200.000 X143.219 Y149.239
G1 F1800.000 X149.239 Y143.220 E656.93519
G0 X149.309 Y143.150
G0 F7200.000 X149.239 Y143.785
G1 F1800.000 X143.785 Y149.239 E657.07244
G0 X143.715 Y149.309
G0 F7200.000 X144.350 Y149.239
G1 F1800.000 X149.239 Y144.351 E657.19546
G0 X149.309 Y144.281
G1 F1800.000 X144.916 Y149.239 E657.30423
G0 F7200.000 X145.482 Y149.239
G1 F1800.000 X149.239 Y145.482 E657.39878
G0 X149.309 Y145.412
G0 F7200.000 X149.239 Y146.048
G1 F1800.000 X146.047 Y149.239 E657.47909
G0 X145.977 Y149.309
G0 F7200.000 X146.613 Y149.239
G1 F1800.000 X149.239 Y146.614 E657.54516
G0 X149.309 Y146.544
G0 F7200.000 X149.239 Y147.180
G1 F1800.000 X147.179 Y149.239 E657.59699
G0 X147.109 Y149.309
G0 F7200.000 X147.745 Y149.239
G1 F1800.000 X149.239 Y147.745 E657.63458
G0 X149.309 Y147.675
G0 F7200.000 X149.239 Y148.311
G1 F1800.000 X148.310 Y149.239 E657.65795
G0 X148.240 Y149.309
G0 F7200.000 X148.876 Y149.239
G1 F1800.000 X149.239 Y148.877 E657.66707
G0 F7200.00000 X149.000 Y148.877
;LAYER:96
G0 X149.400 Y149.400 Z9.900
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y149.400 E658.00160
G1 X130.600 Y130.600 E658.33613
G1 X149.400 Y130.600 E658.67066
G1 X149.400 Y149.400 E659.00519
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y149.800 E659.35396
G1 X130.200 Y130.200 E659.70272
G1 X149.800 Y130.200 E660.05149
G1 X149.800 Y149.800 E660.40026
G0 F7200.00000 X149.239 Y149.239
;TYPE:SKIN
G1 F1800.000 X130.759 Y130.759 E660.86530
G0 F7200.000 X131.325 Y130.759
G1 F1800.000 X149.239 Y148.674 E661.31611
G0 X149.309 Y148.744
G0 F7200.000 X149.239 Y148.108
G1 F1800.000 X131.890 Y130.759 E661.75270
G0 X131.820 Y130.689
G0 F7200.000 X132.456 Y130.759
G1 F1800.000 X149.239 Y147.542 E662.17504
G0 X149.309 Y147.612
G0 F7200.000 X149.239 Y146.977
G1 F1800.000 X133.022 Y130.759 E662.58315
G0 X132.952 Y130.689
G0 F7200.000 X133.588 Y130.759
G1 F1800.000 X149.239 Y146.411 E662.97701
G0 X149.309 Y146.481
G0 F7200.000 X149.239 Y145.845
G1 F1800.000 X134.153 Y130.759 E663.35665
G0 X134.083 Y130.689
G0 F7200.000 X134.719 Y130.759
G1 F1800.000 X149.239 Y145.280 E663.72205
G0 X149.309 Y145.350
G0 F7200.000 X149.239 Y144.714
G1 F1800.000 X135.285 Y130.759 E664.07322
G0 X135.215 Y130.689
G0 F7200.000 X135.850 Y130.759
G1 F1800.000 X149.239 Y144.148 E664.41015
G0 X149.309 Y144.218
G1 F1800.000 X136.416 Y130.759 E664.73283
G0 F7200.000 X136.982 Y130.759
G1 F1800.000 X149.239 Y143.017 E665.04129
G0 X149.309 Y143.087
G0 F7200.000 X149.239 Y142.451
G1 F1800.000 X137.547 Y130.759 E665.33552
G0 X137.477 Y130.689
G0 F7200.000 X138.113 Y130.759
G1 F1800.000 X149.239 Y141.885 E665.61550
G0 X149.309 Y141.955
G0 F7200.000 X149.239 Y141.320
G1 F1800.000 X138.679 Y130.759 E665.88125
G0 X138.609 Y130.689
G0 F7200.000 X139.244 Y130.759
G1 F1800.000 X149.239 Y140.754 E666.13278
G0 X149.309 Y140.824
G0 F7200.000 X149.239 Y140.188
G1 F1800.000 X139.810 Y130.759 E666.37005
G0 X139.740 Y130.689
G0 F7200.000 X140.376 Y130.759
G1 F1800.000 X149.239 Y139.623 E666.59310
G0 X149.309 Y139.693
G0 F7200.000 X149.239 Y139.057
G1 F1800.000 X140.941 Y130.759 E666.80192
G0 X140.871 Y130.689
G0 F7200.000 X141.507 Y130.759
G1 F1800.000 X149.239 Y138.491 E666.99649
G0 X149.309 Y138.561
G1 F1800.000 X142.073 Y130.759 E667.17684
G0 F7200.000 X142.638 Y130.759
G1 F1800.000 X149.239 Y137.360 E667.34295
G0 X149.309 Y137.430
G0 F7200.000 X149.239 Y136.794
G1 F1800.000 X143.204 Y130.759 E667.49482
G0 X143.134 Y130.689
G0 F7200.000 X143.770 Y130.759
G1 F1800.000 X149.239 Y136.229 E667.63246
G0 X149.309 Y136.299
G0 F7200.000 X149.239 Y135.663
G1 F1800.000 X144.336 Y130.759 E667.75585
G0 X144.266 Y130.689
G0 F7200.000 X144.901 Y130.759
G1 F1800.000 X149.239 Y135.097 E667.86502
G0 X149.309 Y135.167
G0 F7200.000 X149.239 Y134.532
G1 F1800.000 X145.467 Y130.759 E667.95995
G0 X145.397 Y130.689
G0 F7200.000 X146.033 Y130.759
G1 F1800.000 X149.239 Y133.966 E668.04064
G0 X149.309 Y134.036
G0 F7200.000 X149.239 Y133.400
G1 F1800.000 X146.598 Y130.759 E668.10710
G0 X146.528 Y130.689
G0 F7200.000 X147.164 Y130.759
G1 F1800.000 X149.239 Y132.834 E668.15932
G0 X149.309 Y132.904
G1 F1800.000 X147.730 Y130.759 E668.19731
G0 F7200.000 X148.295 Y130.759
G1 F1800.000 X149.239 Y131.703 E668.22106
G0 X149.309 Y131.773
G0 F7200.000 X149.239 Y131.137
G1 F1800.000 X148.861 Y130.759 E668.23057
G0 F7200.00000 X130.759 Y131.325
G1 F1800.000 X148.673 Y149.239 E668.68137
G0 X148.743 Y149.309
G0 F7200.000 X148.107 Y149.239
G1 F1800.000 X130.759 Y131.890 E669.11795
G0 X130.689 Y131.820
G0 F7200.000 X130.759 Y132.456
G1 F1800.000 X147.542 Y149.239 E669.54029
G0 X147.612 Y149.309
G0 F7200.000 X146.976 Y149.239
G1 F1800.000 X130.759 Y133.022 E669.94838
G0 X130.689 Y132.952
G0 F7200.000 X130.759 Y133.588
G1 F1800.000 X146.410 Y149.239 E670.34224
G0 X146.480 Y149.309
G0 F7200.000 X145.845 Y149.239
G1 F1800.000 X130.759 Y134.153 E670.72187
G0 X130.689 Y134.083
G0 F7200.000 X130.759 Y134.719
G1 F1800.000 X145.279 Y149.239 E671.08726
G0 X145.349 Y149.309
G0 F7200.000 X144.713 Y149.239
G1 F1800.000 X130.759 Y135.285 E671.43841
G0 X130.689 Y135.215
G0 F7200.000 X130.759 Y135.850
G1 F1800.000 X144.147 Y149.239 E671.77533
G0 X144.217 Y149.309
G1 F1800.000 X130.759 Y136.416 E672.09802
G0 F7200.000 X130.759 Y136.982
G1 F1800.000 X143.016 Y149.239 E672.40646
G0 X143.086 Y149.309
G0 F7200.000 X142.450 Y149.239
G1 F1800.000 X130.759 Y137.547 E672.70068
G0 X130.689 Y137.477
G0 F7200.000 X130.759 Y138.113
G1 F1800.000 X141.885 Y149.239 E672.98066
G0 X141.955 Y149.309
G0 F7200.000 X141.319 Y149.239
G1 F1800.000 X130.759 Y138.679 E673.24640
G0 X130.689 Y138.609
G0 F7200.000 X130.759 Y139.244
G1 F1800.000 X140.753 Y149.239 E673.49791
G0 X140.823 Y149.309
G0 F7200.000 X140.188 Y149.239
G1 F1800.000 X130.759 Y139.810 E673.73519
G0 X130.689 Y139.740
G0 F7200.000 X130.759 Y140.376
G1 F1800.000 X139.622 Y149.239 E673.95822
G0 X139.692 Y149.309
G0 F7200.000 X139.056 Y149.239
G1 F1800.000 X130.759 Y140.941 E674.16703
G0 X130.689 Y140.871
G0 F7200.000 X130.759 Y141.507
G1 F1800.000 X138.491 Y149.239 E674.36160
G0 X138.561 Y149.309
G1 F1800.000 X130.759 Y142.073 E674.54193
G0 F7200.000 X130.759 Y142.638
G1 F1800.000 X137.359 Y149.239 E674.70803
G0 X137.429 Y149.309
G0 F7200.000 X136.794 Y149.239
G1 F1800.000 X130.759 Y143.204 E674.85990
G0 X130.689 Y143.134
G0 F7200.000 X130.759 Y143.770
G1 F1800.000 X136.228 Y149.239 E674.99753
G0 X136.298 Y149.309
G0 F7200.000 X135.662 Y149.239
G1 F1800.000 X130.759 Y144.336 E675.12091
G0 X130.689 Y144.266
G0 F7200.000 X130.759 Y144.901
G1 F1800.000 X135.096 Y149.239 E675.23006
G0 X135.166 Y149.309
G0 F7200.000 X134.531 Y149.239
G1 F1800.000 X130.759 Y145.467 E675.32498
G0 X130.689 Y145.397
G0 F7200.000 X130.759 Y146.033
G1 F1800.000 X133.965 Y149.239 E675.40566
G0 X134.035 Y149.309
G0 F7200.000 X133.399 Y149.239
G1 F1800.000 X130.759 Y146.598 E675.47211
G0 X130.689 Y146.528
G0 F7200.000 X130.759 Y147.164
G1 F1800.000 X132.834 Y149.239 E675.52433
G0 X132.904 Y149.309
G1 F1800.000 X130.759 Y147.730 E675.56230
G0 F7200.000 X130.759 Y148.295
G1 F1800.000 X131.702 Y149.239 E675.58604
G0 X131.772 Y149.309
G0 F7200.000 X131.137 Y149.239
G1 F1800.000 X130.759 Y148.861 E675.59556
G0 F7200.00000 X131.000 Y148.861
;LAYER:97
G0 X130.600 Y149.400 Z10.000
;TYPE:WALL-INNER
G1 F3600.000 X130.600 Y130.600 E675.93009
G1 X149.400 Y130.600 E676.26462
G1 X149.400 Y149.400 E676.59915
G1 X130.600 Y149.400 E676.93368
;TYPE:WALL-OUTER
G1 F1800.000 X130.200 Y130.200 E677.28244
G1 X149.800 Y130.200 E677.63121
G1 X149.800 Y149.800 E677.97997
G1 X130.200 Y149.800 E678.32874
;TYPE:SKIN
G1 F1800.000 X149.239 Y130.775 E678.79340
G1 F1800.000 X130.759 Y148.688 E679.24457
G1 F1800.000 X148.123 Y130.759 E679.68154
G1 F1800.000 X130.759 Y147.557 E680.10425
G1 F1800.000 X146.991 Y130.759 E680.51273
G1 F1800.000 X130.759 Y146.426 E680.90698
G1 F1800.000 X145.860 Y130.759 E681.28700
G1 F1800.000 X130.759 Y145.294 E681.65277
G1 F1800.000 X144.729 Y130.759 E682.00432
G1 F1800.000 X130.759 Y144.163 E682.34163
G1 F1800.000 X143.597 Y130.759 E682.66469
G1 F1800.000 X130.759 Y143.032 E682.97354
G1 F1800.000 X142.466 Y130.759 E683.26814
G1 F1800.000 X130.759 Y141.900 E683.54850
G1 F1800.000 X141.335 Y130.759 E683.81465
G1 F1800.000 X130.759 Y140.769 E684.06654
G1 F1800.000 X140.203 Y130.759 E684.30420
G1 F1800.000 X130.759 Y139.638 E684.52764
G1 F1800.000 X139.072 Y130.759 E684.73683
G1 F1800.000 X130.759 Y138.506 E684.93178
G1 F1800.000 X137.940 Y130.759 E685.11249
G1 F1800.000 X130.759 Y137.375 E685.27898
G1 F1800.000 X136.809 Y130.759 E685.43123
G1 F1800.000 X130.759 Y136.243 E685.56923
G1 F1800.000 X135.678 Y130.759 E685.69302
G1 F1800.000 X130.759 Y135.112 E685.80256
G1 F1800.000 X134.546 Y130.759 E685.89786
G1 F1800.000 X130.759 Y133.981 E685.97894
G1 F1800.000 X133.415 Y130.759 E686.04578
G1 F1800.000 X130.759 Y132.849 E686.09837
G1 F1800.000 X132.284 Y130.759 E686.13675
G1 F1800.000 X130.759 Y131.718 E686.16088
G1 F1800.000 X131.152 Y130.759 E686.17077
G1 F1800.000 X131.340 Y149.239 E686.62120
G1 F1800.000 X149.239 Y131.906 E687.05739
G1 F1800.000 X132.471 Y149.239 E687.47934
G1 F1800.000 X149.239 Y133.037 E687.88706
G1 F1800.000 X133.602 Y149.239 E688.28055
G1 F1800.000 X149.239 Y134.169 E688.65979
G1 F1800.000 X134.734 Y149.239 E689.02481
G1 F1800.000 X149.239 Y135.300 E689.37559
G1 F1800.000 X135.865 Y149.239 E689.71213
G1 F1800.000 X149.239 Y136.432 E690.03443
G1 F1800.000 X136.996 Y149.239 E690.34251
G1 F1800.000 X149.239 Y137.563 E690.63635
G1 F1800.000 X138.128 Y149.239 E690.91594
G1 F1800.000 X149.239 Y138.694 E691.18130
G1 F1800.000 X139.259 Y149.239 E691.43243
G1 F1800.000 X149.239 Y139.826 E691.66932
G1 F1800.000 X140.391 Y149.239 E691.89198
G1 F1800.000 X149.239 Y140.957 E692.10041
G1 F1800.000 X141.522 Y149.239 E692.29459
G1 F1800.000 X149.239 Y142.088 E692.47454
G1 F1800.000 X142.653 Y149.239 E692.64027
G1 F1800.000 X149.239 Y143.220 E692.79175
G1 F1800.000 X143.785 Y149.239 E692.92899
G1 F1800.000 X149.239 Y144.351 E693.05201
G1 F1800.000 X144.916 Y149.239 E693.16079
G1 F1800.000 X149.239 Y145.482 E693.25533
G1 F1800.000 X146.047 Y149.239 E693.33564
G1 F1800.000 X149.239 Y146.614 E693.40171
G1 F1800.000 X147.179 Y149.239 E693.45354
G1 F1800.000 X149.239 Y147.745 E693.49114
G1 F1800.000 X148.310 Y149.239 E693.51450
G1 F1800.000 X149.239 Y148.877 E693.52363
;End GCode
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+10 E-5 F12000 ;move Z up a bit and retract filament even more
G90 ;absolute positioning
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
;G1 Y230 F3000 ;move Y so the head is out of the way and Plate is moved forward
M84 ;steppers off
;G90 ;absolute positioning
;{profile_string}
M104 S0.000
;End of Gcode
;SETTING_1 [general]\nversion = 1\nname = Current settings\nweight = 0\n\n[setti
;SETTING_1 ngs]\nadhesion_type = skirt\nretraction_extra_prime_amount = 0.1\nmat
;SETTING_1 erial_flow = 107\ninfill_sparse_density = 20.0\nretraction_hop = 0.3\
;SETTING_1 nlayer_height = 0.1\nsupport_enable = False\nmaterial_print_temperatu
;SETTING_1 re = 210\nretraction_min_travel = 20\nretraction_speed = 110\nretract
;SETTING_1 ion_amount = 6.5\nmaterial_bed_temperature = 60\n\n
Gcode from Matter Control w/ Cura slicer
;Generated with Cura_SteamEngine 13.11.2
; automatic settings before start_gcode
G21 ; set units to millimeters
M107 ; fan off
T0 ; set the active extruder to 0
; settings from start_gcode
G28
M104 S210
M190 S60
M109 S210
; BEGINNING OF HEAD MOVEMENT WARNING TONES
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M117 KEEP HANDS AWAY
G4 S3
; END OF HEAD WARNING TONES
; automatic settings after start_gcode
G90 ; use absolute coordinates
G92 E0 ; reset the expected extruder position
M82 ; use absolute distance for extrusion
;Layer count: 99
;LAYER:0
M107
G0 F6000 X11.35 Y-13.25 Z0.35
;TYPE:SKIRT
G1 F6000 E0.00000
G1 F900 X13.25 Y-11.35 E0.19591
G1 X13.25 Y11.35 E1.84690
G1 X11.35 Y13.25 E2.04281
G1 X-11.35 Y13.25 E3.69380
G1 X-13.25 Y11.35 E3.88971
G1 X-13.25 Y-11.35 E5.54070
G1 X-11.35 Y-13.25 E5.73661
G1 X11.35 Y-13.25 E7.38760
G0 F6000 X11.55 Y-13.75
G1 F900 X13.75 Y-11.55 E7.61366
G1 X13.75 Y11.55 E9.29477
G1 X11.55 Y13.75 E9.52083
G1 X-11.55 Y13.75 E11.20194
G1 X-13.75 Y11.55 E11.42800
G1 X-13.75 Y-11.55 E13.10911
G1 X-11.55 Y-13.75 E13.33517
G1 X11.55 Y-13.75 E15.01628
G0 F6000 X9.49 Y-9.40
G0 X8.75 Y-8.75
;TYPE:WALL-INNER
G1 F900 X8.75 Y8.75 E16.28952
G1 X-8.75 Y8.75 E17.56276
G1 X-8.75 Y-8.75 E18.83600
G1 X8.75 Y-8.75 E20.10924
G0 F6000 X9.25 Y-9.25
G1 F900 X9.25 Y9.25 E21.45523
G1 X-9.25 Y9.25 E22.80123
G1 X-9.25 Y-9.25 E24.14723
G1 X9.25 Y-9.25 E25.49322
G0 F6000 X9.75 Y-9.75
;TYPE:WALL-OUTER
G1 F900 X9.75 Y9.75 E26.91197
G1 X-9.75 Y9.75 E28.33073
G1 X-9.75 Y-9.75 E29.74948
G1 X9.75 Y-9.75 E31.16823
G0 F6000 X9.40 Y-9.49
G0 X8.04 Y-8.57
;TYPE:FILL
G1 F900 X8.57 Y-8.04 E31.22297
G0 F6000 X8.57 Y-7.34
G1 F900 X7.34 Y-8.57 E31.35046
G0 F6000 X6.63 Y-8.57
G1 F900 X8.57 Y-6.63 E31.55069
G0 F6000 X8.57 Y-5.92
G1 F900 X5.92 Y-8.57 E31.82366
G0 F6000 X5.21 Y-8.57
G1 F900 X8.57 Y-5.21 E32.16938
G0 F6000 X8.57 Y-4.51
G1 F900 X4.51 Y-8.57 E32.58785
G0 F6000 X3.80 Y-8.57
G1 F900 X8.57 Y-3.80 E33.07917
G0 F6000 X8.57 Y-3.09
G1 F900 X3.09 Y-8.57 E33.64323
G0 F6000 X2.38 Y-8.57
G1 F900 X8.57 Y-2.38 E34.28003
G0 F6000 X8.57 Y-1.68
G1 F900 X1.68 Y-8.57 E34.98959
G0 F6000 X0.97 Y-8.57
G1 F900 X8.57 Y-0.97 E35.77188
G0 F6000 X8.57 Y-0.26
G1 F900 X0.26 Y-8.57 E36.62693
G0 F6000 X-0.44 Y-8.57
G1 F900 X8.57 Y0.44 E37.55461
G0 F6000 X8.57 Y1.15
G1 F900 X-1.15 Y-8.57 E38.55504
G0 F6000 X-1.86 Y-8.57
G1 F900 X8.57 Y1.86 E39.62822
G0 F6000 X8.57 Y2.56
G1 F900 X-2.56 Y-8.57 E40.77414
G0 F6000 X-3.27 Y-8.57
G1 F900 X8.57 Y3.27 E41.99291
G0 F6000 X8.57 Y3.98
G1 F900 X-3.98 Y-8.57 E43.28443
G0 F6000 X-4.68 Y-8.57
G1 F900 X8.57 Y4.68 E44.64869
G0 F6000 X8.57 Y5.39
G1 F900 X-5.39 Y-8.57 E46.08570
G0 F6000 X-6.10 Y-8.57
G1 F900 X8.57 Y6.10 E47.59545
G0 F6000 X8.57 Y6.81
G1 F900 X-6.81 Y-8.57 E49.17795
G0 F6000 X-7.51 Y-8.57
G1 F900 X8.57 Y7.51 E50.83320
G0 F6000 X8.57 Y8.22
G1 F900 X-8.22 Y-8.57 E52.56119
G0 F6000 X-8.57 Y-8.22
G1 F900 X8.22 Y8.57 E54.28918
G0 F6000 X7.51 Y8.57
G1 F900 X-8.57 Y-7.51 E55.94442
G0 F6000 X-8.57 Y-6.81
G1 F900 X6.81 Y8.57 E57.52692
G0 F6000 X6.10 Y8.57
G1 F900 X-8.57 Y-6.10 E59.03667
G0 F6000 X-8.57 Y-5.39
G1 F900 X5.39 Y8.57 E60.47368
G0 F6000 X4.68 Y8.57
G1 F900 X-8.57 Y-4.68 E61.83794
G0 F6000 X-8.57 Y-3.98
G1 F900 X3.98 Y8.57 E63.12946
G0 F6000 X3.27 Y8.57
G1 F900 X-8.57 Y-3.27 E64.34823
G0 F6000 X-8.57 Y-2.56
G1 F900 X2.56 Y8.57 E65.49415
G0 F6000 X1.86 Y8.57
G1 F900 X-8.57 Y-1.86 E66.56733
G0 F6000 X-8.57 Y-1.15
G1 F900 X1.15 Y8.57 E67.56776
G0 F6000 X0.44 Y8.57
G1 F900 X-8.57 Y-0.44 E68.49545
G0 F6000 X-8.57 Y0.26
G1 F900 X-0.26 Y8.57 E69.35049
G0 F6000 X-0.97 Y8.57
G1 F900 X-8.57 Y0.97 E70.13279
G0 F6000 X-8.57 Y1.68
G1 F900 X-1.68 Y8.57 E70.84234
G0 F6000 X-2.38 Y8.57
G1 F900 X-8.57 Y2.38 E71.47915
G0 F6000 X-8.57 Y3.09
G1 F900 X-3.09 Y8.57 E72.04321
G0 F6000 X-3.80 Y8.57
G1 F900 X-8.57 Y3.80 E72.53453
G0 F6000 X-8.57 Y4.51
G1 F900 X-4.51 Y8.57 E72.95299
G0 F6000 X-5.21 Y8.57
G1 F900 X-8.57 Y5.21 E73.29871
G0 F6000 X-8.57 Y5.92
G1 F900 X-5.92 Y8.57 E73.57169
G0 F6000 X-6.63 Y8.57
G1 F900 X-8.57 Y6.63 E73.77192
G0 F6000 X-8.57 Y7.34
G1 F900 X-7.34 Y8.57 E73.89940
G0 F6000 X-8.04 Y8.57
G1 F900 X-8.57 Y8.04 E73.95414
;LAYER:1
M106 S58
G0 F12000 X-8.75 Y8.75 Z0.45
;TYPE:WALL-INNER
G1 F1080 X-8.75 Y-8.75 E74.31793
G1 X8.75 Y-8.75 E74.68171
G1 X8.75 Y8.75 E75.04549
G1 X-8.75 Y8.75 E75.40927
G0 F12000 X-9.25 Y9.25
G1 F1080 X-9.25 Y-9.25 E75.79385
G1 X9.25 Y-9.25 E76.17842
G1 X9.25 Y9.25 E76.56299
G1 X-9.25 Y9.25 E76.94756
G0 F12000 X-9.75 Y9.75
;TYPE:WALL-OUTER
G1 F1080 X-9.75 Y-9.75 E77.35291
G1 X9.75 Y-9.75 E77.75827
G1 X9.75 Y9.75 E78.16363
G1 X-9.75 Y9.75 E78.56899
G0 F12000 X-9.49 Y9.40
G0 X-8.22 Y8.57
;TYPE:FILL
G1 F1080 X8.57 Y-8.22 E79.06270
G0 F12000 X8.22 Y-8.57
G1 F1080 X-8.57 Y8.22 E79.55641
G0 F12000 X-8.57 Y7.51
G1 F1080 X7.51 Y-8.57 E80.02934
G0 F12000 X6.81 Y-8.57
G1 F1080 X-8.57 Y6.81 E80.48148
G0 F12000 X-8.57 Y6.10
G1 F1080 X6.10 Y-8.57 E80.91284
G0 F12000 X5.39 Y-8.57
G1 F1080 X-8.57 Y5.39 E81.32341
G0 F12000 X-8.57 Y4.68
G1 F1080 X4.68 Y-8.57 E81.71320
G0 F12000 X3.98 Y-8.57
G1 F1080 X-8.57 Y3.98 E82.08221
G0 F12000 X-8.57 Y3.27
G1 F1080 X3.27 Y-8.57 E82.43043
G0 F12000 X2.56 Y-8.57
G1 F1080 X-8.57 Y2.56 E82.75783
G0 F12000 X-8.57 Y1.86
G1 F1080 X1.86 Y-8.57 E83.06445
G0 F12000 X1.15 Y-8.57
G1 F1080 X-8.57 Y1.15 E83.35029
G0 F12000 X-8.57 Y0.44
G1 F1080 X0.44 Y-8.57 E83.61535
G0 F12000 X-0.26 Y-8.57
G1 F1080 X-8.57 Y-0.26 E83.85964
G0 F12000 X-8.57 Y-0.97
G1 F1080 X-0.97 Y-8.57 E84.08316
G0 F12000 X-1.68 Y-8.57
G1 F1080 X-8.57 Y-1.68 E84.28589
G0 F12000 X-8.57 Y-2.38
G1 F1080 X-2.38 Y-8.57 E84.46783
G0 F12000 X-3.09 Y-8.57
G1 F1080 X-8.57 Y-3.09 E84.62899
G0 F12000 X-8.57 Y-3.80
G1 F1080 X-3.80 Y-8.57 E84.76937
G0 F12000 X-4.51 Y-8.57
G1 F1080 X-8.57 Y-4.51 E84.88893
G0 F12000 X-8.57 Y-5.21
G1 F1080 X-5.21 Y-8.57 E84.98771
G0 F12000 X-5.92 Y-8.57
G1 F1080 X-8.57 Y-5.92 E85.06570
G0 F12000 X-8.57 Y-6.63
G1 F1080 X-6.63 Y-8.57 E85.12291
G0 F12000 X-7.34 Y-8.57
G1 F1080 X-8.57 Y-7.34 E85.15933
G0 F12000 X-8.57 Y-8.04
G1 F1080 X-8.04 Y-8.57 E85.17497
G0 F12000 X8.57 Y-7.51
G1 F1080 X-7.51 Y8.57 E85.64790
G0 F12000 X-6.81 Y8.57
G1 F1080 X8.57 Y-6.81 E86.10004
G0 F12000 X8.57 Y-6.10
G1 F1080 X-6.10 Y8.57 E86.53140
G0 F12000 X-5.39 Y8.57
G1 F1080 X8.57 Y-5.39 E86.94197
G0 F12000 X8.57 Y-4.68
G1 F1080 X-4.68 Y8.57 E87.33176
G0 F12000 X-3.98 Y8.57
G1 F1080 X8.57 Y-3.98 E87.70077
G0 F12000 X8.57 Y-3.27
G1 F1080 X-3.27 Y8.57 E88.04899
G0 F12000 X-2.56 Y8.57
G1 F1080 X8.57 Y-2.56 E88.37639
G0 F12000 X8.57 Y-1.86
G1 F1080 X-1.86 Y8.57 E88.68302
G0 F12000 X-1.15 Y8.57
G1 F1080 X8.57 Y-1.15 E88.96885
G0 F12000 X8.57 Y-0.44
G1 F1080 X-0.44 Y8.57 E89.23391
G0 F12000 X0.26 Y8.57
G1 F1080 X8.57 Y0.26 E89.47821
G0 F12000 X8.57 Y0.97
G1 F1080 X0.97 Y8.57 E89.70172
G0 F12000 X1.68 Y8.57
G1 F1080 X8.57 Y1.68 E89.90445
G0 F12000 X8.57 Y2.38
G1 F1080 X2.38 Y8.57 E90.08639
G0 F12000 X3.09 Y8.57
G1 F1080 X8.57 Y3.09 E90.24755
G0 F12000 X8.57 Y3.80
G1 F1080 X3.80 Y8.57 E90.38793
G0 F12000 X4.51 Y8.57
G1 F1080 X8.57 Y4.51 E90.50749
G0 F12000 X8.57 Y5.21
G1 F1080 X5.21 Y8.57 E90.60627
G0 F12000 X5.92 Y8.57
G1 F1080 X8.57 Y5.92 E90.68426
G0 F12000 X8.57 Y6.63
G1 F1080 X6.63 Y8.57 E90.74147
G0 F12000 X7.34 Y8.57
G1 F1080 X8.57 Y7.34 E90.77789
G0 F12000 X8.57 Y8.04
G1 F1080 X8.04 Y8.57 E90.79353
;LAYER:2
M106 S122
G0 F12000 X8.75 Y8.75 Z0.55
;TYPE:WALL-INNER
G1 F1200 X-8.75 Y8.75 E91.15732
G1 X-8.75 Y-8.75 E91.52110
G1 X8.75 Y-8.75 E91.88488
G1 X8.75 Y8.75 E92.24867
G0 F12000 X9.25 Y9.25
G1 F1200 X-9.25 Y9.25 E92.63324
G1 X-9.25 Y-9.25 E93.01781
G1 X9.25 Y-9.25 E93.40238
G1 X9.25 Y9.25 E93.78695
G0 F12000 X9.75 Y9.75
;TYPE:WALL-OUTER
G1 F1200 X-9.75 Y9.75 E94.19230
G1 X-9.75 Y-9.75 E94.59766
G1 X9.75 Y-9.75 E95.00302
G1 X9.75 Y9.75 E95.40838
G0 F12000 X9.40 Y9.49
G0 X8.22 Y8.57
;TYPE:FILL
G1 F1200 X-8.57 Y-8.22 E95.90209
G0 F12000 X-8.22 Y-8.57
G1 F1200 X8.57 Y8.22 E96.39580
G0 F12000 X8.57 Y7.51
G1 F1200 X-7.51 Y-8.57 E96.86873
G0 F12000 X-6.81 Y-8.57
G1 F1200 X8.57 Y6.81 E97.32087
G0 F12000 X8.57 Y6.10
G1 F1200 X-6.10 Y-8.57 E97.75223
G0 F12000 X-5.39 Y-8.57
G1 F1200 X8.57 Y5.39 E98.16280
G0 F12000 X8.57 Y4.68
G1 F1200 X-4.68 Y-8.57 E98.55259
G0 F12000 X-3.98 Y-8.57
G1 F1200 X8.57 Y3.98 E98.92160
G0 F12000 X8.57 Y3.27
G1 F1200 X-3.27 Y-8.57 E99.26982
G0 F12000 X-2.56 Y-8.57
G1 F1200 X8.57 Y2.56 E99.59722
G0 F12000 X8.57 Y1.86
G1 F1200 X-1.86 Y-8.57 E99.90384
G0 F12000 X-1.15 Y-8.57
G1 F1200 X8.57 Y1.15 E100.18968
G0 F12000 X8.57 Y0.44
G1 F1200 X-0.44 Y-8.57 E100.45474
G0 F12000 X0.26 Y-8.57
G1 F1200 X8.57 Y-0.26 E100.69903
G0 F12000 X8.57 Y-0.97
G1 F1200 X0.97 Y-8.57 E100.92255
G0 F12000 X1.68 Y-8.57
G1 F1200 X8.57 Y-1.68 E101.12528
G0 F12000 X8.57 Y-2.38
G1 F1200 X2.38 Y-8.57 E101.30722
G0 F12000 X3.09 Y-8.57
G1 F1200 X8.57 Y-3.09 E101.46838
G0 F12000 X8.57 Y-3.80
G1 F1200 X3.80 Y-8.57 E101.60876
G0 F12000 X4.51 Y-8.57
G1 F1200 X8.57 Y-4.51 E101.72832
G0 F12000 X8.57 Y-5.21
G1 F1200 X5.21 Y-8.57 E101.82710
G0 F12000 X5.92 Y-8.57
G1 F1200 X8.57 Y-5.92 E101.90509
G0 F12000 X8.57 Y-6.63
G1 F1200 X6.63 Y-8.57 E101.96230
G0 F12000 X7.34 Y-8.57
G1 F1200 X8.57 Y-7.34 E101.99872
G0 F12000 X8.57 Y-8.04
G1 F1200 X8.04 Y-8.57 E102.01436
G0 F12000 X-8.57 Y-7.51
G1 F1200 X7.51 Y8.57 E102.48729
G0 F12000 X6.81 Y8.57
G1 F1200 X-8.57 Y-6.81 E102.93943
G0 F12000 X-8.57 Y-6.10
G1 F1200 X6.10 Y8.57 E103.37079
G0 F12000 X5.39 Y8.57
G1 F1200 X-8.57 Y-5.39 E103.78136
G0 F12000 X-8.57 Y-4.68
G1 F1200 X4.68 Y8.57 E104.17115
G0 F12000 X3.98 Y8.57
G1 F1200 X-8.57 Y-3.98 E104.54016
G0 F12000 X-8.57 Y-3.27
G1 F1200 X3.27 Y8.57 E104.88838
G0 F12000 X2.56 Y8.57
G1 F1200 X-8.57 Y-2.56 E105.21578
G0 F12000 X-8.57 Y-1.86
G1 F1200 X1.86 Y8.57 E105.52241
G0 F12000 X1.15 Y8.57
G1 F1200 X-8.57 Y-1.15 E105.80824
G0 F12000 X-8.57 Y-0.44
G1 F1200 X0.44 Y8.57 E106.07330
G0 F12000 X-0.26 Y8.57
G1 F1200 X-8.57 Y0.26 E106.31760
G0 F12000 X-8.57 Y0.97
G1 F1200 X-0.97 Y8.57 E106.54111
G0 F12000 X-1.68 Y8.57
G1 F1200 X-8.57 Y1.68 E106.74384
G0 F12000 X-8.57 Y2.38
G1 F1200 X-2.38 Y8.57 E106.92578
G0 F12000 X-3.09 Y8.57
G1 F1200 X-8.57 Y3.09 E107.08694
G0 F12000 X-8.57 Y3.80
G1 F1200 X-3.80 Y8.57 E107.22732
G0 F12000 X-4.51 Y8.57
G1 F1200 X-8.57 Y4.51 E107.34688
G0 F12000 X-8.57 Y5.21
G1 F1200 X-5.21 Y8.57 E107.44566
G0 F12000 X-5.92 Y8.57
G1 F1200 X-8.57 Y5.92 E107.52365
G0 F12000 X-8.57 Y6.63
G1 F1200 X-6.63 Y8.57 E107.58086
G0 F12000 X-7.34 Y8.57
G1 F1200 X-8.57 Y7.34 E107.61728
G0 F12000 X-8.57 Y8.04
G1 F1200 X-8.04 Y8.57 E107.63292
;LAYER:3
M106 S153
G0 F12000 X-8.75 Y8.75 Z0.65
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E107.99671
G1 X8.75 Y-8.75 E108.36049
G1 X8.75 Y8.75 E108.72427
G1 X-8.75 Y8.75 E109.08806
G1 F540 X-9.25 Y-9.25 E109.47263
G1 X9.25 Y-9.25 E109.85720
G1 X9.25 Y9.25 E110.24177
G1 X-9.25 Y9.25 E110.62634
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E111.03169
G1 X9.75 Y-9.75 E111.43705
G1 X9.75 Y9.75 E111.84241
G1 X-9.75 Y9.75 E112.24777
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E112.71726
G0 F12000 X7.40 Y-8.57
G1 F540 X-8.57 Y7.40 E113.18674
G0 F12000 X-8.57 Y5.04
G1 F540 X5.04 Y-8.57 E113.58697
G0 F12000 X2.68 Y-8.57
G1 F540 X-8.57 Y2.68 E113.91793
G0 F12000 X-8.57 Y0.33
G1 F540 X0.33 Y-8.57 E114.17963
G0 F12000 X-2.03 Y-8.57
G1 F540 X-8.57 Y-2.03 E114.37210
G0 F12000 X-8.57 Y-4.38
G1 F540 X-4.38 Y-8.57 E114.49528
G0 F12000 X-6.74 Y-8.57
G1 F540 X-8.57 Y-6.74 E114.54920
G0 F12000 X-5.04 Y8.57
G1 F540 X8.57 Y-5.04 E114.94942
G0 F12000 X8.57 Y-2.68
G1 F540 X-2.68 Y8.57 E115.28039
G0 F12000 X-0.33 Y8.57
G1 F540 X8.57 Y-0.33 E115.54209
G0 F12000 X8.57 Y2.03
G1 F540 X2.03 Y8.57 E115.73456
G0 F12000 X4.38 Y8.57
G1 F540 X8.57 Y4.38 E115.85774
G0 F12000 X8.57 Y6.74
G1 F540 X6.74 Y8.57 E115.91165
;LAYER:4
G0 F12000 X8.75 Y8.75 Z0.75
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E116.27543
G1 X-8.75 Y-8.75 E116.63922
G1 X8.75 Y-8.75 E117.00300
G1 X8.75 Y8.75 E117.36678
G1 F540 X-9.25 Y9.25 E117.75135
G1 X-9.25 Y-9.25 E118.13592
G1 X9.25 Y-9.25 E118.52049
G1 X9.25 Y9.25 E118.90506
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E119.31042
G1 X-9.75 Y-9.75 E119.71578
G1 X9.75 Y-9.75 E120.12114
G1 X9.75 Y9.75 E120.52649
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E120.99598
G0 F12000 X-7.40 Y-8.57
G1 F540 X8.57 Y7.40 E121.46547
G0 F12000 X8.57 Y5.04
G1 F540 X-5.04 Y-8.57 E121.86570
G0 F12000 X-2.68 Y-8.57
G1 F540 X8.57 Y2.68 E122.19666
G0 F12000 X8.57 Y0.33
G1 F540 X-0.33 Y-8.57 E122.45836
G0 F12000 X2.03 Y-8.57
G1 F540 X8.57 Y-2.03 E122.65083
G0 F12000 X8.57 Y-4.38
G1 F540 X4.38 Y-8.57 E122.77401
G0 F12000 X6.74 Y-8.57
G1 F540 X8.57 Y-6.74 E122.82792
G0 F12000 X5.04 Y8.57
G1 F540 X-8.57 Y-5.04 E123.22815
G0 F12000 X-8.57 Y-2.68
G1 F540 X2.68 Y8.57 E123.55911
G0 F12000 X0.33 Y8.57
G1 F540 X-8.57 Y-0.33 E123.82081
G0 F12000 X-8.57 Y2.03
G1 F540 X-2.03 Y8.57 E124.01328
G0 F12000 X-4.38 Y8.57
G1 F540 X-8.57 Y4.38 E124.13646
G0 F12000 X-8.57 Y6.74
G1 F540 X-6.74 Y8.57 E124.19038
;LAYER:5
G0 F12000 X-8.75 Y8.75 Z0.85
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E124.55416
G1 X8.75 Y-8.75 E124.91794
G1 X8.75 Y8.75 E125.28173
G1 X-8.75 Y8.75 E125.64551
G1 F540 X-9.25 Y-9.25 E126.03008
G1 X9.25 Y-9.25 E126.41465
G1 X9.25 Y9.25 E126.79922
G1 X-9.25 Y9.25 E127.18379
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E127.58915
G1 X9.75 Y-9.75 E127.99451
G1 X9.75 Y9.75 E128.39986
G1 X-9.75 Y9.75 E128.80522
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E129.27471
G1 F540 X-8.57 Y7.40 E129.74420
G1 F540 X5.04 Y-8.57 E130.14442
G1 F540 X-8.57 Y2.68 E130.47539
G1 F540 X0.33 Y-8.57 E130.73709
G1 F540 X-8.57 Y-2.03 E130.92956
G1 F540 X-4.38 Y-8.57 E131.05273
G1 F540 X-8.57 Y-6.74 E131.10665
G1 F540 X8.57 Y-5.04 E131.50688
G1 F540 X-2.68 Y8.57 E131.83784
G1 F540 X8.57 Y-0.33 E132.09954
G1 F540 X2.03 Y8.57 E132.29201
G1 F540 X8.57 Y4.38 E132.41519
G1 F540 X6.74 Y8.57 E132.46911
;LAYER:6
G0 F12000 X8.75 Y8.75 Z0.95
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E132.83289
G1 X-8.75 Y-8.75 E133.19667
G1 X8.75 Y-8.75 E133.56045
G1 X8.75 Y8.75 E133.92424
G1 F540 X-9.25 Y9.25 E134.30881
G1 X-9.25 Y-9.25 E134.69338
G1 X9.25 Y-9.25 E135.07795
G1 X9.25 Y9.25 E135.46252
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E135.86788
G1 X-9.75 Y-9.75 E136.27323
G1 X9.75 Y-9.75 E136.67859
G1 X9.75 Y9.75 E137.08395
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E137.55344
G1 F540 X8.57 Y7.40 E138.02292
G1 F540 X-5.04 Y-8.57 E138.42315
G1 F540 X8.57 Y2.68 E138.75411
G1 F540 X-0.33 Y-8.57 E139.01581
G1 F540 X8.57 Y-2.03 E139.20828
G1 F540 X4.38 Y-8.57 E139.33146
G1 F540 X8.57 Y-6.74 E139.38538
G1 F540 X-8.57 Y-5.04 E139.78560
G1 F540 X2.68 Y8.57 E140.11657
G1 F540 X-8.57 Y-0.33 E140.37827
G1 F540 X-2.03 Y8.57 E140.57074
G1 F540 X-8.57 Y4.38 E140.69392
G1 F540 X-6.74 Y8.57 E140.74783
;LAYER:7
G0 F12000 X-8.75 Y8.75 Z1.05
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E141.11161
G1 X8.75 Y-8.75 E141.47540
G1 X8.75 Y8.75 E141.83918
G1 X-8.75 Y8.75 E142.20296
G1 F540 X-9.25 Y-9.25 E142.58753
G1 X9.25 Y-9.25 E142.97210
G1 X9.25 Y9.25 E143.35667
G1 X-9.25 Y9.25 E143.74124
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E144.14660
G1 X9.75 Y-9.75 E144.55196
G1 X9.75 Y9.75 E144.95732
G1 X-9.75 Y9.75 E145.36268
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E145.83216
G1 F540 X-8.57 Y7.40 E146.30165
G1 F540 X5.04 Y-8.57 E146.70188
G1 F540 X-8.57 Y2.68 E147.03284
G1 F540 X0.33 Y-8.57 E147.29454
G1 F540 X-8.57 Y-2.03 E147.48701
G1 F540 X-4.38 Y-8.57 E147.61019
G1 F540 X-8.57 Y-6.74 E147.66410
G1 F540 X8.57 Y-5.04 E148.06433
G1 F540 X-2.68 Y8.57 E148.39529
G1 F540 X8.57 Y-0.33 E148.65700
G1 F540 X2.03 Y8.57 E148.84946
G1 F540 X8.57 Y4.38 E148.97264
G1 F540 X6.74 Y8.57 E149.02656
;LAYER:8
G0 F12000 X8.75 Y8.75 Z1.15
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E149.39034
G1 X-8.75 Y-8.75 E149.75412
G1 X8.75 Y-8.75 E150.11791
G1 X8.75 Y8.75 E150.48169
G1 F540 X-9.25 Y9.25 E150.86626
G1 X-9.25 Y-9.25 E151.25083
G1 X9.25 Y-9.25 E151.63540
G1 X9.25 Y9.25 E152.01997
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E152.42533
G1 X-9.75 Y-9.75 E152.83069
G1 X9.75 Y-9.75 E153.23604
G1 X9.75 Y9.75 E153.64140
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E154.11089
G1 F540 X8.57 Y7.40 E154.58038
G1 F540 X-5.04 Y-8.57 E154.98060
G1 F540 X8.57 Y2.68 E155.31157
G1 F540 X-0.33 Y-8.57 E155.57327
G1 F540 X8.57 Y-2.03 E155.76574
G1 F540 X4.38 Y-8.57 E155.88892
G1 F540 X8.57 Y-6.74 E155.94283
G1 F540 X-8.57 Y-5.04 E156.34306
G1 F540 X2.68 Y8.57 E156.67402
G1 F540 X-8.57 Y-0.33 E156.93572
G1 F540 X-2.03 Y8.57 E157.12819
G1 F540 X-8.57 Y4.38 E157.25137
G1 F540 X-6.74 Y8.57 E157.30529
;LAYER:9
G0 F12000 X-8.75 Y8.75 Z1.25
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E157.66907
G1 X8.75 Y-8.75 E158.03285
G1 X8.75 Y8.75 E158.39663
G1 X-8.75 Y8.75 E158.76042
G1 F540 X-9.25 Y-9.25 E159.14499
G1 X9.25 Y-9.25 E159.52956
G1 X9.25 Y9.25 E159.91413
G1 X-9.25 Y9.25 E160.29870
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E160.70406
G1 X9.75 Y-9.75 E161.10941
G1 X9.75 Y9.75 E161.51477
G1 X-9.75 Y9.75 E161.92013
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E162.38962
G1 F540 X-8.57 Y7.40 E162.85910
G1 F540 X5.04 Y-8.57 E163.25933
G1 F540 X-8.57 Y2.68 E163.59029
G1 F540 X0.33 Y-8.57 E163.85200
G1 F540 X-8.57 Y-2.03 E164.04446
G1 F540 X-4.38 Y-8.57 E164.16764
G1 F540 X-8.57 Y-6.74 E164.22156
G1 F540 X8.57 Y-5.04 E164.62178
G1 F540 X-2.68 Y8.57 E164.95275
G1 F540 X8.57 Y-0.33 E165.21445
G1 F540 X2.03 Y8.57 E165.40692
G1 F540 X8.57 Y4.38 E165.53010
G1 F540 X6.74 Y8.57 E165.58401
;LAYER:10
G0 F12000 X8.75 Y8.75 Z1.35
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E165.94780
G1 X-8.75 Y-8.75 E166.31158
G1 X8.75 Y-8.75 E166.67536
G1 X8.75 Y8.75 E167.03914
G1 F540 X-9.25 Y9.25 E167.42371
G1 X-9.25 Y-9.25 E167.80828
G1 X9.25 Y-9.25 E168.19285
G1 X9.25 Y9.25 E168.57742
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E168.98278
G1 X-9.75 Y-9.75 E169.38814
G1 X9.75 Y-9.75 E169.79350
G1 X9.75 Y9.75 E170.19886
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E170.66834
G1 F540 X8.57 Y7.40 E171.13783
G1 F540 X-5.04 Y-8.57 E171.53806
G1 F540 X8.57 Y2.68 E171.86902
G1 F540 X-0.33 Y-8.57 E172.13072
G1 F540 X8.57 Y-2.03 E172.32319
G1 F540 X4.38 Y-8.57 E172.44637
G1 F540 X8.57 Y-6.74 E172.50029
G1 F540 X-8.57 Y-5.04 E172.90051
G1 F540 X2.68 Y8.57 E173.23147
G1 F540 X-8.57 Y-0.33 E173.49318
G1 F540 X-2.03 Y8.57 E173.68565
G1 F540 X-8.57 Y4.38 E173.80882
G1 F540 X-6.74 Y8.57 E173.86274
;LAYER:11
G0 F12000 X-8.75 Y8.75 Z1.45
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E174.22652
G1 X8.75 Y-8.75 E174.59031
G1 X8.75 Y8.75 E174.95409
G1 X-8.75 Y8.75 E175.31787
G1 F540 X-9.25 Y-9.25 E175.70244
G1 X9.25 Y-9.25 E176.08701
G1 X9.25 Y9.25 E176.47158
G1 X-9.25 Y9.25 E176.85615
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E177.26151
G1 X9.75 Y-9.75 E177.66687
G1 X9.75 Y9.75 E178.07223
G1 X-9.75 Y9.75 E178.47758
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E178.94707
G1 F540 X-8.57 Y7.40 E179.41656
G1 F540 X5.04 Y-8.57 E179.81678
G1 F540 X-8.57 Y2.68 E180.14775
G1 F540 X0.33 Y-8.57 E180.40945
G1 F540 X-8.57 Y-2.03 E180.60192
G1 F540 X-4.38 Y-8.57 E180.72510
G1 F540 X-8.57 Y-6.74 E180.77901
G1 F540 X8.57 Y-5.04 E181.17924
G1 F540 X-2.68 Y8.57 E181.51020
G1 F540 X8.57 Y-0.33 E181.77190
G1 F540 X2.03 Y8.57 E181.96437
G1 F540 X8.57 Y4.38 E182.08755
G1 F540 X6.74 Y8.57 E182.14147
;LAYER:12
G0 F12000 X8.75 Y8.75 Z1.55
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E182.50525
G1 X-8.75 Y-8.75 E182.86903
G1 X8.75 Y-8.75 E183.23281
G1 X8.75 Y8.75 E183.59660
G1 F540 X-9.25 Y9.25 E183.98117
G1 X-9.25 Y-9.25 E184.36574
G1 X9.25 Y-9.25 E184.75031
G1 X9.25 Y9.25 E185.13488
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E185.54024
G1 X-9.75 Y-9.75 E185.94559
G1 X9.75 Y-9.75 E186.35095
G1 X9.75 Y9.75 E186.75631
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E187.22580
G1 F540 X8.57 Y7.40 E187.69529
G1 F540 X-5.04 Y-8.57 E188.09551
G1 F540 X8.57 Y2.68 E188.42647
G1 F540 X-0.33 Y-8.57 E188.68818
G1 F540 X8.57 Y-2.03 E188.88065
G1 F540 X4.38 Y-8.57 E189.00382
G1 F540 X8.57 Y-6.74 E189.05774
G1 F540 X-8.57 Y-5.04 E189.45796
G1 F540 X2.68 Y8.57 E189.78893
G1 F540 X-8.57 Y-0.33 E190.05063
G1 F540 X-2.03 Y8.57 E190.24310
G1 F540 X-8.57 Y4.38 E190.36628
G1 F540 X-6.74 Y8.57 E190.42019
;LAYER:13
G0 F12000 X-8.75 Y8.75 Z1.65
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E190.78398
G1 X8.75 Y-8.75 E191.14776
G1 X8.75 Y8.75 E191.51154
G1 X-8.75 Y8.75 E191.87532
G1 F540 X-9.25 Y-9.25 E192.25989
G1 X9.25 Y-9.25 E192.64447
G1 X9.25 Y9.25 E193.02904
G1 X-9.25 Y9.25 E193.41361
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E193.81896
G1 X9.75 Y-9.75 E194.22432
G1 X9.75 Y9.75 E194.62968
G1 X-9.75 Y9.75 E195.03504
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E195.50452
G1 F540 X-8.57 Y7.40 E195.97401
G1 F540 X5.04 Y-8.57 E196.37424
G1 F540 X-8.57 Y2.68 E196.70520
G1 F540 X0.33 Y-8.57 E196.96690
G1 F540 X-8.57 Y-2.03 E197.15937
G1 F540 X-4.38 Y-8.57 E197.28255
G1 F540 X-8.57 Y-6.74 E197.33647
G1 F540 X8.57 Y-5.04 E197.73669
G1 F540 X-2.68 Y8.57 E198.06766
G1 F540 X8.57 Y-0.33 E198.32936
G1 F540 X2.03 Y8.57 E198.52183
G1 F540 X8.57 Y4.38 E198.64500
G1 F540 X6.74 Y8.57 E198.69892
;LAYER:14
G0 F12000 X8.75 Y8.75 Z1.75
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E199.06270
G1 X-8.75 Y-8.75 E199.42649
G1 X8.75 Y-8.75 E199.79027
G1 X8.75 Y8.75 E200.15405
G1 F540 X-9.25 Y9.25 E200.53862
G1 X-9.25 Y-9.25 E200.92319
G1 X9.25 Y-9.25 E201.30776
G1 X9.25 Y9.25 E201.69233
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E202.09769
G1 X-9.75 Y-9.75 E202.50305
G1 X9.75 Y-9.75 E202.90841
G1 X9.75 Y9.75 E203.31376
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E203.78325
G1 F540 X8.57 Y7.40 E204.25274
G1 F540 X-5.04 Y-8.57 E204.65296
G1 F540 X8.57 Y2.68 E204.98393
G1 F540 X-0.33 Y-8.57 E205.24563
G1 F540 X8.57 Y-2.03 E205.43810
G1 F540 X4.38 Y-8.57 E205.56128
G1 F540 X8.57 Y-6.74 E205.61519
G1 F540 X-8.57 Y-5.04 E206.01542
G1 F540 X2.68 Y8.57 E206.34638
G1 F540 X-8.57 Y-0.33 E206.60808
G1 F540 X-2.03 Y8.57 E206.80055
G1 F540 X-8.57 Y4.38 E206.92373
G1 F540 X-6.74 Y8.57 E206.97765
;LAYER:15
G0 F12000 X-8.75 Y8.75 Z1.85
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E207.34143
G1 X8.75 Y-8.75 E207.70521
G1 X8.75 Y8.75 E208.06900
G1 X-8.75 Y8.75 E208.43278
G1 F540 X-9.25 Y-9.25 E208.81735
G1 X9.25 Y-9.25 E209.20192
G1 X9.25 Y9.25 E209.58649
G1 X-9.25 Y9.25 E209.97106
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E210.37642
G1 X9.75 Y-9.75 E210.78178
G1 X9.75 Y9.75 E211.18713
G1 X-9.75 Y9.75 E211.59249
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E212.06198
G1 F540 X-8.57 Y7.40 E212.53147
G1 F540 X5.04 Y-8.57 E212.93169
G1 F540 X-8.57 Y2.68 E213.26266
G1 F540 X0.33 Y-8.57 E213.52436
G1 F540 X-8.57 Y-2.03 E213.71683
G1 F540 X-4.38 Y-8.57 E213.84000
G1 F540 X-8.57 Y-6.74 E213.89392
G1 F540 X8.57 Y-5.04 E214.29415
G1 F540 X-2.68 Y8.57 E214.62511
G1 F540 X8.57 Y-0.33 E214.88681
G1 F540 X2.03 Y8.57 E215.07928
G1 F540 X8.57 Y4.38 E215.20246
G1 F540 X6.74 Y8.57 E215.25637
;LAYER:16
G0 F12000 X8.75 Y8.75 Z1.95
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E215.62016
G1 X-8.75 Y-8.75 E215.98394
G1 X8.75 Y-8.75 E216.34772
G1 X8.75 Y8.75 E216.71151
G1 F540 X-9.25 Y9.25 E217.09608
G1 X-9.25 Y-9.25 E217.48065
G1 X9.25 Y-9.25 E217.86522
G1 X9.25 Y9.25 E218.24979
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E218.65514
G1 X-9.75 Y-9.75 E219.06050
G1 X9.75 Y-9.75 E219.46586
G1 X9.75 Y9.75 E219.87122
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E220.34071
G1 F540 X8.57 Y7.40 E220.81019
G1 F540 X-5.04 Y-8.57 E221.21042
G1 F540 X8.57 Y2.68 E221.54138
G1 F540 X-0.33 Y-8.57 E221.80308
G1 F540 X8.57 Y-2.03 E221.99555
G1 F540 X4.38 Y-8.57 E222.11873
G1 F540 X8.57 Y-6.74 E222.17265
G1 F540 X-8.57 Y-5.04 E222.57287
G1 F540 X2.68 Y8.57 E222.90384
G1 F540 X-8.57 Y-0.33 E223.16554
G1 F540 X-2.03 Y8.57 E223.35801
G1 F540 X-8.57 Y4.38 E223.48119
G1 F540 X-6.74 Y8.57 E223.53510
;LAYER:17
G0 F12000 X-8.75 Y8.75 Z2.05
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E223.89888
G1 X8.75 Y-8.75 E224.26267
G1 X8.75 Y8.75 E224.62645
G1 X-8.75 Y8.75 E224.99023
G1 F540 X-9.25 Y-9.25 E225.37480
G1 X9.25 Y-9.25 E225.75937
G1 X9.25 Y9.25 E226.14394
G1 X-9.25 Y9.25 E226.52851
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E226.93387
G1 X9.75 Y-9.75 E227.33923
G1 X9.75 Y9.75 E227.74459
G1 X-9.75 Y9.75 E228.14994
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E228.61943
G1 F540 X-8.57 Y7.40 E229.08892
G1 F540 X5.04 Y-8.57 E229.48915
G1 F540 X-8.57 Y2.68 E229.82011
G1 F540 X0.33 Y-8.57 E230.08181
G1 F540 X-8.57 Y-2.03 E230.27428
G1 F540 X-4.38 Y-8.57 E230.39746
G1 F540 X-8.57 Y-6.74 E230.45137
G1 F540 X8.57 Y-5.04 E230.85160
G1 F540 X-2.68 Y8.57 E231.18256
G1 F540 X8.57 Y-0.33 E231.44426
G1 F540 X2.03 Y8.57 E231.63673
G1 F540 X8.57 Y4.38 E231.75991
G1 F540 X6.74 Y8.57 E231.81383
;LAYER:18
G0 F12000 X8.75 Y8.75 Z2.15
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E232.17761
G1 X-8.75 Y-8.75 E232.54139
G1 X8.75 Y-8.75 E232.90518
G1 X8.75 Y8.75 E233.26896
G1 F540 X-9.25 Y9.25 E233.65353
G1 X-9.25 Y-9.25 E234.03810
G1 X9.25 Y-9.25 E234.42267
G1 X9.25 Y9.25 E234.80724
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E235.21260
G1 X-9.75 Y-9.75 E235.61796
G1 X9.75 Y-9.75 E236.02331
G1 X9.75 Y9.75 E236.42867
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E236.89816
G1 F540 X8.57 Y7.40 E237.36765
G1 F540 X-5.04 Y-8.57 E237.76787
G1 F540 X8.57 Y2.68 E238.09884
G1 F540 X-0.33 Y-8.57 E238.36054
G1 F540 X8.57 Y-2.03 E238.55301
G1 F540 X4.38 Y-8.57 E238.67618
G1 F540 X8.57 Y-6.74 E238.73010
G1 F540 X-8.57 Y-5.04 E239.13033
G1 F540 X2.68 Y8.57 E239.46129
G1 F540 X-8.57 Y-0.33 E239.72299
G1 F540 X-2.03 Y8.57 E239.91546
G1 F540 X-8.57 Y4.38 E240.03864
G1 F540 X-6.74 Y8.57 E240.09256
;LAYER:19
G0 F12000 X-8.75 Y8.75 Z2.25
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E240.45634
G1 X8.75 Y-8.75 E240.82012
G1 X8.75 Y8.75 E241.18390
G1 X-8.75 Y8.75 E241.54769
G1 F540 X-9.25 Y-9.25 E241.93226
G1 X9.25 Y-9.25 E242.31683
G1 X9.25 Y9.25 E242.70140
G1 X-9.25 Y9.25 E243.08597
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E243.49133
G1 X9.75 Y-9.75 E243.89668
G1 X9.75 Y9.75 E244.30204
G1 X-9.75 Y9.75 E244.70740
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E245.17689
G1 F540 X-8.57 Y7.40 E245.64637
G1 F540 X5.04 Y-8.57 E246.04660
G1 F540 X-8.57 Y2.68 E246.37756
G1 F540 X0.33 Y-8.57 E246.63926
G1 F540 X-8.57 Y-2.03 E246.83173
G1 F540 X-4.38 Y-8.57 E246.95491
G1 F540 X-8.57 Y-6.74 E247.00883
G1 F540 X8.57 Y-5.04 E247.40905
G1 F540 X-2.68 Y8.57 E247.74002
G1 F540 X8.57 Y-0.33 E248.00172
G1 F540 X2.03 Y8.57 E248.19419
G1 F540 X8.57 Y4.38 E248.31737
G1 F540 X6.74 Y8.57 E248.37128
;LAYER:20
G0 F12000 X8.75 Y8.75 Z2.35
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E248.73506
G1 X-8.75 Y-8.75 E249.09885
G1 X8.75 Y-8.75 E249.46263
G1 X8.75 Y8.75 E249.82641
G1 F540 X-9.25 Y9.25 E250.21098
G1 X-9.25 Y-9.25 E250.59555
G1 X9.25 Y-9.25 E250.98012
G1 X9.25 Y9.25 E251.36469
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E251.77005
G1 X-9.75 Y-9.75 E252.17541
G1 X9.75 Y-9.75 E252.58077
G1 X9.75 Y9.75 E252.98613
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E253.45561
G1 F540 X8.57 Y7.40 E253.92510
G1 F540 X-5.04 Y-8.57 E254.32533
G1 F540 X8.57 Y2.68 E254.65629
G1 F540 X-0.33 Y-8.57 E254.91799
G1 F540 X8.57 Y-2.03 E255.11046
G1 F540 X4.38 Y-8.57 E255.23364
G1 F540 X8.57 Y-6.74 E255.28755
G1 F540 X-8.57 Y-5.04 E255.68778
G1 F540 X2.68 Y8.57 E256.01874
G1 F540 X-8.57 Y-0.33 E256.28045
G1 F540 X-2.03 Y8.57 E256.47291
G1 F540 X-8.57 Y4.38 E256.59609
G1 F540 X-6.74 Y8.57 E256.65001
;LAYER:21
G0 F12000 X-8.75 Y8.75 Z2.45
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E257.01379
G1 X8.75 Y-8.75 E257.37757
G1 X8.75 Y8.75 E257.74136
G1 X-8.75 Y8.75 E258.10514
G1 F540 X-9.25 Y-9.25 E258.48971
G1 X9.25 Y-9.25 E258.87428
G1 X9.25 Y9.25 E259.25885
G1 X-9.25 Y9.25 E259.64342
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E260.04878
G1 X9.75 Y-9.75 E260.45414
G1 X9.75 Y9.75 E260.85949
G1 X-9.75 Y9.75 E261.26485
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E261.73434
G1 F540 X-8.57 Y7.40 E262.20383
G1 F540 X5.04 Y-8.57 E262.60405
G1 F540 X-8.57 Y2.68 E262.93502
G1 F540 X0.33 Y-8.57 E263.19672
G1 F540 X-8.57 Y-2.03 E263.38919
G1 F540 X-4.38 Y-8.57 E263.51237
G1 F540 X-8.57 Y-6.74 E263.56628
G1 F540 X8.57 Y-5.04 E263.96651
G1 F540 X-2.68 Y8.57 E264.29747
G1 F540 X8.57 Y-0.33 E264.55917
G1 F540 X2.03 Y8.57 E264.75164
G1 F540 X8.57 Y4.38 E264.87482
G1 F540 X6.74 Y8.57 E264.92874
;LAYER:22
G0 F12000 X8.75 Y8.75 Z2.55
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E265.29252
G1 X-8.75 Y-8.75 E265.65630
G1 X8.75 Y-8.75 E266.02008
G1 X8.75 Y8.75 E266.38387
G1 F540 X-9.25 Y9.25 E266.76844
G1 X-9.25 Y-9.25 E267.15301
G1 X9.25 Y-9.25 E267.53758
G1 X9.25 Y9.25 E267.92215
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E268.32751
G1 X-9.75 Y-9.75 E268.73286
G1 X9.75 Y-9.75 E269.13822
G1 X9.75 Y9.75 E269.54358
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E270.01307
G1 F540 X8.57 Y7.40 E270.48255
G1 F540 X-5.04 Y-8.57 E270.88278
G1 F540 X8.57 Y2.68 E271.21374
G1 F540 X-0.33 Y-8.57 E271.47545
G1 F540 X8.57 Y-2.03 E271.66791
G1 F540 X4.38 Y-8.57 E271.79109
G1 F540 X8.57 Y-6.74 E271.84501
G1 F540 X-8.57 Y-5.04 E272.24523
G1 F540 X2.68 Y8.57 E272.57620
G1 F540 X-8.57 Y-0.33 E272.83790
G1 F540 X-2.03 Y8.57 E273.03037
G1 F540 X-8.57 Y4.38 E273.15355
G1 F540 X-6.74 Y8.57 E273.20746
;LAYER:23
G0 F12000 X-8.75 Y8.75 Z2.65
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E273.57125
G1 X8.75 Y-8.75 E273.93503
G1 X8.75 Y8.75 E274.29881
G1 X-8.75 Y8.75 E274.66259
G1 F540 X-9.25 Y-9.25 E275.04716
G1 X9.25 Y-9.25 E275.43173
G1 X9.25 Y9.25 E275.81630
G1 X-9.25 Y9.25 E276.20087
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E276.60623
G1 X9.75 Y-9.75 E277.01159
G1 X9.75 Y9.75 E277.41695
G1 X-9.75 Y9.75 E277.82231
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E278.29179
G1 F540 X-8.57 Y7.40 E278.76128
G1 F540 X5.04 Y-8.57 E279.16151
G1 F540 X-8.57 Y2.68 E279.49247
G1 F540 X0.33 Y-8.57 E279.75417
G1 F540 X-8.57 Y-2.03 E279.94664
G1 F540 X-4.38 Y-8.57 E280.06982
G1 F540 X-8.57 Y-6.74 E280.12374
G1 F540 X8.57 Y-5.04 E280.52396
G1 F540 X-2.68 Y8.57 E280.85492
G1 F540 X8.57 Y-0.33 E281.11663
G1 F540 X2.03 Y8.57 E281.30910
G1 F540 X8.57 Y4.38 E281.43227
G1 F540 X6.74 Y8.57 E281.48619
;LAYER:24
G0 F12000 X8.75 Y8.75 Z2.75
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E281.84997
G1 X-8.75 Y-8.75 E282.21376
G1 X8.75 Y-8.75 E282.57754
G1 X8.75 Y8.75 E282.94132
G1 F540 X-9.25 Y9.25 E283.32589
G1 X-9.25 Y-9.25 E283.71046
G1 X9.25 Y-9.25 E284.09503
G1 X9.25 Y9.25 E284.47960
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E284.88496
G1 X-9.75 Y-9.75 E285.29032
G1 X9.75 Y-9.75 E285.69568
G1 X9.75 Y9.75 E286.10103
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E286.57052
G1 F540 X8.57 Y7.40 E287.04001
G1 F540 X-5.04 Y-8.57 E287.44023
G1 F540 X8.57 Y2.68 E287.77120
G1 F540 X-0.33 Y-8.57 E288.03290
G1 F540 X8.57 Y-2.03 E288.22537
G1 F540 X4.38 Y-8.57 E288.34855
G1 F540 X8.57 Y-6.74 E288.40246
G1 F540 X-8.57 Y-5.04 E288.80269
G1 F540 X2.68 Y8.57 E289.13365
G1 F540 X-8.57 Y-0.33 E289.39535
G1 F540 X-2.03 Y8.57 E289.58782
G1 F540 X-8.57 Y4.38 E289.71100
G1 F540 X-6.74 Y8.57 E289.76492
;LAYER:25
G0 F12000 X-8.75 Y8.75 Z2.85
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E290.12870
G1 X8.75 Y-8.75 E290.49248
G1 X8.75 Y8.75 E290.85626
G1 X-8.75 Y8.75 E291.22005
G1 F540 X-9.25 Y-9.25 E291.60462
G1 X9.25 Y-9.25 E291.98919
G1 X9.25 Y9.25 E292.37376
G1 X-9.25 Y9.25 E292.75833
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E293.16369
G1 X9.75 Y-9.75 E293.56904
G1 X9.75 Y9.75 E293.97440
G1 X-9.75 Y9.75 E294.37976
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E294.84925
G1 F540 X-8.57 Y7.40 E295.31874
G1 F540 X5.04 Y-8.57 E295.71896
G1 F540 X-8.57 Y2.68 E296.04992
G1 F540 X0.33 Y-8.57 E296.31163
G1 F540 X-8.57 Y-2.03 E296.50410
G1 F540 X-4.38 Y-8.57 E296.62727
G1 F540 X-8.57 Y-6.74 E296.68119
G1 F540 X8.57 Y-5.04 E297.08141
G1 F540 X-2.68 Y8.57 E297.41238
G1 F540 X8.57 Y-0.33 E297.67408
G1 F540 X2.03 Y8.57 E297.86655
G1 F540 X8.57 Y4.38 E297.98973
G1 F540 X6.74 Y8.57 E298.04364
;LAYER:26
G0 F12000 X8.75 Y8.75 Z2.95
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E298.40743
G1 X-8.75 Y-8.75 E298.77121
G1 X8.75 Y-8.75 E299.13499
G1 X8.75 Y8.75 E299.49877
G1 F540 X-9.25 Y9.25 E299.88334
G1 X-9.25 Y-9.25 E300.26792
G1 X9.25 Y-9.25 E300.65249
G1 X9.25 Y9.25 E301.03706
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E301.44241
G1 X-9.75 Y-9.75 E301.84777
G1 X9.75 Y-9.75 E302.25313
G1 X9.75 Y9.75 E302.65849
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E303.12797
G1 F540 X8.57 Y7.40 E303.59746
G1 F540 X-5.04 Y-8.57 E303.99769
G1 F540 X8.57 Y2.68 E304.32865
G1 F540 X-0.33 Y-8.57 E304.59035
G1 F540 X8.57 Y-2.03 E304.78282
G1 F540 X4.38 Y-8.57 E304.90600
G1 F540 X8.57 Y-6.74 E304.95992
G1 F540 X-8.57 Y-5.04 E305.36014
G1 F540 X2.68 Y8.57 E305.69111
G1 F540 X-8.57 Y-0.33 E305.95281
G1 F540 X-2.03 Y8.57 E306.14528
G1 F540 X-8.57 Y4.38 E306.26845
G1 F540 X-6.74 Y8.57 E306.32237
;LAYER:27
G0 F12000 X-8.75 Y8.75 Z3.05
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E306.68615
G1 X8.75 Y-8.75 E307.04994
G1 X8.75 Y8.75 E307.41372
G1 X-8.75 Y8.75 E307.77750
G1 F540 X-9.25 Y-9.25 E308.16207
G1 X9.25 Y-9.25 E308.54664
G1 X9.25 Y9.25 E308.93121
G1 X-9.25 Y9.25 E309.31578
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E309.72114
G1 X9.75 Y-9.75 E310.12650
G1 X9.75 Y9.75 E310.53186
G1 X-9.75 Y9.75 E310.93721
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E311.40670
G1 F540 X-8.57 Y7.40 E311.87619
G1 F540 X5.04 Y-8.57 E312.27641
G1 F540 X-8.57 Y2.68 E312.60738
G1 F540 X0.33 Y-8.57 E312.86908
G1 F540 X-8.57 Y-2.03 E313.06155
G1 F540 X-4.38 Y-8.57 E313.18473
G1 F540 X-8.57 Y-6.74 E313.23864
G1 F540 X8.57 Y-5.04 E313.63887
G1 F540 X-2.68 Y8.57 E313.96983
G1 F540 X8.57 Y-0.33 E314.23153
G1 F540 X2.03 Y8.57 E314.42400
G1 F540 X8.57 Y4.38 E314.54718
G1 F540 X6.74 Y8.57 E314.60110
;LAYER:28
G0 F12000 X8.75 Y8.75 Z3.15
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E314.96488
G1 X-8.75 Y-8.75 E315.32866
G1 X8.75 Y-8.75 E315.69245
G1 X8.75 Y8.75 E316.05623
G1 F540 X-9.25 Y9.25 E316.44080
G1 X-9.25 Y-9.25 E316.82537
G1 X9.25 Y-9.25 E317.20994
G1 X9.25 Y9.25 E317.59451
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E317.99987
G1 X-9.75 Y-9.75 E318.40523
G1 X9.75 Y-9.75 E318.81058
G1 X9.75 Y9.75 E319.21594
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E319.68543
G1 F540 X8.57 Y7.40 E320.15492
G1 F540 X-5.04 Y-8.57 E320.55514
G1 F540 X8.57 Y2.68 E320.88611
G1 F540 X-0.33 Y-8.57 E321.14781
G1 F540 X8.57 Y-2.03 E321.34028
G1 F540 X4.38 Y-8.57 E321.46345
G1 F540 X8.57 Y-6.74 E321.51737
G1 F540 X-8.57 Y-5.04 E321.91760
G1 F540 X2.68 Y8.57 E322.24856
G1 F540 X-8.57 Y-0.33 E322.51026
G1 F540 X-2.03 Y8.57 E322.70273
G1 F540 X-8.57 Y4.38 E322.82591
G1 F540 X-6.74 Y8.57 E322.87982
;LAYER:29
G0 F12000 X-8.75 Y8.75 Z3.25
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E323.24361
G1 X8.75 Y-8.75 E323.60739
G1 X8.75 Y8.75 E323.97117
G1 X-8.75 Y8.75 E324.33496
G1 F540 X-9.25 Y-9.25 E324.71953
G1 X9.25 Y-9.25 E325.10410
G1 X9.25 Y9.25 E325.48867
G1 X-9.25 Y9.25 E325.87324
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E326.27859
G1 X9.75 Y-9.75 E326.68395
G1 X9.75 Y9.75 E327.08931
G1 X-9.75 Y9.75 E327.49467
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E327.96416
G1 F540 X-8.57 Y7.40 E328.43364
G1 F540 X5.04 Y-8.57 E328.83387
G1 F540 X-8.57 Y2.68 E329.16483
G1 F540 X0.33 Y-8.57 E329.42653
G1 F540 X-8.57 Y-2.03 E329.61900
G1 F540 X-4.38 Y-8.57 E329.74218
G1 F540 X-8.57 Y-6.74 E329.79610
G1 F540 X8.57 Y-5.04 E330.19632
G1 F540 X-2.68 Y8.57 E330.52729
G1 F540 X8.57 Y-0.33 E330.78899
G1 F540 X2.03 Y8.57 E330.98146
G1 F540 X8.57 Y4.38 E331.10464
G1 F540 X6.74 Y8.57 E331.15855
;LAYER:30
G0 F12000 X8.75 Y8.75 Z3.35
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E331.52233
G1 X-8.75 Y-8.75 E331.88612
G1 X8.75 Y-8.75 E332.24990
G1 X8.75 Y8.75 E332.61368
G1 F540 X-9.25 Y9.25 E332.99825
G1 X-9.25 Y-9.25 E333.38282
G1 X9.25 Y-9.25 E333.76739
G1 X9.25 Y9.25 E334.15196
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E334.55732
G1 X-9.75 Y-9.75 E334.96268
G1 X9.75 Y-9.75 E335.36804
G1 X9.75 Y9.75 E335.77339
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E336.24288
G1 F540 X8.57 Y7.40 E336.71237
G1 F540 X-5.04 Y-8.57 E337.11260
G1 F540 X8.57 Y2.68 E337.44356
G1 F540 X-0.33 Y-8.57 E337.70526
G1 F540 X8.57 Y-2.03 E337.89773
G1 F540 X4.38 Y-8.57 E338.02091
G1 F540 X8.57 Y-6.74 E338.07482
G1 F540 X-8.57 Y-5.04 E338.47505
G1 F540 X2.68 Y8.57 E338.80601
G1 F540 X-8.57 Y-0.33 E339.06771
G1 F540 X-2.03 Y8.57 E339.26018
G1 F540 X-8.57 Y4.38 E339.38336
G1 F540 X-6.74 Y8.57 E339.43728
;LAYER:31
G0 F12000 X-8.75 Y8.75 Z3.45
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E339.80106
G1 X8.75 Y-8.75 E340.16484
G1 X8.75 Y8.75 E340.52863
G1 X-8.75 Y8.75 E340.89241
G1 F540 X-9.25 Y-9.25 E341.27698
G1 X9.25 Y-9.25 E341.66155
G1 X9.25 Y9.25 E342.04612
G1 X-9.25 Y9.25 E342.43069
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E342.83605
G1 X9.75 Y-9.75 E343.24141
G1 X9.75 Y9.75 E343.64676
G1 X-9.75 Y9.75 E344.05212
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E344.52161
G1 F540 X-8.57 Y7.40 E344.99110
G1 F540 X5.04 Y-8.57 E345.39132
G1 F540 X-8.57 Y2.68 E345.72229
G1 F540 X0.33 Y-8.57 E345.98399
G1 F540 X-8.57 Y-2.03 E346.17646
G1 F540 X-4.38 Y-8.57 E346.29963
G1 F540 X-8.57 Y-6.74 E346.35355
G1 F540 X8.57 Y-5.04 E346.75378
G1 F540 X-2.68 Y8.57 E347.08474
G1 F540 X8.57 Y-0.33 E347.34644
G1 F540 X2.03 Y8.57 E347.53891
G1 F540 X8.57 Y4.38 E347.66209
G1 F540 X6.74 Y8.57 E347.71601
;LAYER:32
G0 F12000 X8.75 Y8.75 Z3.55
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E348.07979
G1 X-8.75 Y-8.75 E348.44357
G1 X8.75 Y-8.75 E348.80735
G1 X8.75 Y8.75 E349.17114
G1 F540 X-9.25 Y9.25 E349.55571
G1 X-9.25 Y-9.25 E349.94028
G1 X9.25 Y-9.25 E350.32485
G1 X9.25 Y9.25 E350.70942
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E351.11478
G1 X-9.75 Y-9.75 E351.52013
G1 X9.75 Y-9.75 E351.92549
G1 X9.75 Y9.75 E352.33085
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E352.80034
G1 F540 X8.57 Y7.40 E353.26982
G1 F540 X-5.04 Y-8.57 E353.67005
G1 F540 X8.57 Y2.68 E354.00101
G1 F540 X-0.33 Y-8.57 E354.26271
G1 F540 X8.57 Y-2.03 E354.45518
G1 F540 X4.38 Y-8.57 E354.57836
G1 F540 X8.57 Y-6.74 E354.63228
G1 F540 X-8.57 Y-5.04 E355.03250
G1 F540 X2.68 Y8.57 E355.36347
G1 F540 X-8.57 Y-0.33 E355.62517
G1 F540 X-2.03 Y8.57 E355.81764
G1 F540 X-8.57 Y4.38 E355.94082
G1 F540 X-6.74 Y8.57 E355.99473
;LAYER:33
G0 F12000 X-8.75 Y8.75 Z3.65
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E356.35851
G1 X8.75 Y-8.75 E356.72230
G1 X8.75 Y8.75 E357.08608
G1 X-8.75 Y8.75 E357.44986
G1 F540 X-9.25 Y-9.25 E357.83443
G1 X9.25 Y-9.25 E358.21900
G1 X9.25 Y9.25 E358.60357
G1 X-9.25 Y9.25 E358.98814
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E359.39350
G1 X9.75 Y-9.75 E359.79886
G1 X9.75 Y9.75 E360.20422
G1 X-9.75 Y9.75 E360.60958
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E361.07906
G1 F540 X-8.57 Y7.40 E361.54855
G1 F540 X5.04 Y-8.57 E361.94878
G1 F540 X-8.57 Y2.68 E362.27974
G1 F540 X0.33 Y-8.57 E362.54144
G1 F540 X-8.57 Y-2.03 E362.73391
G1 F540 X-4.38 Y-8.57 E362.85709
G1 F540 X-8.57 Y-6.74 E362.91100
G1 F540 X8.57 Y-5.04 E363.31123
G1 F540 X-2.68 Y8.57 E363.64219
G1 F540 X8.57 Y-0.33 E363.90390
G1 F540 X2.03 Y8.57 E364.09636
G1 F540 X8.57 Y4.38 E364.21954
G1 F540 X6.74 Y8.57 E364.27346
;LAYER:34
G0 F12000 X8.75 Y8.75 Z3.75
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E364.63724
G1 X-8.75 Y-8.75 E365.00102
G1 X8.75 Y-8.75 E365.36481
G1 X8.75 Y8.75 E365.72859
G1 F540 X-9.25 Y9.25 E366.11316
G1 X-9.25 Y-9.25 E366.49773
G1 X9.25 Y-9.25 E366.88230
G1 X9.25 Y9.25 E367.26687
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E367.67223
G1 X-9.75 Y-9.75 E368.07759
G1 X9.75 Y-9.75 E368.48294
G1 X9.75 Y9.75 E368.88830
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E369.35779
G1 F540 X8.57 Y7.40 E369.82728
G1 F540 X-5.04 Y-8.57 E370.22750
G1 F540 X8.57 Y2.68 E370.55847
G1 F540 X-0.33 Y-8.57 E370.82017
G1 F540 X8.57 Y-2.03 E371.01264
G1 F540 X4.38 Y-8.57 E371.13582
G1 F540 X8.57 Y-6.74 E371.18973
G1 F540 X-8.57 Y-5.04 E371.58996
G1 F540 X2.68 Y8.57 E371.92092
G1 F540 X-8.57 Y-0.33 E372.18262
G1 F540 X-2.03 Y8.57 E372.37509
G1 F540 X-8.57 Y4.38 E372.49827
G1 F540 X-6.74 Y8.57 E372.55219
;LAYER:35
G0 F12000 X-8.75 Y8.75 Z3.85
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E372.91597
G1 X8.75 Y-8.75 E373.27975
G1 X8.75 Y8.75 E373.64353
G1 X-8.75 Y8.75 E374.00732
G1 F540 X-9.25 Y-9.25 E374.39189
G1 X9.25 Y-9.25 E374.77646
G1 X9.25 Y9.25 E375.16103
G1 X-9.25 Y9.25 E375.54560
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E375.95096
G1 X9.75 Y-9.75 E376.35631
G1 X9.75 Y9.75 E376.76167
G1 X-9.75 Y9.75 E377.16703
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E377.63652
G1 F540 X-8.57 Y7.40 E378.10600
G1 F540 X5.04 Y-8.57 E378.50623
G1 F540 X-8.57 Y2.68 E378.83719
G1 F540 X0.33 Y-8.57 E379.09890
G1 F540 X-8.57 Y-2.03 E379.29136
G1 F540 X-4.38 Y-8.57 E379.41454
G1 F540 X-8.57 Y-6.74 E379.46846
G1 F540 X8.57 Y-5.04 E379.86868
G1 F540 X-2.68 Y8.57 E380.19965
G1 F540 X8.57 Y-0.33 E380.46135
G1 F540 X2.03 Y8.57 E380.65382
G1 F540 X8.57 Y4.38 E380.77700
G1 F540 X6.74 Y8.57 E380.83091
;LAYER:36
G0 F12000 X8.75 Y8.75 Z3.95
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E381.19470
G1 X-8.75 Y-8.75 E381.55848
G1 X8.75 Y-8.75 E381.92226
G1 X8.75 Y8.75 E382.28604
G1 F540 X-9.25 Y9.25 E382.67061
G1 X-9.25 Y-9.25 E383.05518
G1 X9.25 Y-9.25 E383.43975
G1 X9.25 Y9.25 E383.82432
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E384.22968
G1 X-9.75 Y-9.75 E384.63504
G1 X9.75 Y-9.75 E385.04040
G1 X9.75 Y9.75 E385.44576
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E385.91524
G1 F540 X8.57 Y7.40 E386.38473
G1 F540 X-5.04 Y-8.57 E386.78496
G1 F540 X8.57 Y2.68 E387.11592
G1 F540 X-0.33 Y-8.57 E387.37762
G1 F540 X8.57 Y-2.03 E387.57009
G1 F540 X4.38 Y-8.57 E387.69327
G1 F540 X8.57 Y-6.74 E387.74719
G1 F540 X-8.57 Y-5.04 E388.14741
G1 F540 X2.68 Y8.57 E388.47837
G1 F540 X-8.57 Y-0.33 E388.74008
G1 F540 X-2.03 Y8.57 E388.93255
G1 F540 X-8.57 Y4.38 E389.05572
G1 F540 X-6.74 Y8.57 E389.10964
;LAYER:37
G0 F12000 X-8.75 Y8.75 Z4.05
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E389.47342
G1 X8.75 Y-8.75 E389.83721
G1 X8.75 Y8.75 E390.20099
G1 X-8.75 Y8.75 E390.56477
G1 F540 X-9.25 Y-9.25 E390.94934
G1 X9.25 Y-9.25 E391.33391
G1 X9.25 Y9.25 E391.71848
G1 X-9.25 Y9.25 E392.10305
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E392.50841
G1 X9.75 Y-9.75 E392.91377
G1 X9.75 Y9.75 E393.31913
G1 X-9.75 Y9.75 E393.72448
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E394.19397
G1 F540 X-8.57 Y7.40 E394.66346
G1 F540 X5.04 Y-8.57 E395.06368
G1 F540 X-8.57 Y2.68 E395.39465
G1 F540 X0.33 Y-8.57 E395.65635
G1 F540 X-8.57 Y-2.03 E395.84882
G1 F540 X-4.38 Y-8.57 E395.97200
G1 F540 X-8.57 Y-6.74 E396.02591
G1 F540 X8.57 Y-5.04 E396.42614
G1 F540 X-2.68 Y8.57 E396.75710
G1 F540 X8.57 Y-0.33 E397.01880
G1 F540 X2.03 Y8.57 E397.21127
G1 F540 X8.57 Y4.38 E397.33445
G1 F540 X6.74 Y8.57 E397.38837
;LAYER:38
G0 F12000 X8.75 Y8.75 Z4.15
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E397.75215
G1 X-8.75 Y-8.75 E398.11593
G1 X8.75 Y-8.75 E398.47971
G1 X8.75 Y8.75 E398.84350
G1 F540 X-9.25 Y9.25 E399.22807
G1 X-9.25 Y-9.25 E399.61264
G1 X9.25 Y-9.25 E399.99721
G1 X9.25 Y9.25 E400.38178
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E400.78714
G1 X-9.75 Y-9.75 E401.19249
G1 X9.75 Y-9.75 E401.59785
G1 X9.75 Y9.75 E402.00321
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E402.47270
G1 F540 X8.57 Y7.40 E402.94219
G1 F540 X-5.04 Y-8.57 E403.34241
G1 F540 X8.57 Y2.68 E403.67337
G1 F540 X-0.33 Y-8.57 E403.93508
G1 F540 X8.57 Y-2.03 E404.12755
G1 F540 X4.38 Y-8.57 E404.25072
G1 F540 X8.57 Y-6.74 E404.30464
G1 F540 X-8.57 Y-5.04 E404.70486
G1 F540 X2.68 Y8.57 E405.03583
G1 F540 X-8.57 Y-0.33 E405.29753
G1 F540 X-2.03 Y8.57 E405.49000
G1 F540 X-8.57 Y4.38 E405.61318
G1 F540 X-6.74 Y8.57 E405.66709
;LAYER:39
G0 F12000 X-8.75 Y8.75 Z4.25
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E406.03088
G1 X8.75 Y-8.75 E406.39466
G1 X8.75 Y8.75 E406.75844
G1 X-8.75 Y8.75 E407.12222
G1 F540 X-9.25 Y-9.25 E407.50679
G1 X9.25 Y-9.25 E407.89137
G1 X9.25 Y9.25 E408.27594
G1 X-9.25 Y9.25 E408.66051
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E409.06586
G1 X9.75 Y-9.75 E409.47122
G1 X9.75 Y9.75 E409.87658
G1 X-9.75 Y9.75 E410.28194
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E410.75142
G1 F540 X-8.57 Y7.40 E411.22091
G1 F540 X5.04 Y-8.57 E411.62114
G1 F540 X-8.57 Y2.68 E411.95210
G1 F540 X0.33 Y-8.57 E412.21380
G1 F540 X-8.57 Y-2.03 E412.40627
G1 F540 X-4.38 Y-8.57 E412.52945
G1 F540 X-8.57 Y-6.74 E412.58337
G1 F540 X8.57 Y-5.04 E412.98359
G1 F540 X-2.68 Y8.57 E413.31456
G1 F540 X8.57 Y-0.33 E413.57626
G1 F540 X2.03 Y8.57 E413.76873
G1 F540 X8.57 Y4.38 E413.89190
G1 F540 X6.74 Y8.57 E413.94582
;LAYER:40
G0 F12000 X8.75 Y8.75 Z4.35
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E414.30960
G1 X-8.75 Y-8.75 E414.67339
G1 X8.75 Y-8.75 E415.03717
G1 X8.75 Y8.75 E415.40095
G1 F540 X-9.25 Y9.25 E415.78552
G1 X-9.25 Y-9.25 E416.17009
G1 X9.25 Y-9.25 E416.55466
G1 X9.25 Y9.25 E416.93923
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E417.34459
G1 X-9.75 Y-9.75 E417.74995
G1 X9.75 Y-9.75 E418.15531
G1 X9.75 Y9.75 E418.56066
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E419.03015
G1 F540 X8.57 Y7.40 E419.49964
G1 F540 X-5.04 Y-8.57 E419.89986
G1 F540 X8.57 Y2.68 E420.23083
G1 F540 X-0.33 Y-8.57 E420.49253
G1 F540 X8.57 Y-2.03 E420.68500
G1 F540 X4.38 Y-8.57 E420.80818
G1 F540 X8.57 Y-6.74 E420.86209
G1 F540 X-8.57 Y-5.04 E421.26232
G1 F540 X2.68 Y8.57 E421.59328
G1 F540 X-8.57 Y-0.33 E421.85498
G1 F540 X-2.03 Y8.57 E422.04745
G1 F540 X-8.57 Y4.38 E422.17063
G1 F540 X-6.74 Y8.57 E422.22455
;LAYER:41
G0 F12000 X-8.75 Y8.75 Z4.45
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E422.58833
G1 X8.75 Y-8.75 E422.95211
G1 X8.75 Y8.75 E423.31590
G1 X-8.75 Y8.75 E423.67968
G1 F540 X-9.25 Y-9.25 E424.06425
G1 X9.25 Y-9.25 E424.44882
G1 X9.25 Y9.25 E424.83339
G1 X-9.25 Y9.25 E425.21796
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E425.62332
G1 X9.75 Y-9.75 E426.02868
G1 X9.75 Y9.75 E426.43403
G1 X-9.75 Y9.75 E426.83939
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E427.30888
G1 F540 X-8.57 Y7.40 E427.77837
G1 F540 X5.04 Y-8.57 E428.17859
G1 F540 X-8.57 Y2.68 E428.50956
G1 F540 X0.33 Y-8.57 E428.77126
G1 F540 X-8.57 Y-2.03 E428.96373
G1 F540 X-4.38 Y-8.57 E429.08690
G1 F540 X-8.57 Y-6.74 E429.14082
G1 F540 X8.57 Y-5.04 E429.54105
G1 F540 X-2.68 Y8.57 E429.87201
G1 F540 X8.57 Y-0.33 E430.13371
G1 F540 X2.03 Y8.57 E430.32618
G1 F540 X8.57 Y4.38 E430.44936
G1 F540 X6.74 Y8.57 E430.50327
;LAYER:42
G0 F12000 X8.75 Y8.75 Z4.55
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E430.86706
G1 X-8.75 Y-8.75 E431.23084
G1 X8.75 Y-8.75 E431.59462
G1 X8.75 Y8.75 E431.95841
G1 F540 X-9.25 Y9.25 E432.34298
G1 X-9.25 Y-9.25 E432.72755
G1 X9.25 Y-9.25 E433.11212
G1 X9.25 Y9.25 E433.49669
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E433.90204
G1 X-9.75 Y-9.75 E434.30740
G1 X9.75 Y-9.75 E434.71276
G1 X9.75 Y9.75 E435.11812
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E435.58761
G1 F540 X8.57 Y7.40 E436.05709
G1 F540 X-5.04 Y-8.57 E436.45732
G1 F540 X8.57 Y2.68 E436.78828
G1 F540 X-0.33 Y-8.57 E437.04998
G1 F540 X8.57 Y-2.03 E437.24245
G1 F540 X4.38 Y-8.57 E437.36563
G1 F540 X8.57 Y-6.74 E437.41955
G1 F540 X-8.57 Y-5.04 E437.81977
G1 F540 X2.68 Y8.57 E438.15074
G1 F540 X-8.57 Y-0.33 E438.41244
G1 F540 X-2.03 Y8.57 E438.60491
G1 F540 X-8.57 Y4.38 E438.72809
G1 F540 X-6.74 Y8.57 E438.78200
;LAYER:43
G0 F12000 X-8.75 Y8.75 Z4.65
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E439.14578
G1 X8.75 Y-8.75 E439.50957
G1 X8.75 Y8.75 E439.87335
G1 X-8.75 Y8.75 E440.23713
G1 F540 X-9.25 Y-9.25 E440.62170
G1 X9.25 Y-9.25 E441.00627
G1 X9.25 Y9.25 E441.39084
G1 X-9.25 Y9.25 E441.77541
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E442.18077
G1 X9.75 Y-9.75 E442.58613
G1 X9.75 Y9.75 E442.99149
G1 X-9.75 Y9.75 E443.39684
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E443.86633
G1 F540 X-8.57 Y7.40 E444.33582
G1 F540 X5.04 Y-8.57 E444.73605
G1 F540 X-8.57 Y2.68 E445.06701
G1 F540 X0.33 Y-8.57 E445.32871
G1 F540 X-8.57 Y-2.03 E445.52118
G1 F540 X-4.38 Y-8.57 E445.64436
G1 F540 X-8.57 Y-6.74 E445.69827
G1 F540 X8.57 Y-5.04 E446.09850
G1 F540 X-2.68 Y8.57 E446.42946
G1 F540 X8.57 Y-0.33 E446.69116
G1 F540 X2.03 Y8.57 E446.88363
G1 F540 X8.57 Y4.38 E447.00681
G1 F540 X6.74 Y8.57 E447.06073
;LAYER:44
G0 F12000 X8.75 Y8.75 Z4.75
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E447.42451
G1 X-8.75 Y-8.75 E447.78829
G1 X8.75 Y-8.75 E448.15208
G1 X8.75 Y8.75 E448.51586
G1 F540 X-9.25 Y9.25 E448.90043
G1 X-9.25 Y-9.25 E449.28500
G1 X9.25 Y-9.25 E449.66957
G1 X9.25 Y9.25 E450.05414
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E450.45950
G1 X-9.75 Y-9.75 E450.86486
G1 X9.75 Y-9.75 E451.27021
G1 X9.75 Y9.75 E451.67557
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E452.14506
G1 F540 X8.57 Y7.40 E452.61455
G1 F540 X-5.04 Y-8.57 E453.01477
G1 F540 X8.57 Y2.68 E453.34574
G1 F540 X-0.33 Y-8.57 E453.60744
G1 F540 X8.57 Y-2.03 E453.79991
G1 F540 X4.38 Y-8.57 E453.92308
G1 F540 X8.57 Y-6.74 E453.97700
G1 F540 X-8.57 Y-5.04 E454.37723
G1 F540 X2.68 Y8.57 E454.70819
G1 F540 X-8.57 Y-0.33 E454.96989
G1 F540 X-2.03 Y8.57 E455.16236
G1 F540 X-8.57 Y4.38 E455.28554
G1 F540 X-6.74 Y8.57 E455.33946
;LAYER:45
G0 F12000 X-8.75 Y8.75 Z4.85
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E455.70324
G1 X8.75 Y-8.75 E456.06702
G1 X8.75 Y8.75 E456.43080
G1 X-8.75 Y8.75 E456.79459
G1 F540 X-9.25 Y-9.25 E457.17916
G1 X9.25 Y-9.25 E457.56373
G1 X9.25 Y9.25 E457.94830
G1 X-9.25 Y9.25 E458.33287
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E458.73823
G1 X9.75 Y-9.75 E459.14358
G1 X9.75 Y9.75 E459.54894
G1 X-9.75 Y9.75 E459.95430
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E460.42379
G1 F540 X-8.57 Y7.40 E460.89327
G1 F540 X5.04 Y-8.57 E461.29350
G1 F540 X-8.57 Y2.68 E461.62446
G1 F540 X0.33 Y-8.57 E461.88616
G1 F540 X-8.57 Y-2.03 E462.07863
G1 F540 X-4.38 Y-8.57 E462.20181
G1 F540 X-8.57 Y-6.74 E462.25573
G1 F540 X8.57 Y-5.04 E462.65595
G1 F540 X-2.68 Y8.57 E462.98692
G1 F540 X8.57 Y-0.33 E463.24862
G1 F540 X2.03 Y8.57 E463.44109
G1 F540 X8.57 Y4.38 E463.56427
G1 F540 X6.74 Y8.57 E463.61818
;LAYER:46
G0 F12000 X8.75 Y8.75 Z4.95
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E463.98196
G1 X-8.75 Y-8.75 E464.34575
G1 X8.75 Y-8.75 E464.70953
G1 X8.75 Y8.75 E465.07331
G1 F540 X-9.25 Y9.25 E465.45788
G1 X-9.25 Y-9.25 E465.84245
G1 X9.25 Y-9.25 E466.22702
G1 X9.25 Y9.25 E466.61159
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E467.01695
G1 X-9.75 Y-9.75 E467.42231
G1 X9.75 Y-9.75 E467.82767
G1 X9.75 Y9.75 E468.23303
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E468.70251
G1 F540 X8.57 Y7.40 E469.17200
G1 F540 X-5.04 Y-8.57 E469.57223
G1 F540 X8.57 Y2.68 E469.90319
G1 F540 X-0.33 Y-8.57 E470.16489
G1 F540 X8.57 Y-2.03 E470.35736
G1 F540 X4.38 Y-8.57 E470.48054
G1 F540 X8.57 Y-6.74 E470.53445
G1 F540 X-8.57 Y-5.04 E470.93468
G1 F540 X2.68 Y8.57 E471.26564
G1 F540 X-8.57 Y-0.33 E471.52735
G1 F540 X-2.03 Y8.57 E471.71981
G1 F540 X-8.57 Y4.38 E471.84299
G1 F540 X-6.74 Y8.57 E471.89691
;LAYER:47
G0 F12000 X-8.75 Y8.75 Z5.05
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E472.26069
G1 X8.75 Y-8.75 E472.62447
G1 X8.75 Y8.75 E472.98826
G1 X-8.75 Y8.75 E473.35204
G1 F540 X-9.25 Y-9.25 E473.73661
G1 X9.25 Y-9.25 E474.12118
G1 X9.25 Y9.25 E474.50575
G1 X-9.25 Y9.25 E474.89032
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E475.29568
G1 X9.75 Y-9.75 E475.70104
G1 X9.75 Y9.75 E476.10639
G1 X-9.75 Y9.75 E476.51175
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E476.98124
G1 F540 X-8.57 Y7.40 E477.45073
G1 F540 X5.04 Y-8.57 E477.85095
G1 F540 X-8.57 Y2.68 E478.18192
G1 F540 X0.33 Y-8.57 E478.44362
G1 F540 X-8.57 Y-2.03 E478.63609
G1 F540 X-4.38 Y-8.57 E478.75927
G1 F540 X-8.57 Y-6.74 E478.81318
G1 F540 X8.57 Y-5.04 E479.21341
G1 F540 X-2.68 Y8.57 E479.54437
G1 F540 X8.57 Y-0.33 E479.80607
G1 F540 X2.03 Y8.57 E479.99854
G1 F540 X8.57 Y4.38 E480.12172
G1 F540 X6.74 Y8.57 E480.17564
;LAYER:48
G0 F12000 X8.75 Y8.75 Z5.15
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E480.53942
G1 X-8.75 Y-8.75 E480.90320
G1 X8.75 Y-8.75 E481.26698
G1 X8.75 Y8.75 E481.63077
G1 F540 X-9.25 Y9.25 E482.01534
G1 X-9.25 Y-9.25 E482.39991
G1 X9.25 Y-9.25 E482.78448
G1 X9.25 Y9.25 E483.16905
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E483.57441
G1 X-9.75 Y-9.75 E483.97976
G1 X9.75 Y-9.75 E484.38512
G1 X9.75 Y9.75 E484.79048
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E485.25997
G1 F540 X8.57 Y7.40 E485.72945
G1 F540 X-5.04 Y-8.57 E486.12968
G1 F540 X8.57 Y2.68 E486.46064
G1 F540 X-0.33 Y-8.57 E486.72235
G1 F540 X8.57 Y-2.03 E486.91481
G1 F540 X4.38 Y-8.57 E487.03799
G1 F540 X8.57 Y-6.74 E487.09191
G1 F540 X-8.57 Y-5.04 E487.49213
G1 F540 X2.68 Y8.57 E487.82310
G1 F540 X-8.57 Y-0.33 E488.08480
G1 F540 X-2.03 Y8.57 E488.27727
G1 F540 X-8.57 Y4.38 E488.40045
G1 F540 X-6.74 Y8.57 E488.45436
;LAYER:49
G0 F12000 X-8.75 Y8.75 Z5.25
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E488.81815
G1 X8.75 Y-8.75 E489.18193
G1 X8.75 Y8.75 E489.54571
G1 X-8.75 Y8.75 E489.90949
G1 F540 X-9.25 Y-9.25 E490.29406
G1 X9.25 Y-9.25 E490.67863
G1 X9.25 Y9.25 E491.06320
G1 X-9.25 Y9.25 E491.44777
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E491.85313
G1 X9.75 Y-9.75 E492.25849
G1 X9.75 Y9.75 E492.66385
G1 X-9.75 Y9.75 E493.06921
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E493.53869
G1 F540 X-8.57 Y7.40 E494.00818
G1 F540 X5.04 Y-8.57 E494.40841
G1 F540 X-8.57 Y2.68 E494.73937
G1 F540 X0.33 Y-8.57 E495.00107
G1 F540 X-8.57 Y-2.03 E495.19354
G1 F540 X-4.38 Y-8.57 E495.31672
G1 F540 X-8.57 Y-6.74 E495.37064
G1 F540 X8.57 Y-5.04 E495.77086
G1 F540 X-2.68 Y8.57 E496.10182
G1 F540 X8.57 Y-0.33 E496.36353
G1 F540 X2.03 Y8.57 E496.55600
G1 F540 X8.57 Y4.38 E496.67917
G1 F540 X6.74 Y8.57 E496.73309
;LAYER:50
G0 F12000 X8.75 Y8.75 Z5.35
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E497.09687
G1 X-8.75 Y-8.75 E497.46066
G1 X8.75 Y-8.75 E497.82444
G1 X8.75 Y8.75 E498.18822
G1 F540 X-9.25 Y9.25 E498.57279
G1 X-9.25 Y-9.25 E498.95736
G1 X9.25 Y-9.25 E499.34193
G1 X9.25 Y9.25 E499.72650
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E500.13186
G1 X-9.75 Y-9.75 E500.53722
G1 X9.75 Y-9.75 E500.94258
G1 X9.75 Y9.75 E501.34793
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E501.81742
G1 F540 X8.57 Y7.40 E502.28691
G1 F540 X-5.04 Y-8.57 E502.68713
G1 F540 X8.57 Y2.68 E503.01810
G1 F540 X-0.33 Y-8.57 E503.27980
G1 F540 X8.57 Y-2.03 E503.47227
G1 F540 X4.38 Y-8.57 E503.59545
G1 F540 X8.57 Y-6.74 E503.64936
G1 F540 X-8.57 Y-5.04 E504.04959
G1 F540 X2.68 Y8.57 E504.38055
G1 F540 X-8.57 Y-0.33 E504.64225
G1 F540 X-2.03 Y8.57 E504.83472
G1 F540 X-8.57 Y4.38 E504.95790
G1 F540 X-6.74 Y8.57 E505.01182
;LAYER:51
G0 F12000 X-8.75 Y8.75 Z5.45
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E505.37560
G1 X8.75 Y-8.75 E505.73938
G1 X8.75 Y8.75 E506.10316
G1 X-8.75 Y8.75 E506.46695
G1 F540 X-9.25 Y-9.25 E506.85152
G1 X9.25 Y-9.25 E507.23609
G1 X9.25 Y9.25 E507.62066
G1 X-9.25 Y9.25 E508.00523
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E508.41059
G1 X9.75 Y-9.75 E508.81594
G1 X9.75 Y9.75 E509.22130
G1 X-9.75 Y9.75 E509.62666
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E510.09615
G1 F540 X-8.57 Y7.40 E510.56564
G1 F540 X5.04 Y-8.57 E510.96586
G1 F540 X-8.57 Y2.68 E511.29682
G1 F540 X0.33 Y-8.57 E511.55853
G1 F540 X-8.57 Y-2.03 E511.75100
G1 F540 X-4.38 Y-8.57 E511.87417
G1 F540 X-8.57 Y-6.74 E511.92809
G1 F540 X8.57 Y-5.04 E512.32831
G1 F540 X-2.68 Y8.57 E512.65928
G1 F540 X8.57 Y-0.33 E512.92098
G1 F540 X2.03 Y8.57 E513.11345
G1 F540 X8.57 Y4.38 E513.23663
G1 F540 X6.74 Y8.57 E513.29054
;LAYER:52
G0 F12000 X8.75 Y8.75 Z5.55
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E513.65433
G1 X-8.75 Y-8.75 E514.01811
G1 X8.75 Y-8.75 E514.38189
G1 X8.75 Y8.75 E514.74567
G1 F540 X-9.25 Y9.25 E515.13024
G1 X-9.25 Y-9.25 E515.51481
G1 X9.25 Y-9.25 E515.89939
G1 X9.25 Y9.25 E516.28396
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E516.68931
G1 X-9.75 Y-9.75 E517.09467
G1 X9.75 Y-9.75 E517.50003
G1 X9.75 Y9.75 E517.90539
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E518.37487
G1 F540 X8.57 Y7.40 E518.84436
G1 F540 X-5.04 Y-8.57 E519.24459
G1 F540 X8.57 Y2.68 E519.57555
G1 F540 X-0.33 Y-8.57 E519.83725
G1 F540 X8.57 Y-2.03 E520.02972
G1 F540 X4.38 Y-8.57 E520.15290
G1 F540 X8.57 Y-6.74 E520.20682
G1 F540 X-8.57 Y-5.04 E520.60704
G1 F540 X2.68 Y8.57 E520.93801
G1 F540 X-8.57 Y-0.33 E521.19971
G1 F540 X-2.03 Y8.57 E521.39218
G1 F540 X-8.57 Y4.38 E521.51535
G1 F540 X-6.74 Y8.57 E521.56927
;LAYER:53
G0 F12000 X-8.75 Y8.75 Z5.65
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E521.93305
G1 X8.75 Y-8.75 E522.29684
G1 X8.75 Y8.75 E522.66062
G1 X-8.75 Y8.75 E523.02440
G1 F540 X-9.25 Y-9.25 E523.40897
G1 X9.25 Y-9.25 E523.79354
G1 X9.25 Y9.25 E524.17811
G1 X-9.25 Y9.25 E524.56268
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E524.96804
G1 X9.75 Y-9.75 E525.37340
G1 X9.75 Y9.75 E525.77876
G1 X-9.75 Y9.75 E526.18411
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E526.65360
G1 F540 X-8.57 Y7.40 E527.12309
G1 F540 X5.04 Y-8.57 E527.52331
G1 F540 X-8.57 Y2.68 E527.85428
G1 F540 X0.33 Y-8.57 E528.11598
G1 F540 X-8.57 Y-2.03 E528.30845
G1 F540 X-4.38 Y-8.57 E528.43163
G1 F540 X-8.57 Y-6.74 E528.48554
G1 F540 X8.57 Y-5.04 E528.88577
G1 F540 X-2.68 Y8.57 E529.21673
G1 F540 X8.57 Y-0.33 E529.47843
G1 F540 X2.03 Y8.57 E529.67090
G1 F540 X8.57 Y4.38 E529.79408
G1 F540 X6.74 Y8.57 E529.84800
;LAYER:54
G0 F12000 X8.75 Y8.75 Z5.75
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E530.21178
G1 X-8.75 Y-8.75 E530.57556
G1 X8.75 Y-8.75 E530.93935
G1 X8.75 Y8.75 E531.30313
G1 F540 X-9.25 Y9.25 E531.68770
G1 X-9.25 Y-9.25 E532.07227
G1 X9.25 Y-9.25 E532.45684
G1 X9.25 Y9.25 E532.84141
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E533.24677
G1 X-9.75 Y-9.75 E533.65213
G1 X9.75 Y-9.75 E534.05748
G1 X9.75 Y9.75 E534.46284
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E534.93233
G1 F540 X8.57 Y7.40 E535.40182
G1 F540 X-5.04 Y-8.57 E535.80204
G1 F540 X8.57 Y2.68 E536.13300
G1 F540 X-0.33 Y-8.57 E536.39471
G1 F540 X8.57 Y-2.03 E536.58718
G1 F540 X4.38 Y-8.57 E536.71035
G1 F540 X8.57 Y-6.74 E536.76427
G1 F540 X-8.57 Y-5.04 E537.16450
G1 F540 X2.68 Y8.57 E537.49546
G1 F540 X-8.57 Y-0.33 E537.75716
G1 F540 X-2.03 Y8.57 E537.94963
G1 F540 X-8.57 Y4.38 E538.07281
G1 F540 X-6.74 Y8.57 E538.12672
;LAYER:55
G0 F12000 X-8.75 Y8.75 Z5.85
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E538.49051
G1 X8.75 Y-8.75 E538.85429
G1 X8.75 Y8.75 E539.21807
G1 X-8.75 Y8.75 E539.58186
G1 F540 X-9.25 Y-9.25 E539.96643
G1 X9.25 Y-9.25 E540.35100
G1 X9.25 Y9.25 E540.73557
G1 X-9.25 Y9.25 E541.12014
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E541.52549
G1 X9.75 Y-9.75 E541.93085
G1 X9.75 Y9.75 E542.33621
G1 X-9.75 Y9.75 E542.74157
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E543.21106
G1 F540 X-8.57 Y7.40 E543.68054
G1 F540 X5.04 Y-8.57 E544.08077
G1 F540 X-8.57 Y2.68 E544.41173
G1 F540 X0.33 Y-8.57 E544.67343
G1 F540 X-8.57 Y-2.03 E544.86590
G1 F540 X-4.38 Y-8.57 E544.98908
G1 F540 X-8.57 Y-6.74 E545.04300
G1 F540 X8.57 Y-5.04 E545.44322
G1 F540 X-2.68 Y8.57 E545.77419
G1 F540 X8.57 Y-0.33 E546.03589
G1 F540 X2.03 Y8.57 E546.22836
G1 F540 X8.57 Y4.38 E546.35154
G1 F540 X6.74 Y8.57 E546.40545
;LAYER:56
G0 F12000 X8.75 Y8.75 Z5.95
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E546.76923
G1 X-8.75 Y-8.75 E547.13302
G1 X8.75 Y-8.75 E547.49680
G1 X8.75 Y8.75 E547.86058
G1 F540 X-9.25 Y9.25 E548.24515
G1 X-9.25 Y-9.25 E548.62972
G1 X9.25 Y-9.25 E549.01429
G1 X9.25 Y9.25 E549.39886
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E549.80422
G1 X-9.75 Y-9.75 E550.20958
G1 X9.75 Y-9.75 E550.61494
G1 X9.75 Y9.75 E551.02029
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E551.48978
G1 F540 X8.57 Y7.40 E551.95927
G1 F540 X-5.04 Y-8.57 E552.35950
G1 F540 X8.57 Y2.68 E552.69046
G1 F540 X-0.33 Y-8.57 E552.95216
G1 F540 X8.57 Y-2.03 E553.14463
G1 F540 X4.38 Y-8.57 E553.26781
G1 F540 X8.57 Y-6.74 E553.32172
G1 F540 X-8.57 Y-5.04 E553.72195
G1 F540 X2.68 Y8.57 E554.05291
G1 F540 X-8.57 Y-0.33 E554.31461
G1 F540 X-2.03 Y8.57 E554.50708
G1 F540 X-8.57 Y4.38 E554.63026
G1 F540 X-6.74 Y8.57 E554.68418
;LAYER:57
G0 F12000 X-8.75 Y8.75 Z6.05
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E555.04796
G1 X8.75 Y-8.75 E555.41174
G1 X8.75 Y8.75 E555.77553
G1 X-8.75 Y8.75 E556.13931
G1 F540 X-9.25 Y-9.25 E556.52388
G1 X9.25 Y-9.25 E556.90845
G1 X9.25 Y9.25 E557.29302
G1 X-9.25 Y9.25 E557.67759
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E558.08295
G1 X9.75 Y-9.75 E558.48831
G1 X9.75 Y9.75 E558.89366
G1 X-9.75 Y9.75 E559.29902
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E559.76851
G1 F540 X-8.57 Y7.40 E560.23800
G1 F540 X5.04 Y-8.57 E560.63822
G1 F540 X-8.57 Y2.68 E560.96919
G1 F540 X0.33 Y-8.57 E561.23089
G1 F540 X-8.57 Y-2.03 E561.42336
G1 F540 X-4.38 Y-8.57 E561.54653
G1 F540 X-8.57 Y-6.74 E561.60045
G1 F540 X8.57 Y-5.04 E562.00068
G1 F540 X-2.68 Y8.57 E562.33164
G1 F540 X8.57 Y-0.33 E562.59334
G1 F540 X2.03 Y8.57 E562.78581
G1 F540 X8.57 Y4.38 E562.90899
G1 F540 X6.74 Y8.57 E562.96290
;LAYER:58
G0 F12000 X8.75 Y8.75 Z6.15
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E563.32669
G1 X-8.75 Y-8.75 E563.69047
G1 X8.75 Y-8.75 E564.05425
G1 X8.75 Y8.75 E564.41804
G1 F540 X-9.25 Y9.25 E564.80261
G1 X-9.25 Y-9.25 E565.18718
G1 X9.25 Y-9.25 E565.57175
G1 X9.25 Y9.25 E565.95632
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E566.36168
G1 X-9.75 Y-9.75 E566.76703
G1 X9.75 Y-9.75 E567.17239
G1 X9.75 Y9.75 E567.57775
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E568.04724
G1 F540 X8.57 Y7.40 E568.51672
G1 F540 X-5.04 Y-8.57 E568.91695
G1 F540 X8.57 Y2.68 E569.24791
G1 F540 X-0.33 Y-8.57 E569.50961
G1 F540 X8.57 Y-2.03 E569.70208
G1 F540 X4.38 Y-8.57 E569.82526
G1 F540 X8.57 Y-6.74 E569.87918
G1 F540 X-8.57 Y-5.04 E570.27940
G1 F540 X2.68 Y8.57 E570.61037
G1 F540 X-8.57 Y-0.33 E570.87207
G1 F540 X-2.03 Y8.57 E571.06454
G1 F540 X-8.57 Y4.38 E571.18772
G1 F540 X-6.74 Y8.57 E571.24163
;LAYER:59
G0 F12000 X-8.75 Y8.75 Z6.25
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E571.60541
G1 X8.75 Y-8.75 E571.96920
G1 X8.75 Y8.75 E572.33298
G1 X-8.75 Y8.75 E572.69676
G1 F540 X-9.25 Y-9.25 E573.08133
G1 X9.25 Y-9.25 E573.46590
G1 X9.25 Y9.25 E573.85047
G1 X-9.25 Y9.25 E574.23504
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E574.64040
G1 X9.75 Y-9.75 E575.04576
G1 X9.75 Y9.75 E575.45112
G1 X-9.75 Y9.75 E575.85648
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E576.32596
G1 F540 X-8.57 Y7.40 E576.79545
G1 F540 X5.04 Y-8.57 E577.19568
G1 F540 X-8.57 Y2.68 E577.52664
G1 F540 X0.33 Y-8.57 E577.78834
G1 F540 X-8.57 Y-2.03 E577.98081
G1 F540 X-4.38 Y-8.57 E578.10399
G1 F540 X-8.57 Y-6.74 E578.15790
G1 F540 X8.57 Y-5.04 E578.55813
G1 F540 X-2.68 Y8.57 E578.88909
G1 F540 X8.57 Y-0.33 E579.15080
G1 F540 X2.03 Y8.57 E579.34326
G1 F540 X8.57 Y4.38 E579.46644
G1 F540 X6.74 Y8.57 E579.52036
;LAYER:60
G0 F12000 X8.75 Y8.75 Z6.35
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E579.88414
G1 X-8.75 Y-8.75 E580.24792
G1 X8.75 Y-8.75 E580.61171
G1 X8.75 Y8.75 E580.97549
G1 F540 X-9.25 Y9.25 E581.36006
G1 X-9.25 Y-9.25 E581.74463
G1 X9.25 Y-9.25 E582.12920
G1 X9.25 Y9.25 E582.51377
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E582.91913
G1 X-9.75 Y-9.75 E583.32449
G1 X9.75 Y-9.75 E583.72984
G1 X9.75 Y9.75 E584.13520
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E584.60469
G1 F540 X8.57 Y7.40 E585.07418
G1 F540 X-5.04 Y-8.57 E585.47440
G1 F540 X8.57 Y2.68 E585.80537
G1 F540 X-0.33 Y-8.57 E586.06707
G1 F540 X8.57 Y-2.03 E586.25954
G1 F540 X4.38 Y-8.57 E586.38272
G1 F540 X8.57 Y-6.74 E586.43663
G1 F540 X-8.57 Y-5.04 E586.83686
G1 F540 X2.68 Y8.57 E587.16782
G1 F540 X-8.57 Y-0.33 E587.42952
G1 F540 X-2.03 Y8.57 E587.62199
G1 F540 X-8.57 Y4.38 E587.74517
G1 F540 X-6.74 Y8.57 E587.79909
;LAYER:61
G0 F12000 X-8.75 Y8.75 Z6.45
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E588.16287
G1 X8.75 Y-8.75 E588.52665
G1 X8.75 Y8.75 E588.89043
G1 X-8.75 Y8.75 E589.25422
G1 F540 X-9.25 Y-9.25 E589.63879
G1 X9.25 Y-9.25 E590.02336
G1 X9.25 Y9.25 E590.40793
G1 X-9.25 Y9.25 E590.79250
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E591.19786
G1 X9.75 Y-9.75 E591.60321
G1 X9.75 Y9.75 E592.00857
G1 X-9.75 Y9.75 E592.41393
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E592.88342
G1 F540 X-8.57 Y7.40 E593.35290
G1 F540 X5.04 Y-8.57 E593.75313
G1 F540 X-8.57 Y2.68 E594.08409
G1 F540 X0.33 Y-8.57 E594.34580
G1 F540 X-8.57 Y-2.03 E594.53826
G1 F540 X-4.38 Y-8.57 E594.66144
G1 F540 X-8.57 Y-6.74 E594.71536
G1 F540 X8.57 Y-5.04 E595.11558
G1 F540 X-2.68 Y8.57 E595.44655
G1 F540 X8.57 Y-0.33 E595.70825
G1 F540 X2.03 Y8.57 E595.90072
G1 F540 X8.57 Y4.38 E596.02390
G1 F540 X6.74 Y8.57 E596.07781
;LAYER:62
G0 F12000 X8.75 Y8.75 Z6.55
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E596.44160
G1 X-8.75 Y-8.75 E596.80538
G1 X8.75 Y-8.75 E597.16916
G1 X8.75 Y8.75 E597.53294
G1 F540 X-9.25 Y9.25 E597.91751
G1 X-9.25 Y-9.25 E598.30208
G1 X9.25 Y-9.25 E598.68665
G1 X9.25 Y9.25 E599.07122
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E599.47658
G1 X-9.75 Y-9.75 E599.88194
G1 X9.75 Y-9.75 E600.28730
G1 X9.75 Y9.75 E600.69266
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E601.16214
G1 F540 X8.57 Y7.40 E601.63163
G1 F540 X-5.04 Y-8.57 E602.03186
G1 F540 X8.57 Y2.68 E602.36282
G1 F540 X-0.33 Y-8.57 E602.62452
G1 F540 X8.57 Y-2.03 E602.81699
G1 F540 X4.38 Y-8.57 E602.94017
G1 F540 X8.57 Y-6.74 E602.99409
G1 F540 X-8.57 Y-5.04 E603.39431
G1 F540 X2.68 Y8.57 E603.72527
G1 F540 X-8.57 Y-0.33 E603.98698
G1 F540 X-2.03 Y8.57 E604.17945
G1 F540 X-8.57 Y4.38 E604.30262
G1 F540 X-6.74 Y8.57 E604.35654
;LAYER:63
G0 F12000 X-8.75 Y8.75 Z6.65
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E604.72032
G1 X8.75 Y-8.75 E605.08411
G1 X8.75 Y8.75 E605.44789
G1 X-8.75 Y8.75 E605.81167
G0 F12000 X-9.25 Y9.25
G1 F540 X-9.25 Y-9.25 E606.19624
G1 X9.25 Y-9.25 E606.58081
G1 X9.25 Y9.25 E606.96538
G1 X-9.25 Y9.25 E607.34995
G0 F12000 X-9.75 Y9.75
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E607.75531
G1 X9.75 Y-9.75 E608.16067
G1 X9.75 Y9.75 E608.56603
G1 X-9.75 Y9.75 E608.97138
G0 F12000 X-9.49 Y9.40
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E609.44087
G1 F540 X-8.57 Y7.40 E609.91036
G1 F540 X5.04 Y-8.57 E610.31058
G1 F540 X-8.57 Y2.68 E610.64155
G1 F540 X0.33 Y-8.57 E610.90325
G1 F540 X-8.57 Y-2.03 E611.09572
G1 F540 X-4.38 Y-8.57 E611.21890
G1 F540 X-8.57 Y-6.74 E611.27281
G1 F540 X8.57 Y-5.04 E611.67304
G1 F540 X-2.68 Y8.57 E612.00400
G1 F540 X8.57 Y-0.33 E612.26570
G1 F540 X2.03 Y8.57 E612.45817
G1 F540 X8.57 Y4.38 E612.58135
G1 F540 X6.74 Y8.57 E612.63527
;LAYER:64
G0 F12000 X8.75 Y8.75 Z6.75
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E612.99905
G1 X-8.75 Y-8.75 E613.36283
G1 X8.75 Y-8.75 E613.72661
G1 X8.75 Y8.75 E614.09040
G1 F540 X-9.25 Y9.25 E614.47497
G1 X-9.25 Y-9.25 E614.85954
G1 X9.25 Y-9.25 E615.24411
G1 X9.25 Y9.25 E615.62868
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E616.03404
G1 X-9.75 Y-9.75 E616.43939
G1 X9.75 Y-9.75 E616.84475
G1 X9.75 Y9.75 E617.25011
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E617.71960
G1 F540 X8.57 Y7.40 E618.18909
G1 F540 X-5.04 Y-8.57 E618.58931
G1 F540 X8.57 Y2.68 E618.92027
G1 F540 X-0.33 Y-8.57 E619.18198
G1 F540 X8.57 Y-2.03 E619.37445
G1 F540 X4.38 Y-8.57 E619.49762
G1 F540 X8.57 Y-6.74 E619.55154
G1 F540 X-8.57 Y-5.04 E619.95176
G1 F540 X2.68 Y8.57 E620.28273
G1 F540 X-8.57 Y-0.33 E620.54443
G1 F540 X-2.03 Y8.57 E620.73690
G1 F540 X-8.57 Y4.38 E620.86008
G1 F540 X-6.74 Y8.57 E620.91399
;LAYER:65
G0 F12000 X-8.75 Y8.75 Z6.85
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E621.27778
G1 X8.75 Y-8.75 E621.64156
G1 X8.75 Y8.75 E622.00534
G1 X-8.75 Y8.75 E622.36912
G1 F540 X-9.25 Y-9.25 E622.75369
G1 X9.25 Y-9.25 E623.13826
G1 X9.25 Y9.25 E623.52284
G1 X-9.25 Y9.25 E623.90741
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E624.31276
G1 X9.75 Y-9.75 E624.71812
G1 X9.75 Y9.75 E625.12348
G1 X-9.75 Y9.75 E625.52884
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E625.99832
G1 F540 X-8.57 Y7.40 E626.46781
G1 F540 X5.04 Y-8.57 E626.86804
G1 F540 X-8.57 Y2.68 E627.19900
G1 F540 X0.33 Y-8.57 E627.46070
G1 F540 X-8.57 Y-2.03 E627.65317
G1 F540 X-4.38 Y-8.57 E627.77635
G1 F540 X-8.57 Y-6.74 E627.83027
G1 F540 X8.57 Y-5.04 E628.23049
G1 F540 X-2.68 Y8.57 E628.56146
G1 F540 X8.57 Y-0.33 E628.82316
G1 F540 X2.03 Y8.57 E629.01563
G1 F540 X8.57 Y4.38 E629.13880
G1 F540 X6.74 Y8.57 E629.19272
;LAYER:66
G0 F12000 X8.75 Y8.75 Z6.95
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E629.55650
G1 X-8.75 Y-8.75 E629.92029
G1 X8.75 Y-8.75 E630.28407
G1 X8.75 Y8.75 E630.64785
G1 F540 X-9.25 Y9.25 E631.03242
G1 X-9.25 Y-9.25 E631.41699
G1 X9.25 Y-9.25 E631.80156
G1 X9.25 Y9.25 E632.18613
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E632.59149
G1 X-9.75 Y-9.75 E632.99685
G1 X9.75 Y-9.75 E633.40221
G1 X9.75 Y9.75 E633.80756
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E634.27705
G1 F540 X8.57 Y7.40 E634.74654
G1 F540 X-5.04 Y-8.57 E635.14676
G1 F540 X8.57 Y2.68 E635.47773
G1 F540 X-0.33 Y-8.57 E635.73943
G1 F540 X8.57 Y-2.03 E635.93190
G1 F540 X4.38 Y-8.57 E636.05508
G1 F540 X8.57 Y-6.74 E636.10899
G1 F540 X-8.57 Y-5.04 E636.50922
G1 F540 X2.68 Y8.57 E636.84018
G1 F540 X-8.57 Y-0.33 E637.10188
G1 F540 X-2.03 Y8.57 E637.29435
G1 F540 X-8.57 Y4.38 E637.41753
G1 F540 X-6.74 Y8.57 E637.47145
;LAYER:67
G0 F12000 X-8.75 Y8.75 Z7.05
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E637.83523
G1 X8.75 Y-8.75 E638.19901
G1 X8.75 Y8.75 E638.56280
G1 X-8.75 Y8.75 E638.92658
G1 F540 X-9.25 Y-9.25 E639.31115
G1 X9.25 Y-9.25 E639.69572
G1 X9.25 Y9.25 E640.08029
G1 X-9.25 Y9.25 E640.46486
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E640.87022
G1 X9.75 Y-9.75 E641.27558
G1 X9.75 Y9.75 E641.68093
G1 X-9.75 Y9.75 E642.08629
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E642.55578
G1 F540 X-8.57 Y7.40 E643.02527
G1 F540 X5.04 Y-8.57 E643.42549
G1 F540 X-8.57 Y2.68 E643.75645
G1 F540 X0.33 Y-8.57 E644.01816
G1 F540 X-8.57 Y-2.03 E644.21063
G1 F540 X-4.38 Y-8.57 E644.33380
G1 F540 X-8.57 Y-6.74 E644.38772
G1 F540 X8.57 Y-5.04 E644.78795
G1 F540 X-2.68 Y8.57 E645.11891
G1 F540 X8.57 Y-0.33 E645.38061
G1 F540 X2.03 Y8.57 E645.57308
G1 F540 X8.57 Y4.38 E645.69626
G1 F540 X6.74 Y8.57 E645.75017
;LAYER:68
G0 F12000 X8.75 Y8.75 Z7.15
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E646.11396
G1 X-8.75 Y-8.75 E646.47774
G1 X8.75 Y-8.75 E646.84152
G1 X8.75 Y8.75 E647.20531
G0 F12000 X9.25 Y9.25
G1 F540 X-9.25 Y9.25 E647.58988
G1 X-9.25 Y-9.25 E647.97445
G1 X9.25 Y-9.25 E648.35902
G1 X9.25 Y9.25 E648.74359
G0 F12000 X9.75 Y9.75
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E649.14894
G1 X-9.75 Y-9.75 E649.55430
G1 X9.75 Y-9.75 E649.95966
G1 X9.75 Y9.75 E650.36502
G0 F12000 X9.40 Y9.49
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E650.83451
G1 F540 X8.57 Y7.40 E651.30399
G1 F540 X-5.04 Y-8.57 E651.70422
G1 F540 X8.57 Y2.68 E652.03518
G1 F540 X-0.33 Y-8.57 E652.29688
G1 F540 X8.57 Y-2.03 E652.48935
G1 F540 X4.38 Y-8.57 E652.61253
G1 F540 X8.57 Y-6.74 E652.66645
G1 F540 X-8.57 Y-5.04 E653.06667
G1 F540 X2.68 Y8.57 E653.39764
G1 F540 X-8.57 Y-0.33 E653.65934
G1 F540 X-2.03 Y8.57 E653.85181
G1 F540 X-8.57 Y4.38 E653.97499
G1 F540 X-6.74 Y8.57 E654.02890
;LAYER:69
G0 F12000 X-8.75 Y8.75 Z7.25
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E654.39268
G1 X8.75 Y-8.75 E654.75647
G1 X8.75 Y8.75 E655.12025
G1 X-8.75 Y8.75 E655.48403
G1 F540 X-9.25 Y-9.25 E655.86860
G1 X9.25 Y-9.25 E656.25317
G1 X9.25 Y9.25 E656.63774
G1 X-9.25 Y9.25 E657.02231
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E657.42767
G1 X9.75 Y-9.75 E657.83303
G1 X9.75 Y9.75 E658.23839
G1 X-9.75 Y9.75 E658.64374
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E659.11323
G1 F540 X-8.57 Y7.40 E659.58272
G1 F540 X5.04 Y-8.57 E659.98295
G1 F540 X-8.57 Y2.68 E660.31391
G1 F540 X0.33 Y-8.57 E660.57561
G1 F540 X-8.57 Y-2.03 E660.76808
G1 F540 X-4.38 Y-8.57 E660.89126
G1 F540 X-8.57 Y-6.74 E660.94517
G1 F540 X8.57 Y-5.04 E661.34540
G1 F540 X-2.68 Y8.57 E661.67636
G1 F540 X8.57 Y-0.33 E661.93806
G1 F540 X2.03 Y8.57 E662.13053
G1 F540 X8.57 Y4.38 E662.25371
G1 F540 X6.74 Y8.57 E662.30763
;LAYER:70
G0 F12000 X8.75 Y8.75 Z7.35
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E662.67141
G1 X-8.75 Y-8.75 E663.03519
G1 X8.75 Y-8.75 E663.39898
G1 X8.75 Y8.75 E663.76276
G1 F540 X-9.25 Y9.25 E664.14733
G1 X-9.25 Y-9.25 E664.53190
G1 X9.25 Y-9.25 E664.91647
G1 X9.25 Y9.25 E665.30104
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E665.70640
G1 X-9.75 Y-9.75 E666.11176
G1 X9.75 Y-9.75 E666.51711
G1 X9.75 Y9.75 E666.92247
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E667.39196
G1 F540 X8.57 Y7.40 E667.86145
G1 F540 X-5.04 Y-8.57 E668.26167
G1 F540 X8.57 Y2.68 E668.59264
G1 F540 X-0.33 Y-8.57 E668.85434
G1 F540 X8.57 Y-2.03 E669.04681
G1 F540 X4.38 Y-8.57 E669.16998
G1 F540 X8.57 Y-6.74 E669.22390
G1 F540 X-8.57 Y-5.04 E669.62413
G1 F540 X2.68 Y8.57 E669.95509
G1 F540 X-8.57 Y-0.33 E670.21679
G1 F540 X-2.03 Y8.57 E670.40926
G1 F540 X-8.57 Y4.38 E670.53244
G1 F540 X-6.74 Y8.57 E670.58635
;LAYER:71
G0 F12000 X-8.75 Y8.75 Z7.45
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E670.95014
G1 X8.75 Y-8.75 E671.31392
G1 X8.75 Y8.75 E671.67770
G1 X-8.75 Y8.75 E672.04149
G1 F540 X-9.25 Y-9.25 E672.42606
G1 X9.25 Y-9.25 E672.81063
G1 X9.25 Y9.25 E673.19520
G1 X-9.25 Y9.25 E673.57977
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E673.98512
G1 X9.75 Y-9.75 E674.39048
G1 X9.75 Y9.75 E674.79584
G1 X-9.75 Y9.75 E675.20120
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E675.67069
G0 F12000 X7.40 Y-8.57
G1 F540 X-8.57 Y7.40 E676.14017
G0 F12000 X-8.57 Y5.04
G1 F540 X5.04 Y-8.57 E676.54040
G0 F12000 X2.68 Y-8.57
G1 F540 X-8.57 Y2.68 E676.87136
G0 F12000 X-8.57 Y0.33
G1 F540 X0.33 Y-8.57 E677.13306
G0 F12000 X-2.03 Y-8.57
G1 F540 X-8.57 Y-2.03 E677.32553
G0 F12000 X-8.57 Y-4.38
G1 F540 X-4.38 Y-8.57 E677.44871
G0 F12000 X-6.74 Y-8.57
G1 F540 X-8.57 Y-6.74 E677.50263
G0 F12000 X-5.04 Y8.57
G1 F540 X8.57 Y-5.04 E677.90285
G0 F12000 X8.57 Y-2.68
G1 F540 X-2.68 Y8.57 E678.23382
G0 F12000 X-0.33 Y8.57
G1 F540 X8.57 Y-0.33 E678.49552
G0 F12000 X8.57 Y2.03
G1 F540 X2.03 Y8.57 E678.68799
G0 F12000 X4.38 Y8.57
G1 F540 X8.57 Y4.38 E678.81117
G0 F12000 X8.57 Y6.74
G1 F540 X6.74 Y8.57 E678.86508
;LAYER:72
G0 F12000 X8.75 Y8.75 Z7.55
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E679.22886
G1 X-8.75 Y-8.75 E679.59265
G1 X8.75 Y-8.75 E679.95643
G1 X8.75 Y8.75 E680.32021
G1 F540 X-9.25 Y9.25 E680.70478
G1 X-9.25 Y-9.25 E681.08935
G1 X9.25 Y-9.25 E681.47392
G1 X9.25 Y9.25 E681.85849
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E682.26385
G1 X-9.75 Y-9.75 E682.66921
G1 X9.75 Y-9.75 E683.07457
G1 X9.75 Y9.75 E683.47993
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E683.94941
G0 F12000 X-7.40 Y-8.57
G1 F540 X8.57 Y7.40 E684.41890
G0 F12000 X8.57 Y5.04
G1 F540 X-5.04 Y-8.57 E684.81913
G0 F12000 X-2.68 Y-8.57
G1 F540 X8.57 Y2.68 E685.15009
G0 F12000 X8.57 Y0.33
G1 F540 X-0.33 Y-8.57 E685.41179
G0 F12000 X2.03 Y-8.57
G1 F540 X8.57 Y-2.03 E685.60426
G0 F12000 X8.57 Y-4.38
G1 F540 X4.38 Y-8.57 E685.72744
G0 F12000 X6.74 Y-8.57
G1 F540 X8.57 Y-6.74 E685.78135
G0 F12000 X5.04 Y8.57
G1 F540 X-8.57 Y-5.04 E686.18158
G0 F12000 X-8.57 Y-2.68
G1 F540 X2.68 Y8.57 E686.51254
G0 F12000 X0.33 Y8.57
G1 F540 X-8.57 Y-0.33 E686.77425
G0 F12000 X-8.57 Y2.03
G1 F540 X-2.03 Y8.57 E686.96671
G0 F12000 X-4.38 Y8.57
G1 F540 X-8.57 Y4.38 E687.08989
G0 F12000 X-8.57 Y6.74
G1 F540 X-6.74 Y8.57 E687.14381
;LAYER:73
G0 F12000 X-8.75 Y8.75 Z7.65
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E687.50759
G1 X8.75 Y-8.75 E687.87137
G1 X8.75 Y8.75 E688.23516
G1 X-8.75 Y8.75 E688.59894
G1 F540 X-9.25 Y-9.25 E688.98351
G1 X9.25 Y-9.25 E689.36808
G1 X9.25 Y9.25 E689.75265
G1 X-9.25 Y9.25 E690.13722
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E690.54258
G1 X9.75 Y-9.75 E690.94794
G1 X9.75 Y9.75 E691.35329
G1 X-9.75 Y9.75 E691.75865
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E692.22814
G1 F540 X-8.57 Y7.40 E692.69763
G1 F540 X5.04 Y-8.57 E693.09785
G1 F540 X-8.57 Y2.68 E693.42882
G1 F540 X0.33 Y-8.57 E693.69052
G1 F540 X-8.57 Y-2.03 E693.88299
G1 F540 X-4.38 Y-8.57 E694.00617
G1 F540 X-8.57 Y-6.74 E694.06008
G1 F540 X8.57 Y-5.04 E694.46031
G1 F540 X-2.68 Y8.57 E694.79127
G1 F540 X8.57 Y-0.33 E695.05297
G1 F540 X2.03 Y8.57 E695.24544
G1 F540 X8.57 Y4.38 E695.36862
G1 F540 X6.74 Y8.57 E695.42254
;LAYER:74
G0 F12000 X8.75 Y8.75 Z7.75
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E695.78632
G1 X-8.75 Y-8.75 E696.15010
G1 X8.75 Y-8.75 E696.51388
G1 X8.75 Y8.75 E696.87767
G1 F540 X-9.25 Y9.25 E697.26224
G1 X-9.25 Y-9.25 E697.64681
G1 X9.25 Y-9.25 E698.03138
G1 X9.25 Y9.25 E698.41595
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E698.82131
G1 X-9.75 Y-9.75 E699.22666
G1 X9.75 Y-9.75 E699.63202
G1 X9.75 Y9.75 E700.03738
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E700.50687
G1 F540 X8.57 Y7.40 E700.97635
G1 F540 X-5.04 Y-8.57 E701.37658
G1 F540 X8.57 Y2.68 E701.70754
G1 F540 X-0.33 Y-8.57 E701.96925
G1 F540 X8.57 Y-2.03 E702.16171
G1 F540 X4.38 Y-8.57 E702.28489
G1 F540 X8.57 Y-6.74 E702.33881
G1 F540 X-8.57 Y-5.04 E702.73903
G1 F540 X2.68 Y8.57 E703.07000
G1 F540 X-8.57 Y-0.33 E703.33170
G1 F540 X-2.03 Y8.57 E703.52417
G1 F540 X-8.57 Y4.38 E703.64735
G1 F540 X-6.74 Y8.57 E703.70126
;LAYER:75
G0 F12000 X-8.75 Y8.75 Z7.85
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E704.06505
G1 X8.75 Y-8.75 E704.42883
G1 X8.75 Y8.75 E704.79261
G1 X-8.75 Y8.75 E705.15639
G1 F540 X-9.25 Y-9.25 E705.54096
G1 X9.25 Y-9.25 E705.92553
G1 X9.25 Y9.25 E706.31010
G1 X-9.25 Y9.25 E706.69467
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E707.10003
G1 X9.75 Y-9.75 E707.50539
G1 X9.75 Y9.75 E707.91075
G1 X-9.75 Y9.75 E708.31611
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E708.78559
G1 F540 X-8.57 Y7.40 E709.25508
G1 F540 X5.04 Y-8.57 E709.65531
G1 F540 X-8.57 Y2.68 E709.98627
G1 F540 X0.33 Y-8.57 E710.24797
G1 F540 X-8.57 Y-2.03 E710.44044
G1 F540 X-4.38 Y-8.57 E710.56362
G1 F540 X-8.57 Y-6.74 E710.61754
G1 F540 X8.57 Y-5.04 E711.01776
G1 F540 X-2.68 Y8.57 E711.34872
G1 F540 X8.57 Y-0.33 E711.61043
G1 F540 X2.03 Y8.57 E711.80290
G1 F540 X8.57 Y4.38 E711.92607
G1 F540 X6.74 Y8.57 E711.97999
;LAYER:76
G0 F12000 X8.75 Y8.75 Z7.95
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E712.34377
G1 X-8.75 Y-8.75 E712.70756
G1 X8.75 Y-8.75 E713.07134
G1 X8.75 Y8.75 E713.43512
G1 F540 X-9.25 Y9.25 E713.81969
G1 X-9.25 Y-9.25 E714.20426
G1 X9.25 Y-9.25 E714.58883
G1 X9.25 Y9.25 E714.97340
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E715.37876
G1 X-9.75 Y-9.75 E715.78412
G1 X9.75 Y-9.75 E716.18948
G1 X9.75 Y9.75 E716.59483
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E717.06432
G1 F540 X8.57 Y7.40 E717.53381
G1 F540 X-5.04 Y-8.57 E717.93403
G1 F540 X8.57 Y2.68 E718.26500
G1 F540 X-0.33 Y-8.57 E718.52670
G1 F540 X8.57 Y-2.03 E718.71917
G1 F540 X4.38 Y-8.57 E718.84235
G1 F540 X8.57 Y-6.74 E718.89626
G1 F540 X-8.57 Y-5.04 E719.29649
G1 F540 X2.68 Y8.57 E719.62745
G1 F540 X-8.57 Y-0.33 E719.88915
G1 F540 X-2.03 Y8.57 E720.08162
G1 F540 X-8.57 Y4.38 E720.20480
G1 F540 X-6.74 Y8.57 E720.25872
;LAYER:77
G0 F12000 X-8.75 Y8.75 Z8.05
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E720.62250
G1 X8.75 Y-8.75 E720.98628
G1 X8.75 Y8.75 E721.35006
G1 X-8.75 Y8.75 E721.71385
G1 F540 X-9.25 Y-9.25 E722.09842
G1 X9.25 Y-9.25 E722.48299
G1 X9.25 Y9.25 E722.86756
G1 X-9.25 Y9.25 E723.25213
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E723.65749
G1 X9.75 Y-9.75 E724.06284
G1 X9.75 Y9.75 E724.46820
G1 X-9.75 Y9.75 E724.87356
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E725.34305
G1 F540 X-8.57 Y7.40 E725.81254
G1 F540 X5.04 Y-8.57 E726.21276
G1 F540 X-8.57 Y2.68 E726.54372
G1 F540 X0.33 Y-8.57 E726.80543
G1 F540 X-8.57 Y-2.03 E726.99790
G1 F540 X-4.38 Y-8.57 E727.12107
G1 F540 X-8.57 Y-6.74 E727.17499
G1 F540 X8.57 Y-5.04 E727.57521
G1 F540 X-2.68 Y8.57 E727.90618
G1 F540 X8.57 Y-0.33 E728.16788
G1 F540 X2.03 Y8.57 E728.36035
G1 F540 X8.57 Y4.38 E728.48353
G1 F540 X6.74 Y8.57 E728.53744
;LAYER:78
G0 F12000 X8.75 Y8.75 Z8.15
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E728.90123
G1 X-8.75 Y-8.75 E729.26501
G1 X8.75 Y-8.75 E729.62879
G1 X8.75 Y8.75 E729.99257
G1 F540 X-9.25 Y9.25 E730.37714
G1 X-9.25 Y-9.25 E730.76171
G1 X9.25 Y-9.25 E731.14629
G1 X9.25 Y9.25 E731.53086
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E731.93621
G1 X-9.75 Y-9.75 E732.34157
G1 X9.75 Y-9.75 E732.74693
G1 X9.75 Y9.75 E733.15229
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E733.62177
G1 F540 X8.57 Y7.40 E734.09126
G1 F540 X-5.04 Y-8.57 E734.49149
G1 F540 X8.57 Y2.68 E734.82245
G1 F540 X-0.33 Y-8.57 E735.08415
G1 F540 X8.57 Y-2.03 E735.27662
G1 F540 X4.38 Y-8.57 E735.39980
G1 F540 X8.57 Y-6.74 E735.45372
G1 F540 X-8.57 Y-5.04 E735.85394
G1 F540 X2.68 Y8.57 E736.18491
G1 F540 X-8.57 Y-0.33 E736.44661
G1 F540 X-2.03 Y8.57 E736.63908
G1 F540 X-8.57 Y4.38 E736.76225
G1 F540 X-6.74 Y8.57 E736.81617
;LAYER:79
G0 F12000 X-8.75 Y8.75 Z8.25
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E737.17995
G1 X8.75 Y-8.75 E737.54374
G1 X8.75 Y8.75 E737.90752
G1 X-8.75 Y8.75 E738.27130
G1 F540 X-9.25 Y-9.25 E738.65587
G1 X9.25 Y-9.25 E739.04044
G1 X9.25 Y9.25 E739.42501
G1 X-9.25 Y9.25 E739.80958
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E740.21494
G1 X9.75 Y-9.75 E740.62030
G1 X9.75 Y9.75 E741.02566
G1 X-9.75 Y9.75 E741.43101
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E741.90050
G1 F540 X-8.57 Y7.40 E742.36999
G1 F540 X5.04 Y-8.57 E742.77021
G1 F540 X-8.57 Y2.68 E743.10118
G1 F540 X0.33 Y-8.57 E743.36288
G1 F540 X-8.57 Y-2.03 E743.55535
G1 F540 X-4.38 Y-8.57 E743.67853
G1 F540 X-8.57 Y-6.74 E743.73244
G1 F540 X8.57 Y-5.04 E744.13267
G1 F540 X-2.68 Y8.57 E744.46363
G1 F540 X8.57 Y-0.33 E744.72533
G1 F540 X2.03 Y8.57 E744.91780
G1 F540 X8.57 Y4.38 E745.04098
G1 F540 X6.74 Y8.57 E745.09490
;LAYER:80
G0 F12000 X8.75 Y8.75 Z8.35
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E745.45868
G1 X-8.75 Y-8.75 E745.82246
G1 X8.75 Y-8.75 E746.18625
G1 X8.75 Y8.75 E746.55003
G1 F540 X-9.25 Y9.25 E746.93460
G1 X-9.25 Y-9.25 E747.31917
G1 X9.25 Y-9.25 E747.70374
G1 X9.25 Y9.25 E748.08831
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E748.49367
G1 X-9.75 Y-9.75 E748.89903
G1 X9.75 Y-9.75 E749.30438
G1 X9.75 Y9.75 E749.70974
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E750.17923
G1 F540 X8.57 Y7.40 E750.64872
G1 F540 X-5.04 Y-8.57 E751.04894
G1 F540 X8.57 Y2.68 E751.37990
G1 F540 X-0.33 Y-8.57 E751.64161
G1 F540 X8.57 Y-2.03 E751.83408
G1 F540 X4.38 Y-8.57 E751.95725
G1 F540 X8.57 Y-6.74 E752.01117
G1 F540 X-8.57 Y-5.04 E752.41140
G1 F540 X2.68 Y8.57 E752.74236
G1 F540 X-8.57 Y-0.33 E753.00406
G1 F540 X-2.03 Y8.57 E753.19653
G1 F540 X-8.57 Y4.38 E753.31971
G1 F540 X-6.74 Y8.57 E753.37362
;LAYER:81
G0 F12000 X-8.75 Y8.75 Z8.45
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E753.73741
G1 X8.75 Y-8.75 E754.10119
G1 X8.75 Y8.75 E754.46497
G1 X-8.75 Y8.75 E754.82876
G1 F540 X-9.25 Y-9.25 E755.21333
G1 X9.25 Y-9.25 E755.59790
G1 X9.25 Y9.25 E755.98247
G1 X-9.25 Y9.25 E756.36704
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E756.77239
G1 X9.75 Y-9.75 E757.17775
G1 X9.75 Y9.75 E757.58311
G1 X-9.75 Y9.75 E757.98847
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E758.45796
G1 F540 X-8.57 Y7.40 E758.92744
G1 F540 X5.04 Y-8.57 E759.32767
G1 F540 X-8.57 Y2.68 E759.65863
G1 F540 X0.33 Y-8.57 E759.92033
G1 F540 X-8.57 Y-2.03 E760.11280
G1 F540 X-4.38 Y-8.57 E760.23598
G1 F540 X-8.57 Y-6.74 E760.28990
G1 F540 X8.57 Y-5.04 E760.69012
G1 F540 X-2.68 Y8.57 E761.02109
G1 F540 X8.57 Y-0.33 E761.28279
G1 F540 X2.03 Y8.57 E761.47526
G1 F540 X8.57 Y4.38 E761.59843
G1 F540 X6.74 Y8.57 E761.65235
;LAYER:82
G0 F12000 X8.75 Y8.75 Z8.55
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E762.01613
G1 X-8.75 Y-8.75 E762.37992
G1 X8.75 Y-8.75 E762.74370
G1 X8.75 Y8.75 E763.10748
G1 F540 X-9.25 Y9.25 E763.49205
G1 X-9.25 Y-9.25 E763.87662
G1 X9.25 Y-9.25 E764.26119
G1 X9.25 Y9.25 E764.64576
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E765.05112
G1 X-9.75 Y-9.75 E765.45648
G1 X9.75 Y-9.75 E765.86184
G1 X9.75 Y9.75 E766.26719
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E766.73668
G1 F540 X8.57 Y7.40 E767.20617
G1 F540 X-5.04 Y-8.57 E767.60640
G1 F540 X8.57 Y2.68 E767.93736
G1 F540 X-0.33 Y-8.57 E768.19906
G1 F540 X8.57 Y-2.03 E768.39153
G1 F540 X4.38 Y-8.57 E768.51471
G1 F540 X8.57 Y-6.74 E768.56862
G1 F540 X-8.57 Y-5.04 E768.96885
G1 F540 X2.68 Y8.57 E769.29981
G1 F540 X-8.57 Y-0.33 E769.56151
G1 F540 X-2.03 Y8.57 E769.75398
G1 F540 X-8.57 Y4.38 E769.87716
G1 F540 X-6.74 Y8.57 E769.93108
;LAYER:83
G0 F12000 X-8.75 Y8.75 Z8.65
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E770.29486
G1 X8.75 Y-8.75 E770.65864
G1 X8.75 Y8.75 E771.02243
G1 X-8.75 Y8.75 E771.38621
G1 F540 X-9.25 Y-9.25 E771.77078
G1 X9.25 Y-9.25 E772.15535
G1 X9.25 Y9.25 E772.53992
G1 X-9.25 Y9.25 E772.92449
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E773.32985
G1 X9.75 Y-9.75 E773.73521
G1 X9.75 Y9.75 E774.14056
G1 X-9.75 Y9.75 E774.54592
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E775.01541
G1 F540 X-8.57 Y7.40 E775.48490
G1 F540 X5.04 Y-8.57 E775.88512
G1 F540 X-8.57 Y2.68 E776.21609
G1 F540 X0.33 Y-8.57 E776.47779
G1 F540 X-8.57 Y-2.03 E776.67026
G1 F540 X-4.38 Y-8.57 E776.79343
G1 F540 X-8.57 Y-6.74 E776.84735
G1 F540 X8.57 Y-5.04 E777.24758
G1 F540 X-2.68 Y8.57 E777.57854
G1 F540 X8.57 Y-0.33 E777.84024
G1 F540 X2.03 Y8.57 E778.03271
G1 F540 X8.57 Y4.38 E778.15589
G1 F540 X6.74 Y8.57 E778.20980
;LAYER:84
G0 F12000 X8.75 Y8.75 Z8.75
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E778.57359
G1 X-8.75 Y-8.75 E778.93737
G1 X8.75 Y-8.75 E779.30115
G1 X8.75 Y8.75 E779.66494
G1 F540 X-9.25 Y9.25 E780.04951
G1 X-9.25 Y-9.25 E780.43408
G1 X9.25 Y-9.25 E780.81865
G1 X9.25 Y9.25 E781.20322
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E781.60857
G1 X-9.75 Y-9.75 E782.01393
G1 X9.75 Y-9.75 E782.41929
G1 X9.75 Y9.75 E782.82465
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E783.29414
G1 F540 X8.57 Y7.40 E783.76362
G1 F540 X-5.04 Y-8.57 E784.16385
G1 F540 X8.57 Y2.68 E784.49481
G1 F540 X-0.33 Y-8.57 E784.75651
G1 F540 X8.57 Y-2.03 E784.94898
G1 F540 X4.38 Y-8.57 E785.07216
G1 F540 X8.57 Y-6.74 E785.12608
G1 F540 X-8.57 Y-5.04 E785.52630
G1 F540 X2.68 Y8.57 E785.85727
G1 F540 X-8.57 Y-0.33 E786.11897
G1 F540 X-2.03 Y8.57 E786.31144
G1 F540 X-8.57 Y4.38 E786.43462
G1 F540 X-6.74 Y8.57 E786.48853
;LAYER:85
G0 F12000 X-8.75 Y8.75 Z8.85
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E786.85231
G1 X8.75 Y-8.75 E787.21610
G1 X8.75 Y8.75 E787.57988
G1 X-8.75 Y8.75 E787.94366
G1 F540 X-9.25 Y-9.25 E788.32823
G1 X9.25 Y-9.25 E788.71280
G1 X9.25 Y9.25 E789.09737
G1 X-9.25 Y9.25 E789.48194
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E789.88730
G1 X9.75 Y-9.75 E790.29266
G1 X9.75 Y9.75 E790.69802
G1 X-9.75 Y9.75 E791.10338
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E791.57286
G1 F540 X-8.57 Y7.40 E792.04235
G1 F540 X5.04 Y-8.57 E792.44258
G1 F540 X-8.57 Y2.68 E792.77354
G1 F540 X0.33 Y-8.57 E793.03524
G1 F540 X-8.57 Y-2.03 E793.22771
G1 F540 X-4.38 Y-8.57 E793.35089
G1 F540 X-8.57 Y-6.74 E793.40480
G1 F540 X8.57 Y-5.04 E793.80503
G1 F540 X-2.68 Y8.57 E794.13599
G1 F540 X8.57 Y-0.33 E794.39770
G1 F540 X2.03 Y8.57 E794.59016
G1 F540 X8.57 Y4.38 E794.71334
G1 F540 X6.74 Y8.57 E794.76726
;LAYER:86
G0 F12000 X8.75 Y8.75 Z8.95
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E795.13104
G1 X-8.75 Y-8.75 E795.49482
G1 X8.75 Y-8.75 E795.85861
G1 X8.75 Y8.75 E796.22239
G1 F540 X-9.25 Y9.25 E796.60696
G1 X-9.25 Y-9.25 E796.99153
G1 X9.25 Y-9.25 E797.37610
G1 X9.25 Y9.25 E797.76067
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E798.16603
G1 X-9.75 Y-9.75 E798.57139
G1 X9.75 Y-9.75 E798.97674
G1 X9.75 Y9.75 E799.38210
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E799.85159
G1 F540 X8.57 Y7.40 E800.32108
G1 F540 X-5.04 Y-8.57 E800.72130
G1 F540 X8.57 Y2.68 E801.05227
G1 F540 X-0.33 Y-8.57 E801.31397
G1 F540 X8.57 Y-2.03 E801.50644
G1 F540 X4.38 Y-8.57 E801.62962
G1 F540 X8.57 Y-6.74 E801.68353
G1 F540 X-8.57 Y-5.04 E802.08376
G1 F540 X2.68 Y8.57 E802.41472
G1 F540 X-8.57 Y-0.33 E802.67642
G1 F540 X-2.03 Y8.57 E802.86889
G1 F540 X-8.57 Y4.38 E802.99207
G1 F540 X-6.74 Y8.57 E803.04599
;LAYER:87
G0 F12000 X-8.75 Y8.75 Z9.05
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E803.40977
G1 X8.75 Y-8.75 E803.77355
G1 X8.75 Y8.75 E804.13733
G1 X-8.75 Y8.75 E804.50112
G1 F540 X-9.25 Y-9.25 E804.88569
G1 X9.25 Y-9.25 E805.27026
G1 X9.25 Y9.25 E805.65483
G1 X-9.25 Y9.25 E806.03940
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E806.44476
G1 X9.75 Y-9.75 E806.85011
G1 X9.75 Y9.75 E807.25547
G1 X-9.75 Y9.75 E807.66083
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E808.13032
G1 F540 X-8.57 Y7.40 E808.59980
G1 F540 X5.04 Y-8.57 E809.00003
G1 F540 X-8.57 Y2.68 E809.33099
G1 F540 X0.33 Y-8.57 E809.59270
G1 F540 X-8.57 Y-2.03 E809.78516
G1 F540 X-4.38 Y-8.57 E809.90834
G1 F540 X-8.57 Y-6.74 E809.96226
G1 F540 X8.57 Y-5.04 E810.36248
G1 F540 X-2.68 Y8.57 E810.69345
G1 F540 X8.57 Y-0.33 E810.95515
G1 F540 X2.03 Y8.57 E811.14762
G1 F540 X8.57 Y4.38 E811.27080
G1 F540 X6.74 Y8.57 E811.32471
;LAYER:88
G0 F12000 X8.75 Y8.75 Z9.15
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E811.68850
G1 X-8.75 Y-8.75 E812.05228
G1 X8.75 Y-8.75 E812.41606
G1 X8.75 Y8.75 E812.77984
G1 F540 X-9.25 Y9.25 E813.16441
G1 X-9.25 Y-9.25 E813.54898
G1 X9.25 Y-9.25 E813.93355
G1 X9.25 Y9.25 E814.31812
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E814.72348
G1 X-9.75 Y-9.75 E815.12884
G1 X9.75 Y-9.75 E815.53420
G1 X9.75 Y9.75 E815.93956
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E816.40904
G1 F540 X8.57 Y7.40 E816.87853
G1 F540 X-5.04 Y-8.57 E817.27876
G1 F540 X8.57 Y2.68 E817.60972
G1 F540 X-0.33 Y-8.57 E817.87142
G1 F540 X8.57 Y-2.03 E818.06389
G1 F540 X4.38 Y-8.57 E818.18707
G1 F540 X8.57 Y-6.74 E818.24099
G1 F540 X-8.57 Y-5.04 E818.64121
G1 F540 X2.68 Y8.57 E818.97217
G1 F540 X-8.57 Y-0.33 E819.23388
G1 F540 X-2.03 Y8.57 E819.42635
G1 F540 X-8.57 Y4.38 E819.54952
G1 F540 X-6.74 Y8.57 E819.60344
;LAYER:89
G0 F12000 X-8.75 Y8.75 Z9.25
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E819.96722
G1 X8.75 Y-8.75 E820.33100
G1 X8.75 Y8.75 E820.69479
G1 X-8.75 Y8.75 E821.05857
G1 F540 X-9.25 Y-9.25 E821.44314
G1 X9.25 Y-9.25 E821.82771
G1 X9.25 Y9.25 E822.21228
G1 X-9.25 Y9.25 E822.59685
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E823.00221
G1 X9.75 Y-9.75 E823.40757
G1 X9.75 Y9.75 E823.81293
G1 X-9.75 Y9.75 E824.21828
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E824.68777
G1 F540 X-8.57 Y7.40 E825.15726
G1 F540 X5.04 Y-8.57 E825.55748
G1 F540 X-8.57 Y2.68 E825.88845
G1 F540 X0.33 Y-8.57 E826.15015
G1 F540 X-8.57 Y-2.03 E826.34262
G1 F540 X-4.38 Y-8.57 E826.46580
G1 F540 X-8.57 Y-6.74 E826.51971
G1 F540 X8.57 Y-5.04 E826.91994
G1 F540 X-2.68 Y8.57 E827.25090
G1 F540 X8.57 Y-0.33 E827.51260
G1 F540 X2.03 Y8.57 E827.70507
G1 F540 X8.57 Y4.38 E827.82825
G1 F540 X6.74 Y8.57 E827.88217
;LAYER:90
G0 F12000 X8.75 Y8.75 Z9.35
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E828.24595
G1 X-8.75 Y-8.75 E828.60973
G1 X8.75 Y-8.75 E828.97351
G1 X8.75 Y8.75 E829.33730
G1 F540 X-9.25 Y9.25 E829.72187
G1 X-9.25 Y-9.25 E830.10644
G1 X9.25 Y-9.25 E830.49101
G1 X9.25 Y9.25 E830.87558
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E831.28094
G1 X-9.75 Y-9.75 E831.68629
G1 X9.75 Y-9.75 E832.09165
G1 X9.75 Y9.75 E832.49701
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E832.96650
G1 F540 X8.57 Y7.40 E833.43598
G1 F540 X-5.04 Y-8.57 E833.83621
G1 F540 X8.57 Y2.68 E834.16717
G1 F540 X-0.33 Y-8.57 E834.42888
G1 F540 X8.57 Y-2.03 E834.62135
G1 F540 X4.38 Y-8.57 E834.74452
G1 F540 X8.57 Y-6.74 E834.79844
G1 F540 X-8.57 Y-5.04 E835.19866
G1 F540 X2.68 Y8.57 E835.52963
G1 F540 X-8.57 Y-0.33 E835.79133
G1 F540 X-2.03 Y8.57 E835.98380
G1 F540 X-8.57 Y4.38 E836.10698
G1 F540 X-6.74 Y8.57 E836.16089
;LAYER:91
G0 F12000 X-8.75 Y8.75 Z9.45
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E836.52468
G1 X8.75 Y-8.75 E836.88846
G1 X8.75 Y8.75 E837.25224
G1 X-8.75 Y8.75 E837.61602
G1 F540 X-9.25 Y-9.25 E838.00059
G1 X9.25 Y-9.25 E838.38516
G1 X9.25 Y9.25 E838.76974
G1 X-9.25 Y9.25 E839.15431
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E839.55966
G1 X9.75 Y-9.75 E839.96502
G1 X9.75 Y9.75 E840.37038
G1 X-9.75 Y9.75 E840.77574
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E841.24522
G1 F540 X-8.57 Y7.40 E841.71471
G1 F540 X5.04 Y-8.57 E842.11494
G1 F540 X-8.57 Y2.68 E842.44590
G1 F540 X0.33 Y-8.57 E842.70760
G1 F540 X-8.57 Y-2.03 E842.90007
G1 F540 X-4.38 Y-8.57 E843.02325
G1 F540 X-8.57 Y-6.74 E843.07717
G1 F540 X8.57 Y-5.04 E843.47739
G1 F540 X-2.68 Y8.57 E843.80836
G1 F540 X8.57 Y-0.33 E844.07006
G1 F540 X2.03 Y8.57 E844.26253
G1 F540 X8.57 Y4.38 E844.38570
G1 F540 X6.74 Y8.57 E844.43962
;LAYER:92
G0 F12000 X8.75 Y8.75 Z9.55
;TYPE:WALL-INNER
G1 F540 X-8.75 Y8.75 E844.80340
G1 X-8.75 Y-8.75 E845.16719
G1 X8.75 Y-8.75 E845.53097
G1 X8.75 Y8.75 E845.89475
G1 F540 X-9.25 Y9.25 E846.27932
G1 X-9.25 Y-9.25 E846.66389
G1 X9.25 Y-9.25 E847.04846
G1 X9.25 Y9.25 E847.43303
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y9.75 E847.83839
G1 X-9.75 Y-9.75 E848.24375
G1 X9.75 Y-9.75 E848.64911
G1 X9.75 Y9.75 E849.05446
G0 X7.40 Y8.57
;TYPE:FILL
G1 F540 X-8.57 Y-7.40 E849.52395
G1 F540 X8.57 Y7.40 E849.99344
G1 F540 X-5.04 Y-8.57 E850.39366
G1 F540 X8.57 Y2.68 E850.72463
G1 F540 X-0.33 Y-8.57 E850.98633
G1 F540 X8.57 Y-2.03 E851.17880
G1 F540 X4.38 Y-8.57 E851.30198
G1 F540 X8.57 Y-6.74 E851.35589
G1 F540 X-8.57 Y-5.04 E851.75612
G1 F540 X2.68 Y8.57 E852.08708
G1 F540 X-8.57 Y-0.33 E852.34878
G1 F540 X-2.03 Y8.57 E852.54125
G1 F540 X-8.57 Y4.38 E852.66443
G1 F540 X-6.74 Y8.57 E852.71835
;LAYER:93
G0 F12000 X-8.75 Y8.75 Z9.65
;TYPE:WALL-INNER
G1 F540 X-8.75 Y-8.75 E853.08213
G1 X8.75 Y-8.75 E853.44591
G1 X8.75 Y8.75 E853.80970
G1 X-8.75 Y8.75 E854.17348
G1 F540 X-9.25 Y-9.25 E854.55805
G1 X9.25 Y-9.25 E854.94262
G1 X9.25 Y9.25 E855.32719
G1 X-9.25 Y9.25 E855.71176
;TYPE:WALL-OUTER
G1 F540 X-9.75 Y-9.75 E856.11712
G1 X9.75 Y-9.75 E856.52248
G1 X9.75 Y9.75 E856.92783
G1 X-9.75 Y9.75 E857.33319
G0 X-7.40 Y8.57
;TYPE:FILL
G1 F540 X8.57 Y-7.40 E857.80268
G1 F540 X-8.57 Y7.40 E858.27217
G1 F540 X5.04 Y-8.57 E858.67239
G1 F540 X-8.57 Y2.68 E859.00335
G1 F540 X0.33 Y-8.57 E859.26506
G1 F540 X-8.57 Y-2.03 E859.45753
G1 F540 X-4.38 Y-8.57 E859.58070
G1 F540 X-8.57 Y-6.74 E859.63462
G1 F540 X8.57 Y-5.04 E860.03485
G1 F540 X-2.68 Y8.57 E860.36581
G1 F540 X8.57 Y-0.33 E860.62751
G1 F540 X2.03 Y8.57 E860.81998
G1 F540 X8.57 Y4.38 E860.94316
G1 F540 X6.74 Y8.57 E860.99707
;LAYER:94
M106 S186
G0 F12000 X8.75 Y8.75 Z9.75
;TYPE:WALL-INNER
G1 F1200 X-8.75 Y8.75 E861.36086
G1 X-8.75 Y-8.75 E861.72464
G1 X8.75 Y-8.75 E862.08842
G1 X8.75 Y8.75 E862.45221
G1 F1200 X-9.25 Y9.25 E862.83678
G1 X-9.25 Y-9.25 E863.22135
G1 X9.25 Y-9.25 E863.60592
G1 X9.25 Y9.25 E863.99049
;TYPE:WALL-OUTER
G1 F1200 X-9.75 Y9.75 E864.39584
G1 X-9.75 Y-9.75 E864.80120
G1 X9.75 Y-9.75 E865.20656
G1 X9.75 Y9.75 E865.61192
G0 X8.22 Y8.57
;TYPE:FILL
G1 F1200 X-8.57 Y-8.22 E866.10563
G0 F12000 X-8.22 Y-8.57
G1 F1200 X8.57 Y8.22 E866.59934
G0 F12000 X8.57 Y7.51
G1 F1200 X-7.51 Y-8.57 E867.07227
G0 F12000 X-6.81 Y-8.57
G1 F1200 X8.57 Y6.81 E867.52441
G0 F12000 X8.57 Y6.10
G1 F1200 X-6.10 Y-8.57 E867.95577
G0 F12000 X-5.39 Y-8.57
G1 F1200 X8.57 Y5.39 E868.36634
G0 F12000 X8.57 Y4.68
G1 F1200 X-4.68 Y-8.57 E868.75613
G0 F12000 X-3.98 Y-8.57
G1 F1200 X8.57 Y3.98 E869.12514
G0 F12000 X8.57 Y3.27
G1 F1200 X-3.27 Y-8.57 E869.47336
G0 F12000 X-2.56 Y-8.57
G1 F1200 X8.57 Y2.56 E869.80076
G0 F12000 X8.57 Y1.86
G1 F1200 X-1.86 Y-8.57 E870.10738
G0 F12000 X-1.15 Y-8.57
G1 F1200 X8.57 Y1.15 E870.39322
G0 F12000 X8.57 Y0.44
G1 F1200 X-0.44 Y-8.57 E870.65828
G0 F12000 X0.26 Y-8.57
G1 F1200 X8.57 Y-0.26 E870.90257
G0 F12000 X8.57 Y-0.97
G1 F1200 X0.97 Y-8.57 E871.12609
G0 F12000 X1.68 Y-8.57
G1 F1200 X8.57 Y-1.68 E871.32882
G0 F12000 X8.57 Y-2.38
G1 F1200 X2.38 Y-8.57 E871.51076
G0 F12000 X3.09 Y-8.57
G1 F1200 X8.57 Y-3.09 E871.67192
G0 F12000 X8.57 Y-3.80
G1 F1200 X3.80 Y-8.57 E871.81230
G0 F12000 X4.51 Y-8.57
G1 F1200 X8.57 Y-4.51 E871.93186
G0 F12000 X8.57 Y-5.21
G1 F1200 X5.21 Y-8.57 E872.03064
G0 F12000 X5.92 Y-8.57
G1 F1200 X8.57 Y-5.92 E872.10863
G0 F12000 X8.57 Y-6.63
G1 F1200 X6.63 Y-8.57 E872.16584
G0 F12000 X7.34 Y-8.57
G1 F1200 X8.57 Y-7.34 E872.20226
G0 F12000 X8.57 Y-8.04
G1 F1200 X8.04 Y-8.57 E872.21790
G0 F12000 X-8.57 Y-7.51
G1 F1200 X7.51 Y8.57 E872.69083
G0 F12000 X6.81 Y8.57
G1 F1200 X-8.57 Y-6.81 E873.14297
G0 F12000 X-8.57 Y-6.10
G1 F1200 X6.10 Y8.57 E873.57433
G0 F12000 X5.39 Y8.57
G1 F1200 X-8.57 Y-5.39 E873.98490
G0 F12000 X-8.57 Y-4.68
G1 F1200 X4.68 Y8.57 E874.37469
G0 F12000 X3.98 Y8.57
G1 F1200 X-8.57 Y-3.98 E874.74370
G0 F12000 X-8.57 Y-3.27
G1 F1200 X3.27 Y8.57 E875.09192
G0 F12000 X2.56 Y8.57
G1 F1200 X-8.57 Y-2.56 E875.41932
G0 F12000 X-8.57 Y-1.86
G1 F1200 X1.86 Y8.57 E875.72595
G0 F12000 X1.15 Y8.57
G1 F1200 X-8.57 Y-1.15 E876.01178
G0 F12000 X-8.57 Y-0.44
G1 F1200 X0.44 Y8.57 E876.27684
G0 F12000 X-0.26 Y8.57
G1 F1200 X-8.57 Y0.26 E876.52114
G0 F12000 X-8.57 Y0.97
G1 F1200 X-0.97 Y8.57 E876.74465
G0 F12000 X-1.68 Y8.57
G1 F1200 X-8.57 Y1.68 E876.94738
G0 F12000 X-8.57 Y2.38
G1 F1200 X-2.38 Y8.57 E877.12932
G0 F12000 X-3.09 Y8.57
G1 F1200 X-8.57 Y3.09 E877.29048
G0 F12000 X-8.57 Y3.80
G1 F1200 X-3.80 Y8.57 E877.43086
G0 F12000 X-4.51 Y8.57
G1 F1200 X-8.57 Y4.51 E877.55042
G0 F12000 X-8.57 Y5.21
G1 F1200 X-5.21 Y8.57 E877.64920
G0 F12000 X-5.92 Y8.57
G1 F1200 X-8.57 Y5.92 E877.72719
G0 F12000 X-8.57 Y6.63
G1 F1200 X-6.63 Y8.57 E877.78440
G0 F12000 X-7.34 Y8.57
G1 F1200 X-8.57 Y7.34 E877.82082
G0 F12000 X-8.57 Y8.04
G1 F1200 X-8.04 Y8.57 E877.83646
;LAYER:95
G0 F12000 X-8.75 Y8.75 Z9.85
;TYPE:WALL-INNER
G1 F1200 X-8.75 Y-8.75 E878.20025
G1 X8.75 Y-8.75 E878.56403
G1 X8.75 Y8.75 E878.92781
G1 X-8.75 Y8.75 E879.29160
G1 F1200 X-9.25 Y-9.25 E879.67617
G1 X9.25 Y-9.25 E880.06074
G1 X9.25 Y9.25 E880.44531
G1 X-9.25 Y9.25 E880.82988
;TYPE:WALL-OUTER
G1 F1200 X-9.75 Y-9.75 E881.23523
G1 X9.75 Y-9.75 E881.64059
G1 X9.75 Y9.75 E882.04595
G1 X-9.75 Y9.75 E882.45131
G0 X-8.22 Y8.57
;TYPE:FILL
G1 F1200 X8.57 Y-8.22 E882.94502
G0 F12000 X8.22 Y-8.57
G1 F1200 X-8.57 Y8.22 E883.43873
G0 F12000 X-8.57 Y7.51
G1 F1200 X7.51 Y-8.57 E883.91166
G0 F12000 X6.81 Y-8.57
G1 F1200 X-8.57 Y6.81 E884.36380
G0 F12000 X-8.57 Y6.10
G1 F1200 X6.10 Y-8.57 E884.79516
G0 F12000 X5.39 Y-8.57
G1 F1200 X-8.57 Y5.39 E885.20573
G0 F12000 X-8.57 Y4.68
G1 F1200 X4.68 Y-8.57 E885.59552
G0 F12000 X3.98 Y-8.57
G1 F1200 X-8.57 Y3.98 E885.96453
G0 F12000 X-8.57 Y3.27
G1 F1200 X3.27 Y-8.57 E886.31275
G0 F12000 X2.56 Y-8.57
G1 F1200 X-8.57 Y2.56 E886.64015
G0 F12000 X-8.57 Y1.86
G1 F1200 X1.86 Y-8.57 E886.94677
G0 F12000 X1.15 Y-8.57
G1 F1200 X-8.57 Y1.15 E887.23261
G0 F12000 X-8.57 Y0.44
G1 F1200 X0.44 Y-8.57 E887.49767
G0 F12000 X-0.26 Y-8.57
G1 F1200 X-8.57 Y-0.26 E887.74196
G0 F12000 X-8.57 Y-0.97
G1 F1200 X-0.97 Y-8.57 E887.96548
G0 F12000 X-1.68 Y-8.57
G1 F1200 X-8.57 Y-1.68 E888.16821
G0 F12000 X-8.57 Y-2.38
G1 F1200 X-2.38 Y-8.57 E888.35015
G0 F12000 X-3.09 Y-8.57
G1 F1200 X-8.57 Y-3.09 E888.51131
G0 F12000 X-8.57 Y-3.80
G1 F1200 X-3.80 Y-8.57 E888.65169
G0 F12000 X-4.51 Y-8.57
G1 F1200 X-8.57 Y-4.51 E888.77125
G0 F12000 X-8.57 Y-5.21
G1 F1200 X-5.21 Y-8.57 E888.87003
G0 F12000 X-5.92 Y-8.57
G1 F1200 X-8.57 Y-5.92 E888.94802
G0 F12000 X-8.57 Y-6.63
G1 F1200 X-6.63 Y-8.57 E889.00523
G0 F12000 X-7.34 Y-8.57
G1 F1200 X-8.57 Y-7.34 E889.04165
G0 F12000 X-8.57 Y-8.04
G1 F1200 X-8.04 Y-8.57 E889.05729
G0 F12000 X8.57 Y-7.51
G1 F1200 X-7.51 Y8.57 E889.53022
G0 F12000 X-6.81 Y8.57
G1 F1200 X8.57 Y-6.81 E889.98236
G0 F12000 X8.57 Y-6.10
G1 F1200 X-6.10 Y8.57 E890.41372
G0 F12000 X-5.39 Y8.57
G1 F1200 X8.57 Y-5.39 E890.82429
G0 F12000 X8.57 Y-4.68
G1 F1200 X-4.68 Y8.57 E891.21408
G0 F12000 X-3.98 Y8.57
G1 F1200 X8.57 Y-3.98 E891.58309
G0 F12000 X8.57 Y-3.27
G1 F1200 X-3.27 Y8.57 E891.93131
G0 F12000 X-2.56 Y8.57
G1 F1200 X8.57 Y-2.56 E892.25871
G0 F12000 X8.57 Y-1.86
G1 F1200 X-1.86 Y8.57 E892.56534
G0 F12000 X-1.15 Y8.57
G1 F1200 X8.57 Y-1.15 E892.85117
G0 F12000 X8.57 Y-0.44
G1 F1200 X-0.44 Y8.57 E893.11623
G0 F12000 X0.26 Y8.57
G1 F1200 X8.57 Y0.26 E893.36053
G0 F12000 X8.57 Y0.97
G1 F1200 X0.97 Y8.57 E893.58404
G0 F12000 X1.68 Y8.57
G1 F1200 X8.57 Y1.68 E893.78677
G0 F12000 X8.57 Y2.38
G1 F1200 X2.38 Y8.57 E893.96871
G0 F12000 X3.09 Y8.57
G1 F1200 X8.57 Y3.09 E894.12987
G0 F12000 X8.57 Y3.80
G1 F1200 X3.80 Y8.57 E894.27025
G0 F12000 X4.51 Y8.57
G1 F1200 X8.57 Y4.51 E894.38981
G0 F12000 X8.57 Y5.21
G1 F1200 X5.21 Y8.57 E894.48859
G0 F12000 X5.92 Y8.57
G1 F1200 X8.57 Y5.92 E894.56658
G0 F12000 X8.57 Y6.63
G1 F1200 X6.63 Y8.57 E894.62379
G0 F12000 X7.34 Y8.57
G1 F1200 X8.57 Y7.34 E894.66021
G0 F12000 X8.57 Y8.04
G1 F1200 X8.04 Y8.57 E894.67585
;LAYER:96
G0 F12000 X8.75 Y8.75 Z9.95
;TYPE:WALL-INNER
G1 F1200 X-8.75 Y8.75 E895.03964
G1 X-8.75 Y-8.75 E895.40342
G1 X8.75 Y-8.75 E895.76720
G1 X8.75 Y8.75 E896.13099
G1 F1200 X-9.25 Y9.25 E896.51556
G1 X-9.25 Y-9.25 E896.90013
G1 X9.25 Y-9.25 E897.28470
G1 X9.25 Y9.25 E897.66927
;TYPE:WALL-OUTER
G1 F1200 X-9.75 Y9.75 E898.07462
G1 X-9.75 Y-9.75 E898.47998
G1 X9.75 Y-9.75 E898.88534
G1 X9.75 Y9.75 E899.29070
G0 X8.22 Y8.57
;TYPE:FILL
G1 F1200 X-8.57 Y-8.22 E899.78441
G1 F1200 X8.57 Y8.22 E900.27812
G1 F1200 X-7.51 Y-8.57 E900.75105
G1 F1200 X8.57 Y6.81 E901.20319
G1 F1200 X-6.10 Y-8.57 E901.63455
G1 F1200 X8.57 Y5.39 E902.04512
G1 F1200 X-4.68 Y-8.57 E902.43491
G1 F1200 X8.57 Y3.98 E902.80392
G1 F1200 X-3.27 Y-8.57 E903.15214
G1 F1200 X8.57 Y2.56 E903.47954
G1 F1200 X-1.86 Y-8.57 E903.78616
G1 F1200 X8.57 Y1.15 E904.07200
G1 F1200 X-0.44 Y-8.57 E904.33706
G1 F1200 X8.57 Y-0.26 E904.58135
G1 F1200 X0.97 Y-8.57 E904.80487
G1 F1200 X8.57 Y-1.68 E905.00760
G1 F1200 X2.38 Y-8.57 E905.18954
G1 F1200 X8.57 Y-3.09 E905.35070
G1 F1200 X3.80 Y-8.57 E905.49108
G1 F1200 X8.57 Y-4.51 E905.61064
G1 F1200 X5.21 Y-8.57 E905.70942
G1 F1200 X8.57 Y-5.92 E905.78741
G1 F1200 X6.63 Y-8.57 E905.84462
G1 F1200 X8.57 Y-7.34 E905.88104
G1 F1200 X8.04 Y-8.57 E905.89668
G1 F1200 X7.51 Y8.57 E906.36961
G1 F1200 X-8.57 Y-6.81 E906.82175
G1 F1200 X6.10 Y8.57 E907.25311
G1 F1200 X-8.57 Y-5.39 E907.66368
G1 F1200 X4.68 Y8.57 E908.05347
G1 F1200 X-8.57 Y-3.98 E908.42248
G1 F1200 X3.27 Y8.57 E908.77070
G1 F1200 X-8.57 Y-2.56 E909.09810
G1 F1200 X1.86 Y8.57 E909.40473
G1 F1200 X-8.57 Y-1.15 E909.69056
G1 F1200 X0.44 Y8.57 E909.95562
G1 F1200 X-8.57 Y0.26 E910.19992
G1 F1200 X-0.97 Y8.57 E910.42343
G1 F1200 X-8.57 Y1.68 E910.62616
G1 F1200 X-2.38 Y8.57 E910.80810
G1 F1200 X-8.57 Y3.09 E910.96926
G1 F1200 X-3.80 Y8.57 E911.10964
G1 F1200 X-8.57 Y4.51 E911.22920
G1 F1200 X-5.21 Y8.57 E911.32798
G1 F1200 X-8.57 Y5.92 E911.40597
G1 F1200 X-6.63 Y8.57 E911.46318
G1 F1200 X-8.57 Y7.34 E911.49960
G1 F1200 X-8.04 Y8.57 E911.51524
;LAYER:97
G0 F12000 X-8.75 Y8.75 Z10.05
;TYPE:WALL-INNER
G1 F1200 X-8.75 Y-8.75 E911.87903
G1 X8.75 Y-8.75 E912.24281
G1 X8.75 Y8.75 E912.60659
G1 X-8.75 Y8.75 E912.97038
G1 F1200 X-9.25 Y-9.25 E913.35495
G1 X9.25 Y-9.25 E913.73952
G1 X9.25 Y9.25 E914.12409
G1 X-9.25 Y9.25 E914.50866
;TYPE:WALL-OUTER
G1 F1200 X-9.75 Y-9.75 E914.91401
G1 X9.75 Y-9.75 E915.31937
G1 X9.75 Y9.75 E915.72473
G1 X-9.75 Y9.75 E916.13009
G0 X-8.22 Y8.57
;TYPE:FILL
G1 F1200 X8.57 Y-8.22 E916.62380
G1 F1200 X-8.57 Y8.22 E917.11751
G1 F1200 X7.51 Y-8.57 E917.59044
G1 F1200 X-8.57 Y6.81 E918.04258
G1 F1200 X6.10 Y-8.57 E918.47394
G1 F1200 X-8.57 Y5.39 E918.88451
G1 F1200 X4.68 Y-8.57 E919.27430
G1 F1200 X-8.57 Y3.98 E919.64331
G1 F1200 X3.27 Y-8.57 E919.99153
G1 F1200 X-8.57 Y2.56 E920.31893
G1 F1200 X1.86 Y-8.57 E920.62556
G1 F1200 X-8.57 Y1.15 E920.91139
G1 F1200 X0.44 Y-8.57 E921.17645
G1 F1200 X-8.57 Y-0.26 E921.42074
G1 F1200 X-0.97 Y-8.57 E921.64426
G1 F1200 X-8.57 Y-1.68 E921.84699
G1 F1200 X-2.38 Y-8.57 E922.02893
G1 F1200 X-8.57 Y-3.09 E922.19009
G1 F1200 X-3.80 Y-8.57 E922.33047
G1 F1200 X-8.57 Y-4.51 E922.45003
G1 F1200 X-5.21 Y-8.57 E922.54881
G1 F1200 X-8.57 Y-5.92 E922.62680
G1 F1200 X-6.63 Y-8.57 E922.68401
G1 F1200 X-8.57 Y-7.34 E922.72043
G1 F1200 X-8.04 Y-8.57 E922.73607
G1 F1200 X-7.51 Y8.57 E923.20900
G1 F1200 X8.57 Y-6.81 E923.66114
G1 F1200 X-6.10 Y8.57 E924.09250
G1 F1200 X8.57 Y-5.39 E924.50307
G1 F1200 X-4.68 Y8.57 E924.89286
G1 F1200 X8.57 Y-3.98 E925.26187
G1 F1200 X-3.27 Y8.57 E925.61009
G1 F1200 X8.57 Y-2.56 E925.93749
G1 F1200 X-1.86 Y8.57 E926.24412
G1 F1200 X8.57 Y-1.15 E926.52995
G1 F1200 X-0.44 Y8.57 E926.79501
G1 F1200 X8.57 Y0.26 E927.03931
G1 F1200 X0.97 Y8.57 E927.26282
G1 F1200 X8.57 Y1.68 E927.46555
G1 F1200 X2.38 Y8.57 E927.64749
G1 F1200 X8.57 Y3.09 E927.80865
G1 F1200 X3.80 Y8.57 E927.94903
G1 F1200 X8.57 Y4.51 E928.06859
G1 F1200 X5.21 Y8.57 E928.16737
G1 F1200 X8.57 Y5.92 E928.24536
G1 F1200 X6.63 Y8.57 E928.30257
G1 F1200 X8.57 Y7.34 E928.33899
G1 F1200 X8.04 Y8.57 E928.35463
;LAYER:98
G0 F12000 X8.75 Y8.75 Z10.15
;TYPE:WALL-INNER
G1 F1200 X-8.75 Y8.75 E928.71842
G1 X-8.75 Y-8.75 E929.08220
G1 X8.75 Y-8.75 E929.44598
G1 X8.75 Y8.75 E929.80977
G1 F1200 X-9.25 Y9.25 E930.19434
G1 X-9.25 Y-9.25 E930.57891
G1 X9.25 Y-9.25 E930.96348
G1 X9.25 Y9.25 E931.34805
;TYPE:WALL-OUTER
G1 F1200 X-9.75 Y9.75 E931.75340
G1 X-9.75 Y-9.75 E932.15876
G1 X9.75 Y-9.75 E932.56412
G1 X9.75 Y9.75 E932.96948
G0 X8.22 Y8.57
;TYPE:FILL
G1 F1200 X-8.57 Y-8.22 E933.46319
G1 F1200 X8.57 Y8.22 E933.95690
G1 F1200 X-7.51 Y-8.57 E934.42983
G1 F1200 X8.57 Y6.81 E934.88197
G1 F1200 X-6.10 Y-8.57 E935.31333
G1 F1200 X8.57 Y5.39 E935.72390
G1 F1200 X-4.68 Y-8.57 E936.11369
G1 F1200 X8.57 Y3.98 E936.48270
G1 F1200 X-3.27 Y-8.57 E936.83092
G1 F1200 X8.57 Y2.56 E937.15832
G1 F1200 X-1.86 Y-8.57 E937.46495
G1 F1200 X8.57 Y1.15 E937.75078
G1 F1200 X-0.44 Y-8.57 E938.01584
G1 F1200 X8.57 Y-0.26 E938.26013
G1 F1200 X0.97 Y-8.57 E938.48365
G1 F1200 X8.57 Y-1.68 E938.68638
G1 F1200 X2.38 Y-8.57 E938.86832
G1 F1200 X8.57 Y-3.09 E939.02948
G1 F1200 X3.80 Y-8.57 E939.16986
G1 F1200 X8.57 Y-4.51 E939.28942
G1 F1200 X5.21 Y-8.57 E939.38820
G1 F1200 X8.57 Y-5.92 E939.46619
G1 F1200 X6.63 Y-8.57 E939.52340
G1 F1200 X8.57 Y-7.34 E939.55982
G1 F1200 X8.04 Y-8.57 E939.57546
G1 F1200 X7.51 Y8.57 E940.04839
G1 F1200 X-8.57 Y-6.81 E940.50053
G1 F1200 X6.10 Y8.57 E940.93189
G1 F1200 X-8.57 Y-5.39 E941.34246
G1 F1200 X4.68 Y8.57 E941.73225
G1 F1200 X-8.57 Y-3.98 E942.10126
G1 F1200 X3.27 Y8.57 E942.44948
G1 F1200 X-8.57 Y-2.56 E942.77688
G1 F1200 X1.86 Y8.57 E943.08351
G1 F1200 X-8.57 Y-1.15 E943.36934
G1 F1200 X0.44 Y8.57 E943.63440
G1 F1200 X-8.57 Y0.26 E943.87870
G1 F1200 X-0.97 Y8.57 E944.10221
G1 F1200 X-8.57 Y1.68 E944.30494
G1 F1200 X-2.38 Y8.57 E944.48688
G1 F1200 X-8.57 Y3.09 E944.64804
G1 F1200 X-3.80 Y8.57 E944.78842
G1 F1200 X-8.57 Y4.51 E944.90798
G1 F1200 X-5.21 Y8.57 E945.00676
G1 F1200 X-8.57 Y5.92 E945.08475
G1 F1200 X-6.63 Y8.57 E945.14196
G1 F1200 X-8.57 Y7.34 E945.17838
G1 F1200 X-8.04 Y8.57 E945.19402
M107
G1 F6000 E939.79402
G0 F12000 X-8.04 Y8.57 Z15.00
M104 S0 ; turn off temperature
M140 S0 ; turn off bed temperature
G91
G1 Z10 E-5. F18000
G90
G28 ; home X axis
M84     ; disable motors
; BEGINNING OF PRINT FINISHED TONES
M117 PRINT FINISHED
M120 S6 P10
G4 P40
M117 WAIT UNTIL COOL
G4 P40
M120 S6 P10
G4 P40
M120 S6 P10
G4 P40
M120 S6 P10
G4 P40
M120 S6 P10
G4 P40
; END OF PRINT FINISHED TONES
; filament used = filament_used_replace_mm (filament_used_replace_cm3)
; MatterControl Version 1.5.3 Build 1.5.3.6894 : GCode settings used
; Date 06/17/2016 00:00:00 Time 10:49
; avoid_crossing_perimeters = 0
; bed_shape = circular
; bed_size = 280,280
; bed_temperature = 60
; bottom_clip_amount = 0
; bottom_solid_layers = 3
; bridge_acceleration = 0
; bridge_fan_speed = 100
; bridge_flow_ratio = 1
; bridge_speed = 30
; brim_width = 0
; build_height = 350
; cancel_gcode = M104 S0\nM140 S0\nG28\nM4
; center_part_on_bed = 1
; complete_objects = 0
; connect_gcode =
; cool_extruder_lift = 0
; print_leveling_solution = 7 Point Disk
; print_leveling_method = Manual
; print_leveling_required_to_print = 0
; manual_probe_paper_width = .1
; cooling = 1
; create_raft = 0
; default_acceleration = 0
; disable_fan_first_layers = 2
; end_gcode = M104 S0 ; turn off temperature\nM140 S0 ; turn off bed temperature\nG91\nG1 Z10 E-5. F18000\nG90\nG28 ; home X axis\nM84     ; disable motors\n; BEGINNING OF PRINT FINISHED TONES\nM117 PRINT FINISHED\nM120 S6 P10\nG4 P40\nM117 WAIT UNTIL COOL\nG4 P40\nM120 S6 P10\nG4 P40\nM120 S6 P10\nG4 P40\nM120 S6 P10\nG4 P40\nM120 S6 P10\nG4 P40\n; END OF PRINT FINISHED TONES
; external_perimeter_speed = 30
; external_perimeters_first = 0
; extra_perimeters = 1
; extruder_clearance_height = 20
; extruder_clearance_radius = 20
; extruder_count = 1
; extruder_offset = 0x0
; extruder_wipe_temperature = 0
; extruders_share_temperature = 0
; extrusion_axis = E
; extrusion_multiplier = 1.0
; extrusion_width = .45
; fan_always_on = 1
; fan_below_layer_time = 120
; filament_diameter = 1.75
; fill_angle = 45
; fill_density = .3
; fill_pattern = rectilinear
; first_layer_acceleration = 0
; first_layer_bed_temperature = 60
; first_layer_extrusion_width = .6
; first_layer_height = .35
; first_layer_speed = 15
; first_layer_temperature = 210
; g0 = 0
; gap_fill_speed = 30
; gcode_arcs = 0
; gcode_comments = 0
; gcode_flavor = reprap
; gcode_output_type = REPRAP
; has_fan = 1
; has_hardware_leveling = 0
; has_heated_bed = 1
; has_power_control = 0
; has_sd_card_reader = 1
; show_reset_connection = 0
; heat_extruder_before_homing = 0
; include_firmware_updater = None
; infill_acceleration = 0
; infill_every_layers = 1
; infill_extruder = 1
; infill_extrusion_width = .45
; infill_first = 0
; infill_only_where_needed = 0
; infill_overlap_perimeter = .1
; infill_speed = 30
; infill_type = TRIANGLES
; layer_gcode =
; layer_height = 0.1
; layer_to_pause =
; max_fan_speed = 100
; min_extrusion_before_retract = 1.5
; min_fan_speed = 60
; min_print_speed = 5
; min_skirt_length = 0
; notes =
; nozzle_diameter = 0.5
; only_retract_when_crossing_perimeters = 1
; ooze_prevention = 0
; output_filename_format = [input_filename_base].gcode
; overhangs = 1
; pause_gcode = G91\nG1 Z10 E-10 F12000\nG90
; perimeter_acceleration = 0
; perimeter_extruder = 1
; perimeter_extrusion_width = .45
; external_perimeter_extrusion_width = 100%
; perimeter_speed = 30
; perimeters = 3
; post_process =
; print_center = 0,0
; raft_air_gap = .2
; raft_extruder = 0
; raft_extra_distance_around_part = 5
; raft_fan_speed_percent = 100
; raft_layers = 0
; raft_print_speed = 100%
; bed_remove_part_temperature = 0
; randomize_start = 0
; repair_outlines_extensive_stitching = 1
; repair_outlines_keep_open = 1
; resolution = 0
; resume_gcode = G91\nG1 Z-10 E10.8 F12000\nG90
; retract_before_travel = 2
; retract_layer_change = 1
; retract_length = 5.4
; retract_length_tool_change = 10
; retract_lift = .2
; retract_restart_extra = .1
; retract_restart_extra_toolchange = 0
; retract_when_changing_islands = 1
; retract_speed = 100
; skirt_distance = 3
; skirt_height = 1
; skirts = 2
; slowdown_below_layer_time = 40
; small_perimeter_speed = 30
; solid_fill_pattern = concentric
; solid_infill_below_area = 70
; solid_infill_every_layers = 0
; solid_infill_extrusion_width = .45
; solid_infill_speed = 30
; solid_shell = 0
; spiral_vase =
; standby_temperature_delta = -5
; start_gcode = G28\nM104 S210\nM190 S60\nM109 S210\n; BEGINNING OF HEAD MOVEMENT WARNING TONES\nM120 S4 P10\nG4 P40\nM120 S4 P10\nG4 P40\nM120 S4 P10\nG4 P40\nM120 S4 P10\nG4 P40\nM120 S4 P10\nG4 P40\nM117 KEEP HANDS AWAY\nG4 S3\n; END OF HEAD WARNING TONES
; start_perimeters_at_concave_points = 0
; start_perimeters_at_non_overhang = 1
; support_air_gap = .3
; support_material =
; support_material_angle = 0
; support_material_percent = 50
; support_material_create_internal_support = 0
; support_material_create_perimeter = 1
; support_material_enforce_layers = 0
; support_material_extruder = 1
; support_material_extrusion_width = .45
; support_material_infill_angle = 45
; support_material_interface_extruder = 1
; support_material_interface_layers = 0
; support_material_interface_spacing = 0
; support_material_pattern = rectilinear
; support_material_spacing = 1.8
; support_material_speed = 30
; support_material_threshold = 30
; support_material_xy_distance = 0.7
; support_material_z_distance = 0.15
; support_material_z_gap_layers = 1
; support_type = LINES
; temperature = 210
; thin_walls = 1
; threads = 5
; toolchange_gcode =
; top_infill_extrusion_width = .4
; top_solid_infill_speed = 30
; top_solid_layers = 5
; travel_speed = 200
; use_firmware_retraction = 0
; use_relative_e_distances = 0
; vibration_limit = 0
; wipe = 0
; wipe_shield_distance = 0
; wipe_tower_size = 0
; z_can_be_negative = 0
; z_offset = 0
greyghost
Re: New version: 2.1.2
Post by greyghost »
Okay I think I figured it out. For some reason it was still loading my old json file and not the updated one. I uninstalled Cura and added the new printer profile and ran my gcode for the test cube and this is what I got. It looks a lot better now. I'll give this a spin this afternoon. If it works then we're closer to getting it to work.
;FLAVOR:RepRap
;TIME:1200
M190 S80.000000
M104 S250.000000
M109 S250.000000
;Basic settings: Layer height: 0.1 Walls: 0.8 Fill: 20
G28 ; Home extruder
M107 ; Turn off fan
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
M117 HEATING ELEMENTS
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
G4 S3
;Put printing message on LCD screen
M117 Rostock Printing...
;Generated with Cura_SteamEngine 2.1.2
;LAYER_COUNT:98
;LAYER:0
M107
G0 F7200.000000 X0.000 Y0.000 Z0.300
G1 F3000.000 E-6.50000
G1 Z0.375
G0 F7200.000 X17.800 Y-10.000 Z0.375
;TYPE:SKIRT
G1 Z0.300
G1 F3000.000 E0.00000
G1 F900.00000 X17.800 Y10.000 E1.06765
G1 X17.760 Y10.789 E1.10982
G1 X17.641 Y11.569 E1.15194
G1 X17.443 Y12.334 E1.19413
G1 X17.169 Y13.074 E1.23625
G1 X16.821 Y13.783 E1.27841
G1 X16.403 Y14.454 E1.32061
G1 X15.920 Y15.078 E1.36274
G1 X15.377 Y15.651 E1.40488
G1 X14.778 Y16.166 E1.44705
G1 X14.130 Y16.617 E1.48919
G1 X13.439 Y17.001 E1.53139
G1 X12.714 Y17.313 E1.57353
G1 X11.961 Y17.550 E1.61567
G1 X11.187 Y17.709 E1.65785
G1 X10.402 Y17.790 E1.69998
G1 X10.000 Y17.800 E1.72144
G1 X-10.000 Y17.800 E2.78909
G1 X-10.789 Y17.760 E2.83127
G1 X-11.569 Y17.641 E2.87339
G1 X-12.334 Y17.443 E2.91557
G1 X-13.074 Y17.169 E2.95769
G1 X-13.783 Y16.821 E2.99986
G1 X-14.454 Y16.403 E3.04206
G1 X-15.078 Y15.920 E3.08418
G1 X-15.651 Y15.377 E3.12632
G1 X-16.166 Y14.778 E3.16849
G1 X-16.617 Y14.130 E3.21064
G1 X-17.001 Y13.439 E3.25284
G1 X-17.313 Y12.714 E3.29497
G1 X-17.550 Y11.961 E3.33711
G1 X-17.709 Y11.187 E3.37929
G1 X-17.790 Y10.402 E3.42142
G1 X-17.800 Y10.000 E3.44289
G1 X-17.800 Y-10.000 E4.51054
G1 X-17.760 Y-10.789 E4.55271
G1 X-17.641 Y-11.569 E4.59483
G1 X-17.443 Y-12.334 E4.63701
G1 X-17.169 Y-13.074 E4.67914
G1 X-16.821 Y-13.783 E4.72130
G1 X-16.403 Y-14.454 E4.76350
G1 X-15.920 Y-15.078 E4.80563
G1 X-15.377 Y-15.651 E4.84777
G1 X-14.778 Y-16.166 E4.88994
G1 X-14.130 Y-16.617 E4.93208
G1 X-13.439 Y-17.001 E4.97428
G1 X-12.714 Y-17.313 E5.01642
G1 X-11.961 Y-17.550 E5.05856
G1 X-11.187 Y-17.709 E5.10074
G1 X-10.402 Y-17.790 E5.14287
G1 X-10.000 Y-17.800 E5.16433
G1 X10.000 Y-17.800 E6.23198
G1 X10.789 Y-17.760 E6.27415
G1 X11.569 Y-17.641 E6.31628
G1 X12.334 Y-17.443 E6.35846
G1 X13.074 Y-17.169 E6.40058
G1 X13.783 Y-16.821 E6.44274
G1 X14.454 Y-16.403 E6.48495
G1 X15.078 Y-15.920 E6.52707
G1 X15.651 Y-15.377 E6.56921
G1 X16.166 Y-14.778 E6.61138
G1 X16.617 Y-14.130 E6.65353
G1 X17.001 Y-13.439 E6.69573
G1 X17.313 Y-12.714 E6.73786
G1 X17.550 Y-11.961 E6.78000
G1 X17.709 Y-11.187 E6.82218
G1 X17.790 Y-10.402 E6.86431
G1 X17.800 Y-10.000 E6.88578
G0 F7200.00000 X17.400 Y-10.000
G1 F900.000 X17.400 Y10.000 E7.95343
G1 X17.360 Y10.768 E7.99448
G1 X17.241 Y11.528 E8.03554
G1 X17.043 Y12.271 E8.07659
G1 X16.769 Y12.990 E8.11767
G1 X16.422 Y13.676 E8.15871
G1 X16.006 Y14.323 E8.19977
G1 X15.525 Y14.923 E8.24082
G1 X14.984 Y15.470 E8.28189
G1 X14.389 Y15.958 E8.32297
G1 X13.747 Y16.381 E8.36401
G1 X13.064 Y16.736 E8.40510
G1 X12.349 Y17.017 E8.44611
G1 X11.607 Y17.223 E8.48722
G1 X10.849 Y17.351 E8.52825
G1 X10.000 Y17.400 E8.57365
G1 X-10.000 Y17.400 E9.64130
G1 X-10.768 Y17.360 E9.68236
G1 X-11.528 Y17.241 E9.72342
G1 X-12.271 Y17.043 E9.76447
G1 X-12.990 Y16.769 E9.80554
G1 X-13.676 Y16.422 E9.84658
G1 X-14.323 Y16.006 E9.88764
G1 X-14.923 Y15.525 E9.92869
G1 X-15.470 Y14.984 E9.96976
G1 X-15.958 Y14.389 E10.01084
G1 X-16.381 Y13.747 E10.05188
G1 X-16.736 Y13.064 E10.09298
G1 X-17.017 Y12.349 E10.13399
G1 X-17.223 Y11.607 E10.17509
G1 X-17.351 Y10.849 E10.21613
G1 X-17.400 Y10.000 E10.26153
G1 X-17.400 Y-10.000 E11.32918
G1 X-17.360 Y-10.768 E11.37023
G1 X-17.241 Y-11.528 E11.41130
G1 X-17.043 Y-12.271 E11.45234
G1 X-16.769 Y-12.990 E11.49342
G1 X-16.422 Y-13.676 E11.53446
G1 X-16.006 Y-14.323 E11.57552
G1 X-15.525 Y-14.923 E11.61657
G1 X-14.984 Y-15.470 E11.65764
G1 X-14.389 Y-15.958 E11.69872
G1 X-13.747 Y-16.381 E11.73976
G1 X-13.064 Y-16.736 E11.78085
G1 X-12.349 Y-17.017 E11.82186
G1 X-11.607 Y-17.223 E11.86297
G1 X-10.849 Y-17.351 E11.90401
G1 X-10.000 Y-17.400 E11.94940
G1 X10.000 Y-17.400 E13.01706
G1 X10.768 Y-17.360 E13.05811
G1 X11.528 Y-17.241 E13.09917
G1 X12.271 Y-17.043 E13.14022
G1 X12.990 Y-16.769 E13.18130
G1 X13.676 Y-16.422 E13.22233
G1 X14.323 Y-16.006 E13.26340
G1 X14.923 Y-15.525 E13.30445
G1 X15.470 Y-14.984 E13.34552
G1 X15.958 Y-14.389 E13.38660
G1 X16.381 Y-13.747 E13.42764
G1 X16.736 Y-13.064 E13.46873
G1 X17.017 Y-12.349 E13.50974
G1 X17.223 Y-11.607 E13.55085
G1 X17.351 Y-10.849 E13.59188
G1 X17.400 Y-10.000 E13.63728
G0 F7200.00000 X17.000 Y-10.000
G1 F900.000 X17.000 Y10.000 E14.70493
G1 X16.960 Y10.747 E14.74487
G1 X16.841 Y11.485 E14.78477
G1 X16.643 Y12.207 E14.82474
G1 X16.370 Y12.903 E14.86465
G1 X16.023 Y13.566 E14.90459
G1 X15.608 Y14.189 E14.94455
G1 X15.129 Y14.763 E14.98446
G1 X14.592 Y15.284 E15.02440
G1 X14.002 Y15.743 E15.06431
G1 X13.366 Y16.138 E15.10427
G1 X12.692 Y16.462 E15.14420
G1 X11.987 Y16.712 E15.18413
G1 X11.259 Y16.886 E15.22408
G1 X10.517 Y16.981 E15.26402
G1 X10.000 Y17.000 E15.29163
G1 X-10.000 Y17.000 E16.35928
G1 X-10.747 Y16.960 E16.39922
G1 X-11.485 Y16.841 E16.43912
G1 X-12.207 Y16.643 E16.47909
G1 X-12.903 Y16.370 E16.51900
G1 X-13.566 Y16.023 E16.55895
G1 X-14.189 Y15.608 E16.59891
G1 X-14.763 Y15.129 E16.63882
G1 X-15.284 Y14.592 E16.67876
G1 X-15.743 Y14.002 E16.71866
G1 X-16.138 Y13.366 E16.75863
G1 X-16.462 Y12.692 E16.79855
G1 X-16.712 Y11.987 E16.83848
G1 X-16.886 Y11.259 E16.87844
G1 X-16.981 Y10.517 E16.91837
G1 X-17.000 Y10.000 E16.94599
G1 X-17.000 Y-10.000 E18.01364
G1 X-16.960 Y-10.747 E18.05357
G1 X-16.841 Y-11.485 E18.09348
G1 X-16.643 Y-12.207 E18.13344
G1 X-16.370 Y-12.903 E18.17335
G1 X-16.023 Y-13.566 E18.21330
G1 X-15.608 Y-14.189 E18.25326
G1 X-15.129 Y-14.763 E18.29317
G1 X-14.592 Y-15.284 E18.33311
G1 X-14.002 Y-15.743 E18.37301
G1 X-13.366 Y-16.138 E18.41298
G1 X-12.692 Y-16.462 E18.45290
G1 X-11.987 Y-16.712 E18.49283
G1 X-11.259 Y-16.886 E18.53279
G1 X-10.517 Y-16.981 E18.57272
G1 X-10.000 Y-17.000 E18.60034
G1 X10.000 Y-17.000 E19.66799
G1 X10.747 Y-16.960 E19.70792
G1 X11.485 Y-16.841 E19.74783
G1 X12.207 Y-16.643 E19.78779
G1 X12.903 Y-16.370 E19.82770
G1 X13.566 Y-16.023 E19.86765
G1 X14.189 Y-15.608 E19.90761
G1 X14.763 Y-15.129 E19.94752
G1 X15.284 Y-14.592 E19.98746
G1 X15.743 Y-14.002 E20.02737
G1 X16.138 Y-13.366 E20.06733
G1 X16.462 Y-12.692 E20.10725
G1 X16.712 Y-11.987 E20.14718
G1 X16.886 Y-11.259 E20.18714
G1 X16.981 Y-10.517 E20.22708
G1 X17.000 Y-10.000 E20.25469
G0 F7200.00000 X16.600 Y-10.000
G1 F900.000 X16.600 Y10.000 E21.32234
G1 X16.560 Y10.725 E21.36110
G1 X16.441 Y11.442 E21.39990
G1 X16.243 Y12.141 E21.43869
G1 X15.970 Y12.814 E21.47746
G1 X15.625 Y13.453 E21.51622
G1 X15.211 Y14.050 E21.55500
G1 X14.735 Y14.598 E21.59375
G1 X14.201 Y15.091 E21.63255
G1 X13.616 Y15.521 E21.67131
G1 X12.987 Y15.885 E21.71010
G1 X12.322 Y16.178 E21.74889
G1 X11.629 Y16.396 E21.78767
G1 X10.917 Y16.536 E21.82641
G1 X10.000 Y16.600 E21.87548
G1 X-10.000 Y16.600 E22.94313
G1 X-10.725 Y16.560 E22.98189
G1 X-11.442 Y16.441 E23.02069
G1 X-12.141 Y16.243 E23.05947
G1 X-12.814 Y15.970 E23.09824
G1 X-13.453 Y15.625 E23.13701
G1 X-14.050 Y15.211 E23.17579
G1 X-14.598 Y14.735 E23.21454
G1 X-15.091 Y14.201 E23.25334
G1 X-15.521 Y13.616 E23.29210
G1 X-15.885 Y12.987 E23.33089
G1 X-16.178 Y12.322 E23.36968
G1 X-16.396 Y11.629 E23.40846
G1 X-16.536 Y10.917 E23.44720
G1 X-16.600 Y10.000 E23.49627
G1 X-16.600 Y-10.000 E24.56392
G1 X-16.560 Y-10.725 E24.60268
G1 X-16.441 Y-11.442 E24.64148
G1 X-16.243 Y-12.141 E24.68026
G1 X-15.970 Y-12.814 E24.71903
G1 X-15.625 Y-13.453 E24.75780
G1 X-15.211 Y-14.050 E24.79658
G1 X-14.735 Y-14.598 E24.83533
G1 X-14.201 Y-15.091 E24.87413
G1 X-13.616 Y-15.521 E24.91289
G1 X-12.987 Y-15.885 E24.95168
G1 X-12.322 Y-16.178 E24.99047
G1 X-11.629 Y-16.396 E25.02925
G1 X-10.917 Y-16.536 E25.06799
G1 X-10.000 Y-16.600 E25.11706
G1 X10.000 Y-16.600 E26.18471
G1 X10.725 Y-16.560 E26.22347
G1 X11.442 Y-16.441 E26.26227
G1 X12.141 Y-16.243 E26.30105
G1 X12.814 Y-15.970 E26.33982
G1 X13.453 Y-15.625 E26.37859
G1 X14.050 Y-15.211 E26.41737
G1 X14.598 Y-14.735 E26.45612
G1 X15.091 Y-14.201 E26.49492
G1 X15.521 Y-13.616 E26.53367
G1 X15.885 Y-12.987 E26.57247
G1 X16.178 Y-12.322 E26.61126
G1 X16.396 Y-11.629 E26.65004
G1 X16.536 Y-10.917 E26.68878
G1 X16.600 Y-10.000 E26.73785
G0 F7200.00000 X16.200 Y-10.000
G1 F900.000 X16.200 Y10.000 E27.80550
G1 X16.160 Y10.703 E27.84309
G1 X16.041 Y11.397 E27.88068
G1 X15.843 Y12.072 E27.91823
G1 X15.571 Y12.721 E27.95579
G1 X15.226 Y13.335 E27.99339
G1 X14.815 Y13.906 E28.03095
G1 X14.341 Y14.427 E28.06855
G1 X13.811 Y14.891 E28.10615
G1 X13.232 Y15.291 E28.14372
G1 X12.611 Y15.623 E28.18131
G1 X11.957 Y15.883 E28.21888
G1 X11.277 Y16.067 E28.25648
G1 X10.581 Y16.173 E28.29407
G1 X10.000 Y16.200 E28.32511
G1 X-10.000 Y16.200 E29.39277
G1 X-10.703 Y16.160 E29.43035
G1 X-11.397 Y16.041 E29.46794
G1 X-12.072 Y15.843 E29.50549
G1 X-12.721 Y15.571 E29.54306
G1 X-13.335 Y15.226 E29.58065
G1 X-13.906 Y14.815 E29.61821
G1 X-14.427 Y14.341 E29.65581
G1 X-14.891 Y13.811 E29.69341
G1 X-15.291 Y13.232 E29.73098
G1 X-15.623 Y12.611 E29.76857
G1 X-15.883 Y11.957 E29.80614
G1 X-16.067 Y11.277 E29.84375
G1 X-16.173 Y10.581 E29.88133
G1 X-16.200 Y10.000 E29.91238
G1 X-16.200 Y-10.000 E30.98003
G1 X-16.160 Y-10.703 E31.01762
G1 X-16.041 Y-11.397 E31.05521
G1 X-15.843 Y-12.072 E31.09276
G1 X-15.571 Y-12.721 E31.13032
G1 X-15.226 Y-13.335 E31.16792
G1 X-14.815 Y-13.906 E31.20548
G1 X-14.341 Y-14.427 E31.24308
G1 X-13.811 Y-14.891 E31.28068
G1 X-13.232 Y-15.291 E31.31825
G1 X-12.611 Y-15.623 E31.35584
G1 X-11.957 Y-15.883 E31.39341
G1 X-11.277 Y-16.067 E31.43101
G1 X-10.581 Y-16.173 E31.46860
G1 X-10.000 Y-16.200 E31.49964
G1 X10.000 Y-16.200 E32.56729
G1 X10.703 Y-16.160 E32.60488
G1 X11.397 Y-16.041 E32.64247
G1 X12.072 Y-15.843 E32.68002
G1 X12.721 Y-15.571 E32.71759
G1 X13.335 Y-15.226 E32.75518
G1 X13.906 Y-14.815 E32.79274
G1 X14.427 Y-14.341 E32.83034
G1 X14.891 Y-13.811 E32.86794
G1 X15.291 Y-13.232 E32.90551
G1 X15.623 Y-12.611 E32.94310
G1 X15.883 Y-11.957 E32.98067
G1 X16.067 Y-11.277 E33.01828
G1 X16.173 Y-10.581 E33.05586
G1 X16.200 Y-10.000 E33.08691
G0 F7200.00000 X15.800 Y-10.000
G1 F900.000 X15.800 Y10.000 E34.15456
G1 X15.760 Y10.680 E34.19092
G1 X15.641 Y11.350 E34.22725
G1 X15.444 Y12.002 E34.26361
G1 X15.172 Y12.626 E34.29995
G1 X14.828 Y13.214 E34.33631
G1 X14.418 Y13.758 E34.37268
G1 X13.947 Y14.249 E34.40900
G1 X13.422 Y14.683 E34.44536
G1 X12.850 Y15.052 E34.48170
G1 X12.238 Y15.351 E34.51806
G1 X11.596 Y15.576 E34.55437
G1 X10.931 Y15.725 E34.59075
G1 X10.000 Y15.800 E34.64061
G1 X-10.000 Y15.800 E35.70826
G1 X-10.680 Y15.760 E35.74462
G1 X-11.350 Y15.641 E35.78095
G1 X-12.002 Y15.444 E35.81731
G1 X-12.626 Y15.172 E35.85365
G1 X-13.214 Y14.828 E35.89001
G1 X-13.758 Y14.418 E35.92638
G1 X-14.249 Y13.947 E35.96270
G1 X-14.683 Y13.422 E35.99906
G1 X-15.052 Y12.850 E36.03540
G1 X-15.351 Y12.238 E36.07176
G1 X-15.576 Y11.596 E36.10807
G1 X-15.725 Y10.931 E36.14445
G1 X-15.800 Y10.000 E36.19431
G1 X-15.800 Y-10.000 E37.26196
G1 X-15.760 Y-10.680 E37.29833
G1 X-15.641 Y-11.350 E37.33465
G1 X-15.444 Y-12.002 E37.37101
G1 X-15.172 Y-12.626 E37.40735
G1 X-14.828 Y-13.214 E37.44372
G1 X-14.418 Y-13.758 E37.48008
G1 X-13.947 Y-14.249 E37.51640
G1 X-13.422 Y-14.683 E37.55276
G1 X-12.850 Y-15.052 E37.58910
G1 X-12.238 Y-15.351 E37.62546
G1 X-11.596 Y-15.576 E37.66178
G1 X-10.931 Y-15.725 E37.69816
G1 X-10.000 Y-15.800 E37.74802
G1 X10.000 Y-15.800 E38.81567
G1 X10.680 Y-15.760 E38.85203
G1 X11.350 Y-15.641 E38.88836
G1 X12.002 Y-15.444 E38.92472
G1 X12.626 Y-15.172 E38.96105
G1 X13.214 Y-14.828 E38.99742
G1 X13.758 Y-14.418 E39.03378
G1 X14.249 Y-13.947 E39.07010
G1 X14.683 Y-13.422 E39.10647
G1 X15.052 Y-12.850 E39.14280
G1 X15.351 Y-12.238 E39.17916
G1 X15.576 Y-11.596 E39.21548
G1 X15.725 Y-10.931 E39.25186
G1 X15.800 Y-10.000 E39.30172
G0 F7200.00000 X15.400 Y-10.000
G1 F900.000 X15.400 Y10.000 E40.36937
G1 X15.360 Y10.656 E40.40445
G1 X15.241 Y11.302 E40.43952
G1 X15.044 Y11.929 E40.47460
G1 X14.772 Y12.527 E40.50967
G1 X14.430 Y13.088 E40.54475
G1 X14.022 Y13.603 E40.57982
G1 X13.555 Y14.065 E40.61489
G1 X13.035 Y14.466 E40.64994
G1 X12.471 Y14.802 E40.68499
G1 X11.869 Y15.066 E40.72008
G1 X11.240 Y15.256 E40.75515
G1 X10.593 Y15.367 E40.79020
G1 X10.000 Y15.400 E40.82190
G1 X-10.000 Y15.400 E41.88955
G1 X-10.656 Y15.360 E41.92464
G1 X-11.302 Y15.241 E41.95970
G1 X-11.929 Y15.044 E41.99479
G1 X-12.527 Y14.772 E42.02986
G1 X-13.088 Y14.430 E42.06493
G1 X-13.603 Y14.022 E42.10000
G1 X-14.065 Y13.555 E42.13507
G1 X-14.466 Y13.035 E42.17012
G1 X-14.802 Y12.471 E42.20517
G1 X-15.066 Y11.869 E42.24026
G1 X-15.256 Y11.240 E42.27534
G1 X-15.367 Y10.593 E42.31038
G1 X-15.400 Y10.000 E42.34209
G1 X-15.400 Y-10.000 E43.40974
G1 X-15.360 Y-10.656 E43.44482
G1 X-15.241 Y-11.302 E43.47988
G1 X-15.044 Y-11.929 E43.51497
G1 X-14.772 Y-12.527 E43.55004
G1 X-14.430 Y-13.088 E43.58511
G1 X-14.022 Y-13.603 E43.62019
G1 X-13.555 Y-14.065 E43.65525
G1 X-13.035 Y-14.466 E43.69031
G1 X-12.471 Y-14.802 E43.72535
G1 X-11.869 Y-15.066 E43.76044
G1 X-11.240 Y-15.256 E43.79552
G1 X-10.593 Y-15.367 E43.83056
G1 X-10.000 Y-15.400 E43.86227
G1 X10.000 Y-15.400 E44.92992
G1 X10.656 Y-15.360 E44.96500
G1 X11.302 Y-15.241 E45.00007
G1 X11.929 Y-15.044 E45.03515
G1 X12.527 Y-14.772 E45.07022
G1 X13.088 Y-14.430 E45.10530
G1 X13.603 Y-14.022 E45.14037
G1 X14.065 Y-13.555 E45.17544
G1 X14.466 Y-13.035 E45.21049
G1 X14.802 Y-12.471 E45.24554
G1 X15.066 Y-11.869 E45.28063
G1 X15.256 Y-11.240 E45.31570
G1 X15.367 Y-10.593 E45.35075
G1 X15.400 Y-10.000 E45.38245
G0 F7200.00000 X15.000 Y-10.000
G1 F900.000 X15.000 Y10.000 E46.45010
G1 X14.960 Y10.631 E46.48385
G1 X14.841 Y11.252 E46.51761
G1 X14.644 Y11.852 E46.55132
G1 X14.373 Y12.424 E46.58511
G1 X14.033 Y12.956 E46.61881
G1 X13.627 Y13.441 E46.65258
G1 X13.164 Y13.871 E46.68631
G1 X12.650 Y14.240 E46.72008
G1 X12.094 Y14.540 E46.75381
G1 X11.505 Y14.768 E46.78753
G1 X10.891 Y14.920 E46.82129
G1 X10.000 Y15.000 E46.86905
G1 X-10.000 Y15.000 E47.93670
G1 X-10.631 Y14.960 E47.97045
G1 X-11.252 Y14.841 E48.00420
G1 X-11.852 Y14.644 E48.03792
G1 X-12.424 Y14.373 E48.07170
G1 X-12.956 Y14.033 E48.10541
G1 X-13.441 Y13.627 E48.13917
G1 X-13.871 Y13.164 E48.17290
G1 X-14.240 Y12.650 E48.20668
G1 X-14.540 Y12.094 E48.24041
G1 X-14.768 Y11.505 E48.27412
G1 X-14.920 Y10.891 E48.30789
G1 X-15.000 Y10.000 E48.35564
G1 X-15.000 Y-10.000 E49.42329
G1 X-14.960 Y-10.631 E49.45705
G1 X-14.841 Y-11.252 E49.49080
G1 X-14.644 Y-11.852 E49.52451
G1 X-14.373 Y-12.424 E49.55830
G1 X-14.033 Y-12.956 E49.59200
G1 X-13.627 Y-13.441 E49.62577
G1 X-13.164 Y-13.871 E49.65950
G1 X-12.650 Y-14.240 E49.69328
G1 X-12.094 Y-14.540 E49.72700
G1 X-11.505 Y-14.768 E49.76072
G1 X-10.891 Y-14.920 E49.79448
G1 X-10.000 Y-15.000 E49.84224
G1 X10.000 Y-15.000 E50.90989
G1 X10.631 Y-14.960 E50.94364
G1 X11.252 Y-14.841 E50.97740
G1 X11.852 Y-14.644 E51.01111
G1 X12.424 Y-14.373 E51.04490
G1 X12.956 Y-14.033 E51.07860
G1 X13.441 Y-13.627 E51.11236
G1 X13.871 Y-13.164 E51.14610
G1 X14.240 Y-12.650 E51.17987
G1 X14.540 Y-12.094 E51.21360
G1 X14.768 Y-11.505 E51.24731
G1 X14.920 Y-10.891 E51.28108
G1 X15.000 Y-10.000 E51.32884
G0 F7200.00000 X14.600 Y-10.000
G1 F900.000 X14.600 Y10.000 E52.39649
G1 X14.560 Y10.605 E52.42885
G1 X14.441 Y11.199 E52.46119
G1 X14.245 Y11.773 E52.49357
G1 X13.974 Y12.316 E52.52597
G1 X13.635 Y12.819 E52.55835
G1 X13.233 Y13.272 E52.59068
G1 X12.775 Y13.669 E52.62303
G1 X12.268 Y14.002 E52.65541
G1 X11.722 Y14.266 E52.68779
G1 X11.146 Y14.455 E52.72015
G1 X10.550 Y14.567 E52.75252
G1 X10.000 Y14.600 E52.78194
G1 X-10.000 Y14.600 E53.84959
G1 X-10.605 Y14.560 E53.88195
G1 X-11.199 Y14.441 E53.91429
G1 X-11.773 Y14.245 E53.94667
G1 X-12.316 Y13.974 E53.97907
G1 X-12.819 Y13.635 E54.01145
G1 X-13.272 Y13.233 E54.04378
G1 X-13.669 Y12.775 E54.07614
G1 X-14.002 Y12.268 E54.10852
G1 X-14.266 Y11.722 E54.14089
G1 X-14.455 Y11.146 E54.17325
G1 X-14.567 Y10.550 E54.20563
G1 X-14.600 Y10.000 E54.23504
G1 X-14.600 Y-10.000 E55.30269
G1 X-14.560 Y-10.605 E55.33506
G1 X-14.441 Y-11.199 E55.36740
G1 X-14.245 Y-11.773 E55.39977
G1 X-13.974 Y-12.316 E55.43217
G1 X-13.635 Y-12.819 E55.46455
G1 X-13.233 Y-13.272 E55.49688
G1 X-12.775 Y-13.669 E55.52924
G1 X-12.268 Y-14.002 E55.56162
G1 X-11.722 Y-14.266 E55.59399
G1 X-11.146 Y-14.455 E55.62636
G1 X-10.550 Y-14.567 E55.65873
G1 X-10.000 Y-14.600 E55.68814
G1 X10.000 Y-14.600 E56.75579
G1 X10.605 Y-14.560 E56.78816
G1 X11.199 Y-14.441 E56.82050
G1 X11.773 Y-14.245 E56.85288
G1 X12.316 Y-13.974 E56.88527
G1 X12.819 Y-13.635 E56.91765
G1 X13.272 Y-13.233 E56.94998
G1 X13.669 Y-12.775 E56.98234
G1 X14.002 Y-12.268 E57.01472
G1 X14.266 Y-11.722 E57.04710
G1 X14.455 Y-11.146 E57.07946
G1 X14.567 Y-10.550 E57.11183
G1 X14.600 Y-10.000 E57.14124
G0 F7200.00000 X14.200 Y-10.000
G1 F900.000 X14.200 Y10.000 E58.20889
G1 X14.160 Y10.578 E58.23982
G1 X14.041 Y11.145 E58.27075
G1 X13.845 Y11.690 E58.30167
G1 X13.576 Y12.203 E58.33259
G1 X13.239 Y12.674 E58.36351
G1 X12.840 Y13.094 E58.39443
G1 X12.387 Y13.456 E58.42539
G1 X11.889 Y13.751 E58.45628
G1 X11.355 Y13.976 E58.48722
G1 X10.795 Y14.124 E58.51814
G1 X10.000 Y14.200 E58.56077
G1 X-10.000 Y14.200 E59.62842
G1 X-10.578 Y14.160 E59.65935
G1 X-11.145 Y14.041 E59.69028
G1 X-11.690 Y13.845 E59.72120
G1 X-12.203 Y13.576 E59.75212
G1 X-12.674 Y13.239 E59.78303
G1 X-13.094 Y12.840 E59.81396
G1 X-13.456 Y12.387 E59.84491
G1 X-13.751 Y11.889 E59.87581
G1 X-13.976 Y11.355 E59.90675
G1 X-14.124 Y10.795 E59.93767
G1 X-14.200 Y10.000 E59.98030
G1 X-14.200 Y-10.000 E61.04795
G1 X-14.160 Y-10.578 E61.07888
G1 X-14.041 Y-11.145 E61.10981
G1 X-13.845 Y-11.690 E61.14072
G1 X-13.576 Y-12.203 E61.17164
G1 X-13.239 Y-12.674 E61.20256
G1 X-12.840 Y-13.094 E61.23349
G1 X-12.387 Y-13.456 E61.26444
G1 X-11.889 Y-13.751 E61.29534
G1 X-11.355 Y-13.976 E61.32627
G1 X-10.795 Y-14.124 E61.35719
G1 X-10.000 Y-14.200 E61.39983
G1 X10.000 Y-14.200 E62.46748
G1 X10.578 Y-14.160 E62.49841
G1 X11.145 Y-14.041 E62.52933
G1 X11.690 Y-13.845 E62.56025
G1 X12.203 Y-13.576 E62.59117
G1 X12.674 Y-13.239 E62.62209
G1 X13.094 Y-12.840 E62.65301
G1 X13.456 Y-12.387 E62.68397
G1 X13.751 Y-11.889 E62.71487
G1 X13.976 Y-11.355 E62.74580
G1 X14.124 Y-10.795 E62.77672
G1 X14.200 Y-10.000 E62.81935
G0 F7200.00000 X13.800 Y-10.000
G1 F900.000 X13.800 Y10.000 E63.88700
G1 X13.760 Y10.550 E63.91644
G1 X13.641 Y11.088 E63.94586
G1 X13.445 Y11.603 E63.97527
G1 X13.177 Y12.084 E64.00467
G1 X12.843 Y12.522 E64.03407
G1 X12.448 Y12.906 E64.06348
G1 X12.002 Y13.230 E64.09291
G1 X11.514 Y13.485 E64.12230
G1 X10.994 Y13.668 E64.15173
G1 X10.453 Y13.773 E64.18115
G1 X10.000 Y13.800 E64.20537
G1 X-10.000 Y13.800 E65.27302
G1 X-10.550 Y13.760 E65.30246
G1 X-11.088 Y13.641 E65.33187
G1 X-11.603 Y13.445 E65.36129
G1 X-12.084 Y13.177 E65.39068
G1 X-12.522 Y12.843 E65.42009
G1 X-12.906 Y12.448 E65.44949
G1 X-13.230 Y12.002 E65.47892
G1 X-13.485 Y11.514 E65.50831
G1 X-13.668 Y10.994 E65.53774
G1 X-13.773 Y10.453 E65.56716
G1 X-13.800 Y10.000 E65.59139
G1 X-13.800 Y-10.000 E66.65904
G1 X-13.760 Y-10.550 E66.68847
G1 X-13.641 Y-11.088 E66.71789
G1 X-13.445 Y-11.603 E66.74730
G1 X-13.177 Y-12.084 E66.77670
G1 X-12.843 Y-12.522 E66.80610
G1 X-12.448 Y-12.906 E66.83551
G1 X-12.002 Y-13.230 E66.86494
G1 X-11.514 Y-13.485 E66.89433
G1 X-10.994 Y-13.668 E66.92376
G1 X-10.453 Y-13.773 E66.95318
G1 X-10.000 Y-13.800 E66.97740
G1 X10.000 Y-13.800 E68.04505
G1 X10.550 Y-13.760 E68.07449
G1 X11.088 Y-13.641 E68.10390
G1 X11.603 Y-13.445 E68.13332
G1 X12.084 Y-13.177 E68.16271
G1 X12.522 Y-12.843 E68.19212
G1 X12.906 Y-12.448 E68.22153
G1 X13.230 Y-12.002 E68.25095
G1 X13.485 Y-11.514 E68.28035
G1 X13.668 Y-10.994 E68.30977
G1 X13.773 Y-10.453 E68.33919
G1 X13.800 Y-10.000 E68.36342
G0 F7200.00000 X13.400 Y-10.000
G1 F900.000 X13.400 Y10.000 E69.43107
G1 X13.360 Y10.520 E69.45891
G1 X13.241 Y11.027 E69.48671
G1 X13.046 Y11.510 E69.51452
G1 X12.780 Y11.958 E69.54233
G1 X12.448 Y12.360 E69.57016
G1 X12.058 Y12.706 E69.59799
G1 X11.620 Y12.989 E69.62583
G1 X11.145 Y13.202 E69.65362
G1 X10.642 Y13.339 E69.68145
G1 X10.000 Y13.400 E69.71587
G1 X-10.000 Y13.400 E70.78353
G1 X-10.520 Y13.360 E70.81137
G1 X-11.027 Y13.241 E70.83917
G1 X-11.510 Y13.046 E70.86697
G1 X-11.958 Y12.780 E70.89479
G1 X-12.360 Y12.448 E70.92262
G1 X-12.706 Y12.058 E70.95045
G1 X-12.989 Y11.620 E70.97829
G1 X-13.202 Y11.145 E71.00608
G1 X-13.339 Y10.642 E71.03391
G1 X-13.400 Y10.000 E71.06833
G1 X-13.400 Y-10.000 E72.13598
G1 X-13.360 Y-10.520 E72.16382
G1 X-13.241 Y-11.027 E72.19162
G1 X-13.046 Y-11.510 E72.21943
G1 X-12.780 Y-11.958 E72.24724
G1 X-12.448 Y-12.360 E72.27507
G1 X-12.058 Y-12.706 E72.30291
G1 X-11.620 Y-12.989 E72.33074
G1 X-11.145 Y-13.202 E72.35853
G1 X-10.642 Y-13.339 E72.38636
G1 X-10.000 Y-13.400 E72.42079
G1 X10.000 Y-13.400 E73.48844
G1 X10.520 Y-13.360 E73.51628
G1 X11.027 Y-13.241 E73.54408
G1 X11.510 Y-13.046 E73.57189
G1 X11.958 Y-12.780 E73.59970
G1 X12.360 Y-12.448 E73.62753
G1 X12.706 Y-12.058 E73.65536
G1 X12.989 Y-11.620 E73.68320
G1 X13.202 Y-11.145 E73.71099
G1 X13.339 Y-10.642 E73.73882
G1 X13.400 Y-10.000 E73.77325
G0 F7200.00000 X13.000 Y-10.000
G1 F900.000 X13.000 Y10.000 E74.84090
G1 X12.960 Y10.488 E74.86703
G1 X12.841 Y10.963 E74.89317
G1 X12.647 Y11.412 E74.91928
G1 X12.382 Y11.824 E74.94543
G1 X12.054 Y12.187 E74.97155
G1 X11.671 Y12.492 E74.99769
G1 X11.243 Y12.730 E75.02383
G1 X10.783 Y12.896 E75.04994
G1 X10.302 Y12.985 E75.07605
G1 X10.000 Y13.000 E75.09219
G1 X-10.000 Y13.000 E76.15984
G1 X-10.488 Y12.960 E76.18598
G1 X-10.963 Y12.841 E76.21212
G1 X-11.412 Y12.647 E76.23823
G1 X-11.824 Y12.382 E76.26438
G1 X-12.187 Y12.054 E76.29050
G1 X-12.492 Y11.671 E76.31663
G1 X-12.730 Y11.243 E76.34278
G1 X-12.896 Y10.783 E76.36888
G1 X-12.985 Y10.302 E76.39499
G1 X-13.000 Y10.000 E76.41114
G1 X-13.000 Y-10.000 E77.47879
G1 X-12.960 Y-10.488 E77.50492
G1 X-12.841 Y-10.963 E77.53106
G1 X-12.647 Y-11.412 E77.55717
G1 X-12.382 Y-11.824 E77.58332
G1 X-12.054 Y-12.187 E77.60944
G1 X-11.671 Y-12.492 E77.63558
G1 X-11.243 Y-12.730 E77.66172
G1 X-10.783 Y-12.896 E77.68783
G1 X-10.302 Y-12.985 E77.71394
G1 X-10.000 Y-13.000 E77.73008
G1 X10.000 Y-13.000 E78.79773
G1 X10.488 Y-12.960 E78.82387
G1 X10.963 Y-12.841 E78.85001
G1 X11.412 Y-12.647 E78.87612
G1 X11.824 Y-12.382 E78.90227
G1 X12.187 Y-12.054 E78.92839
G1 X12.492 Y-11.671 E78.95452
G1 X12.730 Y-11.243 E78.98067
G1 X12.896 Y-10.783 E79.00677
G1 X12.985 Y-10.302 E79.03288
G1 X13.000 Y-10.000 E79.04903
G0 F7200.00000 X12.600 Y-10.000
G1 F900.000 X12.600 Y10.000 E80.11668
G1 X12.560 Y10.454 E80.14101
G1 X12.442 Y10.894 E80.16532
G1 X12.248 Y11.306 E80.18963
G1 X11.985 Y11.679 E80.21400
G1 X11.662 Y12.000 E80.23831
G1 X11.287 Y12.259 E80.26264
G1 X10.873 Y12.449 E80.28695
G1 X10.432 Y12.564 E80.31128
G1 X10.000 Y12.600 E80.33442
G1 X-10.000 Y12.600 E81.40207
G1 X-10.454 Y12.560 E81.42640
G1 X-10.894 Y12.442 E81.45072
G1 X-11.306 Y12.248 E81.47503
G1 X-11.679 Y11.985 E81.49939
G1 X-12.000 Y11.662 E81.52370
G1 X-12.259 Y11.287 E81.54803
G1 X-12.449 Y10.873 E81.57235
G1 X-12.564 Y10.432 E81.59668
G1 X-12.600 Y10.000 E81.61982
G1 X-12.600 Y-10.000 E82.68747
G1 X-12.560 Y-10.454 E82.71180
G1 X-12.442 Y-10.894 E82.73612
G1 X-12.248 Y-11.306 E82.76043
G1 X-11.985 Y-11.679 E82.78479
G1 X-11.662 Y-12.000 E82.80910
G1 X-11.287 Y-12.259 E82.83343
G1 X-10.873 Y-12.449 E82.85775
G1 X-10.432 Y-12.564 E82.88208
G1 X-10.000 Y-12.600 E82.90522
G1 X10.000 Y-12.600 E83.97287
G1 X10.454 Y-12.560 E83.99720
G1 X10.894 Y-12.442 E84.02151
G1 X11.306 Y-12.248 E84.04582
G1 X11.679 Y-11.985 E84.07019
G1 X12.000 Y-11.662 E84.09450
G1 X12.259 Y-11.287 E84.11883
G1 X12.449 Y-10.873 E84.14314
G1 X12.564 Y-10.432 E84.16747
G1 X12.600 Y-10.000 E84.19061
G0 F7200.00000 X12.200 Y-10.000
G1 F900.000 X12.200 Y10.000 E85.25826
G1 X12.160 Y10.417 E85.28063
G1 X12.042 Y10.819 E85.30299
G1 X11.849 Y11.191 E85.32536
G1 X11.590 Y11.520 E85.34772
G1 X11.273 Y11.794 E85.37008
G1 X10.910 Y12.003 E85.39244
G1 X10.513 Y12.139 E85.41484
G1 X10.000 Y12.200 E85.44242
G1 X-10.000 Y12.200 E86.51007
G1 X-10.417 Y12.160 E86.53244
G1 X-10.819 Y12.042 E86.55480
G1 X-11.191 Y11.849 E86.57717
G1 X-11.520 Y11.590 E86.59952
G1 X-11.794 Y11.273 E86.62189
G1 X-12.003 Y10.910 E86.64425
G1 X-12.139 Y10.513 E86.66665
G1 X-12.200 Y10.000 E86.69423
G1 X-12.200 Y-10.000 E87.76188
G1 X-12.160 Y-10.417 E87.78425
G1 X-12.042 Y-10.819 E87.80661
G1 X-11.849 Y-11.191 E87.82898
G1 X-11.590 Y-11.520 E87.85133
G1 X-11.273 Y-11.794 E87.87370
G1 X-10.910 Y-12.003 E87.89606
G1 X-10.513 Y-12.139 E87.91846
G1 X-10.000 Y-12.200 E87.94604
G1 X10.000 Y-12.200 E89.01369
G1 X10.417 Y-12.160 E89.03606
G1 X10.819 Y-12.042 E89.05842
G1 X11.191 Y-11.849 E89.08079
G1 X11.520 Y-11.590 E89.10314
G1 X11.794 Y-11.273 E89.12551
G1 X12.003 Y-10.910 E89.14787
G1 X12.139 Y-10.513 E89.17027
G1 X12.200 Y-10.000 E89.19785
G0 F7200.00000 X11.800 Y-10.000
G1 F900.000 X11.800 Y10.000 E90.26550
G1 X11.760 Y10.377 E90.28574
G1 X11.642 Y10.737 E90.30596
G1 X11.452 Y11.064 E90.32615
G1 X11.197 Y11.345 E90.34641
G1 X10.888 Y11.565 E90.36666
G1 X10.541 Y11.717 E90.38688
G1 X10.000 Y11.800 E90.41610
G1 X-10.000 Y11.800 E91.48375
G1 X-10.377 Y11.760 E91.50399
G1 X-10.737 Y11.642 E91.52421
G1 X-11.064 Y11.452 E91.54440
G1 X-11.345 Y11.197 E91.56466
G1 X-11.565 Y10.888 E91.58491
G1 X-11.717 Y10.541 E91.60513
G1 X-11.800 Y10.000 E91.63435
G1 X-11.800 Y-10.000 E92.70200
G1 X-11.760 Y-10.377 E92.72223
G1 X-11.642 Y-10.737 E92.74246
G1 X-11.452 Y-11.064 E92.76265
G1 X-11.197 Y-11.345 E92.78290
G1 X-10.888 Y-11.565 E92.80315
G1 X-10.541 Y-11.717 E92.82338
G1 X-10.000 Y-11.800 E92.85259
G1 X10.000 Y-11.800 E93.92024
G1 X10.377 Y-11.760 E93.94048
G1 X10.737 Y-11.642 E93.96071
G1 X11.064 Y-11.452 E93.98089
G1 X11.345 Y-11.197 E94.00115
G1 X11.565 Y-10.888 E94.02140
G1 X11.717 Y-10.541 E94.04162
G1 X11.800 Y-10.000 E94.07084
G0 F7200.00000 X11.400 Y-10.000
G1 F900.000 X11.400 Y10.000 E95.13849
G1 X11.360 Y10.332 E95.15634
G1 X11.243 Y10.644 E95.17413
G1 X11.055 Y10.921 E95.19200
G1 X10.807 Y11.144 E95.20980
G1 X10.513 Y11.303 E95.22765
G1 X10.189 Y11.387 E95.24552
G1 X10.000 Y11.400 E95.25563
G1 X-10.000 Y11.400 E96.32328
G1 X-10.332 Y11.360 E96.34113
G1 X-10.644 Y11.243 E96.35892
G1 X-10.921 Y11.055 E96.37679
G1 X-11.144 Y10.807 E96.39459
G1 X-11.303 Y10.513 E96.41244
G1 X-11.387 Y10.189 E96.43030
G1 X-11.400 Y10.000 E96.44042
G1 X-11.400 Y-10.000 E97.50807
G1 X-11.360 Y-10.332 E97.52592
G1 X-11.243 Y-10.644 E97.54371
G1 X-11.055 Y-10.921 E97.56158
G1 X-10.807 Y-11.144 E97.57938
G1 X-10.513 Y-11.303 E97.59722
G1 X-10.189 Y-11.387 E97.61509
G1 X-10.000 Y-11.400 E97.62520
G1 X10.000 Y-11.400 E98.69285
G1 X10.332 Y-11.360 E98.71071
G1 X10.644 Y-11.243 E98.72849
G1 X10.921 Y-11.055 E98.74636
G1 X11.144 Y-10.807 E98.76417
G1 X11.303 Y-10.513 E98.78201
G1 X11.387 Y-10.189 E98.79988
G1 X11.400 Y-10.000 E98.80999
G0 F7200.00000 X11.000 Y-10.000
G1 F900.000 X11.000 Y10.000 E99.87764
G1 X10.960 Y10.279 E99.89269
G1 X10.844 Y10.536 E99.90774
G1 X10.661 Y10.751 E99.92281
G1 X10.425 Y10.905 E99.93786
G1 X10.155 Y10.988 E99.95293
G1 X10.000 Y11.000 E99.96123
G1 X-10.000 Y11.000 E101.02888
G1 X-10.279 Y10.960 E101.04393
G1 X-10.536 Y10.844 E101.05898
G1 X-10.751 Y10.661 E101.07405
G1 X-10.905 Y10.425 E101.08910
G1 X-10.988 Y10.155 E101.10418
G1 X-11.000 Y10.000 E101.11248
G1 X-11.000 Y-10.000 E102.18013
G1 X-10.960 Y-10.279 E102.19517
G1 X-10.844 Y-10.536 E102.21022
G1 X-10.661 Y-10.751 E102.22530
G1 X-10.425 Y-10.905 E102.24034
G1 X-10.155 Y-10.988 E102.25542
G1 X-10.000 Y-11.000 E102.26372
G1 X10.000 Y-11.000 E103.33137
G1 X10.279 Y-10.960 E103.34641
G1 X10.536 Y-10.844 E103.36146
G1 X10.751 Y-10.661 E103.37654
G1 X10.905 Y-10.425 E103.39158
G1 X10.988 Y-10.155 E103.40666
G1 X11.000 Y-10.000 E103.41496
G0 F7200.00000 X10.600 Y-10.000
G1 F900.000 X10.600 Y10.000 E104.48261
G1 X10.560 Y10.215 E104.49428
G1 X10.447 Y10.401 E104.50590
G1 X10.274 Y10.534 E104.51755
G1 X10.000 Y10.600 E104.53259
G1 X-10.000 Y10.600 E105.60024
G1 X-10.215 Y10.560 E105.61192
G1 X-10.401 Y10.447 E105.62354
G1 X-10.534 Y10.274 E105.63519
G1 X-10.600 Y10.000 E105.65023
G1 X-10.600 Y-10.000 E106.71788
G1 X-10.560 Y-10.215 E106.72956
G1 X-10.447 Y-10.401 E106.74117
G1 X-10.274 Y-10.534 E106.75282
G1 X-10.000 Y-10.600 E106.76787
G1 X10.000 Y-10.600 E107.83552
G1 X10.215 Y-10.560 E107.84719
G1 X10.401 Y-10.447 E107.85881
G1 X10.534 Y-10.274 E107.87046
G1 X10.600 Y-10.000 E107.88550
G0 F7200.00000 X10.000 Y-10.200
G1 F900.000 X10.119 Y-10.161 E107.89219
G1 X10.200 Y-10.000 E107.90181
G1 X10.200 Y10.000 E108.96946
G1 X10.161 Y10.119 E108.97615
G1 X10.000 Y10.200 E108.98577
G1 X-10.000 Y10.200 E110.05342
G1 X-10.119 Y10.161 E110.06010
G1 X-10.200 Y10.000 E110.06972
G1 X-10.200 Y-10.000 E111.13737
G1 X-10.161 Y-10.119 E111.14406
G1 X-10.000 Y-10.200 E111.15368
G1 X10.000 Y-10.200 E112.22133
G0 F7200.00000 X9.400 Y-9.400
;TYPE:WALL-INNER
G1 F900.000 X9.400 Y9.400 E113.22492
G1 X-9.400 Y9.400 E114.22851
G1 X-9.400 Y-9.400 E115.23210
G1 X9.400 Y-9.400 E116.23569
G0 F7200.00000 X9.800 Y-9.800
;TYPE:WALL-OUTER
G1 F900.000 X9.800 Y9.800 E117.28199
G1 X-9.800 Y9.800 E118.32829
G1 X-9.800 Y-9.800 E119.37459
G1 X9.800 Y-9.800 E120.42088
G0 F7200.00000 X8.862 Y-9.239
;TYPE:SKIN
G1 F900.000 X9.239 Y-8.862 E120.44935
G0 F7200.00000 X9.239 Y-8.296
G1 F900.000 X8.296 Y-9.239 E120.52054
G0 X8.226 Y-9.309
G0 F7200.000 X7.730 Y-9.239
G1 F900.000 X9.239 Y-7.730 E120.63446
G0 X9.309 Y-7.660
G0 F7200.000 X9.239 Y-7.165
G1 F900.000 X7.165 Y-9.239 E120.79103
G0 X7.095 Y-9.309
G0 F7200.000 X6.599 Y-9.239
G1 F900.000 X9.239 Y-6.599 E120.99034
G0 X9.309 Y-6.529
G0 F7200.000 X9.239 Y-6.033
G1 F900.000 X6.033 Y-9.239 E121.23237
G0 X5.963 Y-9.309
G0 F7200.000 X5.468 Y-9.239
G1 F900.000 X9.239 Y-5.468 E121.51706
G0 X9.309 Y-5.398
G0 F7200.000 X9.239 Y-4.902
G1 F900.000 X4.902 Y-9.239 E121.84448
G0 X4.832 Y-9.309
G0 F7200.000 X4.336 Y-9.239
G1 F900.000 X9.239 Y-4.336 E122.21463
G0 X9.309 Y-4.266
G0 F7200.000 X9.239 Y-3.771
G1 F900.000 X3.771 Y-9.239 E122.62743
G0 X3.701 Y-9.309
G0 F7200.000 X3.205 Y-9.239
G1 F900.000 X9.239 Y-3.205 E123.08296
G0 X9.309 Y-3.135
G0 F7200.000 X9.239 Y-2.639
G1 F900.000 X2.639 Y-9.239 E123.58123
G0 X2.569 Y-9.309
G0 F7200.000 X2.073 Y-9.239
G1 F900.000 X9.239 Y-2.073 E124.12222
G0 X9.309 Y-2.003
G0 F7200.000 X9.239 Y-1.508
G1 F900.000 X1.508 Y-9.239 E124.70586
G0 X1.438 Y-9.309
G0 F7200.000 X0.942 Y-9.239
G1 F900.000 X9.239 Y-0.942 E125.33224
G0 X9.309 Y-0.872
G0 F7200.000 X9.239 Y-0.376
G1 F900.000 X0.376 Y-9.239 E126.00135
G0 X0.306 Y-9.309
G0 F7200.000 X-0.188 Y-9.239
G1 F900.000 X9.239 Y0.188 E126.71303
G0 X9.309 Y0.258
G0 F7200.000 X9.239 Y0.754
G1 F900.000 X-0.754 Y-9.239 E127.46744
G0 X-0.824 Y-9.309
G0 F7200.000 X-1.320 Y-9.239
G1 F900.000 X9.239 Y1.320 E128.26459
G0 X9.309 Y1.390
G0 F7200.000 X9.239 Y1.885
G1 F900.000 X-1.885 Y-9.239 E129.10439
G0 X-1.955 Y-9.309
G0 F7200.000 X-2.451 Y-9.239
G1 F900.000 X9.239 Y2.451 E129.98691
G0 X9.309 Y2.521
G0 F7200.000 X9.239 Y3.017
G1 F900.000 X-3.017 Y-9.239 E130.91217
G0 X-3.087 Y-9.309
G0 F7200.000 X-3.582 Y-9.239
G1 F900.000 X9.239 Y3.582 E131.88008
G0 X9.309 Y3.652
G0 F7200.000 X9.239 Y4.148
G1 F900.000 X-4.148 Y-9.239 E132.89073
G0 X-4.218 Y-9.309
G0 F7200.000 X-4.714 Y-9.239
G1 F900.000 X9.239 Y4.714 E133.94410
G0 X9.309 Y4.784
G0 F7200.000 X9.239 Y5.279
G1 F900.000 X-5.279 Y-9.239 E135.04012
G0 X-5.349 Y-9.309
G0 F7200.000 X-5.845 Y-9.239
G1 F900.000 X9.239 Y5.845 E136.17888
G0 X9.309 Y5.915
G0 F7200.000 X9.239 Y6.411
G1 F900.000 X-6.411 Y-9.239 E137.36037
G0 X-6.481 Y-9.309
G0 F7200.000 X-6.977 Y-9.239
G1 F900.000 X9.239 Y6.977 E138.58458
G0 X9.309 Y7.047
G0 F7200.000 X9.239 Y7.542
G1 F900.000 X-7.542 Y-9.239 E139.85145
G0 X-7.612 Y-9.309
G0 F7200.000 X-8.108 Y-9.239
G1 F900.000 X9.239 Y8.108 E141.16105
G0 X9.309 Y8.178
G0 F7200.000 X9.239 Y8.674
G1 F900.000 X-8.674 Y-9.239 E142.51338
G0 X-8.744 Y-9.309
G0 F7200.000 X-9.239 Y-9.239
G1 F900.000 X9.239 Y9.239 E143.90836
G0 X9.309 Y9.309
G0 F7200.000 X8.674 Y9.239
G1 F900.000 X-9.239 Y-8.674 E145.26069
G0 X-9.309 Y-8.744
G0 F7200.000 X-9.239 Y-8.108
G1 F900.000 X8.108 Y9.239 E146.57029
G0 X8.178 Y9.309
G0 F7200.000 X7.542 Y9.239
G1 F900.000 X-9.239 Y-7.542 E147.83716
G0 X-9.309 Y-7.612
G0 F7200.000 X-9.239 Y-6.977
G1 F900.000 X6.977 Y9.239 E149.06137
G0 X7.047 Y9.309
G0 F7200.000 X6.411 Y9.239
G1 F900.000 X-9.239 Y-6.411 E150.24286
G0 X-9.309 Y-6.481
G0 F7200.000 X-9.239 Y-5.845
G1 F900.000 X5.845 Y9.239 E151.38162
G0 X5.915 Y9.309
G0 F7200.000 X5.279 Y9.239
G1 F900.000 X-9.239 Y-5.279 E152.47764
G0 X-9.309 Y-5.349
G0 F7200.000 X-9.239 Y-4.714
G1 F900.000 X4.714 Y9.239 E153.53101
G0 X4.784 Y9.309
G0 F7200.000 X4.148 Y9.239
G1 F900.000 X-9.239 Y-4.148 E154.54166
G0 X-9.309 Y-4.218
G0 F7200.000 X-9.239 Y-3.582
G1 F900.000 X3.582 Y9.239 E155.50957
G0 X3.652 Y9.309
G0 F7200.000 X3.017 Y9.239
G1 F900.000 X-9.239 Y-3.017 E156.43483
G0 X-9.309 Y-3.087
G0 F7200.000 X-9.239 Y-2.451
G1 F900.000 X2.451 Y9.239 E157.31735
G0 X2.521 Y9.309
G0 F7200.000 X1.885 Y9.239
G1 F900.000 X-9.239 Y-1.885 E158.15715
G0 X-9.309 Y-1.955
G0 F7200.000 X-9.239 Y-1.320
G1 F900.000 X1.320 Y9.239 E158.95430
G0 X1.390 Y9.309
G0 F7200.000 X0.754 Y9.239
G1 F900.000 X-9.239 Y-0.754 E159.70871
G0 X-9.309 Y-0.824
G0 F7200.000 X-9.239 Y-0.188
G1 F900.000 X0.188 Y9.239 E160.42040
G0 X0.258 Y9.309
G0 F7200.000 X-0.376 Y9.239
G1 F900.000 X-9.239 Y0.376 E161.08950
G0 X-9.309 Y0.306
G0 F7200.000 X-9.239 Y0.942
G1 F900.000 X-0.942 Y9.239 E161.71588
G0 X-0.872 Y9.309
G0 F7200.000 X-1.508 Y9.239
G1 F900.000 X-9.239 Y1.508 E162.29952
G0 X-9.309 Y1.438
G0 F7200.000 X-9.239 Y2.073
G1 F900.000 X-2.073 Y9.239 E162.84052
G0 X-2.003 Y9.309
G0 F7200.000 X-2.639 Y9.239
G1 F900.000 X-9.239 Y2.639 E163.33878
G0 X-9.309 Y2.569
G0 F7200.000 X-9.239 Y3.205
G1 F900.000 X-3.205 Y9.239 E163.79431
G0 X-3.135 Y9.309
G0 F7200.000 X-3.771 Y9.239
G1 F900.000 X-9.239 Y3.771 E164.20711
G0 X-9.309 Y3.701
G0 F7200.000 X-9.239 Y4.336
G1 F900.000 X-4.336 Y9.239 E164.57726
G0 X-4.266 Y9.309
G0 F7200.000 X-4.902 Y9.239
G1 F900.000 X-9.239 Y4.902 E164.90468
G0 X-9.309 Y4.832
G0 F7200.000 X-9.239 Y5.468
G1 F900.000 X-5.468 Y9.239 E165.18937
G0 X-5.398 Y9.309
G0 F7200.000 X-6.033 Y9.239
G1 F900.000 X-9.239 Y6.033 E165.43140
G0 X-9.309 Y5.963
G0 F7200.000 X-9.239 Y6.599
G1 F900.000 X-6.599 Y9.239 E165.63071
G0 X-6.529 Y9.309
G0 F7200.000 X-7.165 Y9.239
G1 F900.000 X-9.239 Y7.165 E165.78728
G0 X-9.309 Y7.095
G0 F7200.000 X-9.239 Y7.730
G1 F900.000 X-7.730 Y9.239 E165.90120
G0 X-7.660 Y9.309
G0 F7200.000 X-8.296 Y9.239
G1 F900.000 X-9.239 Y8.296 E165.97240
G0 X-9.309 Y8.226
G0 F7200.000 X-9.239 Y8.862
G1 F900.000 X-8.862 Y9.239 E166.00086
G0 F7200.00000 X-8.862 Y9.000
;LAYER:1
G0 X-9.400 Y9.400 Z0.400
;TYPE:WALL-INNER
G1 F2250.000 X-9.400 Y-9.400 E166.33539
G1 X9.400 Y-9.400 E166.66992
G1 X9.400 Y9.400 E167.00445
G1 X-9.400 Y9.400 E167.33898
G0 F7200.00000 X-9.800 Y9.800
;TYPE:WALL-OUTER
G1 F1350.000 X-9.800 Y-9.800 E167.68774
G1 X9.800 Y-9.800 E168.03651
G1 X9.800 Y9.800 E168.38528
G1 X-9.800 Y9.800 E168.73404
G0 F7200.00000 X-9.239 Y9.239
;TYPE:SKIN
G1 F900.000 X9.239 Y-9.239 E169.19904
G0 X9.309 Y-9.309
G0 F7200.000 X8.674 Y-9.239
G1 F900.000 X-9.239 Y8.674 E169.64981
G0 X-9.309 Y8.744
G0 F7200.000 X-9.239 Y8.108
G1 F900.000 X8.108 Y-9.239 E170.08635
G0 X8.178 Y-9.309
G0 F7200.000 X7.542 Y-9.239
G1 F900.000 X-9.239 Y7.542 E170.50864
G0 X-9.309 Y7.612
G0 F7200.000 X-9.239 Y6.977
G1 F900.000 X6.977 Y-9.239 E170.91671
G0 X7.047 Y-9.309
G0 F7200.000 X6.411 Y-9.239
G1 F900.000 X-9.239 Y6.411 E171.31054
G0 X-9.309 Y6.481
G0 F7200.000 X-9.239 Y5.845
G1 F900.000 X5.845 Y-9.239 E171.69012
G0 X5.915 Y-9.309
G0 F7200.000 X5.279 Y-9.239
G1 F900.000 X-9.239 Y5.279 E172.05546
G0 X-9.309 Y5.349
G0 F7200.000 X-9.239 Y4.714
G1 F900.000 X4.714 Y-9.239 E172.40659
G0 X4.784 Y-9.309
G0 F7200.000 X4.148 Y-9.239
G1 F900.000 X-9.239 Y4.148 E172.74347
G0 X-9.309 Y4.218
G0 F7200.000 X-9.239 Y3.582
G1 F900.000 X3.582 Y-9.239 E173.06610
G0 X3.652 Y-9.309
G0 F7200.000 X3.017 Y-9.239
G1 F900.000 X-9.239 Y3.017 E173.37452
G0 X-9.309 Y3.087
G0 F7200.000 X-9.239 Y2.451
G1 F900.000 X2.451 Y-9.239 E173.66870
G0 X2.521 Y-9.309
G0 F7200.000 X1.885 Y-9.239
G1 F900.000 X-9.239 Y1.885 E173.94863
G0 X-9.309 Y1.955
G0 F7200.000 X-9.239 Y1.320
G1 F900.000 X1.320 Y-9.239 E174.21435
G0 X1.390 Y-9.309
G0 F7200.000 X0.754 Y-9.239
G1 F900.000 X-9.239 Y0.754 E174.46582
G0 X-9.309 Y0.824
G0 F7200.000 X-9.239 Y0.188
G1 F900.000 X0.188 Y-9.239 E174.70305
G0 X0.258 Y-9.309
G0 F7200.000 X-0.376 Y-9.239
G1 F900.000 X-9.239 Y-0.376 E174.92608
G0 X-9.309 Y-0.306
G0 F7200.000 X-9.239 Y-0.942
G1 F900.000 X-0.942 Y-9.239 E175.13487
G0 X-0.872 Y-9.309
G0 F7200.000 X-1.508 Y-9.239
G1 F900.000 X-9.239 Y-1.508 E175.32942
G0 X-9.309 Y-1.438
G0 F7200.000 X-9.239 Y-2.073
G1 F900.000 X-2.073 Y-9.239 E175.50975
G0 X-2.003 Y-9.309
G0 F7200.000 X-2.639 Y-9.239
G1 F900.000 X-9.239 Y-2.639 E175.67584
G0 X-9.309 Y-2.569
G0 F7200.000 X-9.239 Y-3.205
G1 F900.000 X-3.205 Y-9.239 E175.82769
G0 X-3.135 Y-9.309
G0 F7200.000 X-3.771 Y-9.239
G1 F900.000 X-9.239 Y-3.771 E175.96529
G0 X-9.309 Y-3.701
G0 F7200.000 X-9.239 Y-4.336
G1 F900.000 X-4.336 Y-9.239 E176.08867
G0 X-4.266 Y-9.309
G0 F7200.000 X-4.902 Y-9.239
G1 F900.000 X-9.239 Y-4.902 E176.19781
G0 X-9.309 Y-4.832
G0 F7200.000 X-9.239 Y-5.468
G1 F900.000 X-5.468 Y-9.239 E176.29271
G0 X-5.398 Y-9.309
G0 F7200.000 X-6.033 Y-9.239
G1 F900.000 X-9.239 Y-6.033 E176.37338
G0 X-9.309 Y-5.963
G0 F7200.000 X-9.239 Y-6.599
G1 F900.000 X-6.599 Y-9.239 E176.43982
G0 X-6.529 Y-9.309
G0 F7200.000 X-7.165 Y-9.239
G1 F900.000 X-9.239 Y-7.165 E176.49201
G0 X-9.309 Y-7.095
G0 F7200.000 X-9.239 Y-7.730
G1 F900.000 X-7.730 Y-9.239 E176.52998
G0 X-7.660 Y-9.309
G0 F7200.000 X-8.296 Y-9.239
G1 F900.000 X-9.239 Y-8.296 E176.55371
G0 X-9.309 Y-8.226
G0 F7200.000 X-9.239 Y-8.862
G1 F900.000 X-8.862 Y-9.239 E176.56320
G0 F7200.00000 X9.239 Y-8.674
G1 F900.000 X-8.674 Y9.239 E177.01398
G0 X-8.744 Y9.309
G0 F7200.000 X-8.108 Y9.239
G1 F900.000 X9.239 Y-8.108 E177.45051
G0 X9.309 Y-8.178
G0 F7200.000 X9.239 Y-7.542
G1 F900.000 X-7.542 Y9.239 E177.87280
G0 X-7.612 Y9.309
G0 F7200.000 X-6.977 Y9.239
G1 F900.000 X9.239 Y-6.977 E178.28087
G0 X9.309 Y-7.047
G0 F7200.000 X9.239 Y-6.411
G1 F900.000 X-6.411 Y9.239 E178.67470
G0 X-6.481 Y9.309
G0 F7200.000 X-5.845 Y9.239
G1 F900.000 X9.239 Y-5.845 E179.05429
G0 X9.309 Y-5.915
G0 F7200.000 X9.239 Y-5.279
G1 F900.000 X-5.279 Y9.239 E179.41963
G0 X-5.349 Y9.309
G0 F7200.000 X-4.714 Y9.239
G1 F900.000 X9.239 Y-4.714 E179.77075
G0 X9.309 Y-4.784
G0 F7200.000 X9.239 Y-4.148
G1 F900.000 X-4.148 Y9.239 E180.10763
G0 X-4.218 Y9.309
G0 F7200.000 X-3.582 Y9.239
G1 F900.000 X9.239 Y-3.582 E180.43027
G0 X9.309 Y-3.652
G0 F7200.000 X9.239 Y-3.017
G1 F900.000 X-3.017 Y9.239 E180.73869
G0 X-3.087 Y9.309
G0 F7200.000 X-2.451 Y9.239
G1 F900.000 X9.239 Y-2.451 E181.03287
G0 X9.309 Y-2.521
G0 F7200.000 X9.239 Y-1.885
G1 F900.000 X-1.885 Y9.239 E181.31280
G0 X-1.955 Y9.309
G0 F7200.000 X-1.320 Y9.239
G1 F900.000 X9.239 Y-1.320 E181.57851
G0 X9.309 Y-1.390
G0 F7200.000 X9.239 Y-0.754
G1 F900.000 X-0.754 Y9.239 E181.82998
G0 X-0.824 Y9.309
G0 F7200.000 X-0.188 Y9.239
G1 F900.000 X9.239 Y-0.188 E182.06721
G0 X9.309 Y-0.258
G0 F7200.000 X9.239 Y0.376
G1 F900.000 X0.376 Y9.239 E182.29025
G0 X0.306 Y9.309
G0 F7200.000 X0.942 Y9.239
G1 F900.000 X9.239 Y0.942 E182.49904
G0 X9.309 Y0.872
G0 F7200.000 X9.239 Y1.508
G1 F900.000 X1.508 Y9.239 E182.69359
G0 X1.438 Y9.309
G0 F7200.000 X2.073 Y9.239
G1 F900.000 X9.239 Y2.073 E182.87392
G0 X9.309 Y2.003
G0 F7200.000 X9.239 Y2.639
G1 F900.000 X2.639 Y9.239 E183.04001
G0 X2.569 Y9.309
G0 F7200.000 X3.205 Y9.239
G1 F900.000 X9.239 Y3.205 E183.19185
G0 X9.309 Y3.135
G0 F7200.000 X9.239 Y3.771
G1 F900.000 X3.771 Y9.239 E183.32945
G0 X3.701 Y9.309
G0 F7200.000 X4.336 Y9.239
G1 F900.000 X9.239 Y4.336 E183.45283
G0 X9.309 Y4.266
G0 F7200.000 X9.239 Y4.902
G1 F900.000 X4.902 Y9.239 E183.56197
G0 X4.832 Y9.309
G0 F7200.000 X5.468 Y9.239
G1 F900.000 X9.239 Y5.468 E183.65687
G0 X9.309 Y5.398
G0 F7200.000 X9.239 Y6.033
G1 F900.000 X6.033 Y9.239 E183.73755
G0 X5.963 Y9.309
G0 F7200.000 X6.599 Y9.239
G1 F900.000 X9.239 Y6.599 E183.80398
G0 X9.309 Y6.529
G0 F7200.000 X9.239 Y7.165
G1 F900.000 X7.165 Y9.239 E183.85617
G0 X7.095 Y9.309
G0 F7200.000 X7.730 Y9.239
G1 F900.000 X9.239 Y7.730 E183.89415
G0 X9.309 Y7.660
G0 F7200.000 X9.239 Y8.296
G1 F900.000 X8.296 Y9.239 E183.91788
G0 X8.226 Y9.309
G0 F7200.000 X8.862 Y9.239
G1 F900.000 X9.239 Y8.862 E183.92737
G0 F7200.00000 X9.000 Y8.862
;LAYER:2
G0 X9.400 Y9.400 Z0.500
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y9.400 E184.26190
G1 X-9.400 Y-9.400 E184.59643
G1 X9.400 Y-9.400 E184.93096
G1 X9.400 Y9.400 E185.26549
G0 F7200.00000 X9.800 Y9.800
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y9.800 E185.61425
G1 X-9.800 Y-9.800 E185.96302
G1 X9.800 Y-9.800 E186.31179
G1 X9.800 Y9.800 E186.66055
G0 F7200.00000 X9.239 Y9.239
;TYPE:SKIN
G1 F900.000 X-9.239 Y-9.239 E187.12555
G0 X-9.309 Y-9.309
G0 F7200.000 X-8.674 Y-9.239
G1 F900.000 X9.239 Y8.674 E187.57632
G0 X9.309 Y8.744
G0 F7200.000 X9.239 Y8.108
G1 F900.000 X-8.108 Y-9.239 E188.01285
G0 X-8.178 Y-9.309
G0 F7200.000 X-7.542 Y-9.239
G1 F900.000 X9.239 Y7.542 E188.43514
G0 X9.309 Y7.612
G0 F7200.000 X9.239 Y6.977
G1 F900.000 X-6.977 Y-9.239 E188.84322
G0 X-7.047 Y-9.309
G0 F7200.000 X-6.411 Y-9.239
G1 F900.000 X9.239 Y6.411 E189.23704
G0 X9.309 Y6.481
G0 F7200.000 X9.239 Y5.845
G1 F900.000 X-5.845 Y-9.239 E189.61663
G0 X-5.915 Y-9.309
G0 F7200.000 X-5.279 Y-9.239
G1 F900.000 X9.239 Y5.279 E189.98197
G0 X9.309 Y5.349
G0 F7200.000 X9.239 Y4.714
G1 F900.000 X-4.714 Y-9.239 E190.33310
G0 X-4.784 Y-9.309
G0 F7200.000 X-4.148 Y-9.239
G1 F900.000 X9.239 Y4.148 E190.66998
G0 X9.309 Y4.218
G0 F7200.000 X9.239 Y3.582
G1 F900.000 X-3.582 Y-9.239 E190.99261
G0 X-3.652 Y-9.309
G0 F7200.000 X-3.017 Y-9.239
G1 F900.000 X9.239 Y3.017 E191.30103
G0 X9.309 Y3.087
G0 F7200.000 X9.239 Y2.451
G1 F900.000 X-2.451 Y-9.239 E191.59521
G0 X-2.521 Y-9.309
G0 F7200.000 X-1.885 Y-9.239
G1 F900.000 X9.239 Y1.885 E191.87514
G0 X9.309 Y1.955
G0 F7200.000 X9.239 Y1.320
G1 F900.000 X-1.320 Y-9.239 E192.14086
G0 X-1.390 Y-9.309
G0 F7200.000 X-0.754 Y-9.239
G1 F900.000 X9.239 Y0.754 E192.39233
G0 X9.309 Y0.824
G0 F7200.000 X9.239 Y0.188
G1 F900.000 X-0.188 Y-9.239 E192.62956
G0 X-0.258 Y-9.309
G0 F7200.000 X0.376 Y-9.239
G1 F900.000 X9.239 Y-0.376 E192.85259
G0 X9.309 Y-0.306
G0 F7200.000 X9.239 Y-0.942
G1 F900.000 X0.942 Y-9.239 E193.06138
G0 X0.872 Y-9.309
G0 F7200.000 X1.508 Y-9.239
G1 F900.000 X9.239 Y-1.508 E193.25593
G0 X9.309 Y-1.438
G0 F7200.000 X9.239 Y-2.073
G1 F900.000 X2.073 Y-9.239 E193.43626
G0 X2.003 Y-9.309
G0 F7200.000 X2.639 Y-9.239
G1 F900.000 X9.239 Y-2.639 E193.60235
G0 X9.309 Y-2.569
G0 F7200.000 X9.239 Y-3.205
G1 F900.000 X3.205 Y-9.239 E193.75419
G0 X3.135 Y-9.309
G0 F7200.000 X3.771 Y-9.239
G1 F900.000 X9.239 Y-3.771 E193.89180
G0 X9.309 Y-3.701
G0 F7200.000 X9.239 Y-4.336
G1 F900.000 X4.336 Y-9.239 E194.01518
G0 X4.266 Y-9.309
G0 F7200.000 X4.902 Y-9.239
G1 F900.000 X9.239 Y-4.902 E194.12432
G0 X9.309 Y-4.832
G0 F7200.000 X9.239 Y-5.468
G1 F900.000 X5.468 Y-9.239 E194.21921
G0 X5.398 Y-9.309
G0 F7200.000 X6.033 Y-9.239
G1 F900.000 X9.239 Y-6.033 E194.29989
G0 X9.309 Y-5.963
G0 F7200.000 X9.239 Y-6.599
G1 F900.000 X6.599 Y-9.239 E194.36633
G0 X6.529 Y-9.309
G0 F7200.000 X7.165 Y-9.239
G1 F900.000 X9.239 Y-7.165 E194.41852
G0 X9.309 Y-7.095
G0 F7200.000 X9.239 Y-7.730
G1 F900.000 X7.730 Y-9.239 E194.45649
G0 X7.660 Y-9.309
G0 F7200.000 X8.296 Y-9.239
G1 F900.000 X9.239 Y-8.296 E194.48022
G0 X9.309 Y-8.226
G0 F7200.000 X9.239 Y-8.862
G1 F900.000 X8.862 Y-9.239 E194.48971
G0 F7200.00000 X-9.239 Y-8.674
G1 F900.000 X8.674 Y9.239 E194.94049
G0 X8.744 Y9.309
G0 F7200.000 X8.108 Y9.239
G1 F900.000 X-9.239 Y-8.108 E195.37702
G0 X-9.309 Y-8.178
G0 F7200.000 X-9.239 Y-7.542
G1 F900.000 X7.542 Y9.239 E195.79931
G0 X7.612 Y9.309
G0 F7200.000 X6.977 Y9.239
G1 F900.000 X-9.239 Y-6.977 E196.20738
G0 X-9.309 Y-7.047
G0 F7200.000 X-9.239 Y-6.411
G1 F900.000 X6.411 Y9.239 E196.60121
G0 X6.481 Y9.309
G0 F7200.000 X5.845 Y9.239
G1 F900.000 X-9.239 Y-5.845 E196.98079
G0 X-9.309 Y-5.915
G0 F7200.000 X-9.239 Y-5.279
G1 F900.000 X5.279 Y9.239 E197.34614
G0 X5.349 Y9.309
G0 F7200.000 X4.714 Y9.239
G1 F900.000 X-9.239 Y-4.714 E197.69726
G0 X-9.309 Y-4.784
G0 F7200.000 X-9.239 Y-4.148
G1 F900.000 X4.148 Y9.239 E198.03414
G0 X4.218 Y9.309
G0 F7200.000 X3.582 Y9.239
G1 F900.000 X-9.239 Y-3.582 E198.35678
G0 X-9.309 Y-3.652
G0 F7200.000 X-9.239 Y-3.017
G1 F900.000 X3.017 Y9.239 E198.66520
G0 X3.087 Y9.309
G0 F7200.000 X2.451 Y9.239
G1 F900.000 X-9.239 Y-2.451 E198.95937
G0 X-9.309 Y-2.521
G0 F7200.000 X-9.239 Y-1.885
G1 F900.000 X1.885 Y9.239 E199.23931
G0 X1.955 Y9.309
G0 F7200.000 X1.320 Y9.239
G1 F900.000 X-9.239 Y-1.320 E199.50502
G0 X-9.309 Y-1.390
G0 F7200.000 X-9.239 Y-0.754
G1 F900.000 X0.754 Y9.239 E199.75649
G0 X0.824 Y9.309
G0 F7200.000 X0.188 Y9.239
G1 F900.000 X-9.239 Y-0.188 E199.99372
G0 X-9.309 Y-0.258
G0 F7200.000 X-9.239 Y0.376
G1 F900.000 X-0.376 Y9.239 E200.21676
G0 X-0.306 Y9.309
G0 F7200.000 X-0.942 Y9.239
G1 F900.000 X-9.239 Y0.942 E200.42555
G0 X-9.309 Y0.872
G0 F7200.000 X-9.239 Y1.508
G1 F900.000 X-1.508 Y9.239 E200.62010
G0 X-1.438 Y9.309
G0 F7200.000 X-2.073 Y9.239
G1 F900.000 X-9.239 Y2.073 E200.80043
G0 X-9.309 Y2.003
G0 F7200.000 X-9.239 Y2.639
G1 F900.000 X-2.639 Y9.239 E200.96652
G0 X-2.569 Y9.309
G0 F7200.000 X-3.205 Y9.239
G1 F900.000 X-9.239 Y3.205 E201.11836
G0 X-9.309 Y3.135
G0 F7200.000 X-9.239 Y3.771
G1 F900.000 X-3.771 Y9.239 E201.25596
G0 X-3.701 Y9.309
G0 F7200.000 X-4.336 Y9.239
G1 F900.000 X-9.239 Y4.336 E201.37934
G0 X-9.309 Y4.266
G0 F7200.000 X-9.239 Y4.902
G1 F900.000 X-4.902 Y9.239 E201.48848
G0 X-4.832 Y9.309
G0 F7200.000 X-5.468 Y9.239
G1 F900.000 X-9.239 Y5.468 E201.58338
G0 X-9.309 Y5.398
G0 F7200.000 X-9.239 Y6.033
G1 F900.000 X-6.033 Y9.239 E201.66406
G0 X-5.963 Y9.309
G0 F7200.000 X-6.599 Y9.239
G1 F900.000 X-9.239 Y6.599 E201.73049
G0 X-9.309 Y6.529
G0 F7200.000 X-9.239 Y7.165
G1 F900.000 X-7.165 Y9.239 E201.78268
G0 X-7.095 Y9.309
G0 F7200.000 X-7.730 Y9.239
G1 F900.000 X-9.239 Y7.730 E201.82066
G0 X-9.309 Y7.660
G0 F7200.000 X-9.239 Y8.296
G1 F900.000 X-8.296 Y9.239 E201.84439
G0 X-8.226 Y9.309
G0 F7200.000 X-8.862 Y9.239
G1 F900.000 X-9.239 Y8.862 E201.85388
G0 F7200.00000 X-9.000 Y8.862
;LAYER:3
G0 X-9.239 Y9.239 Z0.600
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E202.31887
G0 X9.309 Y-9.309
G0 F7200.000 X9.300 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E202.35684
G0 X9.309 Y-7.660
G0 F7200.000 X9.300 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E202.67948
G0 X-3.652 Y9.309
G0 F7200.000 X-3.652 Y9.300
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E202.85981
G0 X-9.309 Y2.003
G0 F7200.000 X-9.300 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E203.18245
G0 X3.652 Y-9.309
G0 F7200.000 X3.652 Y-9.300
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E203.36278
G0 X9.309 Y-2.003
G0 F7200.000 X9.300 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E203.54311
G0 X2.003 Y9.309
G0 F7200.000 X2.003 Y9.300
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E203.86575
G0 X-9.309 Y-3.652
G0 F7200.000 X-9.300 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E204.04608
G0 X-2.003 Y-9.309
G0 F7200.000 X-2.003 Y-9.300
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E204.36872
G0 X9.309 Y3.652
G0 F7200.000 X9.300 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E204.40669
G0 X7.660 Y9.309
G0 F7200.000 X7.660 Y9.300
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E204.87168
G0 X-9.309 Y-9.309
G0 F7200.000 X-9.300 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E204.90966
G0 X-7.660 Y-9.309
G0 F7200.000 X-7.660 Y-9.300
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E204.94763
G0 X-7.660 Y9.309
G0 F7200.000 X-7.660 Y9.300
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E205.28216
G1 X9.400 Y-9.400 E205.61669
G1 X9.400 Y9.400 E205.95122
G1 X-9.400 Y9.400 E206.28575
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E206.63452
G1 X9.800 Y-9.800 E206.98328
G1 X9.800 Y9.800 E207.33205
G1 X-9.800 Y9.800 E207.68082
G0 F7200.00000 X-9.118 Y9.000
;LAYER:4
G0 X-9.239 Y9.239 Z0.700
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E208.14581
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E208.18378
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E208.50642
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E208.68675
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E209.00939
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E209.18972
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E209.37005
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E209.69269
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E209.87302
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E210.19566
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E210.23363
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E210.69862
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E210.73660
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E210.77457
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E211.10910
G1 X9.400 Y-9.400 E211.44363
G1 X9.400 Y9.400 E211.77816
G1 X-9.400 Y9.400 E212.11269
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E212.46146
G1 X9.800 Y-9.800 E212.81022
G1 X9.800 Y9.800 E213.15899
G1 X-9.800 Y9.800 E213.50776
;LAYER:5
G0 X-9.239 Y9.239 Z0.800
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E213.97275
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E214.01072
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E214.33336
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E214.51369
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E214.83633
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E215.01666
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E215.19699
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E215.51963
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E215.69996
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E216.02260
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E216.06057
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E216.52556
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E216.56354
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E216.60151
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E216.93604
G1 X9.400 Y-9.400 E217.27057
G1 X9.400 Y9.400 E217.60510
G1 X-9.400 Y9.400 E217.93963
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E218.28840
G1 X9.800 Y-9.800 E218.63716
G1 X9.800 Y9.800 E218.98593
G1 X-9.800 Y9.800 E219.33470
;LAYER:6
G0 X-9.239 Y9.239 Z0.900
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E219.79969
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E219.83766
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E220.16030
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E220.34063
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E220.66327
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E220.84360
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E221.02393
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E221.34657
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E221.52690
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E221.84954
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E221.88751
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E222.35250
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E222.39048
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E222.42845
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E222.76298
G1 X9.400 Y-9.400 E223.09751
G1 X9.400 Y9.400 E223.43204
G1 X-9.400 Y9.400 E223.76657
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E224.11534
G1 X9.800 Y-9.800 E224.46411
G1 X9.800 Y9.800 E224.81287
G1 X-9.800 Y9.800 E225.16164
;LAYER:7
G0 X-9.239 Y9.239 Z1.000
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E225.62663
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E225.66460
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E225.98724
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E226.16757
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E226.49021
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E226.67054
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E226.85087
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E227.17351
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E227.35384
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E227.67648
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E227.71445
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E228.17945
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E228.21742
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E228.25539
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E228.58992
G1 X9.400 Y-9.400 E228.92445
G1 X9.400 Y9.400 E229.25898
G1 X-9.400 Y9.400 E229.59351
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E229.94228
G1 X9.800 Y-9.800 E230.29105
G1 X9.800 Y9.800 E230.63981
G1 X-9.800 Y9.800 E230.98858
;LAYER:8
G0 X-9.239 Y9.239 Z1.100
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E231.45357
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E231.49155
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E231.81418
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E231.99451
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E232.31715
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E232.49748
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E232.67781
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E233.00045
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E233.18078
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E233.50342
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E233.54139
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E234.00639
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E234.04436
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E234.08233
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E234.41686
G1 X9.400 Y-9.400 E234.75139
G1 X9.400 Y9.400 E235.08592
G1 X-9.400 Y9.400 E235.42045
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E235.76922
G1 X9.800 Y-9.800 E236.11799
G1 X9.800 Y9.800 E236.46675
G1 X-9.800 Y9.800 E236.81552
;LAYER:9
G0 X-9.239 Y9.239 Z1.200
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E237.28051
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E237.31849
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E237.64112
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E237.82145
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E238.14409
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E238.32442
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E238.50475
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E238.82739
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E239.00772
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E239.33036
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E239.36833
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E239.83333
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E239.87130
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E239.90927
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E240.24380
G1 X9.400 Y-9.400 E240.57833
G1 X9.400 Y9.400 E240.91286
G1 X-9.400 Y9.400 E241.24740
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E241.59616
G1 X9.800 Y-9.800 E241.94493
G1 X9.800 Y9.800 E242.29369
G1 X-9.800 Y9.800 E242.64246
;LAYER:10
G0 X-9.239 Y9.239 Z1.300
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E243.10745
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E243.14543
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E243.46806
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E243.64839
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E243.97103
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E244.15136
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E244.33169
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E244.65433
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E244.83466
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E245.15730
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E245.19527
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E245.66027
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E245.69824
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E245.73621
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E246.07074
G1 X9.400 Y-9.400 E246.40527
G1 X9.400 Y9.400 E246.73981
G1 X-9.400 Y9.400 E247.07434
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E247.42310
G1 X9.800 Y-9.800 E247.77187
G1 X9.800 Y9.800 E248.12063
G1 X-9.800 Y9.800 E248.46940
;LAYER:11
G0 X-9.239 Y9.239 Z1.400
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E248.93439
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E248.97237
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E249.29500
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E249.47533
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E249.79797
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E249.97830
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E250.15863
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E250.48127
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E250.66160
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E250.98424
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E251.02221
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E251.48721
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E251.52518
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E251.56315
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E251.89768
G1 X9.400 Y-9.400 E252.23222
G1 X9.400 Y9.400 E252.56675
G1 X-9.400 Y9.400 E252.90128
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E253.25004
G1 X9.800 Y-9.800 E253.59881
G1 X9.800 Y9.800 E253.94757
G1 X-9.800 Y9.800 E254.29634
;LAYER:12
G0 X-9.239 Y9.239 Z1.500
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E254.76133
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E254.79931
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E255.12194
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E255.30228
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E255.62491
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E255.80524
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E255.98557
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E256.30821
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E256.48854
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E256.81118
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E256.84915
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E257.31415
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E257.35212
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E257.39009
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E257.72462
G1 X9.400 Y-9.400 E258.05916
G1 X9.400 Y9.400 E258.39369
G1 X-9.400 Y9.400 E258.72822
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E259.07698
G1 X9.800 Y-9.800 E259.42575
G1 X9.800 Y9.800 E259.77451
G1 X-9.800 Y9.800 E260.12328
;LAYER:13
G0 X-9.239 Y9.239 Z1.600
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E260.58827
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E260.62625
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E260.94888
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E261.12922
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E261.45185
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E261.63218
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E261.81251
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E262.13515
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E262.31548
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E262.63812
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E262.67609
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E263.14109
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E263.17906
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E263.21703
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E263.55157
G1 X9.400 Y-9.400 E263.88610
G1 X9.400 Y9.400 E264.22063
G1 X-9.400 Y9.400 E264.55516
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E264.90392
G1 X9.800 Y-9.800 E265.25269
G1 X9.800 Y9.800 E265.60145
G1 X-9.800 Y9.800 E265.95022
;LAYER:14
G0 X-9.239 Y9.239 Z1.700
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E266.41521
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E266.45319
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E266.77583
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E266.95616
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E267.27879
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E267.45912
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E267.63945
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E267.96209
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E268.14242
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E268.46506
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E268.50303
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E268.96803
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E269.00600
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E269.04398
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E269.37851
G1 X9.400 Y-9.400 E269.71304
G1 X9.400 Y9.400 E270.04757
G1 X-9.400 Y9.400 E270.38210
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E270.73086
G1 X9.800 Y-9.800 E271.07963
G1 X9.800 Y9.800 E271.42839
G1 X-9.800 Y9.800 E271.77716
;LAYER:15
G0 X-9.239 Y9.239 Z1.800
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E272.24215
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E272.28013
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E272.60277
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E272.78310
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E273.10573
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E273.28606
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E273.46640
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E273.78903
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E273.96936
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E274.29200
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E274.32997
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E274.79497
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E274.83294
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E274.87092
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E275.20545
G1 X9.400 Y-9.400 E275.53998
G1 X9.400 Y9.400 E275.87451
G1 X-9.400 Y9.400 E276.20904
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E276.55780
G1 X9.800 Y-9.800 E276.90657
G1 X9.800 Y9.800 E277.25533
G1 X-9.800 Y9.800 E277.60410
;LAYER:16
G0 X-9.239 Y9.239 Z1.900
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E278.06910
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E278.10707
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E278.42971
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E278.61004
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E278.93267
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E279.11300
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E279.29334
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E279.61597
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E279.79630
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E280.11894
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E280.15691
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E280.62191
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E280.65988
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E280.69786
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E281.03239
G1 X9.400 Y-9.400 E281.36692
G1 X9.400 Y9.400 E281.70145
G1 X-9.400 Y9.400 E282.03598
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E282.38474
G1 X9.800 Y-9.800 E282.73351
G1 X9.800 Y9.800 E283.08228
G1 X-9.800 Y9.800 E283.43104
;LAYER:17
G0 X-9.239 Y9.239 Z2.000
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E283.89604
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E283.93401
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E284.25665
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E284.43698
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E284.75961
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E284.93995
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E285.12028
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E285.44291
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E285.62324
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E285.94588
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E285.98385
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E286.44885
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E286.48682
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E286.52480
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E286.85933
G1 X9.400 Y-9.400 E287.19386
G1 X9.400 Y9.400 E287.52839
G1 X-9.400 Y9.400 E287.86292
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E288.21168
G1 X9.800 Y-9.800 E288.56045
G1 X9.800 Y9.800 E288.90922
G1 X-9.800 Y9.800 E289.25798
;LAYER:18
G0 X-9.239 Y9.239 Z2.100
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E289.72298
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E289.76095
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E290.08359
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E290.26392
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E290.58655
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E290.76689
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E290.94722
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E291.26985
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E291.45018
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E291.77282
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E291.81080
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E292.27579
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E292.31376
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E292.35174
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E292.68627
G1 X9.400 Y-9.400 E293.02080
G1 X9.400 Y9.400 E293.35533
G1 X-9.400 Y9.400 E293.68986
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E294.03862
G1 X9.800 Y-9.800 E294.38739
G1 X9.800 Y9.800 E294.73616
G1 X-9.800 Y9.800 E295.08492
;LAYER:19
G0 X-9.239 Y9.239 Z2.200
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E295.54992
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E295.58789
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E295.91053
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E296.09086
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E296.41350
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E296.59383
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E296.77416
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E297.09679
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E297.27712
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E297.59976
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E297.63774
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E298.10273
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E298.14070
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E298.17868
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E298.51321
G1 X9.400 Y-9.400 E298.84774
G1 X9.400 Y9.400 E299.18227
G1 X-9.400 Y9.400 E299.51680
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E299.86557
G1 X9.800 Y-9.800 E300.21433
G1 X9.800 Y9.800 E300.56310
G1 X-9.800 Y9.800 E300.91186
;LAYER:20
G0 X-9.239 Y9.239 Z2.300
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E301.37686
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E301.41483
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E301.73747
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E301.91780
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E302.24044
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E302.42077
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E302.60110
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E302.92373
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E303.10407
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E303.42670
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E303.46468
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E303.92967
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E303.96764
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E304.00562
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E304.34015
G1 X9.400 Y-9.400 E304.67468
G1 X9.400 Y9.400 E305.00921
G1 X-9.400 Y9.400 E305.34374
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E305.69251
G1 X9.800 Y-9.800 E306.04127
G1 X9.800 Y9.800 E306.39004
G1 X-9.800 Y9.800 E306.73880
;LAYER:21
G0 X-9.239 Y9.239 Z2.400
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E307.20380
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E307.24177
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E307.56441
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E307.74474
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E308.06738
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E308.24771
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E308.42804
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E308.75067
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E308.93101
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E309.25364
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E309.29162
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E309.75661
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E309.79458
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E309.83256
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E310.16709
G1 X9.400 Y-9.400 E310.50162
G1 X9.400 Y9.400 E310.83615
G1 X-9.400 Y9.400 E311.17068
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E311.51945
G1 X9.800 Y-9.800 E311.86821
G1 X9.800 Y9.800 E312.21698
G1 X-9.800 Y9.800 E312.56574
;LAYER:22
G0 X-9.239 Y9.239 Z2.500
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E313.03074
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E313.06871
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E313.39135
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E313.57168
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E313.89432
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E314.07465
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E314.25498
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E314.57762
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E314.75795
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E315.08058
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E315.11856
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E315.58355
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E315.62153
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E315.65950
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E315.99403
G1 X9.400 Y-9.400 E316.32856
G1 X9.400 Y9.400 E316.66309
G1 X-9.400 Y9.400 E316.99762
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E317.34639
G1 X9.800 Y-9.800 E317.69515
G1 X9.800 Y9.800 E318.04392
G1 X-9.800 Y9.800 E318.39268
;LAYER:23
G0 X-9.239 Y9.239 Z2.600
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E318.85768
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E318.89565
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E319.21829
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E319.39862
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E319.72126
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E319.90159
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E320.08192
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E320.40456
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E320.58489
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E320.90752
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E320.94550
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E321.41049
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E321.44847
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E321.48644
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E321.82097
G1 X9.400 Y-9.400 E322.15550
G1 X9.400 Y9.400 E322.49003
G1 X-9.400 Y9.400 E322.82456
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E323.17333
G1 X9.800 Y-9.800 E323.52209
G1 X9.800 Y9.800 E323.87086
G1 X-9.800 Y9.800 E324.21962
;LAYER:24
G0 X-9.239 Y9.239 Z2.700
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E324.68462
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E324.72259
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E325.04523
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E325.22556
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E325.54820
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E325.72853
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E325.90886
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E326.23150
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E326.41183
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E326.73446
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E326.77244
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E327.23743
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E327.27541
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E327.31338
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E327.64791
G1 X9.400 Y-9.400 E327.98244
G1 X9.400 Y9.400 E328.31697
G1 X-9.400 Y9.400 E328.65150
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E329.00027
G1 X9.800 Y-9.800 E329.34903
G1 X9.800 Y9.800 E329.69780
G1 X-9.800 Y9.800 E330.04656
;LAYER:25
G0 X-9.239 Y9.239 Z2.800
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E330.51156
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E330.54953
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E330.87217
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E331.05250
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E331.37514
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E331.55547
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E331.73580
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E332.05844
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E332.23877
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E332.56140
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E332.59938
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E333.06437
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E333.10235
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E333.14032
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E333.47485
G1 X9.400 Y-9.400 E333.80938
G1 X9.400 Y9.400 E334.14391
G1 X-9.400 Y9.400 E334.47844
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E334.82721
G1 X9.800 Y-9.800 E335.17597
G1 X9.800 Y9.800 E335.52474
G1 X-9.800 Y9.800 E335.87350
;LAYER:26
G0 X-9.239 Y9.239 Z2.900
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E336.33850
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E336.37647
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E336.69911
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E336.87944
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E337.20208
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E337.38241
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E337.56274
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E337.88538
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E338.06571
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E338.38835
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E338.42632
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E338.89131
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E338.92929
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E338.96726
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E339.30179
G1 X9.400 Y-9.400 E339.63632
G1 X9.400 Y9.400 E339.97085
G1 X-9.400 Y9.400 E340.30538
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E340.65415
G1 X9.800 Y-9.800 E341.00291
G1 X9.800 Y9.800 E341.35168
G1 X-9.800 Y9.800 E341.70045
;LAYER:27
G0 X-9.239 Y9.239 Z3.000
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E342.16544
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E342.20341
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E342.52605
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E342.70638
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E343.02902
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E343.20935
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E343.38968
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E343.71232
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E343.89265
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E344.21529
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E344.25326
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E344.71825
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E344.75623
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E344.79420
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E345.12873
G1 X9.400 Y-9.400 E345.46326
G1 X9.400 Y9.400 E345.79779
G1 X-9.400 Y9.400 E346.13232
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E346.48109
G1 X9.800 Y-9.800 E346.82985
G1 X9.800 Y9.800 E347.17862
G1 X-9.800 Y9.800 E347.52739
;LAYER:28
G0 X-9.239 Y9.239 Z3.100
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E347.99238
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E348.03035
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E348.35299
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E348.53332
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E348.85596
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E349.03629
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E349.21662
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E349.53926
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E349.71959
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E350.04223
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E350.08020
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E350.54519
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E350.58317
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E350.62114
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E350.95567
G1 X9.400 Y-9.400 E351.29020
G1 X9.400 Y9.400 E351.62473
G1 X-9.400 Y9.400 E351.95926
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E352.30803
G1 X9.800 Y-9.800 E352.65679
G1 X9.800 Y9.800 E353.00556
G1 X-9.800 Y9.800 E353.35433
;LAYER:29
G0 X-9.239 Y9.239 Z3.200
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E353.81932
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E353.85729
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E354.17993
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E354.36026
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E354.68290
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E354.86323
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E355.04356
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E355.36620
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E355.54653
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E355.86917
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E355.90714
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E356.37213
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E356.41011
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E356.44808
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E356.78261
G1 X9.400 Y-9.400 E357.11714
G1 X9.400 Y9.400 E357.45167
G1 X-9.400 Y9.400 E357.78620
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E358.13497
G1 X9.800 Y-9.800 E358.48373
G1 X9.800 Y9.800 E358.83250
G1 X-9.800 Y9.800 E359.18127
;LAYER:30
G0 X-9.239 Y9.239 Z3.300
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E359.64626
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E359.68423
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E360.00687
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E360.18720
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E360.50984
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E360.69017
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E360.87050
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E361.19314
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E361.37347
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E361.69611
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E361.73408
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E362.19907
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E362.23705
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E362.27502
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E362.60955
G1 X9.400 Y-9.400 E362.94408
G1 X9.400 Y9.400 E363.27861
G1 X-9.400 Y9.400 E363.61314
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E363.96191
G1 X9.800 Y-9.800 E364.31068
G1 X9.800 Y9.800 E364.65944
G1 X-9.800 Y9.800 E365.00821
;LAYER:31
G0 X-9.239 Y9.239 Z3.400
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E365.47320
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E365.51117
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E365.83381
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E366.01414
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E366.33678
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E366.51711
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E366.69744
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E367.02008
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E367.20041
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E367.52305
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E367.56102
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E368.02602
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E368.06399
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E368.10196
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E368.43649
G1 X9.400 Y-9.400 E368.77102
G1 X9.400 Y9.400 E369.10555
G1 X-9.400 Y9.400 E369.44008
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E369.78885
G1 X9.800 Y-9.800 E370.13762
G1 X9.800 Y9.800 E370.48638
G1 X-9.800 Y9.800 E370.83515
;LAYER:32
G0 X-9.239 Y9.239 Z3.500
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E371.30014
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E371.33812
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E371.66075
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E371.84108
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E372.16372
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E372.34405
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E372.52438
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E372.84702
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E373.02735
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E373.34999
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E373.38796
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E373.85296
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E373.89093
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E373.92890
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E374.26343
G1 X9.400 Y-9.400 E374.59796
G1 X9.400 Y9.400 E374.93249
G1 X-9.400 Y9.400 E375.26702
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E375.61579
G1 X9.800 Y-9.800 E375.96456
G1 X9.800 Y9.800 E376.31332
G1 X-9.800 Y9.800 E376.66209
;LAYER:33
G0 X-9.239 Y9.239 Z3.600
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E377.12708
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E377.16506
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E377.48769
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E377.66802
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E377.99066
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E378.17099
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E378.35132
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E378.67396
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E378.85429
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E379.17693
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E379.21490
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E379.67990
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E379.71787
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E379.75584
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E380.09037
G1 X9.400 Y-9.400 E380.42490
G1 X9.400 Y9.400 E380.75943
G1 X-9.400 Y9.400 E381.09397
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E381.44273
G1 X9.800 Y-9.800 E381.79150
G1 X9.800 Y9.800 E382.14026
G1 X-9.800 Y9.800 E382.48903
;LAYER:34
G0 X-9.239 Y9.239 Z3.700
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E382.95402
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E382.99200
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E383.31463
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E383.49496
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E383.81760
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E383.99793
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E384.17826
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E384.50090
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E384.68123
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E385.00387
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E385.04184
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E385.50684
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E385.54481
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E385.58278
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E385.91731
G1 X9.400 Y-9.400 E386.25184
G1 X9.400 Y9.400 E386.58638
G1 X-9.400 Y9.400 E386.92091
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E387.26967
G1 X9.800 Y-9.800 E387.61844
G1 X9.800 Y9.800 E387.96720
G1 X-9.800 Y9.800 E388.31597
;LAYER:35
G0 X-9.239 Y9.239 Z3.800
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E388.78096
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E388.81894
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E389.14157
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E389.32190
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E389.64454
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E389.82487
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E390.00520
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E390.32784
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E390.50817
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E390.83081
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E390.86878
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E391.33378
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E391.37175
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E391.40972
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E391.74425
G1 X9.400 Y-9.400 E392.07879
G1 X9.400 Y9.400 E392.41332
G1 X-9.400 Y9.400 E392.74785
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E393.09661
G1 X9.800 Y-9.800 E393.44538
G1 X9.800 Y9.800 E393.79414
G1 X-9.800 Y9.800 E394.14291
;LAYER:36
G0 X-9.239 Y9.239 Z3.900
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E394.60790
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E394.64588
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E394.96851
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E395.14885
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E395.47148
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E395.65181
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E395.83214
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E396.15478
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E396.33511
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E396.65775
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E396.69572
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E397.16072
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E397.19869
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E397.23666
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E397.57120
G1 X9.400 Y-9.400 E397.90573
G1 X9.400 Y9.400 E398.24026
G1 X-9.400 Y9.400 E398.57479
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E398.92355
G1 X9.800 Y-9.800 E399.27232
G1 X9.800 Y9.800 E399.62108
G1 X-9.800 Y9.800 E399.96985
;LAYER:37
G0 X-9.239 Y9.239 Z4.000
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E400.43484
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E400.47282
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E400.79545
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E400.97579
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E401.29842
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E401.47875
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E401.65908
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E401.98172
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E402.16205
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E402.48469
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E402.52266
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E402.98766
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E403.02563
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E403.06361
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E403.39814
G1 X9.400 Y-9.400 E403.73267
G1 X9.400 Y9.400 E404.06720
G1 X-9.400 Y9.400 E404.40173
G0 F7200.00000 X-9.800 Y9.800
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E404.75049
G1 X9.800 Y-9.800 E405.09926
G1 X9.800 Y9.800 E405.44802
G1 X-9.800 Y9.800 E405.79679
;LAYER:38
G0 X-9.239 Y9.239 Z4.100
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E406.26178
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E406.29976
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E406.62240
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E406.80273
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E407.12536
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E407.30569
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E407.48602
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E407.80866
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E407.98899
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E408.31163
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E408.34960
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E408.81460
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E408.85257
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E408.89055
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E409.22508
G1 X9.400 Y-9.400 E409.55961
G1 X9.400 Y9.400 E409.89414
G1 X-9.400 Y9.400 E410.22867
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E410.57743
G1 X9.800 Y-9.800 E410.92620
G1 X9.800 Y9.800 E411.27496
G1 X-9.800 Y9.800 E411.62373
;LAYER:39
G0 X-9.239 Y9.239 Z4.200
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E412.08872
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E412.12670
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E412.44934
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E412.62967
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E412.95230
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E413.13263
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E413.31297
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E413.63560
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E413.81593
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E414.13857
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E414.17654
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E414.64154
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E414.67951
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E414.71749
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E415.05202
G1 X9.400 Y-9.400 E415.38655
G1 X9.400 Y9.400 E415.72108
G1 X-9.400 Y9.400 E416.05561
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E416.40437
G1 X9.800 Y-9.800 E416.75314
G1 X9.800 Y9.800 E417.10190
G1 X-9.800 Y9.800 E417.45067
;LAYER:40
G0 X-9.239 Y9.239 Z4.300
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E417.91567
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E417.95364
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E418.27628
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E418.45661
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E418.77924
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E418.95957
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E419.13991
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E419.46254
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E419.64287
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E419.96551
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E420.00348
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E420.46848
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E420.50645
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E420.54443
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E420.87896
G1 X9.400 Y-9.400 E421.21349
G1 X9.400 Y9.400 E421.54802
G1 X-9.400 Y9.400 E421.88255
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E422.23131
G1 X9.800 Y-9.800 E422.58008
G1 X9.800 Y9.800 E422.92885
G1 X-9.800 Y9.800 E423.27761
;LAYER:41
G0 X-9.239 Y9.239 Z4.400
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E423.74261
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E423.78058
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E424.10322
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E424.28355
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E424.60618
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E424.78652
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E424.96685
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E425.28948
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E425.46981
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E425.79245
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E425.83043
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E426.29542
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E426.33339
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E426.37137
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E426.70590
G1 X9.400 Y-9.400 E427.04043
G1 X9.400 Y9.400 E427.37496
G1 X-9.400 Y9.400 E427.70949
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E428.05825
G1 X9.800 Y-9.800 E428.40702
G1 X9.800 Y9.800 E428.75579
G1 X-9.800 Y9.800 E429.10455
;LAYER:42
G0 X-9.239 Y9.239 Z4.500
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E429.56955
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E429.60752
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E429.93016
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E430.11049
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E430.43313
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E430.61346
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E430.79379
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E431.11642
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E431.29675
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E431.61939
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E431.65737
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E432.12236
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E432.16033
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E432.19831
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E432.53284
G1 X9.400 Y-9.400 E432.86737
G1 X9.400 Y9.400 E433.20190
G1 X-9.400 Y9.400 E433.53643
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E433.88519
G1 X9.800 Y-9.800 E434.23396
G1 X9.800 Y9.800 E434.58273
G1 X-9.800 Y9.800 E434.93149
;LAYER:43
G0 X-9.239 Y9.239 Z4.600
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E435.39649
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E435.43446
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E435.75710
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E435.93743
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E436.26007
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E436.44040
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E436.62073
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E436.94336
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E437.12369
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E437.44633
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E437.48431
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E437.94930
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E437.98727
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E438.02525
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E438.35978
G1 X9.400 Y-9.400 E438.69431
G1 X9.400 Y9.400 E439.02884
G1 X-9.400 Y9.400 E439.36337
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E439.71214
G1 X9.800 Y-9.800 E440.06090
G1 X9.800 Y9.800 E440.40967
G1 X-9.800 Y9.800 E440.75843
;LAYER:44
G0 X-9.239 Y9.239 Z4.700
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E441.22343
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E441.26140
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E441.58404
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E441.76437
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E442.08701
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E442.26734
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E442.44767
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E442.77030
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E442.95064
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E443.27327
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E443.31125
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E443.77624
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E443.81421
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E443.85219
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E444.18672
G1 X9.400 Y-9.400 E444.52125
G1 X9.400 Y9.400 E444.85578
G1 X-9.400 Y9.400 E445.19031
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E445.53908
G1 X9.800 Y-9.800 E445.88784
G1 X9.800 Y9.800 E446.23661
G1 X-9.800 Y9.800 E446.58537
;LAYER:45
G0 X-9.239 Y9.239 Z4.800
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E447.05037
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E447.08834
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E447.41098
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E447.59131
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E447.91395
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E448.09428
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E448.27461
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E448.59725
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E448.77758
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E449.10021
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E449.13819
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E449.60318
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E449.64115
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E449.67913
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E450.01366
G1 X9.400 Y-9.400 E450.34819
G1 X9.400 Y9.400 E450.68272
G1 X-9.400 Y9.400 E451.01725
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E451.36602
G1 X9.800 Y-9.800 E451.71478
G1 X9.800 Y9.800 E452.06355
G1 X-9.800 Y9.800 E452.41231
;LAYER:46
G0 X-9.239 Y9.239 Z4.900
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E452.87731
G0 X9.309 Y-9.309
G0 F7200.000 X9.300 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E452.91528
G0 X9.309 Y-7.660
G0 F7200.000 X9.300 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E453.23792
G0 X-3.652 Y9.309
G0 F7200.000 X-3.652 Y9.300
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E453.41825
G0 X-9.309 Y2.003
G0 F7200.000 X-9.300 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E453.74089
G0 X3.652 Y-9.309
G0 F7200.000 X3.652 Y-9.300
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E453.92122
G0 X9.309 Y-2.003
G0 F7200.000 X9.300 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E454.10155
G0 X2.003 Y9.309
G0 F7200.000 X2.003 Y9.300
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E454.42419
G0 X-9.309 Y-3.652
G0 F7200.000 X-9.300 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E454.60452
G0 X-2.003 Y-9.309
G0 F7200.000 X-2.003 Y-9.300
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E454.92715
G0 X9.309 Y3.652
G0 F7200.000 X9.300 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E454.96513
G0 X7.660 Y9.309
G0 F7200.000 X7.660 Y9.300
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E455.43012
G0 X-9.309 Y-9.309
G0 F7200.000 X-9.300 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E455.46810
G0 X-7.660 Y-9.309
G0 F7200.000 X-7.660 Y-9.300
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E455.50607
G0 X-7.660 Y9.309
G0 F7200.000 X-7.660 Y9.300
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E455.84060
G1 X9.400 Y-9.400 E456.17513
G1 X9.400 Y9.400 E456.50966
G1 X-9.400 Y9.400 E456.84419
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E457.19296
G1 X9.800 Y-9.800 E457.54172
G1 X9.800 Y9.800 E457.89049
G1 X-9.800 Y9.800 E458.23925
G0 F7200.00000 X-9.118 Y9.000
;LAYER:47
G0 X-9.239 Y9.239 Z5.000
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E458.70425
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E458.74222
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E459.06486
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E459.24519
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E459.56783
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E459.74816
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E459.92849
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E460.25113
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E460.43146
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E460.75409
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E460.79207
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E461.25706
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E461.29504
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E461.33301
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E461.66754
G1 X9.400 Y-9.400 E462.00207
G1 X9.400 Y9.400 E462.33660
G1 X-9.400 Y9.400 E462.67113
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E463.01990
G1 X9.800 Y-9.800 E463.36866
G1 X9.800 Y9.800 E463.71743
G1 X-9.800 Y9.800 E464.06619
;LAYER:48
G0 X-9.239 Y9.239 Z5.100
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E464.53119
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E464.56916
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E464.89180
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E465.07213
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E465.39477
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E465.57510
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E465.75543
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E466.07807
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E466.25840
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E466.58103
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E466.61901
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E467.08400
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E467.12198
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E467.15995
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E467.49448
G1 X9.400 Y-9.400 E467.82901
G1 X9.400 Y9.400 E468.16354
G1 X-9.400 Y9.400 E468.49807
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E468.84684
G1 X9.800 Y-9.800 E469.19560
G1 X9.800 Y9.800 E469.54437
G1 X-9.800 Y9.800 E469.89313
;LAYER:49
G0 X-9.239 Y9.239 Z5.200
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E470.35813
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E470.39610
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E470.71874
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E470.89907
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E471.22171
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E471.40204
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E471.58237
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E471.90501
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E472.08534
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E472.40797
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E472.44595
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E472.91094
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E472.94892
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E472.98689
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E473.32142
G1 X9.400 Y-9.400 E473.65595
G1 X9.400 Y9.400 E473.99048
G1 X-9.400 Y9.400 E474.32501
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E474.67378
G1 X9.800 Y-9.800 E475.02254
G1 X9.800 Y9.800 E475.37131
G1 X-9.800 Y9.800 E475.72007
;LAYER:50
G0 X-9.239 Y9.239 Z5.300
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E476.18507
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E476.22304
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E476.54568
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E476.72601
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E477.04865
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E477.22898
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E477.40931
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E477.73195
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E477.91228
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E478.23492
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E478.27289
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E478.73788
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E478.77586
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E478.81383
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E479.14836
G1 X9.400 Y-9.400 E479.48289
G1 X9.400 Y9.400 E479.81742
G1 X-9.400 Y9.400 E480.15195
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E480.50072
G1 X9.800 Y-9.800 E480.84948
G1 X9.800 Y9.800 E481.19825
G1 X-9.800 Y9.800 E481.54702
;LAYER:51
G0 X-9.239 Y9.239 Z5.400
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E482.01201
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E482.04998
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E482.37262
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E482.55295
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E482.87559
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E483.05592
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E483.23625
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E483.55889
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E483.73922
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E484.06186
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E484.09983
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E484.56482
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E484.60280
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E484.64077
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E484.97530
G1 X9.400 Y-9.400 E485.30983
G1 X9.400 Y9.400 E485.64436
G1 X-9.400 Y9.400 E485.97889
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E486.32766
G1 X9.800 Y-9.800 E486.67642
G1 X9.800 Y9.800 E487.02519
G1 X-9.800 Y9.800 E487.37396
;LAYER:52
G0 X-9.239 Y9.239 Z5.500
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E487.83895
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E487.87692
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E488.19956
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E488.37989
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E488.70253
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E488.88286
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E489.06319
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E489.38583
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E489.56616
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E489.88880
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E489.92677
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E490.39176
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E490.42974
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E490.46771
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E490.80224
G1 X9.400 Y-9.400 E491.13677
G1 X9.400 Y9.400 E491.47130
G1 X-9.400 Y9.400 E491.80583
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E492.15460
G1 X9.800 Y-9.800 E492.50336
G1 X9.800 Y9.800 E492.85213
G1 X-9.800 Y9.800 E493.20090
;LAYER:53
G0 X-9.239 Y9.239 Z5.600
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E493.66589
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E493.70386
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E494.02650
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E494.20683
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E494.52947
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E494.70980
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E494.89013
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E495.21277
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E495.39310
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E495.71574
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E495.75371
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E496.21870
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E496.25668
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E496.29465
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E496.62918
G1 X9.400 Y-9.400 E496.96371
G1 X9.400 Y9.400 E497.29824
G1 X-9.400 Y9.400 E497.63277
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E497.98154
G1 X9.800 Y-9.800 E498.33031
G1 X9.800 Y9.800 E498.67907
G1 X-9.800 Y9.800 E499.02784
;LAYER:54
G0 X-9.239 Y9.239 Z5.700
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E499.49283
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E499.53080
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E499.85344
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E500.03377
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E500.35641
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E500.53674
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E500.71707
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E501.03971
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E501.22004
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E501.54268
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E501.58065
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E502.04564
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E502.08362
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E502.12159
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E502.45612
G1 X9.400 Y-9.400 E502.79065
G1 X9.400 Y9.400 E503.12518
G1 X-9.400 Y9.400 E503.45971
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E503.80848
G1 X9.800 Y-9.800 E504.15725
G1 X9.800 Y9.800 E504.50601
G1 X-9.800 Y9.800 E504.85478
;LAYER:55
G0 X-9.239 Y9.239 Z5.800
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E505.31977
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E505.35775
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E505.68038
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E505.86071
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E506.18335
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E506.36368
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E506.54401
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E506.86665
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E507.04698
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E507.36962
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E507.40759
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E507.87259
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E507.91056
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E507.94853
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E508.28306
G1 X9.400 Y-9.400 E508.61759
G1 X9.400 Y9.400 E508.95212
G1 X-9.400 Y9.400 E509.28665
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E509.63542
G1 X9.800 Y-9.800 E509.98419
G1 X9.800 Y9.800 E510.33295
G1 X-9.800 Y9.800 E510.68172
;LAYER:56
G0 X-9.239 Y9.239 Z5.900
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E511.14671
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E511.18469
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E511.50732
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E511.68765
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E512.01029
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E512.19062
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E512.37095
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E512.69359
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E512.87392
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E513.19656
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E513.23453
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E513.69953
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E513.73750
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E513.77547
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E514.11000
G1 X9.400 Y-9.400 E514.44453
G1 X9.400 Y9.400 E514.77906
G1 X-9.400 Y9.400 E515.11359
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E515.46236
G1 X9.800 Y-9.800 E515.81113
G1 X9.800 Y9.800 E516.15989
G1 X-9.800 Y9.800 E516.50866
;LAYER:57
G0 X-9.239 Y9.239 Z6.000
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E516.97365
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E517.01163
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E517.33426
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E517.51459
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E517.83723
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E518.01756
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E518.19789
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E518.52053
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E518.70086
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E519.02350
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E519.06147
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E519.52647
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E519.56444
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E519.60241
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E519.93694
G1 X9.400 Y-9.400 E520.27147
G1 X9.400 Y9.400 E520.60600
G1 X-9.400 Y9.400 E520.94054
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E521.28930
G1 X9.800 Y-9.800 E521.63807
G1 X9.800 Y9.800 E521.98683
G1 X-9.800 Y9.800 E522.33560
;LAYER:58
G0 X-9.239 Y9.239 Z6.100
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E522.80059
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E522.83857
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E523.16120
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E523.34153
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E523.66417
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E523.84450
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E524.02483
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E524.34747
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E524.52780
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E524.85044
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E524.88841
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E525.35341
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E525.39138
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E525.42935
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E525.76388
G1 X9.400 Y-9.400 E526.09841
G1 X9.400 Y9.400 E526.43295
G1 X-9.400 Y9.400 E526.76748
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E527.11624
G1 X9.800 Y-9.800 E527.46501
G1 X9.800 Y9.800 E527.81377
G1 X-9.800 Y9.800 E528.16254
;LAYER:59
G0 X-9.239 Y9.239 Z6.200
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E528.62753
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E528.66551
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E528.98814
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E529.16847
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E529.49111
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E529.67144
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E529.85177
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E530.17441
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E530.35474
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E530.67738
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E530.71535
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E531.18035
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E531.21832
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E531.25629
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E531.59082
G1 X9.400 Y-9.400 E531.92536
G1 X9.400 Y9.400 E532.25989
G1 X-9.400 Y9.400 E532.59442
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E532.94318
G1 X9.800 Y-9.800 E533.29195
G1 X9.800 Y9.800 E533.64071
G1 X-9.800 Y9.800 E533.98948
;LAYER:60
G0 X-9.239 Y9.239 Z6.300
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E534.45447
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E534.49245
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E534.81508
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E534.99542
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E535.31805
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E535.49838
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E535.67871
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E536.00135
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E536.18168
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E536.50432
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E536.54229
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E537.00729
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E537.04526
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E537.08323
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E537.41777
G1 X9.400 Y-9.400 E537.75230
G1 X9.400 Y9.400 E538.08683
G1 X-9.400 Y9.400 E538.42136
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E538.77012
G1 X9.800 Y-9.800 E539.11889
G1 X9.800 Y9.800 E539.46765
G1 X-9.800 Y9.800 E539.81642
;LAYER:61
G0 X-9.239 Y9.239 Z6.400
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E540.28141
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E540.31939
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E540.64202
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E540.82236
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E541.14499
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E541.32532
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E541.50565
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E541.82829
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E542.00862
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E542.33126
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E542.36923
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E542.83423
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E542.87220
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E542.91018
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E543.24471
G1 X9.400 Y-9.400 E543.57924
G1 X9.400 Y9.400 E543.91377
G1 X-9.400 Y9.400 E544.24830
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E544.59706
G1 X9.800 Y-9.800 E544.94583
G1 X9.800 Y9.800 E545.29459
G1 X-9.800 Y9.800 E545.64336
;LAYER:62
G0 X-9.239 Y9.239 Z6.500
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E546.10835
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E546.14633
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E546.46897
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E546.64930
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E546.97193
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E547.15226
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E547.33259
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E547.65523
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E547.83556
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E548.15820
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E548.19617
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E548.66117
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E548.69914
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E548.73712
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E549.07165
G1 X9.400 Y-9.400 E549.40618
G1 X9.400 Y9.400 E549.74071
G1 X-9.400 Y9.400 E550.07524
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E550.42400
G1 X9.800 Y-9.800 E550.77277
G1 X9.800 Y9.800 E551.12153
G1 X-9.800 Y9.800 E551.47030
;LAYER:63
G0 X-9.239 Y9.239 Z6.600
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E551.93529
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E551.97327
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E552.29591
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E552.47624
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E552.79887
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E552.97920
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E553.15954
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E553.48217
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E553.66250
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E553.98514
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E554.02311
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E554.48811
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E554.52608
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E554.56406
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E554.89859
G1 X9.400 Y-9.400 E555.23312
G1 X9.400 Y9.400 E555.56765
G1 X-9.400 Y9.400 E555.90218
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E556.25094
G1 X9.800 Y-9.800 E556.59971
G1 X9.800 Y9.800 E556.94847
G1 X-9.800 Y9.800 E557.29724
;LAYER:64
G0 X-9.239 Y9.239 Z6.700
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E557.76224
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E557.80021
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E558.12285
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E558.30318
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E558.62581
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E558.80614
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E558.98648
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E559.30911
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E559.48944
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E559.81208
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E559.85005
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E560.31505
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E560.35302
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E560.39100
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E560.72553
G1 X9.400 Y-9.400 E561.06006
G1 X9.400 Y9.400 E561.39459
G1 X-9.400 Y9.400 E561.72912
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E562.07788
G1 X9.800 Y-9.800 E562.42665
G1 X9.800 Y9.800 E562.77542
G1 X-9.800 Y9.800 E563.12418
;LAYER:65
G0 X-9.239 Y9.239 Z6.800
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E563.58918
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E563.62715
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E563.94979
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E564.13012
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E564.45275
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E564.63309
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E564.81342
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E565.13605
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E565.31638
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E565.63902
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E565.67700
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E566.14199
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E566.17996
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E566.21794
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E566.55247
G1 X9.400 Y-9.400 E566.88700
G1 X9.400 Y9.400 E567.22153
G1 X-9.400 Y9.400 E567.55606
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E567.90482
G1 X9.800 Y-9.800 E568.25359
G1 X9.800 Y9.800 E568.60236
G1 X-9.800 Y9.800 E568.95112
;LAYER:66
G0 X-9.239 Y9.239 Z6.900
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E569.41612
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E569.45409
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E569.77673
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E569.95706
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E570.27970
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E570.46003
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E570.64036
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E570.96299
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E571.14332
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E571.46596
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E571.50394
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E571.96893
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E572.00690
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E572.04488
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E572.37941
G1 X9.400 Y-9.400 E572.71394
G1 X9.400 Y9.400 E573.04847
G1 X-9.400 Y9.400 E573.38300
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E573.73176
G1 X9.800 Y-9.800 E574.08053
G1 X9.800 Y9.800 E574.42930
G1 X-9.800 Y9.800 E574.77806
;LAYER:67
G0 X-9.239 Y9.239 Z7.000
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E575.24306
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E575.28103
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E575.60367
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E575.78400
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E576.10664
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E576.28697
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E576.46730
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E576.78993
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E576.97026
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E577.29290
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E577.33088
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E577.79587
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E577.83384
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E577.87182
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E578.20635
G1 X9.400 Y-9.400 E578.54088
G1 X9.400 Y9.400 E578.87541
G1 X-9.400 Y9.400 E579.20994
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E579.55871
G1 X9.800 Y-9.800 E579.90747
G1 X9.800 Y9.800 E580.25624
G1 X-9.800 Y9.800 E580.60500
;LAYER:68
G0 X-9.239 Y9.239 Z7.100
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E581.07000
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E581.10797
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E581.43061
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E581.61094
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E581.93358
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E582.11391
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E582.29424
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E582.61687
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E582.79721
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E583.11984
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E583.15782
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E583.62281
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E583.66078
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E583.69876
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E584.03329
G1 X9.400 Y-9.400 E584.36782
G1 X9.400 Y9.400 E584.70235
G1 X-9.400 Y9.400 E585.03688
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E585.38565
G1 X9.800 Y-9.800 E585.73441
G1 X9.800 Y9.800 E586.08318
G1 X-9.800 Y9.800 E586.43194
;LAYER:69
G0 X-9.239 Y9.239 Z7.200
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E586.89694
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E586.93491
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E587.25755
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E587.43788
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E587.76052
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E587.94085
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E588.12118
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E588.44382
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E588.62415
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E588.94678
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E588.98476
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E589.44975
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E589.48772
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E589.52570
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E589.86023
G1 X9.400 Y-9.400 E590.19476
G1 X9.400 Y9.400 E590.52929
G1 X-9.400 Y9.400 E590.86382
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E591.21259
G1 X9.800 Y-9.800 E591.56135
G1 X9.800 Y9.800 E591.91012
G1 X-9.800 Y9.800 E592.25888
;LAYER:70
G0 X-9.239 Y9.239 Z7.300
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E592.72388
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E592.76185
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E593.08449
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E593.26482
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E593.58746
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E593.76779
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E593.94812
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E594.27076
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E594.45109
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E594.77372
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E594.81170
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E595.27669
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E595.31467
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E595.35264
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E595.68717
G1 X9.400 Y-9.400 E596.02170
G1 X9.400 Y9.400 E596.35623
G1 X-9.400 Y9.400 E596.69076
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E597.03953
G1 X9.800 Y-9.800 E597.38829
G1 X9.800 Y9.800 E597.73706
G1 X-9.800 Y9.800 E598.08582
;LAYER:71
G0 X-9.239 Y9.239 Z7.400
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E598.55082
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E598.58879
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E598.91143
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E599.09176
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E599.41440
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E599.59473
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E599.77506
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E600.09770
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E600.27803
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E600.60066
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E600.63864
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E601.10363
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E601.14161
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E601.17958
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E601.51411
G1 X9.400 Y-9.400 E601.84864
G1 X9.400 Y9.400 E602.18317
G1 X-9.400 Y9.400 E602.51770
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E602.86647
G1 X9.800 Y-9.800 E603.21523
G1 X9.800 Y9.800 E603.56400
G1 X-9.800 Y9.800 E603.91276
;LAYER:72
G0 X-9.239 Y9.239 Z7.500
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E604.37776
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E604.41573
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E604.73837
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E604.91870
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E605.24134
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E605.42167
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E605.60200
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E605.92464
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E606.10497
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E606.42760
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E606.46558
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E606.93057
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E606.96855
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E607.00652
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E607.34105
G1 X9.400 Y-9.400 E607.67558
G1 X9.400 Y9.400 E608.01011
G1 X-9.400 Y9.400 E608.34464
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E608.69341
G1 X9.800 Y-9.800 E609.04217
G1 X9.800 Y9.800 E609.39094
G1 X-9.800 Y9.800 E609.73970
;LAYER:73
G0 X-9.239 Y9.239 Z7.600
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E610.20470
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E610.24267
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E610.56531
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E610.74564
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E611.06828
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E611.24861
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E611.42894
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E611.75158
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E611.93191
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E612.25454
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E612.29252
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E612.75751
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E612.79549
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E612.83346
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E613.16799
G1 X9.400 Y-9.400 E613.50252
G1 X9.400 Y9.400 E613.83705
G1 X-9.400 Y9.400 E614.17158
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E614.52035
G1 X9.800 Y-9.800 E614.86911
G1 X9.800 Y9.800 E615.21788
G1 X-9.800 Y9.800 E615.56664
;LAYER:74
G0 X-9.239 Y9.239 Z7.700
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E616.03164
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E616.06961
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E616.39225
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E616.57258
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E616.89522
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E617.07555
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E617.25588
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E617.57852
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E617.75885
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E618.08149
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E618.11946
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E618.58445
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E618.62243
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E618.66040
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E618.99493
G1 X9.400 Y-9.400 E619.32946
G1 X9.400 Y9.400 E619.66399
G1 X-9.400 Y9.400 E619.99852
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E620.34729
G1 X9.800 Y-9.800 E620.69605
G1 X9.800 Y9.800 E621.04482
G1 X-9.800 Y9.800 E621.39359
;LAYER:75
G0 X-9.239 Y9.239 Z7.800
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E621.85858
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E621.89655
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E622.21919
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E622.39952
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E622.72216
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E622.90249
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E623.08282
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E623.40546
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E623.58579
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E623.90843
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E623.94640
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E624.41139
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E624.44937
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E624.48734
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E624.82187
G1 X9.400 Y-9.400 E625.15640
G1 X9.400 Y9.400 E625.49093
G1 X-9.400 Y9.400 E625.82546
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E626.17423
G1 X9.800 Y-9.800 E626.52299
G1 X9.800 Y9.800 E626.87176
G1 X-9.800 Y9.800 E627.22053
;LAYER:76
G0 X-9.239 Y9.239 Z7.900
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E627.68552
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E627.72349
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E628.04613
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E628.22646
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E628.54910
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E628.72943
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E628.90976
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E629.23240
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E629.41273
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E629.73537
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E629.77334
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E630.23833
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E630.27631
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E630.31428
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E630.64881
G1 X9.400 Y-9.400 E630.98334
G1 X9.400 Y9.400 E631.31787
G1 X-9.400 Y9.400 E631.65240
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E632.00117
G1 X9.800 Y-9.800 E632.34993
G1 X9.800 Y9.800 E632.69870
G1 X-9.800 Y9.800 E633.04747
;LAYER:77
G0 X-9.239 Y9.239 Z8.000
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E633.51246
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E633.55043
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E633.87307
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E634.05340
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E634.37604
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E634.55637
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E634.73670
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E635.05934
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E635.23967
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E635.56231
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E635.60028
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E636.06527
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E636.10325
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E636.14122
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E636.47575
G1 X9.400 Y-9.400 E636.81028
G1 X9.400 Y9.400 E637.14481
G1 X-9.400 Y9.400 E637.47934
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E637.82811
G1 X9.800 Y-9.800 E638.17688
G1 X9.800 Y9.800 E638.52564
G1 X-9.800 Y9.800 E638.87441
;LAYER:78
G0 X-9.239 Y9.239 Z8.100
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E639.33940
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E639.37737
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E639.70001
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E639.88034
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E640.20298
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E640.38331
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E640.56364
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E640.88628
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E641.06661
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E641.38925
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E641.42722
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E641.89221
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E641.93019
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E641.96816
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E642.30269
G1 X9.400 Y-9.400 E642.63722
G1 X9.400 Y9.400 E642.97175
G1 X-9.400 Y9.400 E643.30628
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E643.65505
G1 X9.800 Y-9.800 E644.00382
G1 X9.800 Y9.800 E644.35258
G1 X-9.800 Y9.800 E644.70135
;LAYER:79
G0 X-9.239 Y9.239 Z8.200
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E645.16634
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E645.20432
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E645.52695
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E645.70728
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E646.02992
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E646.21025
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E646.39058
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E646.71322
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E646.89355
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E647.21619
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E647.25416
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E647.71916
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E647.75713
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E647.79510
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E648.12963
G1 X9.400 Y-9.400 E648.46416
G1 X9.400 Y9.400 E648.79869
G1 X-9.400 Y9.400 E649.13322
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E649.48199
G1 X9.800 Y-9.800 E649.83076
G1 X9.800 Y9.800 E650.17952
G1 X-9.800 Y9.800 E650.52829
;LAYER:80
G0 X-9.239 Y9.239 Z8.300
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E650.99328
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E651.03126
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E651.35389
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E651.53422
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E651.85686
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E652.03719
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E652.21752
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E652.54016
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E652.72049
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E653.04313
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E653.08110
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E653.54610
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E653.58407
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E653.62204
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E653.95657
G1 X9.400 Y-9.400 E654.29110
G1 X9.400 Y9.400 E654.62563
G1 X-9.400 Y9.400 E654.96016
G0 F7200.00000 X-9.800 Y9.800
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E655.30893
G1 X9.800 Y-9.800 E655.65770
G1 X9.800 Y9.800 E656.00646
G1 X-9.800 Y9.800 E656.35523
;LAYER:81
G0 X-9.239 Y9.239 Z8.400
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E656.82022
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E656.85820
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E657.18083
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E657.36116
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E657.68380
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E657.86413
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E658.04446
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E658.36710
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E658.54743
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E658.87007
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E658.90804
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E659.37304
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E659.41101
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E659.44898
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E659.78351
G1 X9.400 Y-9.400 E660.11804
G1 X9.400 Y9.400 E660.45257
G1 X-9.400 Y9.400 E660.78711
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E661.13587
G1 X9.800 Y-9.800 E661.48464
G1 X9.800 Y9.800 E661.83340
G1 X-9.800 Y9.800 E662.18217
;LAYER:82
G0 X-9.239 Y9.239 Z8.500
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E662.64716
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E662.68514
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E663.00777
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E663.18810
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E663.51074
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E663.69107
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E663.87140
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E664.19404
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E664.37437
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E664.69701
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E664.73498
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E665.19998
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E665.23795
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E665.27592
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E665.61045
G1 X9.400 Y-9.400 E665.94498
G1 X9.400 Y9.400 E666.27952
G1 X-9.400 Y9.400 E666.61405
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E666.96281
G1 X9.800 Y-9.800 E667.31158
G1 X9.800 Y9.800 E667.66034
G1 X-9.800 Y9.800 E668.00911
;LAYER:83
G0 X-9.239 Y9.239 Z8.600
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E668.47410
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E668.51208
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E668.83471
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E669.01504
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E669.33768
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E669.51801
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E669.69834
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E670.02098
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E670.20131
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E670.52395
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E670.56192
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E671.02692
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E671.06489
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E671.10286
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E671.43739
G1 X9.400 Y-9.400 E671.77193
G1 X9.400 Y9.400 E672.10646
G1 X-9.400 Y9.400 E672.44099
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E672.78975
G1 X9.800 Y-9.800 E673.13852
G1 X9.800 Y9.800 E673.48728
G1 X-9.800 Y9.800 E673.83605
;LAYER:84
G0 X-9.239 Y9.239 Z8.700
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E674.30104
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E674.33902
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E674.66165
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E674.84199
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E675.16462
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E675.34495
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E675.52528
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E675.84792
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E676.02825
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E676.35089
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E676.38886
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E676.85386
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E676.89183
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E676.92980
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E677.26434
G1 X9.400 Y-9.400 E677.59887
G1 X9.400 Y9.400 E677.93340
G1 X-9.400 Y9.400 E678.26793
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E678.61669
G1 X9.800 Y-9.800 E678.96546
G1 X9.800 Y9.800 E679.31422
G1 X-9.800 Y9.800 E679.66299
;LAYER:85
G0 X-9.239 Y9.239 Z8.800
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E680.12798
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E680.16596
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E680.48859
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E680.66893
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E680.99156
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E681.17189
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E681.35222
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E681.67486
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E681.85519
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E682.17783
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E682.21580
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E682.68080
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E682.71877
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E682.75675
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E683.09128
G1 X9.400 Y-9.400 E683.42581
G1 X9.400 Y9.400 E683.76034
G1 X-9.400 Y9.400 E684.09487
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E684.44363
G1 X9.800 Y-9.800 E684.79240
G1 X9.800 Y9.800 E685.14116
G1 X-9.800 Y9.800 E685.48993
;LAYER:86
G0 X-9.239 Y9.239 Z8.900
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E685.95492
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E685.99290
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E686.31554
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E686.49587
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E686.81850
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E686.99883
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E687.17916
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E687.50180
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E687.68213
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E688.00477
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E688.04274
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E688.50774
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E688.54571
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E688.58369
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E688.91822
G1 X9.400 Y-9.400 E689.25275
G1 X9.400 Y9.400 E689.58728
G1 X-9.400 Y9.400 E689.92181
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E690.27057
G1 X9.800 Y-9.800 E690.61934
G1 X9.800 Y9.800 E690.96810
G1 X-9.800 Y9.800 E691.31687
;LAYER:87
G0 X-9.239 Y9.239 Z9.000
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E691.78186
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E691.81984
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E692.14248
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E692.32281
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E692.64544
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E692.82577
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E693.00611
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E693.32874
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E693.50907
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E693.83171
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E693.86968
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E694.33468
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E694.37265
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E694.41063
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E694.74516
G1 X9.400 Y-9.400 E695.07969
G1 X9.400 Y9.400 E695.41422
G1 X-9.400 Y9.400 E695.74875
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E696.09751
G1 X9.800 Y-9.800 E696.44628
G1 X9.800 Y9.800 E696.79505
G1 X-9.800 Y9.800 E697.14381
;LAYER:88
G0 X-9.239 Y9.239 Z9.100
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E697.60881
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E697.64678
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E697.96942
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E698.14975
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E698.47238
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E698.65271
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E698.83305
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E699.15568
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E699.33601
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E699.65865
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E699.69662
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E700.16162
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E700.19959
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E700.23757
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E700.57210
G1 X9.400 Y-9.400 E700.90663
G1 X9.400 Y9.400 E701.24116
G1 X-9.400 Y9.400 E701.57569
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E701.92445
G1 X9.800 Y-9.800 E702.27322
G1 X9.800 Y9.800 E702.62199
G1 X-9.800 Y9.800 E702.97075
;LAYER:89
G0 X-9.239 Y9.239 Z9.200
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E703.43575
G0 X9.309 Y-9.309
G0 F7200.000 X9.300 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E703.47372
G0 X9.309 Y-7.660
G0 F7200.000 X9.300 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E703.79636
G0 X-3.652 Y9.309
G0 F7200.000 X-3.652 Y9.300
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E703.97669
G0 X-9.309 Y2.003
G0 F7200.000 X-9.300 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E704.29932
G0 X3.652 Y-9.309
G0 F7200.000 X3.652 Y-9.300
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E704.47966
G0 X9.309 Y-2.003
G0 F7200.000 X9.300 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E704.65999
G0 X2.003 Y9.309
G0 F7200.000 X2.003 Y9.300
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E704.98262
G0 X-9.309 Y-3.652
G0 F7200.000 X-9.300 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E705.16295
G0 X-2.003 Y-9.309
G0 F7200.000 X-2.003 Y-9.300
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E705.48559
G0 X9.309 Y3.652
G0 F7200.000 X9.300 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E705.52357
G0 X7.660 Y9.309
G0 F7200.000 X7.660 Y9.300
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E705.98856
G0 X-9.309 Y-9.309
G0 F7200.000 X-9.300 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E706.02653
G0 X-7.660 Y-9.309
G0 F7200.000 X-7.660 Y-9.300
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E706.06451
G0 X-7.660 Y9.309
G0 F7200.000 X-7.660 Y9.300
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E706.39904
G1 X9.400 Y-9.400 E706.73357
G1 X9.400 Y9.400 E707.06810
G1 X-9.400 Y9.400 E707.40263
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E707.75139
G1 X9.800 Y-9.800 E708.10016
G1 X9.800 Y9.800 E708.44893
G1 X-9.800 Y9.800 E708.79769
G0 F7200.00000 X-9.118 Y9.000
;LAYER:90
G0 X-9.239 Y9.239 Z9.300
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E709.26269
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E709.30066
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E709.62330
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E709.80363
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E710.12627
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E710.30660
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E710.48693
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E710.80956
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E710.98989
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E711.31253
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E711.35051
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E711.81550
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E711.85347
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E711.89145
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E712.22598
G1 X9.400 Y-9.400 E712.56051
G1 X9.400 Y9.400 E712.89504
G1 X-9.400 Y9.400 E713.22957
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E713.57833
G1 X9.800 Y-9.800 E713.92710
G1 X9.800 Y9.800 E714.27587
G1 X-9.800 Y9.800 E714.62463
;LAYER:91
G0 X-9.239 Y9.239 Z9.400
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E715.08963
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E715.12760
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E715.45024
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E715.63057
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E715.95321
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E716.13354
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E716.31387
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E716.63650
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E716.81683
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E717.13947
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E717.17745
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E717.64244
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E717.68041
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E717.71839
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E718.05292
G1 X9.400 Y-9.400 E718.38745
G1 X9.400 Y9.400 E718.72198
G1 X-9.400 Y9.400 E719.05651
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E719.40528
G1 X9.800 Y-9.800 E719.75404
G1 X9.800 Y9.800 E720.10281
G1 X-9.800 Y9.800 E720.45157
;LAYER:92
G0 X-9.239 Y9.239 Z9.500
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E720.91657
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E720.95454
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E721.27718
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E721.45751
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E721.78015
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E721.96048
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E722.14081
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E722.46344
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E722.64378
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E722.96641
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E723.00439
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E723.46938
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E723.50735
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E723.54533
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E723.87986
G1 X9.400 Y-9.400 E724.21439
G1 X9.400 Y9.400 E724.54892
G1 X-9.400 Y9.400 E724.88345
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E725.23222
G1 X9.800 Y-9.800 E725.58098
G1 X9.800 Y9.800 E725.92975
G1 X-9.800 Y9.800 E726.27851
;LAYER:93
G0 X-9.239 Y9.239 Z9.600
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E726.74351
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E726.78148
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E727.10412
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E727.28445
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E727.60709
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E727.78742
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E727.96775
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E728.29039
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E728.47072
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E728.79335
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E728.83133
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E729.29632
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E729.33429
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E729.37227
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E729.70680
G1 X9.400 Y-9.400 E730.04133
G1 X9.400 Y9.400 E730.37586
G1 X-9.400 Y9.400 E730.71039
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E731.05916
G1 X9.800 Y-9.800 E731.40792
G1 X9.800 Y9.800 E731.75669
G1 X-9.800 Y9.800 E732.10545
;LAYER:94
G0 X-9.239 Y9.239 Z9.700
;TYPE:FILL
G1 F4800.000 X9.239 Y-9.239 E732.57045
G0 X9.309 Y-9.309
G0 X7.730 Y-9.239
G1 F4800.000 X9.239 Y-7.730 E732.60842
G0 X9.309 Y-7.660
G0 X9.239 Y-3.582
G1 F4800.000 X-3.582 Y9.239 E732.93106
G0 X-3.652 Y9.309
G0 X-2.073 Y9.239
G1 F4800.000 X-9.239 Y2.073 E733.11139
G0 X-9.309 Y2.003
G0 X-9.239 Y3.582
G1 F4800.000 X3.582 Y-9.239 E733.43403
G0 X3.652 Y-9.309
G0 X2.073 Y-9.239
G1 F4800.000 X9.239 Y-2.073 E733.61436
G0 X9.309 Y-2.003
G0 X9.239 Y2.073
G1 F4800.000 X2.073 Y9.239 E733.79469
G0 X2.003 Y9.309
G0 X3.582 Y9.239
G1 F4800.000 X-9.239 Y-3.582 E734.11733
G0 X-9.309 Y-3.652
G0 X-9.239 Y-2.073
G1 F4800.000 X-2.073 Y-9.239 E734.29766
G0 X-2.003 Y-9.309
G0 X-3.582 Y-9.239
G1 F4800.000 X9.239 Y3.582 E734.62029
G0 X9.309 Y3.652
G0 X9.239 Y7.730
G1 F4800.000 X7.730 Y9.239 E734.65827
G0 X7.660 Y9.309
G0 X9.239 Y9.239
G1 F4800.000 X-9.239 Y-9.239 E735.12326
G0 X-9.309 Y-9.309
G0 X-9.239 Y-7.730
G1 F4800.000 X-7.730 Y-9.239 E735.16124
G0 X-7.660 Y-9.309
G0 X-9.239 Y7.730
G1 F4800.000 X-7.730 Y9.239 E735.19921
G0 X-7.660 Y9.309
G0 X-9.330 Y9.330
G0 X-9.400 Y9.400
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E735.53374
G1 X9.400 Y-9.400 E735.86827
G1 X9.400 Y9.400 E736.20280
G1 X-9.400 Y9.400 E736.53733
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E736.88610
G1 X9.800 Y-9.800 E737.23486
G1 X9.800 Y9.800 E737.58363
G1 X-9.800 Y9.800 E737.93239
;LAYER:95
G0 X-9.400 Y9.400 Z9.800
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E738.26692
G1 X9.400 Y-9.400 E738.60145
G1 X9.400 Y9.400 E738.93599
G1 X-9.400 Y9.400 E739.27052
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E739.61928
G1 X9.800 Y-9.800 E739.96805
G1 X9.800 Y9.800 E740.31681
G1 X-9.800 Y9.800 E740.66558
G0 F7200.00000 X-9.239 Y9.239
;TYPE:SKIN
G1 F900.000 X9.239 Y-9.239 E741.13057
G0 X9.309 Y-9.309
G0 F7200.000 X8.674 Y-9.239
G1 F900.000 X-9.239 Y8.674 E741.58135
G0 X-9.309 Y8.744
G0 F7200.000 X-9.239 Y8.108
G1 F900.000 X8.108 Y-9.239 E742.01788
G0 X8.178 Y-9.309
G0 F7200.000 X7.542 Y-9.239
G1 F900.000 X-9.239 Y7.542 E742.44017
G0 X-9.309 Y7.612
G0 F7200.000 X-9.239 Y6.977
G1 F900.000 X6.977 Y-9.239 E742.84824
G0 X7.047 Y-9.309
G0 F7200.000 X6.411 Y-9.239
G1 F900.000 X-9.239 Y6.411 E743.24207
G0 X-9.309 Y6.481
G0 F7200.000 X-9.239 Y5.845
G1 F900.000 X5.845 Y-9.239 E743.62166
G0 X5.915 Y-9.309
G0 F7200.000 X5.279 Y-9.239
G1 F900.000 X-9.239 Y5.279 E743.98700
G0 X-9.309 Y5.349
G0 F7200.000 X-9.239 Y4.714
G1 F900.000 X4.714 Y-9.239 E744.33812
G0 X4.784 Y-9.309
G0 F7200.000 X4.148 Y-9.239
G1 F900.000 X-9.239 Y4.148 E744.67500
G0 X-9.309 Y4.218
G0 F7200.000 X-9.239 Y3.582
G1 F900.000 X3.582 Y-9.239 E744.99764
G0 X3.652 Y-9.309
G0 F7200.000 X3.017 Y-9.239
G1 F900.000 X-9.239 Y3.017 E745.30606
G0 X-9.309 Y3.087
G0 F7200.000 X-9.239 Y2.451
G1 F900.000 X2.451 Y-9.239 E745.60024
G0 X2.521 Y-9.309
G0 F7200.000 X1.885 Y-9.239
G1 F900.000 X-9.239 Y1.885 E745.88017
G0 X-9.309 Y1.955
G0 F7200.000 X-9.239 Y1.320
G1 F900.000 X1.320 Y-9.239 E746.14588
G0 X1.390 Y-9.309
G0 F7200.000 X0.754 Y-9.239
G1 F900.000 X-9.239 Y0.754 E746.39736
G0 X-9.309 Y0.824
G0 F7200.000 X-9.239 Y0.188
G1 F900.000 X0.188 Y-9.239 E746.63458
G0 X0.258 Y-9.309
G0 F7200.000 X-0.376 Y-9.239
G1 F900.000 X-9.239 Y-0.376 E746.85762
G0 X-9.309 Y-0.306
G0 F7200.000 X-9.239 Y-0.942
G1 F900.000 X-0.942 Y-9.239 E747.06641
G0 X-0.872 Y-9.309
G0 F7200.000 X-1.508 Y-9.239
G1 F900.000 X-9.239 Y-1.508 E747.26096
G0 X-9.309 Y-1.438
G0 F7200.000 X-9.239 Y-2.073
G1 F900.000 X-2.073 Y-9.239 E747.44129
G0 X-2.003 Y-9.309
G0 F7200.000 X-2.639 Y-9.239
G1 F900.000 X-9.239 Y-2.639 E747.60738
G0 X-9.309 Y-2.569
G0 F7200.000 X-9.239 Y-3.205
G1 F900.000 X-3.205 Y-9.239 E747.75922
G0 X-3.135 Y-9.309
G0 F7200.000 X-3.771 Y-9.239
G1 F900.000 X-9.239 Y-3.771 E747.89682
G0 X-9.309 Y-3.701
G0 F7200.000 X-9.239 Y-4.336
G1 F900.000 X-4.336 Y-9.239 E748.02021
G0 X-4.266 Y-9.309
G0 F7200.000 X-4.902 Y-9.239
G1 F900.000 X-9.239 Y-4.902 E748.12935
G0 X-9.309 Y-4.832
G0 F7200.000 X-9.239 Y-5.468
G1 F900.000 X-5.468 Y-9.239 E748.22424
G0 X-5.398 Y-9.309
G0 F7200.000 X-6.033 Y-9.239
G1 F900.000 X-9.239 Y-6.033 E748.30492
G0 X-9.309 Y-5.963
G0 F7200.000 X-9.239 Y-6.599
G1 F900.000 X-6.599 Y-9.239 E748.37136
G0 X-6.529 Y-9.309
G0 F7200.000 X-7.165 Y-9.239
G1 F900.000 X-9.239 Y-7.165 E748.42355
G0 X-9.309 Y-7.095
G0 F7200.000 X-9.239 Y-7.730
G1 F900.000 X-7.730 Y-9.239 E748.46152
G0 X-7.660 Y-9.309
G0 F7200.000 X-8.296 Y-9.239
G1 F900.000 X-9.239 Y-8.296 E748.48525
G0 X-9.309 Y-8.226
G0 F7200.000 X-9.239 Y-8.862
G1 F900.000 X-8.862 Y-9.239 E748.49474
G0 F7200.00000 X9.239 Y-8.674
G1 F900.000 X-8.674 Y9.239 E748.94551
G0 X-8.744 Y9.309
G0 F7200.000 X-8.108 Y9.239
G1 F900.000 X9.239 Y-8.108 E749.38205
G0 X9.309 Y-8.178
G0 F7200.000 X9.239 Y-7.542
G1 F900.000 X-7.542 Y9.239 E749.80434
G0 X-7.612 Y9.309
G0 F7200.000 X-6.977 Y9.239
G1 F900.000 X9.239 Y-6.977 E750.21241
G0 X9.309 Y-7.047
G0 F7200.000 X9.239 Y-6.411
G1 F900.000 X-6.411 Y9.239 E750.60624
G0 X-6.481 Y9.309
G0 F7200.000 X-5.845 Y9.239
G1 F900.000 X9.239 Y-5.845 E750.98582
G0 X9.309 Y-5.915
G0 F7200.000 X9.239 Y-5.279
G1 F900.000 X-5.279 Y9.239 E751.35116
G0 X-5.349 Y9.309
G0 F7200.000 X-4.714 Y9.239
G1 F900.000 X9.239 Y-4.714 E751.70229
G0 X9.309 Y-4.784
G0 F7200.000 X9.239 Y-4.148
G1 F900.000 X-4.148 Y9.239 E752.03917
G0 X-4.218 Y9.309
G0 F7200.000 X-3.582 Y9.239
G1 F900.000 X9.239 Y-3.582 E752.36181
G0 X9.309 Y-3.652
G0 F7200.000 X9.239 Y-3.017
G1 F900.000 X-3.017 Y9.239 E752.67023
G0 X-3.087 Y9.309
G0 F7200.000 X-2.451 Y9.239
G1 F900.000 X9.239 Y-2.451 E752.96440
G0 X9.309 Y-2.521
G0 F7200.000 X9.239 Y-1.885
G1 F900.000 X-1.885 Y9.239 E753.24433
G0 X-1.955 Y9.309
G0 F7200.000 X-1.320 Y9.239
G1 F900.000 X9.239 Y-1.320 E753.51005
G0 X9.309 Y-1.390
G0 F7200.000 X9.239 Y-0.754
G1 F900.000 X-0.754 Y9.239 E753.76152
G0 X-0.824 Y9.309
G0 F7200.000 X-0.188 Y9.239
G1 F900.000 X9.239 Y-0.188 E753.99875
G0 X9.309 Y-0.258
G0 F7200.000 X9.239 Y0.376
G1 F900.000 X0.376 Y9.239 E754.22178
G0 X0.306 Y9.309
G0 F7200.000 X0.942 Y9.239
G1 F900.000 X9.239 Y0.942 E754.43058
G0 X9.309 Y0.872
G0 F7200.000 X9.239 Y1.508
G1 F900.000 X1.508 Y9.239 E754.62513
G0 X1.438 Y9.309
G0 F7200.000 X2.073 Y9.239
G1 F900.000 X9.239 Y2.073 E754.80546
G0 X9.309 Y2.003
G0 F7200.000 X9.239 Y2.639
G1 F900.000 X2.639 Y9.239 E754.97154
G0 X2.569 Y9.309
G0 F7200.000 X3.205 Y9.239
G1 F900.000 X9.239 Y3.205 E755.12339
G0 X9.309 Y3.135
G0 F7200.000 X9.239 Y3.771
G1 F900.000 X3.771 Y9.239 E755.26099
G0 X3.701 Y9.309
G0 F7200.000 X4.336 Y9.239
G1 F900.000 X9.239 Y4.336 E755.38437
G0 X9.309 Y4.266
G0 F7200.000 X9.239 Y4.902
G1 F900.000 X4.902 Y9.239 E755.49351
G0 X4.832 Y9.309
G0 F7200.000 X5.468 Y9.239
G1 F900.000 X9.239 Y5.468 E755.58841
G0 X9.309 Y5.398
G0 F7200.000 X9.239 Y6.033
G1 F900.000 X6.033 Y9.239 E755.66909
G0 X5.963 Y9.309
G0 F7200.000 X6.599 Y9.239
G1 F900.000 X9.239 Y6.599 E755.73552
G0 X9.309 Y6.529
G0 F7200.000 X9.239 Y7.165
G1 F900.000 X7.165 Y9.239 E755.78771
G0 X7.095 Y9.309
G0 F7200.000 X7.730 Y9.239
G1 F900.000 X9.239 Y7.730 E755.82569
G0 X9.309 Y7.660
G0 F7200.000 X9.239 Y8.296
G1 F900.000 X8.296 Y9.239 E755.84942
G0 X8.226 Y9.309
G0 F7200.000 X8.862 Y9.239
G1 F900.000 X9.239 Y8.862 E755.85890
G0 F7200.00000 X9.000 Y8.862
;LAYER:96
G0 X9.400 Y9.400 Z9.900
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y9.400 E756.19343
G1 X-9.400 Y-9.400 E756.52796
G1 X9.400 Y-9.400 E756.86249
G1 X9.400 Y9.400 E757.19702
G0 F7200.00000 X9.800 Y9.800
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y9.800 E757.54579
G1 X-9.800 Y-9.800 E757.89456
G1 X9.800 Y-9.800 E758.24332
G1 X9.800 Y9.800 E758.59209
G0 F7200.00000 X9.239 Y9.239
;TYPE:SKIN
G1 F900.000 X-9.239 Y-9.239 E759.05708
G0 X-9.309 Y-9.309
G0 F7200.000 X-8.674 Y-9.239
G1 F900.000 X9.239 Y8.674 E759.50786
G0 X9.309 Y8.744
G0 F7200.000 X9.239 Y8.108
G1 F900.000 X-8.108 Y-9.239 E759.94439
G0 X-8.178 Y-9.309
G0 F7200.000 X-7.542 Y-9.239
G1 F900.000 X9.239 Y7.542 E760.36668
G0 X9.309 Y7.612
G0 F7200.000 X9.239 Y6.977
G1 F900.000 X-6.977 Y-9.239 E760.77475
G0 X-7.047 Y-9.309
G0 F7200.000 X-6.411 Y-9.239
G1 F900.000 X9.239 Y6.411 E761.16858
G0 X9.309 Y6.481
G0 F7200.000 X9.239 Y5.845
G1 F900.000 X-5.845 Y-9.239 E761.54817
G0 X-5.915 Y-9.309
G0 F7200.000 X-5.279 Y-9.239
G1 F900.000 X9.239 Y5.279 E761.91351
G0 X9.309 Y5.349
G0 F7200.000 X9.239 Y4.714
G1 F900.000 X-4.714 Y-9.239 E762.26463
G0 X-4.784 Y-9.309
G0 F7200.000 X-4.148 Y-9.239
G1 F900.000 X9.239 Y4.148 E762.60151
G0 X9.309 Y4.218
G0 F7200.000 X9.239 Y3.582
G1 F900.000 X-3.582 Y-9.239 E762.92415
G0 X-3.652 Y-9.309
G0 F7200.000 X-3.017 Y-9.239
G1 F900.000 X9.239 Y3.017 E763.23257
G0 X9.309 Y3.087
G0 F7200.000 X9.239 Y2.451
G1 F900.000 X-2.451 Y-9.239 E763.52675
G0 X-2.521 Y-9.309
G0 F7200.000 X-1.885 Y-9.239
G1 F900.000 X9.239 Y1.885 E763.80668
G0 X9.309 Y1.955
G0 F7200.000 X9.239 Y1.320
G1 F900.000 X-1.320 Y-9.239 E764.07239
G0 X-1.390 Y-9.309
G0 F7200.000 X-0.754 Y-9.239
G1 F900.000 X9.239 Y0.754 E764.32387
G0 X9.309 Y0.824
G0 F7200.000 X9.239 Y0.188
G1 F900.000 X-0.188 Y-9.239 E764.56109
G0 X-0.258 Y-9.309
G0 F7200.000 X0.376 Y-9.239
G1 F900.000 X9.239 Y-0.376 E764.78413
G0 X9.309 Y-0.306
G0 F7200.000 X9.239 Y-0.942
G1 F900.000 X0.942 Y-9.239 E764.99292
G0 X0.872 Y-9.309
G0 F7200.000 X1.508 Y-9.239
G1 F900.000 X9.239 Y-1.508 E765.18747
G0 X9.309 Y-1.438
G0 F7200.000 X9.239 Y-2.073
G1 F900.000 X2.073 Y-9.239 E765.36780
G0 X2.003 Y-9.309
G0 F7200.000 X2.639 Y-9.239
G1 F900.000 X9.239 Y-2.639 E765.53389
G0 X9.309 Y-2.569
G0 F7200.000 X9.239 Y-3.205
G1 F900.000 X3.205 Y-9.239 E765.68573
G0 X3.135 Y-9.309
G0 F7200.000 X3.771 Y-9.239
G1 F900.000 X9.239 Y-3.771 E765.82333
G0 X9.309 Y-3.701
G0 F7200.000 X9.239 Y-4.336
G1 F900.000 X4.336 Y-9.239 E765.94672
G0 X4.266 Y-9.309
G0 F7200.000 X4.902 Y-9.239
G1 F900.000 X9.239 Y-4.902 E766.05585
G0 X9.309 Y-4.832
G0 F7200.000 X9.239 Y-5.468
G1 F900.000 X5.468 Y-9.239 E766.15075
G0 X5.398 Y-9.309
G0 F7200.000 X6.033 Y-9.239
G1 F900.000 X9.239 Y-6.033 E766.23143
G0 X9.309 Y-5.963
G0 F7200.000 X9.239 Y-6.599
G1 F900.000 X6.599 Y-9.239 E766.29786
G0 X6.529 Y-9.309
G0 F7200.000 X7.165 Y-9.239
G1 F900.000 X9.239 Y-7.165 E766.35006
G0 X9.309 Y-7.095
G0 F7200.000 X9.239 Y-7.730
G1 F900.000 X7.730 Y-9.239 E766.38803
G0 X7.660 Y-9.309
G0 F7200.000 X8.296 Y-9.239
G1 F900.000 X9.239 Y-8.296 E766.41176
G0 X9.309 Y-8.226
G0 F7200.000 X9.239 Y-8.862
G1 F900.000 X8.862 Y-9.239 E766.42125
G0 F7200.00000 X-9.239 Y-8.674
G1 F900.000 X8.674 Y9.239 E766.87202
G0 X8.744 Y9.309
G0 F7200.000 X8.108 Y9.239
G1 F900.000 X-9.239 Y-8.108 E767.30856
G0 X-9.309 Y-8.178
G0 F7200.000 X-9.239 Y-7.542
G1 F900.000 X7.542 Y9.239 E767.73085
G0 X7.612 Y9.309
G0 F7200.000 X6.977 Y9.239
G1 F900.000 X-9.239 Y-6.977 E768.13892
G0 X-9.309 Y-7.047
G0 F7200.000 X-9.239 Y-6.411
G1 F900.000 X6.411 Y9.239 E768.53275
G0 X6.481 Y9.309
G0 F7200.000 X5.845 Y9.239
G1 F900.000 X-9.239 Y-5.845 E768.91233
G0 X-9.309 Y-5.915
G0 F7200.000 X-9.239 Y-5.279
G1 F900.000 X5.279 Y9.239 E769.27767
G0 X5.349 Y9.309
G0 F7200.000 X4.714 Y9.239
G1 F900.000 X-9.239 Y-4.714 E769.62880
G0 X-9.309 Y-4.784
G0 F7200.000 X-9.239 Y-4.148
G1 F900.000 X4.148 Y9.239 E769.96568
G0 X4.218 Y9.309
G0 F7200.000 X3.582 Y9.239
G1 F900.000 X-9.239 Y-3.582 E770.28832
G0 X-9.309 Y-3.652
G0 F7200.000 X-9.239 Y-3.017
G1 F900.000 X3.017 Y9.239 E770.59674
G0 X3.087 Y9.309
G0 F7200.000 X2.451 Y9.239
G1 F900.000 X-9.239 Y-2.451 E770.89091
G0 X-9.309 Y-2.521
G0 F7200.000 X-9.239 Y-1.885
G1 F900.000 X1.885 Y9.239 E771.17084
G0 X1.955 Y9.309
G0 F7200.000 X1.320 Y9.239
G1 F900.000 X-9.239 Y-1.320 E771.43656
G0 X-9.309 Y-1.390
G0 F7200.000 X-9.239 Y-0.754
G1 F900.000 X0.754 Y9.239 E771.68803
G0 X0.824 Y9.309
G0 F7200.000 X0.188 Y9.239
G1 F900.000 X-9.239 Y-0.188 E771.92526
G0 X-9.309 Y-0.258
G0 F7200.000 X-9.239 Y0.376
G1 F900.000 X-0.376 Y9.239 E772.14829
G0 X-0.306 Y9.309
G0 F7200.000 X-0.942 Y9.239
G1 F900.000 X-9.239 Y0.942 E772.35709
G0 X-9.309 Y0.872
G0 F7200.000 X-9.239 Y1.508
G1 F900.000 X-1.508 Y9.239 E772.55163
G0 X-1.438 Y9.309
G0 F7200.000 X-2.073 Y9.239
G1 F900.000 X-9.239 Y2.073 E772.73196
G0 X-9.309 Y2.003
G0 F7200.000 X-9.239 Y2.639
G1 F900.000 X-2.639 Y9.239 E772.89805
G0 X-2.569 Y9.309
G0 F7200.000 X-3.205 Y9.239
G1 F900.000 X-9.239 Y3.205 E773.04990
G0 X-9.309 Y3.135
G0 F7200.000 X-9.239 Y3.771
G1 F900.000 X-3.771 Y9.239 E773.18750
G0 X-3.701 Y9.309
G0 F7200.000 X-4.336 Y9.239
G1 F900.000 X-9.239 Y4.336 E773.31088
G0 X-9.309 Y4.266
G0 F7200.000 X-9.239 Y4.902
G1 F900.000 X-4.902 Y9.239 E773.42002
G0 X-4.832 Y9.309
G0 F7200.000 X-5.468 Y9.239
G1 F900.000 X-9.239 Y5.468 E773.51492
G0 X-9.309 Y5.398
G0 F7200.000 X-9.239 Y6.033
G1 F900.000 X-6.033 Y9.239 E773.59559
G0 X-5.963 Y9.309
G0 F7200.000 X-6.599 Y9.239
G1 F900.000 X-9.239 Y6.599 E773.66203
G0 X-9.309 Y6.529
G0 F7200.000 X-9.239 Y7.165
G1 F900.000 X-7.165 Y9.239 E773.71422
G0 X-7.095 Y9.309
G0 F7200.000 X-7.730 Y9.239
G1 F900.000 X-9.239 Y7.730 E773.75219
G0 X-9.309 Y7.660
G0 F7200.000 X-9.239 Y8.296
G1 F900.000 X-8.296 Y9.239 E773.77592
G0 X-8.226 Y9.309
G0 F7200.000 X-8.862 Y9.239
G1 F900.000 X-9.239 Y8.862 E773.78541
G0 F7200.00000 X-9.000 Y8.862
;LAYER:97
G0 X-9.400 Y9.400 Z10.000
;TYPE:WALL-INNER
G1 F3600.000 X-9.400 Y-9.400 E774.11994
G1 X9.400 Y-9.400 E774.45447
G1 X9.400 Y9.400 E774.78900
G1 X-9.400 Y9.400 E775.12353
;TYPE:WALL-OUTER
G1 F1800.000 X-9.800 Y-9.800 E775.47230
G1 X9.800 Y-9.800 E775.82107
G1 X9.800 Y9.800 E776.16983
G1 X-9.800 Y9.800 E776.51860
;TYPE:SKIN
G1 F900.000 X9.239 Y-9.239 E776.98359
G0 X9.309 Y-9.309
G1 F900.000 X-9.239 Y8.674 E777.43437
G0 X-9.309 Y8.744
G1 F900.000 X8.108 Y-9.239 E777.87090
G0 X8.178 Y-9.309
G1 F900.000 X-9.239 Y7.542 E778.29319
G0 X-9.309 Y7.612
G1 F900.000 X6.977 Y-9.239 E778.70126
G0 X7.047 Y-9.309
G1 F900.000 X-9.239 Y6.411 E779.09509
G0 X-9.309 Y6.481
G1 F900.000 X5.845 Y-9.239 E779.47468
G0 X5.915 Y-9.309
G1 F900.000 X-9.239 Y5.279 E779.84002
G0 X-9.309 Y5.349
G1 F900.000 X4.714 Y-9.239 E780.19114
G0 X4.784 Y-9.309
G1 F900.000 X-9.239 Y4.148 E780.52802
G0 X-9.309 Y4.218
G1 F900.000 X3.582 Y-9.239 E780.85066
G0 X3.652 Y-9.309
G1 F900.000 X-9.239 Y3.017 E781.15908
G0 X-9.309 Y3.087
G1 F900.000 X2.451 Y-9.239 E781.45326
G0 X2.521 Y-9.309
G1 F900.000 X-9.239 Y1.885 E781.73319
G0 X-9.309 Y1.955
G1 F900.000 X1.320 Y-9.239 E781.99890
G0 X1.390 Y-9.309
G1 F900.000 X-9.239 Y0.754 E782.25037
G0 X-9.309 Y0.824
G1 F900.000 X0.188 Y-9.239 E782.48760
G0 X0.258 Y-9.309
G1 F900.000 X-9.239 Y-0.376 E782.71064
G0 X-9.309 Y-0.306
G1 F900.000 X-0.942 Y-9.239 E782.91943
G0 X-0.872 Y-9.309
G1 F900.000 X-9.239 Y-1.508 E783.11398
G0 X-9.309 Y-1.438
G1 F900.000 X-2.073 Y-9.239 E783.29431
G0 X-2.003 Y-9.309
G1 F900.000 X-9.239 Y-2.639 E783.46040
G0 X-9.309 Y-2.569
G1 F900.000 X-3.205 Y-9.239 E783.61224
G0 X-3.135 Y-9.309
G1 F900.000 X-9.239 Y-3.771 E783.74984
G0 X-9.309 Y-3.701
G1 F900.000 X-4.336 Y-9.239 E783.87322
G0 X-4.266 Y-9.309
G1 F900.000 X-9.239 Y-4.902 E783.98236
G0 X-9.309 Y-4.832
G1 F900.000 X-5.468 Y-9.239 E784.07726
G0 X-5.398 Y-9.309
G1 F900.000 X-9.239 Y-6.033 E784.15794
G0 X-9.309 Y-5.963
G1 F900.000 X-6.599 Y-9.239 E784.22437
G0 X-6.529 Y-9.309
G1 F900.000 X-9.239 Y-7.165 E784.27657
G0 X-9.309 Y-7.095
G1 F900.000 X-7.730 Y-9.239 E784.31454
G0 X-7.660 Y-9.309
G1 F900.000 X-9.239 Y-8.296 E784.33827
G0 X-9.309 Y-8.226
G1 F900.000 X-8.862 Y-9.239 E784.34776
G1 F900.000 X-8.674 Y9.239 E784.79853
G0 X-8.744 Y9.309
G1 F900.000 X9.239 Y-8.108 E785.23507
G0 X9.309 Y-8.178
G1 F900.000 X-7.542 Y9.239 E785.65736
G0 X-7.612 Y9.309
G1 F900.000 X9.239 Y-6.977 E786.06543
G0 X9.309 Y-7.047
G1 F900.000 X-6.411 Y9.239 E786.45926
G0 X-6.481 Y9.309
G1 F900.000 X9.239 Y-5.845 E786.83884
G0 X9.309 Y-5.915
G1 F900.000 X-5.279 Y9.239 E787.20418
G0 X-5.349 Y9.309
G1 F900.000 X9.239 Y-4.714 E787.55531
G0 X9.309 Y-4.784
G1 F900.000 X-4.148 Y9.239 E787.89219
G0 X-4.218 Y9.309
G1 F900.000 X9.239 Y-3.582 E788.21482
G0 X9.309 Y-3.652
G1 F900.000 X-3.017 Y9.239 E788.52324
G0 X-3.087 Y9.309
G1 F900.000 X9.239 Y-2.451 E788.81742
G0 X9.309 Y-2.521
G1 F900.000 X-1.885 Y9.239 E789.09735
G0 X-1.955 Y9.309
G1 F900.000 X9.239 Y-1.320 E789.36307
G0 X9.309 Y-1.390
G1 F900.000 X-0.754 Y9.239 E789.61454
G0 X-0.824 Y9.309
G1 F900.000 X9.239 Y-0.188 E789.85177
G0 X9.309 Y-0.258
G1 F900.000 X0.376 Y9.239 E790.07480
G0 X0.306 Y9.309
G1 F900.000 X9.239 Y0.942 E790.28359
G0 X9.309 Y0.872
G1 F900.000 X1.508 Y9.239 E790.47814
G0 X1.438 Y9.309
G1 F900.000 X9.239 Y2.073 E790.65847
G0 X9.309 Y2.003
G1 F900.000 X2.639 Y9.239 E790.82456
G0 X2.569 Y9.309
G1 F900.000 X9.239 Y3.205 E790.97641
G0 X9.309 Y3.135
G1 F900.000 X3.771 Y9.239 E791.11401
G0 X3.701 Y9.309
G1 F900.000 X9.239 Y4.336 E791.23739
G0 X9.309 Y4.266
G1 F900.000 X4.902 Y9.239 E791.34653
G0 X4.832 Y9.309
G1 F900.000 X9.239 Y5.468 E791.44143
G0 X9.309 Y5.398
G1 F900.000 X6.033 Y9.239 E791.52210
G0 X5.963 Y9.309
G1 F900.000 X9.239 Y6.599 E791.58854
G0 X9.309 Y6.529
G1 F900.000 X7.165 Y9.239 E791.64073
G0 X7.095 Y9.309
G1 F900.000 X9.239 Y7.730 E791.67870
G0 X9.309 Y7.660
G1 F900.000 X8.296 Y9.239 E791.70243
G0 X8.226 Y9.309
G1 F900.000 X9.239 Y8.862 E791.71192
;End GCode
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+10 E-5 F12000 ;move Z up a bit and retract filament even more
G90 ;absolute positioning
G28 ;move X/Y to min endstops, so the head is out of the way
;G1 Y230 F3000
M84 ;steppers off
;G90 ;absolute positioning
M104 S0.000
;End of Gcode
;SETTING_1 [general]\nversion = 1\nname = Current settings\nweight = 0\n\n[setti
;SETTING_1 ngs]\nmaterial_print_temperature = 250\nmaterial_flow = 107\nspeed_to
;SETTING_1 pbottom = 15\nlayer_height = 0.1\nmaterial_bed_temperature = 80\nspee
;SETTING_1 d_infill = 80\nretraction_amount = 6.5\n\n
Nylocke
Re: New version: 2.1.2
Post by Nylocke »
Good luck. I dont have time right now to work on my printer much, otherwise id be trying this out more.
lordbinky
Post by lordbinky »
Yep, the hidden variable was "machine_center_is_zero": { "default": true }, I still moved it to below the machine_heated_bed variable just because I'm OCD like that :lol:
Tincho85
Post by Tincho85 »
Awesome, keep up the good work!
I can't help with coding, but at least I can give you positive feedback :D
Thanks for working with the new release for us delta users.
Martín S.
greyghost
Post by greyghost »
Success!!!!!
Thank you guys for your help. I've completed several successful prints. I'll post pics later. There's still a lot of tweak as far as settings go. The Cura defaults seem to be set high for some things and low for others when compared to my Matter Control settings. The extrusion multiplier being one of those. Cura sets it to 107% in Matter Control mine is set to 100%. Once I get a good set of defaults I'll post them here. I love the brim printing option for ABS helps a ton with warping and comes off perfectly clean.
On another note, usb printing is very spotty. It will start and then just pause mid print. I have had no problem sd card printing which is great since that's my preferred way to print anyways.
PannDemic
Post by PannDemic »
Just getting started with Cura 2.1.3...
Any pearls of wisdom?
greyghost
Post by greyghost »
I haven't updated to 2.1.3 yet, but everything should work just like 2.1.2. I like Cura a lot. It is my go to slicer. There are a few things were MatterSlice slice works better but overall Cura is awesome. One thing I don't like is when I open a file it resizes it down to like 93% of the size. I have to go in and set it back to 100%. It may be a setting or issue with my stl but it's just a minor inconvenience.
I haven't seen that on OSX with 2.1.2 or .3. Od behavior!
greyghost
Post by greyghost »
I've been printing with 2.1.2 for the last couple months. Pretty much everything I did to get it working is documented above. I will probably update to 2.1.3 and can put together a guide with settings and such. I've found that sd card printing is the best way to go. I recently set up octopi so what I have been doing is slicing with Cura and then uploading it to the printer via octopi. There are a ton of great features and settings to tweak my prints have all come out really good. If anyone has any questions let me know.
bimmersix
Post by bimmersix »
I'm going to give your latest .json a shot as Cura looks like it has more settings that I'd like to try as incrementally improve my prints. Having such a long bowden setup makes me think the "coast" settings my be really helpful for stringing, coupled with proper retraction.
Really hope I can get Cura to work. mhackney and greyghost, I may have some questions for you. Appreciate the work you put into this! Mattercontrol is so unbelievably slow, and lacks some of the options, so I wanted to have any slicer/control software to try.
I've heard nothing but terrible things about Simplify3D support, so I am reluctant to pay $150 for something that doesn't seem much better than Cura. I think it's too bad that deltas are well supported in anything but Mattercontrol.
bimmersix
Post by bimmersix »
Everyone, I'm going to start a new thread with how I got Cura 2.3.1 to (mostly) work. greyghost's work was a big part of figuring something out.
greyghost
Post by greyghost »
Great to see the new thread. Look forward to the updated Cura version.
Return to “Cura”
