Filament spool attched to H-1
Posted: Mon Apr 02, 2012 11:37 pm
by michaellatif
I finally got tired of the old PVC pipe holder for the filament spool. The PVC pipe caused too much friction and was always in the way/taking up too much room.
In the pictures attached I printed out four parts (two of each) and added extra threaded rod/nuts and in no time I had a great setup to hold the filament ON the H-1.
This setup gave me more room on my desktop and since it used 608 bearings the filament spool glided freely!
This is modeled after others doing the same with their huxley/makerbots.
The threaded rod/nuts are all 1/4-20 hardware found at your LHS.
Here are the items I needed to print:
2x Filament spool holder/spacer (uses 608 bearing). This one is different then the one I printer previously, this fits the 2Kg filament spool sold by Ultimachine.
http://www.thingiverse.com/thing:14361
2x Bar clamps to hold 1/4-20 threaded rod together (see pictures for details).
http://www.thingiverse.com/thing:18637
Filament_spool_holder_(1)
Filament_spool_holder_(2)
Filament_spool_holder_(3)
Filament_spool_holder_(4)
Filament_spool_holder_(5)
Filament_spool_holder_(6)
Filament_spool_holder_(7)
Re: Filament spool attched to H-1
Posted: Tue Apr 03, 2012 11:00 am
by Chris Muncy
I like it but doesn't it torque the frame?
Posted: Tue Apr 03, 2012 11:06 am
by michaellatif
Chris Muncy wrote:I like it but doesn't it torque the frame?
I was worried about that at first, but with the lighter filament spool (2Kg) and cross bar attached to both Z axis, most of the weight is distributed evenly.
It actually seems to act like a dampener, helping remove the wobble when X or Y change direction quickly.
Posted: Tue Apr 03, 2012 11:08 am
by Chris Muncy
Hmm....
I like the idea of a dampener, specially with the widened print area. I might have to test that.
Posted: Tue Apr 03, 2012 6:06 pm
by cquinby
Mike,
Did you use ReplicatorG to make the spool adapters? I can't make them with Slic3r as there is no way to generate support material and it screws up the bearing pocket.
Thanks,
Posted: Tue Apr 03, 2012 6:17 pm
by Dave_Sohlstrom
Chris Q
Are you printing it flange down. If so change it so the counter bore for the bearing is on the inside and then no need for support material.
Posted: Tue Apr 03, 2012 6:25 pm
by cquinby
Dave,
Printing it outside portion (sticks out of the filament spool) down.
Posted: Tue Apr 03, 2012 6:28 pm
by cquinby
This is the orientation.
Posted: Tue Apr 03, 2012 6:36 pm
by michaellatif
cquinby wrote:Mike,
Hey Chris,
I used slic3r, the pocket was printed using bridges, there was a little slop (in the pocket) at the beginning which I cleaned up after the print completed.
Posted: Tue Apr 03, 2012 6:53 pm
by cquinby
Thanks Mike.
How did you do that? The problem I see is that it wants to print the perimeter first (which falls right into the hole) then do the bridge.
How many perimeters did you use on the print? I used 3 and I wonder if that was kicked up higher it may work with less slop. I don't see any way to clean the part I made up other than turning a 22mm chunck of aluminum down and heating it up and pressing it into the hole to melt the ABS.
Posted: Tue Apr 03, 2012 7:22 pm
by michaellatif
I use 3 perimeters and 4 solid layers. The first solid layer is mostly garbage (gets cleaned out). The second layer just builds up on the first and so forth.
And for cleaning, I just use an exacto knife and gently cut out the excess.
Posted: Tue Apr 03, 2012 7:28 pm
by cquinby
Thanks Mike. I will give that a shot after these Owl's are done printing... Boy did I make a mistake getting talked into that one by my 7 year-old. She thinks scraps are a gift from the gods! :lol:
Posted: Tue Apr 03, 2012 8:56 pm
by cquinby
Mike,
Still waiting for these dang owls to print!!! Once that is done I will give the spool adapter a shot again. If it doesn't work, I think this one will: http://www.thingiverse.com/thing:18909
Posted: Tue Apr 03, 2012 9:12 pm
by michaellatif
You know, those are much better looking spool spacers. I might give them a try later this week.
Posted: Tue Apr 03, 2012 9:30 pm
That's pretty cool. I have ,y spools hanging from the rafters overhead but they are just on a 3/4" dowel so I have to constantly pull the filament. This would allow the extruder to self feed. I'm going to have to see what I need for my spools and print them.
Cheers,
Posted: Wed Apr 04, 2012 12:26 pm
by cquinby
Mike,
I printed out one of the 18909 spool adapters last night to take a look at it and so far, so good. I am expecting my bearings in the mail today so once I get those I will post up some pics of the adapters and the bearing spacer I just made and currently printing. Getting some use out of "Lift Z" function in Slic3r!
Posted: Wed Apr 04, 2012 5:31 pm
by cquinby
Got my bearings and put my stuff together!!!
First off, i made some spacers (bushings) to go between the 1/4-20 all thread and the 608 bearings. You need to print these slow with 1 perimeter and multiple at a time. Also I had to use the Z Lift function to keep from nocking the parts off the table. This actually worked very well... Print in ABS. You will have to almost thread them onto the 1/4-20 rod. I have attached my Slic3r profile for these parts, change the txt extension to ini then load into Slic3r.
.3layer Small Multiple parts .txt
(1.44 KiB) Downloaded 536 times
Here is the spool adapter printed out (ran out of blue ready to go but had red hanging on the wall!)
Next was to put the bearings into their home... Ya, I got blue shielded bearings.
Next we use some 3mm screws, lock nuts and washers to set the bearings into the pockets.
Finally, put together and enought room for 2 more spools if I want!
Printing two more adapters right now to see how well this works. Little worried about the weight on top as the machine doesn't seem quite as stable but watching it work right now it seems to be OK.
Crap, almost forgot to pos the bushing STL...
v3 608 bearing 8mm to .250 bushing.stl.stl
(107.26 KiB) Downloaded 597 times
Posted: Wed Apr 04, 2012 5:54 pm
I like this. Maybe respelling the filament on a smaller spool so it isn't as heavy would help? Also, the wooden "box" I built for my H-1 with the electronics underneath would be a good place to mount the uprights for the spools. Photos in my build thread.
cheers,
Posted: Thu Apr 05, 2012 7:53 am
by johnoly99
Nice looking stuff here. Mike, yes, re-spooling onto smaller spools is a good idea. Especially when you have 5lb. spools of filament! It eliminates any chance of extruder slippage, and just makes sense, doesn't it
Posted: Thu Apr 05, 2012 11:09 am
by Chris Muncy
johnoly99 wrote:Nice looking stuff here. Mike, yes, re-spooling onto smaller spools is a good idea. Especially when you have 5lb. spools of filament! It eliminates any chance of extruder slippage, and just makes sense, doesn't it
My black is on a 5 lb spool and the extruder has no issue grabbing filament off of it. I see pics all the time of guys that respool their filament and never understood why.
Posted: Thu Apr 05, 2012 12:20 pm
I'm thinking more to cut down the weight suspended off the machine. Mine can pull the filament from a wood dowel through the 2" hole, no bearings!
cheers,
Posted: Fri Apr 06, 2012 10:32 pm
by michaellatif
I like the fact that I have a smaller spool that allows me to carry/travel with ease.
BTW NC Maker Faire anyone?? Anyone local thinking of going or even setting up a table with our H-1's?
Posted: Sat Apr 07, 2012 2:16 am
by michaellatif
BTW, I change from a 1/4" threaded rod through the spool to a 5/16" rod. The 1/4" was bowing a bit and I didn't like how flimsy it felt.
I got a 5/16" rod from my LHS and cut it to 16" length, ran it through the bearings and holders. So far so good.
