RADDS
Posted: Sat Jan 09, 2016 12:15 pm
I just picked up a RADDS board from reprap.me prior to realizing that there is a us distributor. Shipping via Fedex economy was very quick! I'm installing it on my custom delta shortly.
I bought the RADDS board, the chinese Due that they sell, as well as the RADDS LCD. I'm using DRV8825 drivers I already had from my BBB/CRAMPS setup.
It supports 6 steppers without any add-on boards and will support 8 extension board.
[img]http://i.imgur.com/oGNpmxt.jpg[/img]
Its pretty simple to set up. Use the programming port to program it and to connect repetier host to - I learned that I couldn't see the eeprom when I used the other port.
Configuration is pretty simple via repetier
http://www.repetier.com/firmware/v091/index.html
http://doku.radds.org/dokumentation/fir ... /repetier/
Punch in all the relevant info and you'll be up and running pretty quick. You can probably even import the data from a rostock max and change out the controller and be up and running even sooner. There are a couple things I will have to double check on to get the proper settings for but I imagine it'll be up and running pretty quick.
I'll post my configuration.h up later once I have it all dialed in, then all someone would need to do is modify it for their printer or use the repetier configuration utility(just upload configuration.h then modify).
One thing I don't really like at the moment is it is powered up by USB so its going to always be on when I have it connected to a banana pro/raspberry pi.
