Anyone running AstroPrint on a Raspberry Pi connected to a V3? I am trying to decide what to load on the Pi. Pros - Cons insights please.
Thank you,
Tim
AstroPrint? Octoprint? Other?
Self designed plasma cutting table running Mach3
Orbot Hadron running and E3d 6, Smoothie on an Azteeg Mini, LCD, fully adjustable glass bed of my design with a silicone mat heater.
Prtrbot Simple Metal
Table top CNC running Mach 3
Re: AstroPrint? Octoprint? Other?
Running Octoprint and love it. I pre-slice so I haven't used the integrated Cura engine much. Haven't tried any others options.
Thank you- I loaded Octopi and have it up and running. I have only been able to run the calibration script g-code as I get an error when I try to run G-code generated from Matter. Maybe the start - stop g-code needs to be looked at.morgandc wrote:Running Octoprint and love it. I pre-slice so I haven't used the integrated Cura engine much. Haven't tried any others options.
I am slicing with Kiss, but used Cura fine as well.
What is the error? OctoPi shouldn't care what's IN the gcode even if it's wrong.
I use OctoPi and slice with S3D. I like being able to check on it from my phone anywhere in the house. Now that I think about it I need to make a mount for the webcam but the empty can of duster works so well...
Ended up the error said the bed sensor was defective so I checked it with an ohm meter and reseated the bed thermistor connection to the Rambo. Problem solved- for now.mhackney wrote:What is the error? OctoPi shouldn't care what's IN the gcode even if it's wrong.
