Hi I'm new here
Posted: Sat Apr 26, 2014 8:47 pm
I have taken the next step, but there are so many yet to reach my goal.
I did some shopping for a printer service and gaged on the cost. I am buying the Max V2, I'm concerned about the height, did you ever hear someone complain about to much build space? My shop space limits the vertical and I need a ladder to change the wire. I want to shorten the vertical rails to the ones the Orion uses. Doable?
Also I would like more plug and play after assembly, I currently have a 4 axis CNC mill with the EMC2 controller on a Debian Linux box, I work in deskproto, bobcad, rhino, microstation 3d, poser, artest. I was hand writing G-code before APPLE fell out of his tree and Gates was still a DOS prompt. I am a 'retired' Master Draftsmen with an exceptional ability to visualize 3D space in my mind.
I have an older PC running XP sitting around that would be a good print server. I have the perfect stl file, hot and ready, what programs will I need to get it printed?
I should read the books for rhino and deskproto they may do slicing to g-code for printing but they need post processors to configure the machine dependent code
Stl to program for g-code?
G-code to controller program?
Controller to printer
End program
What am I missing?
End program
What am I missing?
