Page 1 of 2
error uploading repetier
Posted: Sat Dec 19, 2015 8:09 pm
by jerome0139
i am trying to upload the repetier firmware and it keeps giving me the same error im new to coding so i was looking for Little help or guidance if it is the a hardware issue or if it is a firmware issue i have a rostock max v2 here is the error message that i keep getting if any one wants i can copy whe whole thing in here if it might make it easier to solve
C:\Users\jgardner\AppData\Local\Temp\build42879d3f4a51ad5a156a0c9e9b8b6401.tmp\sketch\libraries\twi.c:1:17: fatal error: twi.c: No such file or directory
#include <twi.c>
compilation terminated.
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
exit status 1
Error compiling.
thank you
Re: error uploading repetier
Posted: Sun Dec 20, 2015 12:47 am
by Earthbound
I'm guessing that the version of Repetier firmware that you are trying to load was written for a different version of the Arduino IDE. The library inclusion is failing because the compiler can't find it. It should be possible to alter the Repetier sketch, but far simpler to just download the matching version of Arduino IDE.
Posted: Sun Dec 20, 2015 10:59 am
by jerome0139
Earthbound wrote:I'm guessing that the version of Repetier firmware that you are trying to load was written for a different version of the Arduino IDE. The library inclusion is failing because the compiler can't find it. It should be possible to alter the Repetier sketch, but far simpler to just download the matching version of Arduino IDE.
from what i know i used everything that seemecnc.com has said to in there instructions i have a rostock max v2 with an arduino/genuino mega or mega2560 trying to upload repetier .091 firmware it looks like everything matches. heres the link from where i got it ( http://www.seemecnc.com/pages/downloads )if you download it and look through the folder and open the libaries folder in that there is a file that is twi.c but it looks like it is the only file in that is .c everything else looks like it is .cpp but i dont know what that mean
thank you
jeremy
Posted: Sun Dec 20, 2015 11:18 am
What version of the Arduino IDE are you running? That is NOT specified on the SeeMeCNC page. The Repetier release on the page is a few years old. It is very possible that you are using the most recent Arduino IDE and it is not compatible. Look at the About dialog in the IDE to get the version #.
Posted: Sun Dec 20, 2015 11:22 am
by jerome0139
mhackney wrote:What version of the Arduino IDE are you running? That is NOT specified on the SeeMeCNC page. The Repetier release on the page is a few years old. It is very possible that you are using the most recent Arduino IDE and it is not compatible. Look at the About dialog in the IDE to get the version #.
if im looking at the right info i beleive it is a rambo 1.31L i got that info from the wiring diagram that came with the set
Posted: Sun Dec 20, 2015 11:23 am
by Eric
It's not a hardware problem, as it's failing before it gets to the upload part, during compiling. Compiling is the step where the human-readable code is turned into machine code.
When you start up the Arduino editor, what is the version number on the top bar? If it's not at least 1.6, you should go get a more current version.
Posted: Sun Dec 20, 2015 11:25 am
jerome, no that is not it. Arduino is the programming environment that compiles the firmware and uploads it to the machine. You get it here: https://www.arduino.cc
You have installed it haven't you?
Posted: Sun Dec 20, 2015 11:29 am
by jerome0139
the header is stating that it is 1.6.7
Posted: Sun Dec 20, 2015 11:33 am
Ok, did you configure Arduino for the correct board under Tools-> Boards menu?
Posted: Sun Dec 20, 2015 11:36 am
by jerome0139
yea its arduino/genuino mega or mega2560 and it is on com5 the eeprom seem to work fine when it had me run that
Posted: Sun Dec 20, 2015 11:48 am
by jerome0139
im not sure if this helps but heres the complete error
Arduino: 1.6.7 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\jgardner\Documents\Arduino\libraries" -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10607 -build-path "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp" -warnings=all -prefs=build.warn_data_percentage=75 -verbose "C:\Users\jgardner\Desktop\Repetier-091-ROSTOCKMAX-master (2)\Repetier-091-ROSTOCKMAX-master\Repetier-091-ROSTOCKMAX\Repetier\Repetier.ino"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\jgardner\Documents\Arduino\libraries" -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10607 -build-path "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp" -warnings=all -prefs=build.warn_data_percentage=75 -verbose "C:\Users\jgardner\Desktop\Repetier-091-ROSTOCKMAX-master (2)\Repetier-091-ROSTOCKMAX-master\Repetier-091-ROSTOCKMAX\Repetier\Repetier.ino"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Repetier.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Repetier.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\SPI.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Commands.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Communication.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Eeprom.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Extruder.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\HAL.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Printer.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\SDCard.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\SdFat.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\CDC.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\HardwareSerial.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\IPAddress.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\Print.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\Stream.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\Tone.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\USBCore.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Repetier.ino.cpp" -o "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\WInterrupts.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\WMath.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\WString.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\main.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\new.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_analog.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_digital.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_pulse.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_shift.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\gcode.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\EEPROM.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\Ethernet.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\Firmata.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\LiquidCrystal.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\OBD.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\SD.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\SPI.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\Servo.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\SoftwareSerial.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\Stepper.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\TinyGPS.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\U8gui.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\WiFi.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\Wire.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\twi.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\motion.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\ui.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino5/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
Using previously compiled file: C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\WInterrupts.c.o
Using previously compiled file: C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring.c.o
Using previously compiled file: C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_analog.c.o
Using previously compiled file: C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_digital.c.o
Using previously compiled file: C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_pulse.c.o
Using previously compiled file: C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_shift.c.o
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\twi.c" -o "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\twi.c.o"
C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\twi.c:1:17: fatal error: twi.c: No such file or directory
#include <twi.c>
exit status 1
Error compiling.
Posted: Sun Dec 20, 2015 3:04 pm
It really seems environmental. The basics: do you have enough free disk space? Have you successfully compiled one of the simple demo apps that comes with Arduino IDE under File->Examples? Pick a few and see if they compile.
Posted: Sun Dec 20, 2015 6:14 pm
by jerome0139
smart thinking
so i tried a couple and they all compiled
if it says compiled complete is that a pretty good idea that the board is working
it seems like my only issue is the repetier firmware and that twi.c
any other ideas i emailed seemecncs support so im curious what they will say i was just really hoping to get this going so i can start calibrating it
jeremy
Posted: Sun Dec 20, 2015 6:16 pm
That's good. That shows arduino ide is setup. How about going to repetier and downloading the firmware. Don't worry about configuring it we just want to see it compile. Would be a good test while you wait.
Posted: Sun Dec 20, 2015 6:28 pm
by jerome0139
might be a dumb question but where do i download it i tried one thins but it seemed more like a slicing program instead of the firmware
Posted: Sun Dec 20, 2015 6:39 pm
Posted: Sun Dec 20, 2015 6:42 pm
by jerome0139
ok so i did that but i wasnt sure how that get to the board and do you know if both the green light and the orange light should always be on
Posted: Sun Dec 20, 2015 6:49 pm
DO NOT upload it. Just test if it compiles.
Posted: Sun Dec 20, 2015 6:52 pm
by jerome0139
gotcha yea no luck on compiling
Posted: Sun Dec 20, 2015 6:58 pm
by jerome0139
i dont know why but im so lost with this at the moment
Posted: Sun Dec 20, 2015 7:38 pm
by teoman
This step is trivial usually. Something is fishy.
Try on a different computer. Download arduino and the repetier firmware and see if it compiles (check mark on the arduino window). (The right arrow compiles and uploads it).
Posted: Sun Dec 20, 2015 7:56 pm
I just did a Skype session. I had him install Arduino 1.6.0 and a fresh copy of the firmware from SeeMe. Same problem. He mentioned this is a work laptop so "ding" - maybe there is some antivirus or lockdown on it. It has to be environmental as I installed the same versions of this stuff and it compiled fine. He's digging out another PC to try.
Posted: Sun Dec 20, 2015 8:04 pm
mhackney wrote:I just did a Skype session. I had him install Arduino 1.6.0 and a fresh copy of the firmware from SeeMe. Same problem. He mentioned this is a work laptop so "ding" - maybe there is some antivirus or lockdown on it. It has to be environmental as I installed the same versions of this stuff and it compiled fine. He's digging out another PC to try.
Good job Michael and thanks to going to such extents to help a fellow Forum member. You DA MAN!
Posted: Sun Dec 20, 2015 8:39 pm
by jerome0139
after that talk with Michael and switched a couple things im ready to go i really appreciate all the help and im sure ill be back for more questions :D :D :D :D :D :D :D :D :D :D :idea: :D
Posted: Sun Dec 20, 2015 8:41 pm
Great! Was there something specific you found or was it the work laptop probably having virus checking?
