I just got done installing a copper heat spreader plate that I hope will help even a tiny bit with getting the bed a consistent temp. I bought a 12x12 inch square .093" thick copper plate, had a friend of a friend cut it to size (about 310mm around) and then I drilled a poorly measured off-center hole for the bed LED (whoops, but the LED shows through mostly anyways!). There are 4 flat sides, since the 310mm bed is a bit over 12 inches, but it fits well and I didn't even need new binder clips!
I also put 2 layers of Kapton tape around the edges to try and get a bit less heat transfer from the copper plate edge to the air, but I don't even know if that was needed, although it did feel super hot around the printer when I'd heat it up without the tape as compared to before the plate, so I think it acted as a sort of radiator. I might get something better to keep the heat in later, but for now it qualitatively feels cooler around the printer with the tape.
The temperatures as measured with both an IR thermometer and a contact thermometer are within .5 C all around the plate now, which is MUCH better than the 20+ C differences before! It takes a small amount of time longer to heat the bed than before and the surface lags the sensor just a bit since the sensor is not touching the plate, but I was thinking that with this setup I could probably use copper RTV silicone to bond the thermistor right onto the copper plate or drill a hole in the center to raise the thermistor into contact or something.
I don't know about printing quality yet, but I would imagine that at the very least it will help with bed adhesion on the edges and maybe with ABS adhesion hours into a big print.
Photo of bed from the webcam I use to keep track of prints:
[img]http://puu.sh/fR2f3/f48b5b3b02.jpg[/img]
The product I purchased:
110 copper 0.093" plate
Copper heat spreader plate for about $45
Check out how others are building and modding their own heated beds
- redoverred
Return to “Heated Bed How-To's”
Jump to
- SeeMeCNC Announcments
- ↳ General Announcments
- ↳ SeeMeCNC crew in the wild
- ↳ 3D Printing Contests
- ↳ Development Topics
- Software
- ↳ Orca Slicer
- ↳ SuperSlicer
- ↳ Cura
- ↳ Simplify3D
- ↳ Slic3r
- ↳ KISSlicer
- ↳ Repetier Host
- ↳ OctoPrint
- ↳ Other
- ↳ Sculptris
- ↳ OpenSCAD
- ↳ FreeCAD
- ↳ Blender
- ↳ SolidWorks
- ↳ AutoDesk 123D
- ↳ EMC2/LinuxCNC
- ↳ Skeinforge
- ↳ Mach3 Software
- ↳ MatterControl
- ↳ Creation Workshop
- ↳ Fusion 360
- General Forums
- ↳ New Member introduction
- ↳ The Lounge
- ↳ Live Stream Announcments
- ↳ Show us your machine!
- ↳ What are YOU making?
- ↳ General Tips 'N Tricks
- ↳ Troubleshooting
- ↳ Rostock MAX Official Docs
- ↳ ORION Official Docs
- ↳ GCode & Test Prints
- ↳ The Build Zone
- ↳ FAIL HAPPENS ! ! !
- ↳ Filament
- ↳ Test Forum
- ↳ Members Marketplace
- Extrusion Based Machines
- ↳ Artemis
- ↳ BOSSdelta 300
- ↳ BOSSdelta 500
- ↳ RostockMAX v4
- ↳ RostockMAX v3.2
- ↳ RostockMAX v3
- ↳ ORION
- ↳ ERIS Delta
- ↳ Hacker Series - H2
- ↳ Rostock MAX v2
- ↳ Rostock MAX
- ↳ H-1.1 3D Printers
- ↳ H-1 3D Printers
- ↳ Other Machines
- ↳ RailCore
- ↳ Scorpius™
- ↳ Constellation
- Regional Forums
- ↳ Sprechen Sie Deutsch
- ↳ Parlez-vous français
- ↳ Hablas español
- ↳ Australia and New Zealand
- UV Liquid Resin Printers
- ↳ DropLit
- ↳ Resin Materials
- ↳ Troubleshooting
- ↳ Development Ideas
- ↳ Skylight
- Hardware Store
- ↳ Nuts and Bolts
- ↳ Computer Hardware
- ↳ Mods and Upgrades
- ↳ Heated Bed How-To's
- Electronics
- ↳ RAMBo
- ↳ RAMPS
- ↳ Azteeg X3 and X3 Pro
- ↳ Beaglebone Black
- ↳ Duet
- ↳ Sanguino (lulu etc...)
- ↳ Gen6 and variants
- ↳ Printrboard
- ↳ Power Supplies
- ↳ Alligator Board
- ↳ Other Controllers
- ↳ OTHER Electronics
- SeeMeEducate
- ↳ Teachers Lounge
- ↳ Show Your Work
- ↳ Software Help
- ↳ Design Help
- ↳ Show and Tell
- SeeMeFPV MultiRotor Forums
- ↳ General FPV topics
- ↳ Motors
- ↳ ESC's
