Hello, from thailand
Posted: Fri Nov 01, 2013 10:53 am
Hi guys.. Just finished assembling my Max a couple of days ago. Here are my first attempts.
My failed attempts at the hollow cube. Left to right. I had a problem with one of the axis motor twitchingafter awhile of printing. It would cause an offset in the prints towards the motor with the problem. With john's help, i managed to fix the problem. Turns out, bundling the endstop wires with the extruder wire is a bad idea,
[img]http://25.media.tumblr.com/03ce3071ff30 ... 4_1280.jpg[/img]
I finally managed to get my first successful print. Used Geneb's setting in the pdf, worked like a charm. There is some artifacting, u can see in the middle picture, left side near the base. I suspect the belts needs tightening.
[img]http://24.media.tumblr.com/50a86ae0d7aa ... 3_1280.jpg[/img]
I got a bit giddy after the hollow cube and went for something bigger. Went for iphone dock. The print got a bit muddied up in the back, but i'll call it a successful print nonetheless. If anyone has any idea y it gets muddy like that, pls let me know.
[img]http://24.media.tumblr.com/eb8146b30f8d ... 2_1280.jpg[/img]
