Orion will not home
Posted: Thu Dec 18, 2014 10:15 pm
by Kevinvandeusen
Someone came in my store today, and decided to play with the lcd controls. Now when you ask to home, it just goes down about 25mm. I am baffled as to what they must have changed?
Re: Orion will not home
Posted: Thu Dec 18, 2014 10:43 pm
by bot
I think they set a new Z height at an absurd value. Try resetting it to a sensible value.
Posted: Sun Apr 02, 2017 6:56 pm
by briankb
I'm having this issue right now and it was because I accidentally pressed on the "Set Z Height" menu item. I have tried, what I thought would correct it, but it still only goes DOWN when I press Home. I would expect it to go UP when I ask it to home until it hits each of the switches.
What I've tried to no avail:
- manually move the hot end tip to just above the center of glass and resetting Z Height via same menu that got it messed up in first place.
- tried running Calibration which I assume would just ignore existing settings and start from scratch.
Posted: Sun Apr 02, 2017 9:28 pm
by joe
You could reset the z height in the eeprom( it's probably showing a weird number) to approximately the right value and then go ahead and then calibrate the z height normally.
Posted: Mon Apr 03, 2017 9:28 am
by briankb
joe wrote:You could reset the z height in the eeprom( it's probably showing a weird number) to approximately the right value and the go ahead and then calibrate the z height normally.
Isn't that what the LCD Menu "Set Z Height" does? I tried that a few times to no avail.
Posted: Mon Apr 03, 2017 4:28 pm
by joe
briankb wrote:joe wrote:You could reset the z height in the eeprom( it's probably showing a weird number) to approximately the right value and the go ahead and then calibrate the z height normally.
Sorry, forgot to mention the you should do it in the eeprom first THEN use the LCD menu.
Posted: Tue Apr 04, 2017 5:10 pm
by briankb
joe wrote:Sorry, forgot to mention the you should do it in the eeprom first THEN use the LCD menu.
That worked. thanks Joe!!!!
Posted: Tue Apr 04, 2017 6:21 pm
by joe
Sweet. You are most welcome.
Posted: Sat May 27, 2017 6:07 pm
by tomcapizzi
By saying: "You could reset the z height in the EEPROM ( it's probably showing a weird number) to approximately the right value and the go ahead and then calibrate the z height normally." You are saying that I should re-send the Repetier config file back to EEPROM?
My menu selection on the Orion console for EEPROM settings are "Store to EEPROM" and "Load from EEPROM", I have wiped the EEPROM and resent the config file numerous times back to the RAMBo board with no change in results. When I home the printer, the head lowers about 1", and it will not configure Z height correctly.
Posted: Thu Sep 07, 2017 12:58 pm
by matanyabs
have you found a solution? having the same problem
Posted: Thu Sep 07, 2017 3:14 pm
by pouncingiguana
The easy way to fix the problem (assuming you've got the newer hot end with the probe) is to connect with MatterControl (or whatever) and open a terminal. Run M502, M500, G29. This will reset the EEProm to stock values, Save, then calibrate to set your endstops, z height, and horizontal radius.
