Bed stopped heating (rambo issue?)
Posted: Tue Dec 15, 2015 4:53 am
My heated bed shut off in the middle of a print, and now won't heat up at all. The hotend works just fine.
I took a volt meter to the pins:
12 volts at the Rambo's A inputs (heated bed power) as well as the other two (though one of the bed power wires was corroded and a bit melted. The block was very slightly melted, but still seemed functional. I redid that wire, made no difference)
12 volts on the pins that come from the back of the power block and are soldered into the Rambo board. (to see if the screw terminals broke from melting)
Polarity seems to be correct as well.
All three fuses have continuity.
With the heated bed attached:
No voltage on bed output when bed is on, led6 very very briefly flickers on at first.
With the heated bed leads removed:
Resistance across the heated bed wires was... I forget, but it seemed reasonable.
Voltage on the bed output was 2.7 volts and led6 stayed lit.
I should note that I modified the firmware for e3d's cyclops hotend, but I had been running on that for a few months. Mainly, I just changed some pin assignments, but not the bed's pin. The printer itself is about a year old.
My suspicion is that something broke on the controller, but I wanted to see if anyone had a better idea before I buy a replacement. Thanks!
