New Orion printing
Posted: Wed Mar 05, 2014 2:53 pm
by bolive
Hello i just bought an Orion printer from SeeMeCNC. This is my first experience with 3d printing. I am running .91 firmware and using the Slic3r ABS files provided to configure slic3r. measured my filament and it had a average diameter of 1.713425. I went into the slic3r config and changed the filament diameter. And it printing just not very well. Here are some pictures for some of my prints if anyone can point me the direction i need to go to get it fixed I would appreciate it. Let me know what other info you need and i will get it for you.
https://dl.dropboxusercontent.com/u/906 ... 083828.jpg
https://dl.dropboxusercontent.com/u/906 ... 070323.jpg
Gear heart center hub the top and botton holes are smaller thean the sides and none of the fit the pins.
https://dl.dropboxusercontent.com/u/906 ... 070447.jpg
https://dl.dropboxusercontent.com/u/906 ... 070502.jpg
This was a planetary gear credit card. the two sides didn't match up and the pins were sloppy.
https://dl.dropboxusercontent.com/u/906 ... 070401.jpg
This was a euro shopping cart token and i stop the run after it started the first layer. there were really large gaps in the fill. and the sides are not bonded very well.
Thanks
Re: New Orion printing
Posted: Wed Mar 05, 2014 3:23 pm
We need to know some of your other Slic3r settings like layer height and width, speeds of printing, and others.
There are a lot of settings in there and they all can effect your prints. Would it be possible to capture your screens and
upload them here?
Posted: Wed Mar 05, 2014 3:52 pm
by bolive
Posted: Wed Mar 05, 2014 4:14 pm
Under Print Settings advanced all the 1st seven settings need to be set at .6 for a .5 nozzle.
The rest of your settings look to be okay, you may want to experiment with the wipe setting.
Change what was noted above and see if you notice an improvement.
Posted: Wed Mar 05, 2014 4:28 pm
by bolive
Thanks I will try it tonight.
Posted: Fri Mar 07, 2014 11:05 am
by bolive
I made the change and it helped. But the print is still rough. here is a picture of the new print
https://dl.dropboxusercontent.com/u/906 ... 095506.jpg
https://dl.dropboxusercontent.com/u/906 ... 100217.jpg
Any more ideas on how to get my printer printing more percise.
Thanks
Brian
Posted: Fri Mar 07, 2014 11:17 am
bolive wrote:I made the change and it helped. But the print is still rough. here is a picture of the new print
Thanks
Brian
Set your layer height to .2mm
Leave 1st layer height as is.
Change all infill speeds to 30/s
