A Tale of Two Problems
Posted: Tue Feb 17, 2015 12:54 am
by Cale
I'm having two problems with my Rostock MAX v2.My first problem is about y-axis.I have recently re-tightened all the cheapskate motion carriages .Now the y-axis is making weird noises when it goes up.My dad is guessing the belt teeth are skipping,but I'm not sure if that is what is going on.My second problem is about leveling.I've always had trouble leveling my printer.When I am able to level it somehow,my printer can only print small objects,but I want to print large objects!!I've been trying both the recommended way to level and the Mattercontrol way,but both haven't leveled out my print-bed.And then there are times when I think it is level,but then the hot-end is too close to the print-bed.Am I doing something wrong in leveling?I would appreciate any help you can give me.
Cale
Re: A Tale of Two Problems
Posted: Tue Feb 17, 2015 1:27 am
by bubbasnow
i would work on a single problem at a time, if your tower is having issues you will never get a level surface. watch the youtube videos for cheapskate installation without belts.
Posted: Tue Feb 17, 2015 3:51 am
by teri1337
Have you adjusted for virtual bed shape? Once you have adjusted the endstop switches so that the z-zero height is similar near all three tower locations, if you find the z-zero height at the center of the bed is too high or too low, adjust the EEPROM "Horizontal Radius" setting. This value determines the virtual "flatness" of the mathematical bed motion, adjusting from slightly concave to slightly convex. Details on how to adjust this setting are in the manual (around page 240). Good luck!
Posted: Wed Feb 18, 2015 12:20 am
by Cale
Thanks guys for the help!To answer Terri1337's question,I do know how to use the horizontal radius setting,but I tend to not use it too much :
(mostly because it is so hard to get the exact number,but I will try harder to use it).As for the y-axis I'm still not sure,but I don't think it is affecting my leveling.Still need help with the y-axis problem.
Cale
Posted: Wed Feb 18, 2015 1:18 am
by bubbasnow
you should try to get a video of the problem
Posted: Thu Feb 19, 2015 12:44 am
by Cale
Just noticed something weird during leveling.Every time I change the horizontal radius,it doesn't affect the horizontal radius
. Does anyone know what is causing this??
Cale
Posted: Thu Feb 19, 2015 7:38 am
by Mac The Knife
If you are looking for a change at the center of the bed, you won't see it there after changing horizontal radius, you will find the change at the outer perimeter of the bed.
Posted: Fri Feb 20, 2015 12:43 am
by Cale
What I am saying is that,I do notice the edges changing and they are not changing right now.
Cale
