Spiral Vase 2 :)
Posted: Sat Dec 06, 2014 11:16 pm
by dunginhawk
So i decided to give something a little bigger, a little more detail a try.
Printed in red PLA at 205c, 60c bed.
Right after this print i added 2 more layer fans, so now im running all three and couldnt be happier.
I really think im starting to get this dialed in.
[img]http://i1132.photobucket.com/albums/m562/dunginhawk/9945A718-557B-40D2-9040-57B6165B382E_zpsrvlu8obl.jpg[/img]
[img]http://i1132.photobucket.com/albums/m562/dunginhawk/18F9054D-8102-4572-898B-2C6E5FE54580_zpsigrbrkmc.jpg[/img]
[img]http://i1132.photobucket.com/albums/m562/dunginhawk/5C8D0AF6-3B2A-4CA2-823B-F0500BA4D333_zpsxe9ls5c7.jpg[/img]
Its pretty jagged and hairy inside, but thats of little consequence to me :)
thanks for looking. any thoughts/advice would always be welcome. im still very new to this.
Re: Spiral Vase 2 :)
Posted: Sun Dec 07, 2014 1:34 am
by bot
Yup that is super nice. Try it in T-glase next (if you want to rip your hair out... I hate that stuff) :)
Posted: Sun Dec 07, 2014 1:35 am
by jdurand
I've got a project that would work well with t-glase, what's the specific problem with it before I find out for myself?
Well, besides it won't print in my current printer.
Posted: Sun Dec 07, 2014 2:00 am
by bot
You have to print it VERY SLOWLY -- it creates a lot of friction going through the nozzle. and even then, it does NOT have good bridging or overhang characteristics, like they claim.
It is very pretty, and if you can get it to play nice for large layers it might work for some applications. Or very simple geometric shapes. Anything complex, though, and you're outta luck. (I was printing a small prototype and it does not work well with support, and it doesn't work well without it.
A piece that printed perfectly in 1.5 hours in PLA took 6 hours to turn out like crap in T glase.
Posted: Sun Dec 07, 2014 2:07 am
by jdurand
Thanks. Looks like I might be sticking with PLA longer than I thought. Still, once I have the RMax working I can use some of the nicer looking PLA.
I just ordered 6 spools of the Afinia PLA for will-call on Tuesday, they print fine in that printer but they're pretty generic looking.
Posted: Sun Dec 07, 2014 8:12 am
dunginhawk, the vase looks very good, and I like the color.
You are definitely getting it dialed in, congratulations!
Posted: Sun Dec 07, 2014 9:22 am
by dunginhawk
thanks everyone.. trying different brands of filament too.. thats red hatchbox brand
Posted: Sun Dec 07, 2014 11:09 pm
by dunginhawk
i have some tglase here.. now you make me nervous to try it :)
Posted: Mon Dec 08, 2014 12:38 am
by bot
Don't be nervous to try it, be prepared. Apparently it's supposed to work better by lying to your slicer about your nozzle size, but I think the real problem is actually diameter fluctuations.
http://taulman3d.com/t-glase-features.html
Posted: Thu Dec 25, 2014 6:24 pm
by JackFoz
T-Glase isn't that bad! I've had some good luck with it on my Orion. but yes you do need to slow the thing down to a snails pace and large layer heights are very pretty. I found increasing the nozzle diameter in the slicer to 0.6mm (its the standard 0.5 mm nozzle) helps with vases. Also I should add it doesn't like to stick to blue painters tape but the glue stick method works really well (I use UHU yellow glue sticks because you can't get Elmer's in the UK)
