Page 1 of 3
3D Printed Enclosure Mounts
Posted: Tue Dec 17, 2013 3:47 pm
by bubbasnow
i purchased some .08in thick
http://www.lowes.com/pd_11230-1638-11G0 ... facetInfo= from lowes. 3 sheets should be enough to surround the RMax. Ill post the files once i finish.
Here is my progress:
[img]
https://lh5.googleusercontent.com/-qAqt ... 131120.jpg[/img]
Re: 3D Printed Enclosure Mounts
Posted: Wed Dec 18, 2013 11:58 am
That looks to be one of the best enclosures I have seen for the RMax.
Great idea you came up with and you chose materials that are not that expensive, good job!
I am looking forward to the finished product.
I bet you don't have a problem finding the knob for your LCD.
Posted: Wed Dec 18, 2013 1:11 pm
by Lochemage
Nice, it's a step up from using a cardboard box lined with tin foil... like I use.
Posted: Wed Dec 18, 2013 4:23 pm
by TFMike
more!
Posted: Wed Dec 18, 2013 9:55 pm
by bubbasnow
[img]
https://lh6.googleusercontent.com/-be6w ... 185229.jpg[/img]
[img]
https://lh6.googleusercontent.com/-4-nF ... 185238.jpg[/img]
now im working on a fixture that will slide down the ends and hold it nice and tight..... Also i will design some hinges for a door on the front end
Posted: Wed Dec 18, 2013 9:58 pm
Looking Good! Damn nice job.
Posted: Wed Dec 18, 2013 10:16 pm
by bvandiepenbos
Nice work! I look forward to seeing how much a "heated" build chamber can really help ABS prints ?
Posted: Wed Dec 18, 2013 10:26 pm
bvandiepenbos wrote:Nice work! I look forward to seeing how much a "heated" build chamber can really help ABS prints ?
My whole house is a heated build chamber, my wife's constant chattering exhales enough hot air to make it so.
Posted: Wed Dec 18, 2013 10:32 pm
by bvandiepenbos
oh your funnnny.
you better hope she does not read this forum
Posted: Thu Dec 19, 2013 12:39 am
by bubbasnow
my wife booted the printer out of the upstairs office.. now i reside in the unfinished basement.. that gets cold.. and drafty... and has spiders (I'm sure)
Posted: Fri Dec 20, 2013 3:52 pm
by bubbasnow
[img]
https://lh6.googleusercontent.com/-vxdn ... 124817.jpg[/img]
i have 27" from top to bottom, so i have been printing these out 9" at a time.
Posted: Fri Dec 20, 2013 4:27 pm
Looking better and better.
Posted: Sat Dec 21, 2013 2:47 am
by bubbasnow
i now regret doing this with the .25 nozzle >.< im almost done printing parts so its too late to switch
Posted: Sat Dec 21, 2013 7:47 am
Is there a film on the panels? They don't look clear, that's why I'm asking.
It's still the best looking enclosure that I have seen. If you had the time to print the parts this would make a great kit minus
the panels. The user could buy the panels locally. The problem is there are so many pieces and so much time to print them
that it may not be cost effective.
Posted: Sat Dec 21, 2013 3:14 pm
by bubbasnow
yea i wont pull the film off until im done with drilling holes. with a .7 or .6 nozzle this would have taken 1/3 of the time
Posted: Sun Dec 22, 2013 6:17 pm
by brent
Can't wait until this is finished, it looks fantastic and I'm going to do this to my RMax when I'm done assembling it.
Posted: Tue Dec 24, 2013 2:22 am
by neurascenic
Has anybody tested with comparisons of an enclosure vs without? Too, are you planning on just using the heat generated by the process, or adding another source of heat for further control? Do you plan of controlling this with a closed loop venting system?
I am curious, cause once I am complete in my built, I have been considering enclosing it.
My thought is to use an 18" Sono-Tube. Probably will have to modify it some by notching out where the skate/trucks are (not sure, there is plenty of room for the platform, but have not gotten to building the trucks to see how much/or not room there is.
Too, probably would have to heat up it by itself to burn out some of that wax that is in it.
Cheers!
Christopher Lund
Posted: Tue Dec 24, 2013 9:31 am
neurascenic wrote:Has anybody tested with comparisons of an enclosure vs without? Too, are you planning on just using the heat generated by the process, or adding another source of heat for further control? Do you plan of controlling this with a closed loop venting system?
Cheers!
Christopher Lund
Since it is going in a cool, drafty basement I think the goal is to eliminate the drafts and create a mini-environment that helps hold the heat in rather than having it escape into the
basement.
Posted: Thu Dec 26, 2013 8:50 pm
by bubbasnow
Posted: Thu Dec 26, 2013 9:46 pm
All that work payed off, that is the best looking enclosure I have seen.
Excellent job!
Posted: Fri Dec 27, 2013 1:39 am
by bubbasnow
http://www.thingiverse.com/thing:213632
files are here, working on a latch for the door
Posted: Fri Dec 27, 2013 11:27 am
by v8tony
Are you going to do anything to heat the space above ambient or is this just something to keep the drafts away in your case?
Very very nice work by the way. You might have mentioned it, but, what material did you print the pieces out of?
Tony
Posted: Fri Dec 27, 2013 2:38 pm
by bubbasnow
I used that 25dollar radio Shack pla... the entire roll. The joints were printed hollow. Use the biggest nozzle you can and you can probably have this printed in a weekend.
Posted: Fri Dec 27, 2013 7:57 pm
by cope413
would you mind posting all of the solidworks files? I'd like to make a few mods to your lovely design
Posted: Sat Dec 28, 2013 12:27 am
by bubbasnow
Cope,
here ya go! One thing i would change is, per drilled screw holes in the top and bottom holders. Because i didn't the exact location i omitted these and regrettably it is not as ridged as it could be. Also, some of the parts have multiple solid bodies that will need to be exported into new parts before .stl is created.
