Tower Homing got Weird
Posted: Tue May 20, 2014 10:56 pm
Hello All,
Home Tower got weird. The last few days I have been having very good success with printing my SolidWorks models, saved as STL’s and imported into Repetier-Host. This morning I had an very good print and shut down for lunch. Later I turned on the computer and printer. When I tried to home towers the cheapskates just go lower about 1 CM. The continuity of the top limit switches are all three broken if I push them manually.
Trying to HOME from the Orion alone or when connected to the computer it has the same problem. G28 does the same 1CC lower. However all of the manual XYX arrow controls on the Repetier-Host work perfectly. I can also run it up and down from the Orion front panel.
From any position it will only move DOWN instead of going up and homing.
I switched the Orion SD chip with an identical copy and still no help.
I’m stuck…
Steve
I’m stuck…
Steve
