Calibrating X,Y, and X axis for first print.
Posted: Mon Aug 18, 2014 9:56 pm
Hello,
This things are manufactured with all of the Rostock MAX V2, injection molding the same. So, unless they change, this won't. It's not a 1,2,3,4 process but, should be allot easier than the start numbers they give you in the book.
Screw in your end stop screws to less than 1/4 inch high from the cheapskate. Then set your "Horizontal Radius" to 129.32 in the EEPROM Settings. If you start with these number, the first time through, there'll a few turns of each end stop screw. But, once you have it right, it's all 1/8th turn and 1/16th turns to pin it down through the next two or three cycles.
Then follow the previous instructions with the 4 GCode Scripts. It should amount to 1, adjust end stop screw, [HOME], paper friction test, 1, adjust end stop screw, [HOME], paper friction test, 1, adjust end stop screw, [HOME], paper friction test, 1, adjust end stop screw, [HOME], paper friction test, 2, adjust end stop screw, [HOME], paper friction test, 2, adjust end stop screw, [HOME], paper friction test, 2, adjust end stop screw, [HOME], paper friction test, 2, adjust end stop screw, [HOME], paper friction test, 3, adjust end stop screw, [HOME], paper friction test, 3, adjust end stop screw, [HOME], paper friction test, 3, adjust end stop screw, [HOME], paper friction test, 3, adjust end stop screw, [HOME], paper friction test, to get the friction right between the hotend and paper and then 4 should be correct. If the friction isn't exactly the same for the first three scripts, adjust -/+ .01 to raise or lower the hotend, and repeat the above procedure.
Unless, SeeMeCNC, changes the arms, universal joints on the cheapskates, or carriage's dimensions, these should be very close to the same for any Rostock MAX V2.
My first time through following the Assembly Manual, resulted in a steep concave, I pushed my Horizontal Radius, all the way to 280, and then the GCode Scripts 1, 2, and 3 stopped working. No matter how that's suppose to lower the print head, it doesn't do it by itself. I didn't finish reading the instructions and make it to the flow chart, and actually took 8 hours to adjust the stupid thing, reinventing the wheel. When I finished adjusting it, I scrolled down to see the flow chart, and realized that the geometry for any machine of this type is so close to the same, you could start with better numbers, and end stop screw starting depths, too keep the hotend from hitting the glass.
