40 mm Stand Alone Fan for My Smoothieboard
Posted: Thu Nov 26, 2015 12:26 pm
by draw-tech
Hi All
Setting up my test station to test the 300C hot end, using a Smoothieboard. i will be pushing the board using relays to power an all aluminum bed plate, It will have two zones controlled with two thermistors,
each zone I estimate will draw about 14 A and about 85 watts. I.m starting out a little overkill, then can cut back on the amount of heating resistors I will need. So I need a fan that I can move around to cool the board, or whatever.
Fan_Stand.zip
(1.63 MiB) Downloaded 321 times
Re: 40 mm Stand Alone Fan for My Smoothieboard
Posted: Fri Nov 27, 2015 7:55 am
by barry99705
That's a cool little fan stand!
Posted: Fri Nov 27, 2015 7:58 am
barry99705 wrote:That's a cool little fan stand!
And it is a breeze to make!
