Rostox Max ignores gcode commands
Posted: Tue May 20, 2014 6:17 am
Have a look around and join today!
https://forum.seemecnc.com/
Most likely you haven't realized that Repetier is case sensitiveMac The Knife wrote:I finished my build last night, and loaded the firmware, drivers etc. At first start up, I discovered that I had the hot end thermistor plugged into the wrong spot on the RAMBo. Once that was corrected, I have full manual operation of the printer through my laptop, motors, hotend heat, and heated bed. I can zero the Z setting in Rambo. However, it ignores any gcode commands sent from repetier.
Did having the thermistor plugged into the wrong spot cause the firmware install to be bad?
The M119 is the correct one.Mac The Knife wrote:Thanks. I'll give that a shot. I did try M119, and m119, with no luck,,,, should it be separated? M 119?
