Thank you,
Tim
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Thank you- I loaded Octopi and have it up and running. I have only been able to run the calibration script g-code as I get an error when I try to run G-code generated from Matter. Maybe the start - stop g-code needs to be looked at.morgandc wrote:Running Octoprint and love it. I pre-slice so I haven't used the integrated Cura engine much. Haven't tried any others options.
Ended up the error said the bed sensor was defective so I checked it with an ohm meter and reseated the bed thermistor connection to the Rambo. Problem solved- for now.mhackney wrote:What is the error? OctoPi shouldn't care what's IN the gcode even if it's wrong.
