Filiment jam
Posted: Wed Dec 23, 2015 7:33 am
by Penged
Printing a glow in the dark unicorn horn for my daughter using inland luminous PLA. Checked on it and it had quit extruding. Upon further review the filiment it had somehow jammed up in the extruded motor. I removed the clear plastic cover to clean it out before I thought to take a picture. Any thoughts?
Re: Filiment jam
Posted: Wed Dec 23, 2015 9:04 am
by Penged
Update.. I also discovered that the thermistor has boken loose from the RTV.
Re: Filiment jam
Posted: Wed Dec 23, 2015 4:07 pm
by lightninjay
It is likely that your current settings are a bit high for your extruder motor and as a result, the extruder overheats and melts your plastic at the motor.
Check
Guanu's post here and see if lowering your extruder motors current helps.
Re: Filiment jam
Posted: Thu Dec 24, 2015 5:18 am
by Penged
Thanks Lightning Jay. I will look into it
Re: Filiment jam
Posted: Fri Jan 15, 2016 1:07 am
by darkjorik
I have some trouble like this with Ninjaflex. Everytime
