Retraction values and stringing?
Posted: Sun Jul 26, 2015 7:54 pm
Hello! I'm trying to eliminate a stringing problem. I'm running a MAX v2, MatterControl with Repetier 0.91, PLA @ 178 deg C. I'm trying to print the standard open pyramid.
Current settings:
Imagine that each of the four posts of the calibration pyramid is numbered 1 to 4. I can see that the EZstruder is retracting as the hot end moves between 1 and 2 and between 3 and 4, but it's not retracting between 2 and 3 or 4 and 1. So there's a stringing problem between 2 and 3 (big time) and between 4 and 1 (not as much, but still not good).
So if I should be seeing retraction for every non-printing move, and I'm not seeing that...what's going on?
Current settings:
- Retraction length on move: 7.5 mm
Speed: 100 mm/s
Z-lift: 0.5 mm
Outside perimeter print speed: 10 mm/s
Inside perimeter print speed: 20 mm/s
