Tilting platform and extuder gear slipping
Posted: Tue Oct 15, 2013 1:14 pm
Hi everyone,
I've had my Rostock since early June and I still don't have a normally working machine.
The first part is a major problem with the effector platform. Suppose you are looking at the rostock from the front, with the electronics door being near you and the Z tower being on the opposite side of the machine from you. As the platform moves from you towards the Z tower, it rotates counterclockwise. As it moves from the Z tower towards you, it rotates clockwise. This means that the effector platform is angled more towards the edges of the build plate, which makes bad surface finishes and prevents me from using dual extruders because the nozzle height becomes uneven by a difference of about 1 milimeter. I attached a couple pictures to try to make it a little bit more clear. The first picture shows the platform near the Z tower; the second picture shows it on the opposite side of the build plate. The angle is greatly exaggerated in the picture so you can see it, but it is preventing my machine from working as it should. I checked to make sure that the edges of the aluminum extrusions are level with the laser etched lines in the base and on the top parts. I'm using magnetic ball arms, but even if they aren't the exact same length, they still shouldn't be causing the angle of the platform to change over the build area.
The second problem is that the Steves extruder is limited to retracts of about 10mm/s instead of ~45mm/s. It can push the filament out fine, but when it changes direction and retracts, the press-fit nylon gear that goes on the stepper motor shaft slips and makes a horrible vibrating grinding sound. I tried taking it off, but it won't move axially along the shaft. So it's basically jammed on the shaft too hard to pull off (even with pliers) but loose enough to slip when the stepper applies torque. Does anyone know a way to get it off without breaking the stepper motor or the gear?
Also, I'm considering buying a hobbed drive roller to make my own direct drive extruder. Would anyone recommend a direct drive extruder over a geared extruder?
