New Orion: Level Sequence?
Posted: Tue Jan 21, 2014 1:11 am
Hello!
Have a couple issues I'm trying to solve as they're a tad tricky. I just got the Orion Delta and am trying to print. Printed a few test files flawlessly over and over just to show off the printer. But now I've gone through the complete setup of repetier. I am able to successfully slice my files and have the Orion execute the .gco file...however the leveling seemed a bit "off"...and now begins my journey :p
The test files "blinky" and "fan" seemed to print okay, but the bottoms weren't smooth like the one sent with the unit (stuff probably shifted during shipment.)
I carefully calibrated the Z with a set of feeler gauges at .1mm in @ 0,0 dead center of the plate.
For some reason though, all my parts would be very thin on one side, then slowly thicker to not adhering/peeling on the other side.
I figured the leveling script was the issue...from my understanding it was take 3 points on the bed with a piece of paper pinched and hit calculate level within the menu.
Whoops.
I calculated 3 points on a triangle @ 60mm radius. Then I went into the menu and hit "Set P1, Set P2, Set P3,"
I would re-home the extruder after every "set Px".
I ended up having very different numbers on the Z prompt when the gauge was "pinched" by the nozzle tip for each point. (For instance, one of them was -0.31!)
After each point was set to be barely pinching the feeler gauge, I hit "calculate level"
Now I try to run a radius calibration print included on the sd card; The nozzle kisses the glass on the far left corner, and appears to be suspended well over 1mm on the far right... From my research on the forum this is a phenomenon called "lensing."
That's where I'm at so far...no idea how to "un-level" it back to factory defaults which albeit were't the best, they were damned better than the calculated level that I've performed...
I'd appreciate some info on;
How can I "reset to factory defaults"?
How do I apply the "lensing" fix on the Orion Delta?..was my leveling procedure incorrect somehow??
Thanks for all the help! Looking forward to seeing one of my own prints on the build glass. This printer seems so nice I'm itchin' to use it.
Whoops.
