24V on the Azteeg X3 Pro?
I'm about to upgrade my Rostock MAX v2 to handle 3 extruders/hotends. Part of the upgrade is to replace the RAMBo with an Azteeg X3 Pro. I'm thinking up upgrading the PSU to a 24V PSU as well. The Azteeg is advertised as allowing a 12V-24V input. Has anyone actually run 24V through an Azteeg X3 Pro? Are there any issues with doing this that I should watch out for?
- Renha
Re: 24V on the Azteeg X3 Pro?
I am using AX3P with 24V, and I haven't any issues.
3D printing is magic!
Are you using an SSR for the heated bed?
- Renha
Nope, pure 24V, input and output.
What is the wattage of your 24V power supply?
- Renha
750W meanwell
Which heated bed revision? Do you know the resistance of it?
That is awesome! you don't have any additional cooling on the board?
- Renha
PeteD wrote:That is awesome! you don't have any additional cooling on the board?
I had two 12v pumps in series for water cooling, but lately I have bought 24v fan for air-cooling
I am also running 24V through my X3 Pro. Its a 360 Watt one I got from Lulzbot. Running the bed and steppers on 24V. Still doing the hotend/other bits on 12V, since they aren't rated/designed for 24V.
