print head buries
Posted: Mon Aug 11, 2014 7:51 pm
by js1515
Hello My orion is having an issue where every time I home it buries the print head into the bed is my best bet to flash the machine? Any help would be appreciated
Re: print head buries
Posted: Mon Aug 11, 2014 7:57 pm
by McSlappy
Have you set the Z-height using the LCD?
Posted: Mon Aug 11, 2014 8:00 pm
by js1515
yes if I go into the menu and dial it down
Posted: Mon Aug 11, 2014 8:23 pm
by js1515
and its weird I was printing just fine I finished a print homed it and then went to re calibrate before doing the next print now nothing makes it home it just always buries the nozzle
Posted: Mon Aug 11, 2014 8:30 pm
I believe you can get this side effect if you accidentally set Z = 0 from the panel at the top.
I'd reset the ZHeight to something reasonable in the EEPROM settings then re zero it from the panel.
FWIW You don;t have to recalibrate between prints, I only ever do it if I change hotend or build surface.
Posted: Mon Aug 11, 2014 8:45 pm
by js1515
hmm ok I'll try that but I cant set z=0 from the printer itself I need to do that from the sd card?
Posted: Tue Aug 12, 2014 12:34 pm
You can set the zero using the front panel - follow the instructions in the user guide and you should be good to go.
