Set Z Height w/o LCD - Possible?
Posted: Fri May 16, 2014 6:10 pm
by edwardjanderson
My RAMbo LCD interface board is on order (original missing from kit). Is it possible to set the Zheight with out the LCD? I am able to tune the extruder and hot bed PIDs from the Repetier-Host -
Re: Set Z Height w/o LCD - Possible?
Posted: Sat May 17, 2014 12:58 am
by ThatDirectorGuy
Can you use MatterControl to set the Z height?
Posted: Sat May 17, 2014 1:51 am
edwardjanderson wrote:My RAMbo LCD interface board is on order (original missing from kit). Is it possible to set the Zheight with out the LCD? I am able to tune the extruder and hot bed PIDs from the Repetier-Host -
Z-height should be a component of the EEPROM which you can access from Repetier-Host - config - EEPROM
Posted: Sat May 17, 2014 3:54 am
by apostoly
edwardjanderson wrote:My RAMbo LCD interface board is on order (original missing from kit). Is it possible to set the Z height with out the LCD? I am able to tune the extruder and hot bed PIDs from the Repetier-Host -
I am actually in the exact same position, PID's all done.. Just waiting on parts to arrive so i can connect my LCD panel.If only there was some instructions on how to do it
Posted: Sat May 17, 2014 4:37 am
by Eric
Posted: Sat May 17, 2014 6:47 am
by apostoly
All good, i did it all manually
thanks
Posted: Mon May 19, 2014 2:34 pm
by Sonrisa3D
ThatDirectorGuy wrote:Can you use MatterControl to set the Z height?
Yes - MatterControl has EEPROM where you can adjust Z-Height.
