Gone Berserk
Posted: Sun Dec 20, 2015 2:28 pm
by tcat007
I tried printing this file:
http://www.thingiverse.com/thing:53235/#files (the v3 version), on my Max v2, with MC/MS. Also tried MC/Slic3r. Nozzle takes off in odd directions, one try ran into Z post, another try ran into X post. Parts fit within 9" diameter and look right in layer view. Is it MC or "me"? Homed and ran Tower Cal right after and printer seems to be doing everything right.
Edit: Success! I opened the file in Slic3r (stand alone) and exported Gcode. Opened Gcode in MC and print started nicely. Will see in 6 hours how it looks/works. Odd though in both MC and Slic3r, when I try to select one of the 6 items in the stl, it picks a different one than I click on, and won't select the tall one at all (unless I select it from t he file list at right), but even then I can't move it, since it immediately deselects as soon as I try to grab it. Anyway, it works.
Re: Gone Berserk
Posted: Sun Dec 20, 2015 6:18 pm
Glad you got it working!
Re: Gone Berserk
Posted: Sun Dec 20, 2015 9:31 pm
by tcat007
6 parts after 5 hrs. After some filing and exacto, all went together. However supposed to play "Happy Birthday", but not coming close. Maybe PLA (Thing material) is tuned better than ABS (what I had going). Not sure if I know enough about music to tune the thing. But it's a really cool mechanism! Parts came out good, but lots of strings jumping from one part to another. Material too hot/cold?
Re: Gone Berserk
Posted: Sun Dec 20, 2015 10:59 pm
tcat007 wrote:6 parts after 5 hrs. After some filing and exacto, all went together. However supposed to play "Happy Birthday", but not coming close. Maybe PLA (Thing material) is tuned better than ABS (what I had going). Not sure if I know enough about music to tune the thing. But it's a really cool mechanism! Parts came out good, but lots of strings jumping from one part to another. Material too hot/cold?
Temperature of the hotend does factor into the problems with strings but so does other settings such as length of retraction and speed of retraction.
Could you post your retraction settings and are you using the stock hotend?
Re: Gone Berserk
Posted: Mon Dec 21, 2015 10:17 am
by tcat007
Eaglezsoar wrote:tcat007 wrote:6 parts after 5 hrs. After some filing and exacto, all went together. However supposed to play "Happy Birthday", but not coming close. Maybe PLA (Thing material) is tuned better than ABS (what I had going). Not sure if I know enough about music to tune the thing. But it's a really cool mechanism! Parts came out good, but lots of strings jumping from one part to another. Material too hot/cold?
Thank you for your help! Stock Max v2 .5mm hotend. 230C, Hatchbox Red ABS. Default Slic3r settings.
Retraction
Length: 2 mm
Lift: 0
Speed: 40
Min travel: 2 mm
I've never messed with anything except temps.
Re: Gone Berserk
Posted: Tue Dec 22, 2015 6:08 pm
tcat007 wrote:Eaglezsoar wrote:tcat007 wrote:6 parts after 5 hrs. After some filing and exacto, all went together. However supposed to play "Happy Birthday", but not coming close. Maybe PLA (Thing material) is tuned better than ABS (what I had going). Not sure if I know enough about music to tune the thing. But it's a really cool mechanism! Parts came out good, but lots of strings jumping from one part to another. Material too hot/cold?
Retraction
Length: 2 mm
Lift: 0
Speed: 40
Min travel: 2 mm
Your retraction speed could come down to about 30 and most run a z-lift of .5 - 1mm
Other than that I see no problems. Extrusion width should be nozzle size + 10% of nozzle size. ( .4mm nozzle results in width of 4.4 or 4.5)
Every hot end is a little different but the general rules of thumb are:
Layer heights shouldn't be more than 80% of the nozzle size. So for a .5 nozzle, .4mm layers is about what you should cap it at.
Extrusion width will likely be 110% -120% of nozzle size as indicated above.
