ERIS for sale ($400)
kswaid
Post by kswaid »
I picked up an ERIS over the summer with the intent to use it as a portable printer, but I frankly haven't been using it very much. Instead of leaving it sitting on my shelf I have decided to put it up for sale to buy other toys ;)
The good:
- It is 100% bone stock and has printed around 1kg of filament, so not a lot of use.
- Will come in the original box with about 1/2 of the blue PLA spool that was included.
- Updated to latest firmware a month or so ago
- Mine seems to generally calibrate fine, although sometimes the printing plane will be tilted with a low point opposite the Z tower.
- Has a SeeMeCNC sticker on top!!!!!!!!!!!!!!!!!!!!!!
The bad:
- The build surface has some PETG that is bonded a bit too well. Still works fine, but doesn't come completely clean.
- Some plastic has oozed around the nozzle threads, leaving burnt plastic residue
Asking $400 and I will deliver for free anywhere within about 100 miles of 06339 as long as it does not involve driving into NYC or Boston. Otherwise we can work out shipping.
Cory_W9CDU
Re: ERIS for sale ($400)
Post by Cory_W9CDU »
Hello,
I'm interested in your printer, would you consider the offer of 400$ including shipping to 47882?
If you immediately know the candlelight is fire, the meal was cooked a long time ago.
-Stargate SG-1
kswaid
Post by kswaid »
Let me run a shipping quote first, but that sounds reasonable.
kswaid
Post by kswaid »
Well I decided to make a big test print to protect the bed during shipping, but apparently the ERIS decided it doesn't want to be sold. It is now having calibration issues unless I manually guide the electrical whip and keep pressure on it. I am going to temporarily remove it from sale until I am satisfied that everything works properly. My guess is there is a loose crimp on the HE280 connector that was made worse by me moving the machine around for pictures.
Cory, I will let you know when all is good.
Cory_W9CDU
Ok, let me know how things turn out.
-Stargate SG-1
kswaid
Post by kswaid »
OK, I am getting consistent operation again after correcting a sloppy crimp. I also separated the cable whip and Bowden tube. The pressure exerted by the Bowden tube on the 8 pin connector was significant and didn't sit well with me.
