Flex3Drive
Posted: Sun Aug 09, 2015 4:27 am
Hi all,
New member forum member here, although I've had the RMax for nearly a year now!
Anyway as per title I'm trying to install a flex3drive (http://mutley3d.com/Flex3Drive/) on the Rmax but can't work out how to change the extruder step rate,
the instructions suggest that the extruder step rate should be increased from 1/16 to 1/8 but in the repetier configuration.h I only see the following line...
/** \brief Micro stepping rate of X, Y and Y tower stepper drivers */
#define MICRO_STEPS 16
So anyone know if this effects the extruder motor also? and basically will this affect the whole printer (in a bad way) if I change this value to 8? Anyway to change just the extruder step rate?
So if anyone has any advice etc etc or has done this before any help would be much appreciated,
Cheers,
Rob
Cheers,
Rob
