Small Layer issue with ABS print
Posted: Mon Jun 22, 2015 4:14 am
Hi,
I am relative new comer to 3d printing and I have a small issue I would like some advice on.
I am printing in ABS, using Elmers glue stick, at 105 degrees bed temp and 230 degrees nozzle temp. THe geberal quality is great except when I have small layers. I am slicing using Repetier and Slic3r.
My issue is shown in the attached picture but basically, it looks like the previous layer is not cooling enough before the next layer is etruded causing small layers to sag. I thought you could set a minimum time for a layer, so that you can control this issue but I cannot find a setting for that.
Any advice would be greatly appreciated, sorry for the poor quality picture.
Carl
Carl
