Orion/E3d v5 and taulman alloy 910
Posted: Tue Sep 22, 2015 1:00 pm
Hi, i am trying to print with taulman alloy 910 with an e3d v5 hotend, the thermistor is a EPCOS B57560G104F
I can't seem to be able to set the extruder temp above 247 C either from the sd card gcode or external PC host,
although it goes above and below that while trying to hold the 247 temp. Another thread on this forum said they
got better results with alloy 910 at 260 C than the manufacture spec of 245 C, so i was trying to set it at 255 C.
i modified the configuration.h file line so max temp is now 260 instead of 240 C.
have I missed something?
also i hear popping and cracking noise as the extruder prints is that due to moisture in the filament
or to low a temp?
thanks
or to low a temp?
thanks
