trouble printing thin walls with abs
Posted: Sat Mar 07, 2015 6:08 pm
				Hello,
I've been printing with my Max V2 using ABS so far, and having pretty good results with the exception of large prints pulling up on the edges. In this case, I'm trying to print a case for my Raspberry Pi and have found that when getting up along the sides if there is a narrow section or bridge, I'm having layer separation and the material is very brittle and little sections just break off. The base (against the build plate) and long sides hold together very well. I'm using a .5 mm nozzle, .2 mm layer height, 228 degree hot end, 80 degree build plate, and using the normal settings found with MatterControl. In addition, I'm using hair spray for holding the model down to plate. Should I be using PLA instead or another material, or are my settings wrong. Thickness of side walls of model are approx .060" (1.5mm).
Thanks in advance,
Cris
Thanks in advance,
Cris
