10" tall vase
Posted: Fri Feb 27, 2015 8:48 am
by dunginhawk
So as my tricklaser arms arrive today so I can hopefully remedy some banding issues etc. I thought id print one last item with the stock setup (minus the 3 layer fans).
So here is a clear PLA vase , default size which is pretty big. It printed very consistently all the way to the top (which i know at height some folks have issues).
I cant tell if the banding in this one is normal or not, it is SOOOO consistent.
let me know what you think. Ill print another after new arms
EDIT - THis was done at 210 degrees, 60 degree bed on PEI (perfect) w/ .15mm layer height.
[img]http://i1132.photobucket.com/albums/m562/dunginhawk/3CB831B9-D767-48D0-A7A3-8E63A31661CB_zpspvp3tsea.jpg[/img]
Re: 10" tall vase
Posted: Fri Feb 27, 2015 8:56 am
by Nareikuk
Hope it works out for you. Cost approx $280 for arms and carriages to see if it will work for me - plan on installing them tomorrow.
Re: 10" tall vase
Posted: Fri Feb 27, 2015 9:04 am
by dunginhawk
i didnt do different carriages, just the arms... my carriages seem quite solid... very firm, roll smooth, never a noticeable miss.
Re: 10" tall vase
Posted: Fri Feb 27, 2015 9:14 am
by KAS
Looks awesome! The real test, will it hold water? Mine leaks little droplets out of a few seams and the inside feels like a torture device if you shove your arm in it.
Re: 10" tall vase
Posted: Fri Feb 27, 2015 9:18 am
by dunginhawk
why would the inside look jagged? its just a single walled vase right? did you not use vase mode and had travel across the opening?
Either way, i just filled it, and NO leaks. In fact i was surprised because it only did 2 layers on the bottom.
the bubbles you see are inside, clinging to the plastic
[img]http://i1132.photobucket.com/albums/m562/dunginhawk/DFC117E9-1952-45D3-8F72-C7CC07E7A89E_zpsvfyyke0z.jpg[/img]
look at the inside. no jaggies
[img]http://i1132.photobucket.com/albums/m562/dunginhawk/7754DC25-3F29-4177-B275-91F0B0164EF5_zpset1bq3rg.jpg[/img]
Re: 10" tall vase
Posted: Fri Feb 27, 2015 9:20 am
Nareikuk wrote:Cost approx $280 for arms and carriages to see if it will work for me - plan on installing them tomorrow.
Why so much? Isn't that about $100 off?
Re: 10" tall vase
Posted: Fri Feb 27, 2015 9:37 am
by Nareikuk
I am in the UK - $135 for the arms and trucks. Approx $40 for postage to UK. Approx $100 for the open builds stuff parts from the UK inc. postage.
Oh, and I must not forget the free clamps you designed and published on Repables
That was the cheap bit.
Re: 10" tall vase
Posted: Fri Feb 27, 2015 10:13 am
by KAS
dunginhawk wrote:why would the inside look jagged? its just a single walled vase right? did you not use vase mode and had travel across the opening?
That vase was like the fourth thing I ever printed when I built the v2. I was so excited it was working but had no clue on the settings. The inside of each angle looked like a Chinese torture device with brutal jaggies everywhere. I don't have a pic it on my PB account, It leaked like crazy. I stopped the print early because it started to step over as the print got higher. I now use it as a tool holder next to my printer for calipers/screwdrivers etc.
[img]http://i482.photobucket.com/albums/rr189/Onuxis/20141231_172454.jpg[/img]
Re: 10" tall vase
Posted: Fri Feb 27, 2015 10:43 am
by dunginhawk
so the banding in yours is visible too...
does anyone who does not suffer from banding have a pic of the vase they printed? im guessing with the angles its likely most would see some banding.
thanks
Re: 10" tall vase
Posted: Sun Mar 08, 2015 8:08 am
by 3D-Print
I just printed this as a pencil holder thus scaled it down about 30% and shortened. Looks smooth but can see some banding inside and out. It is a cool print.
Re: 10" tall vase
Posted: Sun Mar 08, 2015 3:29 pm
by bot
I think the banding you are seeing is aliasing from the low resolution of the stepper axis.
