Strings across features
Posted: Tue May 06, 2014 10:42 pm
by RAMTechRob
Alright folks, I am new to the 3D world, but trying my best. I have a few of the simple prints done already, but need to get some harder ones done. I have a fairly simple design of an outer wall, with 4 towers in the center. When the nozzle transverses between the towers, it leaves strings between them. Can you guys and gals help me out with a new setting for this?
[img]http://img.tapatalk.com/d/14/05/07/pybe9yga.jpg[/img]
[img]http://img.tapatalk.com/d/14/05/07/jyna6aba.jpg[/img]
Specs:
PLA set at 195 nozzle and 65 bed
4 solids layers and 70% fill. 2 perimiters.
I'm not sure what else to re-set to stop the strings. I can put bridges between the outer walls and towers, but I doubt that is needed with your help.
Thanks!! Love the machine and love the forum so far!!
Re: Strings across features
Posted: Tue May 06, 2014 11:00 pm
Are you using Repetier and Slic3r to slice your file?
Posted: Wed May 07, 2014 2:17 am
by RAMTechRob
Yes, I am using both of those.
Posted: Wed May 07, 2014 8:36 am
Try backing off the temp a bit.
Posted: Wed May 07, 2014 12:04 pm
by RAMTechRob
I tried it at 195 witha heated bed. Do you think 190 nozzle and a 40 bed would work better?
Posted: Wed May 07, 2014 5:56 pm
by gajtguy
Doesn't the retraction value have something to do with this as well?
Posted: Wed May 07, 2014 11:57 pm
by DavidF
gajtguy wrote:Doesn't the retraction value have something to do with this as well?
Yep. What are your retraction settings?? the temp for the hot end is right for pla, but bed temp is a little high.. When I first started printing I did not have retraction enabled and thats the same thing that happened when I was printing......
