				Need ideas for a "priming trash bin"
				Posted: Fri Mar 07, 2014 1:58 pm
				by int2str
				I'd like to mount a little "trash can" so I can prime the extruder before printing.
Has anybody does this on our delta printers?
Please post pictures or ideas!
Thx
				Re: Need ideas for a "priming trash bin"
				Posted: Fri Mar 07, 2014 3:26 pm
				by bdjohns1
				I just hold a piece of paper a few inches below the head while I hit the extruder jog button on OctoPrint.  Once I'm primed, I retract 5 mm, and pull off any dangling filament.
				Posted: Fri Mar 07, 2014 3:54 pm
				by Batteau62
				This made me think of an idea foshon had. Here's the thread:
http://forum.seemecnc.com/viewtopic.php ... e&start=80
It's a few posts into the page, he used a printed part & dremel brush as a dump/ wipe station.
You could pm him to see if he took it further, or maybe he will see this
				Posted: Tue Mar 11, 2014 4:00 am
				by foshon
				Here is my solution, very basic. Removable yet sturdy. Used a standard dremel bit (cheap version with one collet, 1/8" iirc).
http://www.thingiverse.com/thing:93820
				Posted: Tue Mar 11, 2014 5:05 am
				by Captain Starfish
				I retract 80mm at the end of the job, fast - it whips the end of the filament back out past the hot end PTC and avoids the heat bulge you get if you leave it there.
So when my temps hit target, I extrude 100mm at 300mm/min which gives me a bit of string and, as it's pushing out, I kick off the job which will hold in the Gcode queue on the Rambo until the extrusion is finished.
As the head drops to start the job I just grab the filament and bin it.
Not automatic, but it is pretty easy and I'm still at the distrustful n00b stage where I like to watch the first couple layers of each job and make sure it's all tickety-boo before walking away.
				Posted: Tue Mar 11, 2014 4:27 pm
				by int2str
				foshon, it's a nice solution, but I'm trying to come up with something that doesn't majorly interfere with the printing area. Also, I'd like something I could go to in the middle of even a larger print. Having it in the spot you have it would not work in that case.
I've played around with a few ideas, but have not found a good solution yet.
				Posted: Tue Mar 11, 2014 7:07 pm
				by Captain Starfish
				Do you have any spare outputs on the Rambo? You could put something like foshon's rig on a swinging stage with a bit of g-code to swing it in and out of play as required...
				Posted: Sat Mar 15, 2014 9:46 am
				by foshon
				int2str wrote:foshon, it's a nice solution, but I'm trying to come up with something that doesn't majorly interfere with the printing area. Also, I'd like something I could go to in the middle of even a larger print. Having it in the spot you have it would not work in that case.
You don’t lose as much as you'd think. The effector hits the tower a little past where this sets. Good luck to ya.
