Page 1 of 2
				I now own a mini CNC router and a 3D printer
				Posted: Tue Apr 03, 2012 5:17 pm
				by Dave_Sohlstrom
				Re: I now own a mini CNC router and a 3D printer
				Posted: Tue Apr 03, 2012 5:30 pm
				by Chris Muncy
				You're such a dawg.......
I WANT!
Do you take PayPal for payment on those parts? :p
				Posted: Tue Apr 03, 2012 6:11 pm
				by Dave_Sohlstrom
				It's called DYI so if you want one you'll need to build you one. You can't afford me took 2 days to build the adapter.
Here are a couple of shots of the first try. A 20mm pocket 2mm deep. Only miked out to 19.96mm
[img]
http://i132.photobucket.com/albums/q3/D ... 0_1210.jpg[/img]
[img]
http://i132.photobucket.com/albums/q3/D ... 0_1211.jpg[/img]
				Posted: Tue Apr 03, 2012 6:29 pm
				by cquinby
				Pretty cool Dave!
				Posted: Tue Apr 03, 2012 6:38 pm
				by michaellatif
				That looks awesome Dave!
				Posted: Tue Apr 03, 2012 9:19 pm
				Very cool Dave. Is that a Foredam hand piece?
Cheers,
				Posted: Tue Apr 03, 2012 10:35 pm
				by Dave_Sohlstrom
				No it is an old style Dremel flex drive.
				Posted: Wed Apr 04, 2012 1:07 pm
				by Geirhart
				Dave,
That is very nice. Are you getting any flex when you machine harder materials?
Gary
				Posted: Wed Apr 04, 2012 5:14 pm
				by Dave_Sohlstrom
				I have not routed any thing other than this PVC foam board. I have more photos in the camera from today. Will UL them later.
				Posted: Wed Apr 04, 2012 7:19 pm
				by Dave_Sohlstrom
				Here is a shot of the first real CNC router cut I have made. Pilot house sides for a model tow boat. Running a 2mm end mill at 35,000 RPN 16" per min feed rate. Took just shy of 2.5 minutes to cut. Material is 3mm PVC foam board
[img]
http://i132.photobucket.com/albums/q3/D ... 0_1216.jpg[/img]
				Posted: Thu Apr 05, 2012 2:01 pm
				by Geirhart
				The foam is really milling well. Are you making forms for aluminum or epoxy \ Acrylic casting?
G
				Posted: Thu Apr 05, 2012 4:14 pm
				by Dave_Sohlstrom
				When I get the heated bed up and running I will be printing molds for wax patterns used for lost wax investment casting.
				Posted: Thu Apr 05, 2012 5:29 pm
				by Geirhart
				That sounds interesting as well are you going to be casting precious metals?
G
				Posted: Thu Apr 05, 2012 6:10 pm
				by Dave_Sohlstrom
				Posted: Thu Apr 05, 2012 11:10 pm
				by Geirhart
				Are those props for RC Boats?
G
				Posted: Fri Apr 06, 2012 1:12 am
				by Dave_Sohlstrom
				Yes It is a Kaplan style 73mm dia X 50mm pitch and will be installed in the Zdrive. Drive will fit in 1/24 scale boats easy and big 1/32 scale boats.
				Posted: Sat Apr 07, 2012 7:37 pm
				by Dave_Sohlstrom
				Here are the 4 linear bearing blocks for the Z axis on the H-1 Tank. Will be cutting them apart and adding some taped holes on the edges just in case. One thing I have discovered is because of the increase in weight of the X axis and extruder I an loosing steps if I rapid up at to high a feed rate. limited to about 16 IPM.
I think that I will be designing a counter weight system so the lear screws do not have to lift all of the weight.
[img]
http://i132.photobucket.com/albums/q3/D ... 0_1232.jpg[/img]
				Posted: Sun Apr 08, 2012 7:55 pm
				by Dave_Sohlstrom
				Well I have the Z axis linear bearing mod complete.  Before the mod when I was routing the PVC foam board the best I could get was 16" per min feed rate. The Z axis was loosing steps when it rapid up for a holding tab. After completing the mod I route one more test route. 40" per min no lost steps. the job finished in 1 minute. Here are some shots of the Z axis bearings.
[img]
http://i132.photobucket.com/albums/q3/D ... 0_1233.jpg[/img]
[img]
http://i132.photobucket.com/albums/q3/D ... 0_1234.jpg[/img]
[img]
http://i132.photobucket.com/albums/q3/D ... 0_1235.jpg[/img]
The test route.
[img]
http://i132.photobucket.com/albums/q3/D ... 0_1236.jpg[/img]
				Posted: Sun Apr 08, 2012 9:15 pm
				by michaellatif
				That's very cool, looks like the tank is complete.
I think I counted about 12 of the original H-1 plastic parts
Nice work Dave!
				Posted: Sun Apr 08, 2012 9:32 pm
				Mike, you must be counting pairs as 1 part!
				Posted: Sun Apr 08, 2012 10:44 pm
				by Dave_Sohlstrom
				16 excluding the extruder.
				Posted: Sun Apr 08, 2012 11:03 pm
				by Dave_Sohlstrom
				My next challenge is to design and build a extruder  that uses resin pellets just like Steve and Johns injection molding machines. It will have three temp zones. Cold, warm where the pellets start to soften and hot where the pellets are at extrusion temp exiting the nozzle. It will have to be all metal
				Posted: Mon Apr 09, 2012 12:02 am
				by JTCUSTOMS
				How will you keep air out of the mix with the pellets, compress them with a screw in  the middle zone?
Most injection molders I have worked on in the past (Van Dorn's and Cincinatti's)  have a "shot" of plastic molten ready to inject before it gets to the nozzle.
Your Z mod looks fantastic! and I am anxiously waiting to see what you come up with for the "granule" type extruder
				Posted: Mon Apr 09, 2012 12:35 am
				by michaellatif
				Have a look at this guy's design.
http://www.kickstarter.com/projects/roc ... ment-maker
You may get some inspiration as to how you can build a pellets to printing extruder.
				Posted: Mon Apr 09, 2012 10:53 am
				by Dave_Sohlstrom
				I think his energy should of gone to printing from pellets rather than making filament. Sure seems slow, at the rate he was getting filament out you would spend hours and hours making filament.
