Hello From the DC Area
Posted: Tue Jan 26, 2016 9:51 am
by dk-info
I am a newbie working in Arlington VA. I Inherited an original Rostock Max V1 that is not in operation. I am interested in getting it up and running, updating it to a V2 if possible. I look forward to the conversation.
Re: Hello From the DC Area
Posted: Tue Jan 26, 2016 10:13 am
by Xenocrates
Welcome to the forums. I hope you get it back into operations, and that your conversion goes smoothly. Let us know if you run into any trouble with it.
Posted: Tue Jan 26, 2016 12:08 pm
Welcome to the forum! You probably have not downloaded the V1 manual for assembly so I will point you to it..
http://download.seemecnc.com/rostockmax ... -Guide.pdf
This manual should guide you to reassembly on your version 1 machine plus please ask us questions when you feel the need
just make sure you always tell us that you are using a version one and what upgrades etc you are using.
SeeMeCNC do make a conversion kit that converts your version one to a version two....
http://www.seemecnc.com/collections/par ... =818774673
I see the kit is out of stock but you can contact them and see when the kit should be made available and that you need one (Black or White).
