Beter printing through radiation
Posted: Thu Sep 11, 2014 9:45 am
Hi all,
I just did something that really helped print quality on my Rostock so I thought I'd share. I can only suspect that this has been done before but I'll toss it out there.
I'm just starting my initial experimentation with printing on my Rostock and I have to say I'm extremely impressed with it. On the friday before labor day I started my third print on it which was a 51 hour print of a center fuselage section for an RC aircraft I'm designing. I started the print and when I came back to work the next tuesday it had finished! There were tons of layer separation issues but I was still pretty impressed.
Soooooooo, I did a redesign of the part to reduce weight ad printed it again (cut in half) and as expected once again I had serious layer separations.
I figured that a heated enclosure would help but didn't really feel like building a big a$$ box around my Rostock so I thought I'd heat the part in the build volume via simple thermal radiation. I did some horrible things to a parabolic radiant space heater so I could tilt it and CHANGING NOTHING I hit print on the same part.
Print results were WAAAAAAAAAYYYYYY better.
