Despirately looking for PTC Connectors
Posted: Fri Mar 20, 2015 8:45 am
by Proto
Disclaimer - I'm not looking to assign blame. I need these parts sooner than ASAP
Short Story - I need 2 PTC connectors to repair my Maxx's feed. preferably in the Metro Detroit Area. http://seemecnc.com/collections/parts-a ... tc-fitting or equivalent.
LONG STORY - My feed tube broke away from the PTC fitting last week and will not go back together. I ordered the parts from SeeMe thinking that it is only a 2 hour drive that I should have have my parts in 1-2 business days. It's been over a week. And the last thing the USPS tracking says is that it left their Fort Wayne IN facility on 3/18.
I have projects I need to get done. I have tried Parker, Airquip, and Grangers. not one stocks this part locally (Detroit Area). I'm half tempted to try Production Tool, even though I believe it is to specialized for them.
I need parts today.
Re: Despirately looking for PTC Connectors
Posted: Fri Mar 20, 2015 6:39 pm
by DanHall
How about a local Fastenal? They're often able to get me otherwise hard to find parts fairly quickly.
Posted: Fri Mar 20, 2015 8:58 pm
by Proto
Thanks Dan
I never dealt with Fastenal before, no luck though.
Fastenal - Not stock in any location within 100mi of me
Granger - Closest stocking location is over an hour away
Parker - Closest stock is in Cleveland
Aeroquip - nothing
local plumbing supply does not stock metric
Things are not looking good for our Hero
Posted: Fri Mar 20, 2015 9:13 pm
Just order some ptfe tubing from seeme or Amazon and epoxy the existing tube into the connector.
Posted: Fri Mar 20, 2015 11:41 pm
by JFettig
Don't know why I didn't think of this earlier: 5/32~=4mm and 10-32~=M5x.8, you can mix and match these and hardly notice a difference.
Posted: Sat Mar 21, 2015 1:39 pm
by Proto
ok, I have officially given up.
I ordered the correct parts from Graingers and will pick them up on Tuesday (having them transferred from another store).
JFettig wrote:Don't know why I didn't think of this earlier: 5/32~=4mm and 10-32~=M5x.8, you can mix and match these and hardly notice a difference.
You are correct, those probably would work. but they are just as rare as the metric versions.
Epoxy & Teflon don't mix, not much sticks to teflon without proper prep work (ie acid etching)
as a quick fix I thought of ductape. but I didn't want it anywhere near the hotend.
Posted: Sat Mar 21, 2015 1:43 pm
FWIW I've actually done the epoxy thing and it is good enough to get by, I did sand the outside of the tube, I bought 10ft of the teflon tubing a few years ago when I needed 2 inches of the stuff, so throwing it away isn't something I worry about.
Posted: Sun Mar 22, 2015 8:25 am
by Proto
And the fates are having a good laugh at my expense
After leaving the Post Office's facility in Fort Wayne IN, 4 days ago, it finally showed up in the Detroit Area.
Of course I had purchased a replacement set yesterday.
Of Course the Original set will be delivered 24hrs before the replacement set.
And such is my life... :P
Posted: Mon Mar 23, 2015 7:34 pm
by dpmacri
Proto wrote:And the fates are having a good laugh at my expense
Not sure if it's too late for you or not, but I had this problem early on with my R-Max. I used a razor blade to trim a bit from the edges from the PTFE 2 to make it small enough to manually thread a nut I had on hand onto the PTFE tubing. Then I used Kapton tabe to tape everything to the PTC connector. It worked while I waited for PTC connectors to come in (I ordered from Amazon with prime, 2-day shipping).
Interestingly enough, I never took the nut off even after the new connectors came in :-)
Posted: Tue Mar 24, 2015 9:12 am
by Proto
The package hit the door yesterday. And my WW Grainger order is ready for pickup today.
:D :( :lol: :cry: :| :| :|
