Heater outputs not working
Posted: Wed Jun 18, 2014 3:42 am
by Generic Default
Hi,
I have two hotends set up on my rostock max, each with a fan for cooling. Both fans are connected to the FAN 0 output of the rambo. The first hotend is connected to HEAT 0 and the second hotend is connected to HEAT 1.
The wiring to connect the fan to the FAN 0 output was soldered and worked fine since August 2013. Just a few minutes ago, the electrical tape that covered the solder joint of the fan wiring came loose, and the solder globs touched each other for a fraction of a second and shorted.
Now none of the outputs are working- the red LED that normally flashes with the heating PWM doesn't show up, and I can't heat up either hotend or turn on the fan. Only the fan shorted, not the heaters. I don't understand why shorting the fan output would instantly fry all of the critical heater outputs. The stepper motors still work, the display still works, and the yellow light shows that the power supply is working. The heater outputs and fan output are what stopped working suddenly.
Is there anything I can do to fix it? Replace fuses, ect. or am I screwed? My rostock just passed its one year anniversary (and warranty) so I won't be able to return the rambo board. If it really is dead, it happened at the worst time possible since I've invested in a printer dependent production job worth thousands of dollars and it's crunch time right now.
If it is dead and there is no hope, what replacement board would you recommend? I'm leaning towards getting another Smoothieboard and skipping on the third extruder for now. I'm low on money and I was really relying on this job, but stuff tends to happen when you least expect it....
Re: Heater outputs not working
Posted: Wed Jun 18, 2014 8:26 am
by guanu
Posted: Wed Jun 18, 2014 2:06 pm
by Generic Default
Thanks for that picture! I'll check the fuse today when I have time. I hope it's the fuse and not the chips!
Posted: Wed Jun 18, 2014 2:12 pm
It's most likely just the fuse, there isn't a lot of sensitive circuitry on that circuit, just the mosfets and passive components.
Posted: Fri Jun 20, 2014 1:21 pm
Was the fuse bad?
Posted: Sat Jul 12, 2014 12:45 am
by Generic Default
Yep, took a long time to get around to it because I'm busy with other stuff. The F3 fuse from that picture isn't showing conductivity.
So next time I order stuff from Mouser I'll see if I can get a replacement fuse or ten. I ordered a Smoothieboard 5x a couple days after the initial thread post, and I'm about to install it now. I'll tell you how it goes with dual (or triple) extruders.
Posted: Tue Jul 22, 2014 9:08 am
by RegB
I have similar symptoms, but the fuses are all good.
The main difference is probably that this is a new build, i.e. it has not YET ever heated the bed.
The wiring has been checked MANY times (-:
There is just no voltage out of Rambo at Heat0 or Heat2.
Thermistors read room temp, slow rise when I put a hand on the bed thermistor or hot end.
Good 12 volts in on all black/yellow pairs.
