Changing Spools mid print using SD card
Posted: Tue Jul 22, 2014 11:44 pm
by elwooddbeauchamp
I am printing from SD card, and being new at this venture, could someone share their procedure for changing to a new spool, same material, mid print on the Rostock Max v2 using the SD card...Thanks
Re: Changing Spools mid print using SD card
Posted: Wed Oct 01, 2014 4:20 pm
by SoCalSteve
I'm interested in this as well. did you ever find out anything?
Posted: Wed Oct 01, 2014 4:31 pm
by Nylocke
In the LCD menu under the SD card menu there is a "pause print" option. Pause it, swap it, resume it. Should work fine (just try to pause it on the infil as to not screw up the perimeters).
If you have a specific spot you want to pause it and switch it at you can add some fancy G-code to lift and pause on that line.
Posted: Wed Oct 01, 2014 4:46 pm
by SoCalSteve
Nylocke wrote:In the LCD menu under the SD card menu there is a "pause print" option. Pause it, swap it, resume it. Should work fine (just try to pause it on the infil as to not screw up the perimeters).
Awesome, Thanks!
Posted: Fri Oct 03, 2014 12:35 pm
by elwooddbeauchamp
Thanks, Mylocke
