Zoe's (Rostock Max V2) Enclosure
Posted: Sun Apr 19, 2015 10:45 pm
by drwho
We just finished the enclosure for our Rostock Max V2. Her name is Zoe :) Thanks to @JFettig for the design work it turned out well.
Re: Zoe's (Rostock Max V2) Enclosure
Posted: Mon Apr 20, 2015 10:44 pm
by JFettig
Looks good :)
Posted: Mon Apr 20, 2015 10:52 pm
by 3D-Print
Looks awesome!!
Posted: Fri Apr 24, 2015 4:53 pm
by drwho
Here is a before and after picture.
[img]http://forum.seemecnc.com/download/file ... 533115eded[/img]
Posted: Fri Apr 24, 2015 5:02 pm
by BenTheRighteous
Boy, JFettig's enclosure sure is popular!
That reminds me, I have to go dig up that thread to make a suggestion... :)
drwho, you should consider swapping out the blue LCD for a yellow one. That would look sliiiiiick next to those yellow brackets!
Posted: Sun Apr 26, 2015 1:06 am
by CRPerryJr
Did you have any difficulties printing the X.stl file? That seems to be the one file I can't get to print.
Posted: Thu Apr 30, 2015 11:35 pm
by drwho
CRPerry Jr. No trouble with printing the X.stl file. What issue is it giving you?
Posted: Fri May 01, 2015 6:09 am
by CRPerryJr
Ny issue printing the x.stl file was the z-lift. it was set to low at default. I received recommendations to raise it to 1 mm, which did the trick!
Posted: Fri May 01, 2015 11:02 am
by drwho
What layer height are you using?
The majority of our pieces are printed at .4 mm height.
