Software/hardware parameter limititing print size
Posted: Sat Apr 07, 2018 10:32 am
Hi,
I've been trying to print some masks, but the printer is cutting off the edges on both sides as if it's hitting a limit.
I'm not sure what to change, there is plenty of room left for the mechanicals to move.
Here's a pic of what it should print. and here's what it's printing: Probably something simple, I've tried changing print area in MatterControl, and recalibrating the H2, I have the long arms installed.
***update***
After 5 hours of firmware updates, recalibrations, and a bunch of test prints, I think I'm back to factory default...
The cal wizard values are all 0.03 or less now however.
Here are my EEPROM settings exported from MC:
Scott
***update***
Baudrate|250000
Advanced User|1
Filament printed [m]|1.107
Printer active |1411
Max. inactive time [ms,0=off]|900000
Stop stepper after inactivity [ms,0=off]|600000
Steps per mm|80.0000
Max. feedrate [mm/s]|250.000
Homing feedrate [mm/s]|80.000
Max. jerk [mm/s]|32.000
X home pos [mm]|0.000
Y home pos [mm]|0.000
Z home pos [mm]|0.000
X max length [mm]|250.000
Y max length [mm]|250.000
Z max length [mm]|179.890
Acceleration [mm/s^2]|1850.000
Travel acceleration [mm/s^2]|3000.000
Diagonal rod length [mm]|291.060
Horizontal rod radius at 0,0 [mm]|98.890
Max printable radius [mm]|105.000
Segments/s for travel|80
Segments/s for printing|200
Tower X endstop offset [steps]|67
Tower Y endstop offset [steps]|0
Tower Z endstop offset [steps]|30
Alpha A(210):|209.670
Alpha B(330):|330.010
Alpha C(90):|90.000
Delta Radius A(0):|0.000
Delta Radius B(0):|0.000
Delta Radius C(0):|0.000
Corr. diagonal A [mm]|0.000
Corr. diagonal B [mm]|0.000
Corr. diagonal C [mm]|0.000
Z-probe height [mm]|-0.100
Max. z-probe - bed dist. [mm]|20.000
Z-probe speed [mm/s]|80.000
Z-probe x-y-speed [mm/s]|50.000
Z-probe offset x [mm]|0.000
Z-probe offset y [mm]|0.000
Z-probe X1|-75.933
Z-probe Y1|-43.840
Z-probe X2|75.933
Z-probe Y2|-43.840
Z-probe X3|0.000
Z-probe Y3|87.690
Autolevel active (1/0)|1
Bed Heat Manager [0-3]|1
Bed PID drive max|255
Bed PID drive min|80
Bed PID P-gain|87.860
Bed PID I-gain|3.010
Bed PID D-gain|641.820
Bed PID max value [0-255]|255
Extr.1 steps per mm|92.400
Extr.1 max. feedrate [mm/s]|100.000
Extr.1 start feedrate [mm/s]|45.000
Extr.1 acceleration [mm/s^2]|6500.000
Extr.1 heat manager [0-3]|1
Extr.1 PID drive max|230
Extr.1 PID drive min|80
Extr.1 PID P-gain/dead-time|48.3000
Extr.1 PID I-gain|9.7000
Extr.1 PID D-gain|60.0000
Extr.1 PID max value [0-255]|255
Extr.1 X-offset [steps]|0
Extr.1 Y-offset [steps]|0
Extr.1 temp. stabilize time |3
Extr.1 temp. for retraction when heating [C]|150
Extr.1 distance to retract when heating [mm]|0
Extr.1 extruder cooler speed [0-255]|200
Extr.1 advance L [0=off]|0.000
Scott
